ISO9001: 2000
ISO14001: 2004
APPROVAL SPECIFICATIONS
Title.
TACT SWITCH
Product Model.
TS-1002N
Customer’s Part NO.
Customer’s Model:
Customer’s Approval Requested.
Please return this copy as a certification of yourapproval.
Checked by:
Date:
Approved by:
Date:
APPROVE
王凱
REVIEW
POLT
李成功
許志明
XUNPU ELECTRONICS CO.,LTD
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
PRODUCT
REVISION
TACT SWITCH
产品符合ROHS
General tolerance:±0.2mm
NO.
NAME
MATERIAL
1
Terminal
2
QTY.
FINISHING
Brass
4
Plating silver
Contact
SUS
1
3
Cover
SPCC
1
PLAting nickel
4
Base
Nylon
1
Black
5
Keystoke
Nylon
1
BlacK
APPROVE BY
王凯12.05.21
CHECKED BY
NATIONALITY
李成功12.05.21
PRPARE BY
许志明12.05.21
Page 1of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
PRODUCT
TS-1002N
REVISION
TACT SWITCH
A.Specification & meanings
The name of the tact switch is composed by type and specification,the particular meaning of the type、specification
and code is as follows.
TS-1002N-
Operating force(refer to chart 2)
Pr oduct height(re fer to char t 1)
1、Product height: It is denoted by three figures:
Code
043
045
Product height(mm)
4.3
4.5
5.0
050
055
060
065
070
075
080
085
5.5
6.0
6.5
7.0
7.5
8.0
8.5
Code
090
095
100
105
110
115
120
125
130
135
Product height(mm) Code
9.0
140
9.5
145
10.0
150
Product height(mm)
14.0
14.5
15.0
155
160
165
170
175
180
185
10.5
11.0
11.5
12.0
12.5
13.0
13.5
15.5
16.0
16.5
17.0
17.5
18.0
18.5
2、Operat ing force: An Engli sh letter e xpresses it, u ni te: N ewton (N),as cha rt 2 show s:
force
Code
Operating
16
26
Spec
1.6
2.6
Press force(N)
1.6±0.5
2.6±0.5
Return force
0.4min
0.4min
Examples: “TS-1002N-04316” denotes the ta ct switch with 6×6 base, the height is 4.3mm,the stem is black ,
theoperating force is 1.6N.
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
PRPARE BY
許志明12.05.21
Page 2 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
PRODUCT
REVISION
TACT SWITCH
1、 概述
GENERAL
1.2 适用范围
APPLICATION
此规格书适用于机械式轻触开关的相关要求
This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT)
1.3 工作温度范围
Operating Temperature Range
-20℃~70℃(在标准大气压、标准湿度条件下)
-20℃~70℃(Normal humidity, normal air pressure)
1.4 贮藏温度范围
Storage Temperature Range
-30℃~80℃(在标准大气压、标准湿度条件下)
-30℃~80℃(Normal humidity, normal air pressure)
1.5 测试条件
Test Conditions
在没有其它特定的条件下,应该在以下的条件下进行测试和测量:
Unless otherwise specified, tests and measurement shall be made in the following standard conditions:
常温…………………………………5℃~35℃
Normal temperature………………5℃~35℃
标准湿度……………………………相对湿度 25%~85%
Normal humidity…………………relative humidity 25%~85%
标准大气压…………………………86KPa~106Kpa
Normal air pressure…………………86Kpa~106Kpa
在制造过程中,测试和测量应该在以下的条件下进行:
If any doubt arise from the judgment, tests shall be conducted at the following conditions:
温度…………………………………20℃±2℃
Temperature………………………20℃±2℃
相对湿度……………………………65%±5%
Relative humidity………………65%±5%
环境气压…………………………86KPa~106Kpa
Airpressure…………………………86KPa~106Kpa
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
PRPARE BY
許志明12.05.21
Page 3 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
PRODUCT
REVISION
TS-1002N
2、
详细说明
2.1
Detailed specification
外观:应无影响、降低产品性能的缺陷;
2.2
Appearance: There should be no defects that affect the serviceability of product.
结构尺寸和安装尺寸:应符合装配图要求;
Style and dimension: shall conform to the assemble drawings.
2.3 操作形式:有触觉反应的操作
Type of actuating: Tactile feedback.
2.4 开关结构:单回路单输出(具体的触点结构在装配图中已绘出);
Contact arrangement: 1 pole, 1 throw
2.5
(Details of contact arrangement are given in the assembly drawings.)
开关工作额定值:DC 12V,50mA(有效值)
Ratings: 12V DC, 50mA (effective value)
3.电气性能:
ELECTRICAL SPECIFICATION
项
目
试 验 条 件
ITEM
1
要求
TEST CONDITIONS
在以 5V 10mA 的直流电源或不低于1KHz 的交流电源
的电路中,以一个等于 2 倍按力的静负荷施加于手柄中心
接触电阻
Contact Resistance
REQUIREMENTS
Applying a static load of 2 times operating force to
the center of the stem, measurements shall be made by
≤100mΩ
5V DC 10mA or more than 1KHZ AC small-current
contact resistance meter.
