1N4007
1N4007
    ZRE(治润)
    DO-41
    1N4007
1N4007 数据手册
1N4001~1N4007 1.0Amp Standard Silicon Rectifiers DO-41 Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 1.0 (25.4) MIN. Open Junction chip Low reverse leakage 0.107 (2.7) 0.080 (2.0) DIA. High forward surge current capability High temperature soldering guaranteed 0.205 (5.2) 0.160(4.1) 250 C/10 seconds at terminals Mechanical Data 1.0 (25.4) MIN. Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 0.030(0.75) 0.020(0.50) DIA. Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0088 ounce, 0.25 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007 UNITS Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL =100 C I(AV) 1.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF 1.10 V Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C IR 10.0 500 uA Typical junction capacitance (Note1) CJ 21.0 pF RqJA 65.0 C/W -55 to +150 C Typical thermal resistance Operating junction and storage temperature range TJ,TSTG Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. Technology Innovation Future Rev.2018 Page 1 1N4001~1N4007 1.0Amp Standard Silicon Rectifiers Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 0.7 0.6 0.5 0.4 0.3 0.2 0 20 40 60 80 100 120 140 30 25 20 15 f=60Hz 10 5 1Cycle 0 160 1 100 Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 0.1 TJ=25 Pulse Width=300us 1% Duty Cycle 0.01 0.2 0.4 0.6 0.8 1.0 1.2 1.4 Volts Instantaneou Foward Voltage Technology Innovation Future 1.6 100 Micro Amperes Amperes 1 Instantaneous Reverse Leakage Current Lead Temperature 10 Instantneous Forward Current 10 Tj = 125°C 10 1.0 Tj = 25°C 0.1 0.01 0 20 40 60 80 100 120 140 Percent Of Rated Peak Reverse Voltage(%) Rev.2018 Page 2 1N4001~1N4007 1.0Amp Standard Silicon Rectifiers Suggested Soldering Temperature Profile Note R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder. Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s. D evices can b e cleaned using standa rd industry m ethods and solvents. If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e p e rfo rm a n c e re q u ire m e n ts . Package Information Taping Specifications Item Symbol Specifications(mm) Component Pitch A 5.0±0.5 Inner Tape Pitch B 52.4±1.5 Component alignment Z 1.2 Max Tape width T 6.0±0.5 Exposed adhesive E 0.8 Max Body eccentricity L1-L2 1.0 Max Ammunition Package Specifications Package Inner Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) DO - 41 255*150*75 5 420*276*312 50 Technology Innovation Future Rev.2018 Page 3
1N4007 价格&库存
很抱歉,暂时无法提供与“1N4007”相匹配的价格&库存,您可以联系我们找货
