SPBD-001T-P0.5
SPBD-001T-P0.5
    JST
    特性:安全锁定结构。插头有吸附区域。高可靠性触点。侧面插入双列类型。涂抹器可与PHD连接器触点的涂抹器互换。材料和表面处理:磷青铜,镀锡(回流处理),符合RoHS2标准。外壳材料:PBT,UL94V ...
SPBD-001T-P0.5 数据手册
PBD CONNECTOR 2.0 mm pitch/Disconnectable Crimp style connectors PBD CONNECTOR Specifications ● ● ● ● ●  ecure locking structure S Sucking area on header High reliability contact Side entry dual-row type Applicator is interchangeable with those of the PHD connector contact. • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: lnitial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 1.0 to 1.5 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. PC board layout and Assembly layout Circuit No.N-1 Circuit No.1 B±0.1 (10.8) 2±0.05 (7.6) Circuit No.N 6.8 (6.5) 3.4 min. 4.4 ±0.1 2.7 min. (2) Circuit No.2 1 min. Contact Applicable wire AWG# mm2 Model No. SPBD-001T-P0.5 SPBD-002T-P0.5 Insulation O.D. (mm) Q'ty/reel 0.13~0.33 26~22 1.0~1.5 10,000 0.08~0.21 28~24 0.8~1.5 10,000 1.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance 6.9 2.85 1.3 Contact Crimping machine Crimp applicator SPBD-001T-P0.5 AP-K2N SPBD-002T-P0.5 Applicator Dies Crimp applicator with dies MKS-L MK/SPBD-001-05 APLMK SPBD001-05 MKS-L-10 MK/SPHD-001-05 APLMK SPHD001-05 MKS-L MK/SPBD-002-05 APLMK SPBD002-05 MKS-L-10 MK/SPHD-002-05 APLMK SPHD002-05 Note: Contact JST for fully automatic crimping applicator. 1 PBD CONNECTOR Housing No. of circuits PBDP-16V-S PBDP-20V-S PBDP-30V-S 16 A 20 7.43 Model No. 30 Dimensions (mm) A B Q'ty/bag 19.7 14.0 500 23.7 18.0 300 33.7 28.0 200 Material and Finish 8 PBT, UL94V-0, natural (white) RoHS2 compliance B Shrouded header No. of circuits 16 6.5 Circuit No.2 6.8 Circuit No.N 0.7 A 20 30 Model No. SM16B-PBDSS-TF SM20B-PBDSS-TF SM30B-PBDSS-TF Dimensions (mm) A B Q'ty/reel 20.0 14.0 800 24.0 18.0 800 34.0 28.0 800 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Base housing: Polyamide resin, UL94V-0, natural (ivory) Base contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: These products listed above are supplied on embossed-tape. Circuit No.1 2 B Circuit No.N-1
SPBD-001T-P0.5 价格&库存
很抱歉,暂时无法提供与“SPBD-001T-P0.5”相匹配的价格&库存,您可以联系我们找货
SPBD-001T-P0.5
    • 1+0.147811+0.01921
    • 10+0.1304210+0.01695
    • 50+0.0956450+0.01243
    • 100+0.08695100+0.01130
    • 500+0.08695500+0.01130
    • 1000+0.078251000+0.01017
    • 2000+0.078252000+0.01017
    库存:9801
    SPBD-001T-P0.5
    • 1+0.970901+0.12619
    • 10+0.3531510+0.04590
    • 25+0.3281925+0.04266
    • 50+0.3104850+0.04036
    • 100+0.29650100+0.03854
    • 250+0.27774250+0.03610
    • 500+0.26434500+0.03436
    • 1000+0.251641000+0.03271
    • 2500+0.235862500+0.03066
    库存:6924
    SPBD-001T-P0.5
    • 10000+0.2037210000+0.02648
    • 20000+0.1939820000+0.02522
    • 30000+0.1885130000+0.02450
    • 50000+0.1818350000+0.02364
    • 70000+0.1775670000+0.02308
    • 100000+0.17314100000+0.02251
    库存:6924
    SPBD-001T-P0.5
      • 10000+0.04000
      库存:10000
      SPBD-001T-P0.5
        • 1067+0.367011067+0.04770
        • 1778+0.220211778+0.02862
        • 7408+0.146817408+0.01908
        库存:7840