绝缘电阻
2
在端子之间施加 DC 100V /1min 的条件下,测量端
子之间底座、盖板的电阻值
Insulation
Measurement shall be made following application of
Resistance
100V DC potential, across terminals, and across
≥100MΩ
terminals and cover, for one minute.
介质耐压
3
在端子之间施加 250V AC(50HZ 或 60HZ)/1min
Dielectric
250V AC (50HZ or 60HZ) shall be applied across
voltage proof
terminals, for one minute.
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
无击穿、无飞弧
There should be
no breakdown and
flashover
PRPARE BY
許志明12.05.21
Page 4 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
PRODUCT
REVISION
TACT SWITCH
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
开关垂直于操作方向放置,在开关驱动件顶端中心逐渐施力,测
量开关导通所需的最大力度。
Placing the switch such that the direction of switch operation is
vertical and then gradually increasing the load applied to the
center of the stem, the maximum load required for the switch to
come to a stop shall be measured.
refer to chart 3
开关垂直于操作方向放置,以一个等于 2 倍按力的静负荷施加在
开关驱动件顶端中心,测量顶端移动的距离。
vertical and then applying static load of 2times operating force to
the center of the stem; the travel distance for the switch to come
0.25±0.1mm
4.机械性能:
MECHANICAL SPECIFICATION
按力
1
2
Operating
Force
最大行程
Full Travel
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
PRPARE BY
許志明12.05.21
Page 5 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
3
4
5
6
PRODUCT
REVISION
TACT SWITCH
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
回弹力
Return Force
停止强度
Stop Strength
手柄拔出强度
Stem
Strength
可焊性
Solderability
APPROVE BY
开关垂直于操作方向放置,在开关驱动件顶端中心下降至全行程
后,测量顶端向自由位置转换的力度。
refer to chart 3
The sample switch is installed such that the direction of switch
operation is vertical and upon depressing the stem in its center
to the whole travel distance, the force of the stem to return to its
free position shall be measured.
开关垂直于操作方向放置,从操作方向向驱动件施加 30N 的静负
荷持续 1min。
无机械和电气损坏
vertical, and then a static load of 30N shall be applied in the
There shall be no sign of
direction of stem operation for a period of 1 min.
damage mechanically and
electrically.
开关垂直于操作方向放置,反方向实施最大操作力,并测量手柄
的行程范围。
20N.min.
vertical, and then the maximum force to withstand a pull applied
opposite to the direction of stem operation shall be measured.
在以下设定条件下进行测量:
Measurements shall be made following the test set forth below:
(1) 焊接温度:245±5℃
Solder temperature : 245±5℃
(2) 浸入时间:2s±0.5s
Immersion time: 2s±0.5s
对于其它步骤参考《GB 5095.6—86》试验12a
The other steps please refer to《GB 5095.6-86》TEST 12a
王凱12.05.21
CHECKED BY
李成功12.05.21
除边缘外涂层应均匀覆盖
90%以上
Except for the edge, the
coating should cover a
minimum 90%
PRPARE BY
許志明12.05.21
Page 6 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
PRODUCT
REVISION
TACT SWITCH
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
低温测试
Resistance
to
low temperature
样品应按照以下实验条件进行测试,实验后样品应放在常温及
标准湿度的环境中 1 小时后做性能测试:
Following the test set forth below the sample shall be left in
normal temperature and humidity conditions for 1 h before
measurements are made:
(1) 温度:-30±2℃
Temperature : -30±2℃
(2) 时间:96h
Time: 96h
接触电阻:≤200mΩ
Contact
resistance:
≤200mΩ
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
高温测试
标准湿度的环境中 1 小时后做性能测试:Following the test set
forth below the sample shall be left in normal temperature and
humidity conditions for 1 h before measurements are made:
(1) 温度:80±2℃
temperature:80±2℃
(2) 时间:96h
time: 96h
5、极限电气性能:
ENVIRONMENTAL SPECIFICATION
1
2
Heat resistance
接触电阻:≤200mΩ
Contact
resistance:
≤200mΩ
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
根据下面的测试要求进行 5 次循环的温度周期性测试,实验后
样品应放在常温及标准湿度的环境中 1 小时后做性能测试。测
试期间样品应保持干燥.
After 5 cycles of following conditions, the sample shall be
allowed to stand under normal temperature and humidity
conditions for 1 h. and measurements shall be made. During
the test water drops shall be removed.
