UX60A-MB-5ST
UX60A-MB-5ST
    HRS(广濑)
    SMD
    USB连接器 Mini-B 5P 卧贴 端口数:1 额定电流:1A 工作温度:-30℃~+75℃
UX60A-MB-5ST 数据手册
NEW Meet requirements of USB 2.0 UX Series ■Features 1. Certified to perform as required in USB 2.0 Standard Tested and certified by USB Association approved laboratory the connectors will perform at transmission speeds up to 480Mbps. 2. Designed for Low Skew performance The distance between twisted pairs conductors (i.e., contact nos. 2 and 3) is of equal electrical length, for receptacle and plug, resulting in zero theoretical skew. 3. Controlled Termination of Individual Conductors The termination part of the contact is firmly attached in the molded insulator body. Hirose’s Electric unique design of the metal shield prevents short circuits, allowing the overmold resin to flow in the terminated area. By not using heat shrinkable tubing (or any other additional process), the non-twisted part of the conductors is very short, suppressing any unwanted impedance disturbances in the termination area. Contact No. 3 Contact No. 2 4. Ease of mating and handling Thin design of the plug assembly and the overmold section allows use in small spaces. The plug also incorporates a build-in snap-lock feature, providing tactile verification of the full and secure mating of plug and receptacle. 5. Two types of metal shields Two styles of the receptacle metal shield are available, depending on the customer’s PCB design requirement: -Surface Mount Termination -Solder Dip Type 6. Printed Circuit Board placement features Precise location on the board can be accomplished using receptacle assemblies with or without the positioning boss. 7. Board placement with Automatic Equipment Receptacle assemblies are provided with a heat resistant flat surfaces, removable after completion of the soldering process and are supplied on the reels. 8. Environmental considerations Plating is lead-free in order to protect environment. 9. Support of Non-halogen Cable Wiring harness can be arranged in non-halogen cable types. Note: Non-halogen items are not covered in the current USB 2.0 Standard. ■Applications Personal and mobile computer peripheral equipment, data terminals, digital cameras, MP3 players, PDA’s, GPS and other devices utilizing standard USB protocols 2002.11 1 ■Product Specifications Current rating 1A Voltage rating 5 V AC Ratings Item Specification 1.Contact resistance -30ç to +75ç Operating temperature range Conditions Measured at 100 mA 50 m ohms max. 2.Insulation resistance 100 M ohms min. Measured at 100 V DC 3.Dielectric No flashover or insulation breakdown Withstanding Voltage 100 V AC / one minute 4.Capacitance 2 PF min. Measured at 1000 ± 10Hz between adjacent contacts 5.Mating/un-mating forces Mating : 35N max. Un-mating : 7N min. With corresponding connector. 6.Durability (mating / un-mating) Contact resistance: 70 m ohms max. Un-mating force: 3N min. 5000 cycles 7.Vibration No electrical discontinuity of 1 ms or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 axis. 8.Shock No electrical discontinuity of 1 ms. min. Frequency: 50 to 2000 Hz, 15 minutes in each of the 3 axis. 9.Shock No electrical discontinuity of 1 ms. min. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 10.Thermal shock Contact resistance: 70 m ohms max. Temperature: -55ç/ +20ç to +35ç/ +85ç/+20çto +35ç Time: 30/ 2 to 3/ 30/ 2 to 3 (Minutes) 10 cycles 11.Humidity Insulation resistance: 10 M ohms min. (Dry state) 168 hours at -10çto +65ç and Relative Humidity of 90% to 98% 7 cycles 12.Salt Spray Contact resistance: 70 m ohms max. Exposed to 5% salt water solution for 48 hours 13.Solderability Wet state, with solder coverage area over 95% Soldering temperature: 245ç Recommended solder immersion time: 2 to 3 seconds ■Materials ●Receptacles Part Material Insulator Synthetic resin Finish Remarks Color: Black UL94V-0 ----------------------------- Contacts Copper alloy Contact area: Gold plating Termination area: Tin alloy plating Metal shield Copper alloy Tin alloy plating Pick-and-place flat plate Polyamide --------------- --------------- Part Material Finish Remarks Insulator Synthetic resin Contacts Copper alloy Metal shield Over-mold compound (Note 1) ●Plugs Color: Black UL94V-0 Contact area: Gold plating Termination area: Tin alloy plating --------------- Steel Tin alloy plating --------------- PVC Black (Note 2) --------------- Note 1: The over-mold compound is applied at the time of the termination of the plug with the cable and can not be ordered as a separate part. Note 2: The over-molding and cables can be supplied in a wide range of colors. Please contact your Hirose Electric account representative for details. 2 ■Ordering information ●Receptacles UX 60 A - MB - 5 S T 1 2 3 4 5 6 7 ●Plugs UX 40 A - MB - 5 P 1 2 8 4 5 6 ●Plug Harnesses UX 40 A - MB - 5 P A - 1000 - 1001 1 2 8 4 5 6 9 10 1 Series name UX 2 Contact wiring 60: SMT type 3 Receptacle serial indication A: Without positioning post 4 Connector type MB: Mini B type 5 Number of contacts 5 6 Contact type S: Female contact P: Male contact 7 Metal shield termination T: SMT type 8 Plug serial indication A: Type supporting thick cable 9 Reverse side connector type A: Standard A type 10 Cable length 1000: 1000 mm (Note 2) 11 40: Solder wiring type 8: Solder dip type (Dip length 0.8) (Note 1) 11 Serial number (Note 3) Note 1: Types with different dip style termination lengths can also be provided. Note 2: Various cable lengths can be provided. Note 3: Detailed specifications of the harness items can be supplied. Please contact your Hirose Electric account representative for details. 3 ■Receptacles ●Metal Shield SMT Type With Positioning Post Part No. CL No. UX60-MB-5ST 240-0001-9 Note : Embossed tape reel packaging(1,000 pieces/reel) Order by the number of reels. 1.6 0.8 0.3 1.6 0.8 9 BRecommended Board Mounting Pattern 0.8 0.5 2 3.25 2.2 2.5 1.25 3.3 6.4 min. ole mh 9m . 0. Dia 9.9 7.7 CONTACT No.1 CONTACT No.5 3.95 1.6 1.6 0.8 0.4 max. 8.4 3.5min. Connector outside diameter 3.5 0.5 No conductive traces 3.5 7.7min. 8.4 0.8 1.2 1.2 3.3 2 6.4 ●Metal Shield SMT Type Without Positioning Post Part No. CL No. UX60A-MB-5ST 240-0003-4 Note : Embossed tape reel packaging(1,000 pieces/reel) Order by the number of reels. 1.6 0.8 0.3 1.6 0.8 BRecommended Board Mounting Pattern 9 8.4 1.6 1.6 0.8 0.8 0.5 2.2 2.5 7.7 CONTACT No.5 3.95 Connector outside diameter 7.65 8.4 9.65 3.1 6 min. 9.9 CONTACT No.1 No conductive traces 3.5 min. 7.7min. 8.4 4 1.2 1.2 3.1 8.4 ■Receptacles ●Metal Shield Dip Type With Positioning Post Part No. CL No. UX60-MB-5S8 240-0002-1 Note : Embossed tape reel packaging(1,000 pieces/reel) Order by the number of reels. 1.6 0.8 0.3 1.6 0.8 1.6 1.6 h ug .4 R0 ho hro (T 2 3.25 0.8(Through hole) 0.8 0.5 0.4max. 0.8 7.7 CONTACT No.1 3.95 hol . Dia 9mm . 