CHS-04A
CHS-04A
    NIDEC(尼得科)
    SMD8_6.6X5.4MM
CHS-04A 数据手册
SLIDE SWITCHES (HALF PITCH) RoHS compliant CHS INTERNAL STRUCTURE ① ② ③ ⑤ ④ ⑥ Part name ■ FEATURES ORoHS compliant OMeets EIAJ SOP standard outline dimensions (B type) OLow profile design of 2.5 mm O12 types of 1, 2, 4, 6, 8 or 10 bit with either gull wing or J-hook available O Excellent contact stability by twin Gold-plated contact Material Flammability ① Cover Polyphenylenesulphide ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin UL94V-0 Polyphenylenesulphide Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION CHS - 06 T A 1 Series name Structure 1:Non-washable type (Without seal tape) Standard type No. of bits 2:Non-washable type (With seal tape) 01:1 bit 02:2 bits 04:4 bits 06:6 bits 08:8 bits 10:110 bits Blank : Washable type (With seal tape) Form of packaging Shape of terminal T :Taping (Reel) M:Magazine Blank:Bulk in plastic bag A:J-hook B:Gull wing ※ Please refer to the LIST OF PART NUMBERS when placing orders. CHS SLIDE SWITCHES (HALF PITCH) ■ LIST OF PART NUMBERS No. of bits 1 2 4 6 8 10 No. of bits 1 2 4 6 8 10 Form of packaging Shape of terminals Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Form of packaging Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Shape of terminals Non-washable type (Without seal tape) Non-washable type (With seal tape) Pieces in package A (J-hook) B (Gull wing)        A (J-hook) B(Gull wing) CHS-01TA1 CHS-01TB1 CHS-01TA2 CHS-01TB2 1000 pcs./reel CHS-01A1 CHS-02TA1 CHS-01B1 CHS-02TB1 CHS-02TA2 CHS-02TB2 50 pcs./pack 500 pcs./reel CHS-02A1 CHS-04TA1 CHS-04MA1 CHS-04A1 CHS-06TA1 CHS-06MA1 CHS-06A1 CHS-08TA1 CHS-08MA1 CHS-08A1 CHS-10TA1 CHS-10MA1 CHS-10A1 CHS-02B1 CHS-04TB1 CHS-04MB1 CHS-04B1 CHS-06TB1 CHS-06MB1 CHS-06B1 CHS-08TB1 CHS-08MB1 CHS-08B1 CHS-10TB1 CHS-10MB1 CHS-10B1 CHS-04TA2 CHS-04TB2 CHS-06TA2 CHS-06TB2 CHS-08TA2 CHS-08TB2 CHS-10TA2 CHS-10TB2 Washable type (With seal tape) Pieces in package A (J-hook) B (Gull wing) CHS-01TA CHS-01TB 1000 pcs./reel CHS-01A CHS-02TA CHS-01B CHS-02TB 50 pcs./pack 500 pcs./reel CHS-02A CHS-04TA CHS-04MA CHS-04A CHS-06TA CHS-06MA CHS-06A CHS-08TA CHS-08MA CHS-08A CHS-10TA CHS-10MA CHS-10A CHS-02B CHS-04TB CHS-04MB CHS-04B CHS-06TB CHS-06MB CHS-06B CHS-08TB CHS-08MB CHS-08B CHS-10TB CHS-10MB CHS-10B 50 pcs./pack 500 pcs./reel 70 pcs./stick 50 pcs./pack 500 pcs./reel 50 pcs./stick 50 pcs./pack 500 pcs./reel 40 pcs./stick 50 pcs./pack 500 pcs./reel 30 pcs./stick 50 pcs./pack   : Not manufactured ※ Verify the above part numbers when placing orders. Taping and magazine version can be supplied only in reel or stick units. 50 pcs./pack 500 pcs./reel 70 pcs./stick 50 pcs./pack 500 pcs./reel 50 pcs./stick 50 pcs./pack 500 pcs./reel 40 pcs./stick 50 pcs./pack 500 pcs./reel 30 pcs./stick 50 pcs./pack CHS SLIDE SWITCHES (HALF PITCH) ■ STANDARD SPECIFICATIONS ■ ELECTRICAL CHARACTERISTICS Operating temp. range Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Storage temp. range Sealing Net weight Washable type available with seal tape Contact resistance Approx. 0.05 g (CHS-01) Approx. 0.08 g (CHS-02) Approx. 0.12 g (CHS-04) Approx. 0.17 g (CHS-06) Approx. 0.22 g (CHS-08) Approx. 0.25 g (CHS-10) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS Operating force DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μA 50 mΩ maximum 1000 MΩ (DC100 V) minimum AC500 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS 0.5 ~ 5 N {0.05 ~ 0.51 kgf} Vibration Amplitude 1.5 mm or Acceleration 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each Stop strength 10 N {1.02 kgf}, 60 s Shock 490 m/s2, 11 ms 6 directions for 3 times each Solderability 245 ± 3 °C, 2 ~ 3 s Load life Continuous load 2000 cycles, DC6 ± 0.5 V, 100 ± 10 mA Reflow:255 °C (Peak temperature) (Please refer to the profile below) Humidity −10 ~ 65 °C, Relative humidity 0 ~ 96 %, 24 h for 10 cycles Soldering heat Manual soldering:350 ± 10 °C, 3 ~ 4 s High temp. exposure 85 °C, 96 h Shear (Adhesion) 5 N {0.51 kgf} 10 s Low temp. exposure − 40 °C, 96 h Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength Thermal shock 5 N {0.51 kgf} 10 s { } : Reference only 〈Reflow profile for soldering heat evaluation〉 (C) 250 Peak : 250 +5 0 C Temperature Over 230 C 200 150 180 C Pre Heating Zone 150 C 90 30 s 100 50 30 10 s Heating time Soldering Zone リフロー回数:2回 Reflow : two times maximum − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-01B1 Non-washable type (Without seal tape) 8 5.4 O N 2 0.3 2.5 max. 0.1 0.6+–0.05 0 0 2.5 0.1–0.1 0.1 0.6+–0.05 0.1 –0.1 2.5 max. 0.3 2.5 Schematic 0.4 min. 0. 0.1 0.15+–0.05 – 2 C – C 0.1 0.15+–0.05 5 0. 5 3.8 Stroke 0.6 Production date code 5.6+0.3 0 5.4 O N Stroke 0.6 Production date code 0.4 min. OCHS-01A1 Non-washable type (Without seal tape) Schematic OCHS-02B1 (EIn accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 1.4±0.15 Schematic 0.4 min. 8 5.4 0.3 4.1 0.1 0.4+–0.05 1.27±0.15 O N C 0.1 0.15+–0.05 2.5 max. 0.10.1 0.10.1 2.5 max. 0.3 C 0.1 0.15+–0.05 0. 5 0. 5 3.8 Stroke 0.6 Production date code 5.6+0.3 0 5.4 O N Stroke 0.6 Production date code 4.1 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. OCHS-02A1 Non-washable type (Without seal tape) CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-04B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 1.4±0.15 8 5.4 6.6 0.3 2.5 max. 0.1±0.1 0.1 0.4+–0.05 1.27±0.15 Schematic Schematic OCHS-06A1 Non-washable type (Without seal tape) OCHS-06B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 2.5 max. Schematic 0.1±0.1 1.4±0.15 0.3 8 5.4 0.1 0.15+–0.05 9.2 0.1 0.4+–0.05 1.27±0.15 O N C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N C Stroke 0.6 0. 5 0.3 2.5 max. 0.1 0.15+–0.05 0.4 min. Production date code Production date code 0.1±0.1 1.4±0.15 9.2 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. 0.1 0.4+–0.05 1.27±0.15 O N C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N C Stroke 0.6 0. 5 0.1 0.15+–0.05 6.6 0.3 2.5 max. 0.1±0.1 0.1 0.15+–0.05 0.4 min. Production date code Production date code 0.4 min. OCHS-04A1 Non-washable type (Without seal tape) CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-08A1 Non-washable type (Without seal tape) OCHS-08B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 8 5.4 O N Stroke 0.6 C 0.1 0.15+–0.05 1.4±0.15 11.7 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic OCHS-10B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) Production date code 8 5.4 O N Stroke 0.6 3.8 5.6 +0.3 0 5.4 O N Stroke 0.6 Production date code 0.1 0.15+–0.05 0.1 0.15+–0.05 14.3 2.5 max. 2.5 max. 0.1±0.1 14.3 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. OCHS-10A1 Non-washable type (Without seal tape) 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. 0.1 0.4+–0.05 1.27±0.15 2.5 max. 0.1±0.1 0.3 11.7 0.4 min. 0. 5 3.8 5.6 +0.3 0 5.4 O N Stroke 0.6 5 0. 2.5 max. 0.1±0.1 0.3 C 0.1 0.15+–0.05 Schematic 0.1±0.1 0.4 min. Production date code Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-01A OCHS-01B Washable type (With seal tape) Washable type (With seal tape) OCHS-01TA2 OCHS-01TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) 0.4 min. Production date code 8 5.4 O N Stroke 0.6 Seal tape 0.1 0.6 +–0.05 0 0.1–0.1 0 0.1 –0.1 0.1 0.6 +–0.05 2.5 0.3 2.5 max. 0.3 2.5 Schematic 0.4 min. 0. 2 Seal tape Schematic OCHS-02A OCHS-02B Washable type (With seal tape) Washable type (With seal tape) OCHS-02TA2 OCHS-02TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) 0.4 min. 0. 5 8 5.4 O N Stroke 0.6 3.8 5.6+0.3 0 5.4 O N 0. 5 0.1 0.4+–0.05 1.27±0.15 C Seal tape 0.3 4.1 0.1 0.15+–0.05 2.5 max. 0.1±0.1 0.3 2.5 max. 0.1±0.1 Production date code 0.1 0.15+–0.05 C Stroke 0.6 Production date code (In accordance with EIAJ ED-7402-1) 4.1 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic Seal tape 1.4±0.15 Schematic 0.4 min. 2.5 max. 0.1 0.15 +–0.05 – 2 C – C 0.1 0.15 +–0.05 5 0. 