APPROVE BY
王凱12.05.21
1cycle
3
温度周期性测试
Change of
temperature
Temperature
-10±2℃
2(hour)
-10~65℃
1
65±2℃
2
65~-10℃
1
CHECKED BY
Time
李成功12.05.21
接触电阻:≤200mΩ
Contact
resistance:
≤200mΩ
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
PRPARE BY
許志明12.05.21
Page 7 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
PRODUCT
REVISION
TACT SWITCH
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
4
湿温测试
Moisture
resistance
(1) 温度:60±2℃
temperature: 60±2℃
(2) 相对湿度:90%~95%
relative humidity:90% to
95%
(3) 时间:96h
time: 96h
接触电阻:≤200mΩ
Contact
resistance:
≤200mΩ
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
5
6
硫化试验
Sulfuration
resistance
盐雾试验
Salt Mist
APPROVE BY
(1) H2S 气体浓度:3ppm±1ppm
H2S gas concentration: 3ppm±1ppm
(2) 时间:72h
Time: 72h
(3) 温度:40±2℃(90~95%RH)
temperature: 40±2℃(90~95%RH)
在以下设定条件下进行测量:
The switch shall be checked after followingtest:
(1)温度:35℃±2℃
temperature: 35℃±2℃
(2)盐溶液浓度:5±1%(质量百分比)
salt solution : 5±1%(solids by mass)
(3)时间:8h±1h
Time: 8h±1 hour
实验后的盐沉积物后水冲掉
After test, salt deposit shall be removed by running water.
王凱12.05.21
CHECKED BY
李成功12.05.21
接触电阻:≤200mΩ
Contact
resistance:
≤200mΩ
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
金属件上没有腐蚀斑点
No remarkable
corrosion
shall
be
recognized in metal part.
PRPARE BY
許志明12.05.21
Page 8 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
1
2
工作寿命
Operation life
振动Vibration
GYE’S P/N
PRODUCT
TS-1002N
6、极限机械性能:
ENDURANCE SPECIFICATION
项目
ITEM
REVISION
TACT SWITCH
试 验 条 件
要求
TEST CONDITIONS
根据下面的测试要求进行测试:
Measurement shall be made following the test set forth below:
(1) DC 12V,50mA 带负载
DC 12V, 50 mA resistive load
(2) 按动速率:1 次/秒
Rate of operation: 1times/s
(3) 按力:按力的 1.5 倍
Operating Force: OperatingForce1.5double
(4) 平均无故障寿命:Average fault-freelife
REQUIREMENTS
16
25
100000 次
100000次
1.6
2.5
根据以下给定条件进行测试:
(1) 振动频率范围:10~55~10Hz
Vibration frequency range: 10 to 55 to 10Hz
(2) 振幅(峰-峰):1.5mm
Amplitude: 1.5mm
(3)
振动方向:包括手柄行程方向在内的三个相互垂直的方
向
(4)
接触电阻≤200mΩContact
resistance≤200mΩ
触点弹力≤10ms
Contact bounce≤10ms按
力 : 初 值 的 ±30%
Operating Force:
initial value±30%
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
项目 3,4.1,4.2,4.3
Item 3,4.1,4.2,4.3
Direction of vibration:Three mutually perpendicular
direction including the direction of stem travel
测试时间:每次 2hours .
Duration: Each 2hours.
7.焊接条件:
SOLDERING CONDITIONS:
请按以下条件进行焊接:
(1) 焊锡温度:≤350℃
(2) 连续焊接时间:≤3 s
手工焊接
7.1
Hand soldering
Please practice according to below conditions:
(1) Soldering temperature:
350℃ Max.
(2) Continuous soldering time: 3 sMax.
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
PRPARE BY
許志明12.05.21
Page 9 of 10
XUNPU
CUSTOMER
CUSTOMER’S P/N
GYE’S P/N
TS-1002N
Conditions for
助焊剂附着量
条件 Condition
不附着于零部件贴装面的程度
Flux built-up
Mounting surface should not be coated with flax
预热温度
印刷电路板焊接面的周围温度 100℃ max.
Preheating temperature
Ambient temperature of the soldered surface of PC board.
100℃ max.
预热温度时间
7.2
REVISION
TACT SWITCH
项目 Items
自动浸焊
Auto-dip
PRODUCT
60s max.
Preheating time
焊接温度
260℃ max.
焊接浸渍时间
5s max.
Continuous dipping time
2 次以下
焊接次数
2times max.
Number of soldering
焊接说明:
1、开关浸焊后,注意不要用溶剂清洗。
After switches were soldered,please be careful not to clean switches with solvent.
1.1 在使用烙铁的情况下,焊锡温度应在350℃以下、3 秒以内。
In the case of using solding iron, solding conditions shall be 350℃ max and 3 sec.max.
1.2 浸焊后,注意不要在顶部施加负荷。
Right after switches were soidered;please be careful not to load to on the knobs of switches.
2、设计中应注意的事项( Design instructions)
2.1 印刷基板的安装孔尺寸参见产品图。
Follow recommended P.W.B. piercing plan in outside drawing page.
3、注意点(Note):
3.1 注意不要施加超负荷的压力或晃动开关。
Please be cautions not to give excessive static load or shock to swiches.
3.2 开关浸焊后,印刷基板注意不要叠放。
Please be careful not to pile up P.W.B.after switches were soldered.
3.3 保管时尤其应注意避开高湿高温和有腐蚀性气体的环境。如需要长时间保存,请不要
打开包装箱。
Preservation under high temperature and high high humidity or corrosive gas should be
avoided Especially . When you need to preserve for a long period ,do not open the carton.
APPROVE BY
王凱12.05.21
CHECKED BY
李成功12.05.21
PRPARE BY
許志明12.05.21
Page 10 of 10
