AU0521P1L
AU0521P1L
    APPLIEDPOWER(应能微)
    DFN1006-2
    AU0521P1L
AU0521P1L 数据手册
AU0521P1L 1-Line Bi-directional TVS Diode Description Mechanical Characteristics The AU0521P1L is a bi-directional TVS diode, utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive data and power line. The AU0521P1L complies with the IEC 61000-4-2 (ESD) with ±30 kV air and ±30kV contact discharge. It is assembled into an ultra-small 1.0x0.6x0.5mm lead-free DFN package. The small size and high ESD surge protection make AU0521P1L an ideal choice to protect cell phone, digital cameras, audio players and many other portable applications. • Package: DFN1006-2 (1.0×0.6×0.5mm) • • Case Material: “Green” Molding Compound. Moisture Sensitivity: Level 3 per J-STD-020 • Terminal Connections: See Diagram Below • Marking Information: See Below Features • Ultra small package: 1.0x0.6x0.5mm • • Protects one data or power line Ultra low leakage: nA level • Low operating voltage: 5V • Low clamping voltage • • 2-pin leadless package Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 4A (8/20μs) • Applications • • Cellular Handsets and Accessories Personal Digital Assistants • Notebooks and Handhelds • Portable Instrumentation • • Digital Cameras Peripherals • Audio Players • Keypads, Side Keys, LCD Displays Marking Information SS SS = Device Marking Code RoHS Compliant Ordering Information Dimensions and Pin Configuration 1.0 Packaging Reel Size AU0521P1L 10000/Tape & Reel 7 inch 0.6 1 Part Number 0.5 Package Dimensions Revision 1.1 2 Circuit and Pin Schematic 1 of 4 www.appliedpowermicro.com AU0521P1L Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 45 W Peak Pulse Current (8/20µs) IPP 4 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 6 Max Unit Test Condition 5 V 8 V IT = 1mA Reverse Leakage Current IR 0.2 μA VRWM = 5V Clamping Voltage VC 8 V IPP = 1A Clamping Voltage VC 11 V IPP = 4A Junction Capacitance CJ pF VR = 0V, f = 1MHz Revision 1.1 9 2 of 4 www.appliedpowermicro.com AU0521P1L Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Clamping Voltage vs. Peak Pulse Current (tp = 8/20μs) TLP IV Curve Power Derating Curve % of Peak Pulse Current 100 80 60 40 20 0 0 20 40 60 80 Time_t(μs) ESD Clamping Voltage 8 X 20μs Pulse Waveform Revision 1.1 8 kV Contact per IEC61000−4−2 3 of 4 www.appliedpowermicro.com AU0521P1L DFN1006-2 Package Outline Drawing e L1 A A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM L1 b E - DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 h h D L c A Bottom View A1 e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 L1 h 0.05REF 0.07 0.12 0.002REF 0.17 0.003 0.005 0.007 Suggested Land Pattern SYM ╋ Y3 DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Y1 Y2 Z ╋ X Contact Information Applied Power Microelectronics Co., Ltd. Website: http://www.appliedpowermicro.com Email: sales@appliedpowermicro.com Phone: +86 (0519) 8399 3606 Applied Power Microelectronics Co., Ltd. (APM) reserves the right to make changes to the product specification and data in this document without notice. APM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does APM assume any liability arising from the application or use of any products or circuits, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Revision 1.1 4 of 4 www.appliedpowermicro.com
AU0521P1L 价格&库存
很抱歉,暂时无法提供与“AU0521P1L”相匹配的价格&库存,您可以联系我们找货
