PS10U200FS
PS10U200FS
    PINGWEI(平伟)
    ITO-220AB
PS10U200FS 数据手册
PS10U200S&PS10U200FS PS10U200S&PS10U200FS 10.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-220AB PS10U200S ITO-220AB PS10U200FS MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U200S&PS10U200FS Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 200 V 140 V 200 V IF(AV) 10.0 A IFSM 150.0 A CJ TJ, TSTG 230 pF -55 to +150 °C Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TC =100°C Total device Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Typical Junction Capacitance (Note 1) Operation Junction Temperature and Storage Temperature Maximum Mounting torque, M3 or 6-32 srew 1.1N•m (10 lbf•in) ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol Test conditions TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current IR TJ=25℃ TJ=125℃ IF=3A IF=5A IF=10A IF=3A IF=5A IF=10A VR=150V VR=150V THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Typ Max 0.70 0.76 0.87 0.59 0.64 0.72 ------- ------0.95 ------0.80 0.1 15 Units V mA Parameter Symbol PS10U200S PS10U200FS Units Typical Thermal Resistance (Note 2) R(JC) 2.0 3.0 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS10U200S&PS10U200FS RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 5.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 200 1 0.1 CASE TEMPERTURE,(℃) TJ=25℃ TJ=125℃ 10 0.6 0.4 0.2 0.8 1.0 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 150 8.3ms Single Half Sine-Wave (JEDEC Method) INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 100 100 50 0 10 1 0.1 0.01 1 10 0.001 100 TJ=125℃ TJ=25℃ 0 40 80 120 160 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) NUMBER OF CYCLES AT 60Hz 2 200 PS10U200S&PS10U200FS PACKAGE OUTLINE DIMENSIONS TO-220AB L I C Dim A B H G C D A E F PIN 1 2 G 3 H I D J E K J F L P TO-220AB Min Max .573(14.55) .603(15.32) ―― .412(10.5) .103(2.62) .113(2.87) .140(3.56) .160(4.06) .510(13.0) .560(14.3) .027(0.68) .037(0.94) .148(3.74) .154(3.91) .230(5.84) .270(6.86) .175(4.44) .185(4.86) .100(2.54) .110(2.79) .014(0.35) .025(0.64) .045(1.14) .055(1.40) .095(2.41) .105(2.67) Dimensions in inches and (millimeters) ITO-220AB B L G I C H A PIN 1 2 D 3 E J F P K ITO-220AB Min Max A .571(14.5) .610(15.5) B .383(9.72) .406(10.3) C .110(2.80) .126(3.20) D .133(3.38) .162(4.10) E .512(13.0) .551(14.0) F .028(0.70) .035(0.90) G .114(2.90) .138(3.50) H .268(6.80) .291(7.40) I .162(4.10) .185(4.70) J .102(2.60) .110(2.80) K .018(0.45) .026(0.65) L .097(2.46) .113(2.86) P .890(2.25) .113(2.85) Dim Dimensions in inches and (millimeters) 3 PS10U200S&PS10U200FS Marking and packaging illustration 1、Marking SYMBOL XX XXXXX XXX A B XXX Explanation A B C D Trademark Product Name Date Code Product Information C D 2、Packaging A B C Tube Inside Box 类别 TO-220 Tube(50EA per tube ) TO-220 Inside Box(1K per box) TO-220 outside Box(6K per box) Outside Box A(mm) B(mm) C(mm) 530±5 7±0.8 33±1 542±5 82±2 78±1 555±5 285±5 245±5 4
PS10U200FS 价格&库存
很抱歉,暂时无法提供与“PS10U200FS”相匹配的价格&库存,您可以联系我们找货
