SY8006
High Efficiency 1.5MHz, 1.2A
Synchronous Step Down LED Driver
Preliminary Spec
General Description
Features
The SY8006 is a high-efficiency 1.5MHz synchronous
step-down LED driver capable of delivering 1.2A
output current. SY8006 operates over a wide input
voltage range from 2.5V to 5.5V and integrate main
switch and synchronous switch with very low RDS(ON)
to minimize the conduction loss. It also features a
100mV feedback voltage for high efficiency operation.
Ordering Information
SY8006□
• low Rds(on) for internal switches (top/bottom):
200mΩ/150 mΩ
• 2.5-5.5V input voltage range
• 1.5MHz switching frequency
• Internal softstart limits the inrush current
• 5% 100mV reference
• 100% dropout operation
• SY8006P: LED current OK indicator output
• Compact package: SOT23-5 (SY8006), SOT23-6
(SY8006P)
Applications
Temerature Code
C: 0°C~85°C
Package Code:
AA:SOT23-5
AB:SOT23-6
Spec Code
Security System
Camcorder
Digital Camera
Emergency lighting
Portable Lamp
Typical Applications
VIN
IN
EN
L
CIN
VOUT
LX
GND
COUT
FB
R
Figure 1
SY8006Rev.0.2
Silergy Corp. Confidential-For Internal Use
1
SY8006
Pinout (top view)
EN
1
GND
2
LX
3
5
4
FB
IN
EN
1
6
FB
GND
2
5
PG
LX
3
4
IN
SOT23-5
SOT23-6
Pin Description
Pin
Name
EN
GND
LX
IN
FB
SY8006
SOT23-5
1
2
3
4
5
SY8006P
SOT23-6
1
2
3
4
6
PG
N/A
5
Pin Description
Enable control. Pull high to turn on. Do not float.
Ground pin
Inductor pin. Connect this pin to the switching node of inductor
Input pin. Decouple this pin to GND pin with at least 1uF ceramic cap
Output Feedback Pin. Connect this pin to the cathode of the LED and insert
the current sense resistor R2 from this point to ground. ILED=0.1V/R2
LED Current OK Indicator. If LED current is below 90% of regulation level,
PG is low; open drain otherwise.
Absolute Maximum Ratings (Note 1)
Supply Input Voltage -------------------------------------------------------------------------------------------- 6V
All Other Pins ----------------------------------------------------------------------------------------------------- VIN + 0.6V
Power Dissipation, PD @ TA = 25°C SOT-23-5/6------------------------------------------------------------ 0.4W
Package Thermal Resistance (Note 2)
SOT-23, θ JA ------------------------------------------------------------------------------------------- 250°C/W
SOT-23, θ JC ------------------------------------------------------------------------------------------- 130°C/W
Junction Temperature Range ----------------------------------------------------------------------------------- 150°C
Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------- 260°C
Storage Temperature Range ------------------------------------------------------------------------------------ -65°C to 150°C
ESD Susceptibility (Note 2)
HBM (Human Body Mode) ------------------------------------------------------------------------------------ 2kV
MM (Machine Mode) -------------------------------------------------------------------------------------------- 200V
Recommended Operating Conditions
(Note 3)
IN pins ------------------------------------------------------------------------------------------------------------- 2.5V to 5.5V
LX pin-------------------------------------------------------------------------------------------------------------- 2.5V to 6V
FB, EN pin ---------------------------------------------------------------------------- ---------------------------- 0 to 5.5V
Junction Temperature Range ----------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range ----------------------------------------------------------------------------------- -40°C to 85°C
SY8006Rev.0.2
2
SY8006
Electrical Characteristics
(VIN = 3.6V, ILED=0.3A, RLED=6ohm, L = 2.2uH, COUT = 10uF, TA = 25°C, IMAX = 1A unless otherwise specified)
Parameter
Input Voltage Range
Quiescent Current
Shutdown Current
Feedback Reference
Voltage
FB Input Current
PFET RON
NFET RON
PFET Current Limit
EN rising threshold
EN falling threshold
Input UVLO threshold
UVLO hysteresis
Oscillator Frequency
Min ON Time
Max Duty Cycle
Thermal Shutdown
Temperature
Symbol
VIN
IQ
ISHDN
VREF
IFB
RDS(ON),P
RDS(ON),N
ISW
VENH
VENL
VUVLO
VHYS
FOSC
Test Conditions
Min
2.5
IOUT=0, VFB=VREF+5%
EN=0
0.09
VFB=VIN
Typ
100
0.1
0.1
-50
Max
5.5
200
1
0.11
Unit
V
µA
µA
V
50
nA
Ω
Ω
A
V
V
V
V
MHz
ns
°C
0.2
0.15
2.4
1.5
0.4
2.4
0.1
1.5
50
IOUT=100mA
100
TSD
150
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
These are for stress ratings. Functional operation of the device at these or any other conditions beyond those
indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating
conditions for extended periods may remain possibility to affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal
conductivity test board of JEDEC 51-3 thermal measurement standard. Pin 2 of SSOT23-6 package is the case
position for θ JC measurement.
Note 3:The device is not guaranteed to function outside its operating conditions.
SY8006Rev.0.2
3
很抱歉,暂时无法提供与“SY8006AAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.22570
- 50+1.19708
- 150+1.17796
- 500+1.15884
- 国内价格
- 1+0.89870
- 200+0.62040
- 1500+0.56430
- 3000+0.52690