0 Connector outside diameter 3.5 7.3 7.7min. 0.5 No conductive traces CONTACT No.5 0.8 e 1.25 3.3 6.4min. 1.7(Through hole) le) 7.3 3.5 min. 9 BRecommended Board Mounting Pattern 3.5 7.3 0.8 1.2 1.2 3.3 2 6.4 BReceptacle - recommended clearance area When considering the placement of the receptacle assembly areas indicated should be free of any materials or components which may interfere with the free movement of the ground contact. 4.9 1 min. 5.6 mni. 2.3 mni. 0.35 min. 0.65 mni. 1.1 max. BDrawing of Mated Assembly - Shown for Reference ) ( 1.5 ) 2 ) 25.4 ( ( 5 ■Plugs ●Assembly Components 7.45 (non-terminated, without overmold) ●Connector Unit 3 CONTACT No.1 CONTACT No.5 ( 0.5) (A) 3 (0.75) 1.2 2.4 (2.4) ( 0.2) 22.7 B 1.2 2.4 14.4 CL No. Dimension A Dimension B Applicable Cable (Note) UX40-MB-5P Part No. 240-0004-7 6.2 6.95 Ø3.5~4.0 UX40A-MB-5P 240-0005-0 7.85 7.85 Ø4.1~4.6 Note: Recommended cable diameters. Actual diameters may vary due to manufacturing process variations. Contact Hirose for recommendations when using cables with different diameters than the recommended. ■Plug Harnesses Part No. CL No. UX40-MB-5PA-1000-2003 240-2003-5 1000 ( 55 ) ( 8.2 ) 16.2 ( B ) ( 9.5 ) ( 6.5 ) ( Ø3.9 ) (30.9 ) 6 BReceptacles Packaging Specification ●Embossed Carrier Tape Dimensions 16 (5.4) (Center of pick-and-place surface) 4 1.4 .5 Ø1 ( 6.3) (24) 22.25 11.5 1.75 Unreeling direction Note: Embossed tape reel packaging(1,000 pieces/reel) Order by the number of reels. ●Reel Dimensions (30.4) ( Ø1 3) ( 24.4) Unreeling direction (Ø 38 0) BRecommended Temperature Profile (Receptacles) Temperature (ç) 170±10ç 80~110S Recommended Conditions 230ç min. max. 50S Reflow : IR 250 Solder: Paste, 96.5 Sn/3.0 Ag/0.5 Cu 230 Test board: Glass epoxy 35mm∞35mm∞0.8 mm thick. 200 170 200ç min. max. 80S 0 (85ç) Time (sec.) Average slope 2ç/sec. 7 USA: HIROSE ELECTRIC U.S.A., INC. 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : 1 805 522 7958 Fax : 1 805 522 3217 http://www.hirose.com GERMANY: EUROPE BRANCH: HIROSE ELECTRIC GmbH HIROSE ELECTRIC CO., LTD. First Class Building 4F, Beechavenue 46.1119PV Zeppelinstrasse 42 D-73760 Ostfildern Kemnat Phone : 49 711 4560021 Schiphol-Rijk, The Netherlands Fax : 49 711 4560729 Phone : 31 20 6557 460 http://www.hirose.de Fax : 31 20 6557 469 http://hiroseeurope.com CHINA: HIROSE ELECTRIC CO., LTD. 10F,No.06, Shanghai Times Square office Tower, 93. Huai Hai Zhong Road, Luwan Shanghai Phone : 86 21 6391 0011 Fax : 86 21 6391 0101 HONG KONG: HIROSE ELECTRIC CO., LTD. Unit 506, Energy Plaza. 92 Granville Road, Tsim Sha Tsui East, Kowloon Phone : 852 2803 5338 Fax : 852 2591 6560 SINGAPORE: HIROSE ELECTRIC CO., LTD. 10 Anson Road #34-13 International Plaza 079903 Phone : 65 6324 6113 Fax : 65 6324 6123 TAIWAN: HIROSE ELECTRIC CO., LTD. No.28 Lane 247 Sec. 2 Yen Ping N,Rd.Taipei Phone : 886 2 2557 7351,7352 Fax : 886 2 2552 9851 to World E inks le eL s onic ctr Crea tiv UNITED KINGDOM: KOREA: HIROSE ELECTRIC UK LTD. HIROSE KOREA CO., LTD. Crownhill Business Centre 22 Vincent Avenue (#2NA311,Shihwa Industrial Complex), Crownhill, Milton Keynes MK8 OAB 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do Phone : 44 1908 305400 Phone : 82 31 496 7000,7124 Fax : 44 1908 305401 Fax : 82 31 496 7101 http://www.hirose.co.uk http://www.hirose.co.kr ® HIROSE ELECTRIC CO., LTD. 5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933 8 The contents of this catalog are current as of data of publication. Contents are subject to change without notice for the purpose of improvements.
UX60A-MB-5ST 价格&库存
很抱歉,暂时无法提供与“UX60A-MB-5ST”相匹配的价格&库存,您可以联系我们找货
UX60A-MB-5ST
  • 1000+4.645581000+0.60044
