PS10U60FS
PS10U60FS
    PINGWEI(平伟)
    ITO-220AB
PS10U60FS 数据手册
PS10U60S&PS10U60FS PS10U60S&PS10U60FS 10 .0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-220AB PS10U60S ITO-220AB PS10U60FS MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U60S&PS10U60FS Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 60 V 42 V 60 V IF(AV) 10.0 A IFSM 120.0 A CJ TJ, TSTG 460 pF -55 to +150 °C Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current Total device at TC =100°C Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Typical Junction Capacitance (Note 1) Operation Junction Temperature and Storage Temperature ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Maximum Forward Voltage Symbol at 5.0A DC VF at 10.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C IR @TA =100°C Typ Max 0.42 ---- 0.54 0.60 ---- 0.25 ---- 50.0 Units V mA THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U60S PS10U60FS Units Typical Thermal Resistance (Note 2) R(JC) 2.0 3.0 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS10U60S&PS10U60FS RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 5.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 10 1 .1 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle .1 CASE TEMPERTURE,(℃) 0.5 .3 0.7 0.9 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 8.3ms Single Half Sine-Wave (JEDEC Method) 150 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 100 50 1.0 TJ=25℃ 0.1 .01 0 0 10 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140 PS10U60S&PS10U60FS PACKAGE OUTLINE DIMENSIONS TO-220AB L I Dim A C H B C G A .140(3.56) .510(13.0) .027(0.68) .148(3.74) .230(5.84) .160(4.06) .560(14.3) .037(0.94) .154(3.91) .270(6.86) L .175(4.44) .100(2.54) .014(0.35) .045(1.14) .185(4.86) .110(2.79) .025(0.64) .055(1.40) P .095(2.41) .105(2.67) D E F PIN 1 2 3 G H I D E J K J F TO-220AB Min Max .573(14.55) .603(15.32) ―― .412(10.5) .103(2.62) .113(2.87) Dimensions in inches and (millimeters) ITO-220AB B L G I C H A ITO-220AB Min Max A .571(14.5) .610(15.5) B .383(9.72) .406(10.3) C .110(2.80) .126(3.20) Dim D E F PIN 1 2 3 G H I D J E K J F L P P .133(3.38) .512(13.0) .028(0.70) .114(2.90) .268(6.80) .162(4.10) .551(14.0) .035(0.90) .138(3.50) .291(7.40) .162(4.10) .102(2.60) .018(0.45) .097(2.46) .890(2.25) .185(4.70) .110(2.80) .026(0.65) .113(2.86) .113(2.85) K Dimensions in inches and (millimeters) 3
PS10U60FS 价格&库存
很抱歉,暂时无法提供与“PS10U60FS”相匹配的价格&库存,您可以联系我们找货