5 3.8 5.6 +0.3 0 5.4 O N Stroke 0.6 Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-04A OCHS-04B Washable type (With seal tape) Washable type (With seal tape) OCHS-04TA2 OCHS-04TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 0.1 0.4+–0.05 1.27±0.15 Seal tape 6.6 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic OCHS-06A 0.4 min. Seal tape 0.4 min. 8 5.4 0.1 0.15+–0.05 2.5 max. 0.1±0.1 0.3 6.6 O N C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N Production date code 0.1 0.15+–0.05 0.3 0.1±0.1 2.5 max. C Stroke 0.6 0. 5 Production date code 1.4±0.15 Schematic OCHS-06B Washable type (With seal tape) Washable type (With seal tape) OCHS-06TA2 OCHS-06TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) Production date code 0.1 0.4+–0.05 1.27±0.15 0.3 2.5 max. Schematic 9.2 0.1 0.4+–0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 0.1 0.15+–0.05 Seal tape 1.4±0.15 O N C Stroke 0.6 0. 5 3.8 5.6+0.3 0 5.4 O N 0.1 0.15+–0.05 0.1±0.1 0.3 0.1±0.1 2.5 max. C Stroke 0.6 0. 5 Production date code 9.2 0.4 min. (In accordance with EIAJ ED-7402-1) CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-08A OCHS-08B Washable type (With seal tape) Washable type (With seal tape) OCHS-08TA2 OCHS-08TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 8 5.4 O N Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N 0.1 0.4+–0.05 1.27±0.15 C Seal tape 2.5 max. 0.1±0.1 0.3 11.7 0.1 0.15+–0.05 1.4±0.15 11.7 0.1 0.4+–0.05 1.27±0.15 Seal tape 0.4 min. Stroke 0.6 5 0. 0.1 0.15+–0.05 C 2.5 max. 0.1±0.1 0.3 0.4 min. Production date code Production date code 1.4±0.15 Schematic Schematic OCHS-10A OCHS-10B  Washable type (With seal tape) Washable type (With seal tape) OCHS-10TA2 OCHS-10TB2 Non-washable type (With seal tape) Non-washable type (With seal tape) Production date code 0.1 0.15+–0.05 Seal tape 14.3 Seal tape 0.1 0.4+–0.05 1.27±0.15 0.1±0.1 0.1±0.1 2.5 max. 2.5 max. 14.3 0.1 0.15+–0.05 1.4±0.15 Schematic 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. 8 5.4 O N Stroke 0.6 3.8 5.6 +0.3 0 5.4 O N Stroke 0.6 Production date code 0.4 min. (In accordance with EIAJ ED-7402-1) CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) OCHS-08D 2.5 max. 0.4 min. 8 5.4 O N 0 0.8 –0.2 Stroke 0.6 Production date code 0.4 min. The D version with opposite pin direction is available upon receipt of your order. 11.7 0.1 0.15+–0.05 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS O1 bit (Unit : mm) A type B type 1 7.62 5.08 0 1.27 1.6 0 1 O2 bits 0.76 7.62 0 5.08 1.6 0 1.27 B type 1.27 1.27 A type 0.76 Note) The zero point is the center of mounting. CHS SLIDE SWITCHES (HALF PITCH) ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS O4 bits (Unit : mm) A type B type 1.27N (N=1~3) =3.81 5.08 0 1.27 1.6 0 7.62 1.27N (N=1~3) =3.81 0.76 0.76 O6 bits A type B type 1.27N (N=1~5) =6.35 5.08 0 1.27 1.6 0 7.62 1.27N (N=1~5) =6.35 0.76 0.76 O8 bits A type B type 1.27N (N=1~7) =8.89 7.62 1.27 1.6 0 5.08 1.27N (N=1~7) =8.89 0.76 0.76 O10 bits A type B type 1.27N (N=1~9) =11.43 0.76 7.62 0 1.27 1.6 0 5.08 1.27N (N=1~9) =11.43 0.76 Note) The zero point is the center of mounting. CHS SLIDE SWITCHES (HALF PITCH) ■ PACKAGING SPECIFICATIONS OTaping version is boxed with two reels. O Taping version (CHS-02 ~ 10 types) are packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. CHS-01 type is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 2000, 3000 pcs., etc. Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: OReel dimensions OEmbossed tape dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) Empty Filled φ 21±0.8 End φ 50 min. (1,2,4,6 bits) φ 100±1 (8,10 bits) Empty 17.4±1 (1,2,4,6 bits) 25.4±1 (8,10 bits) 2±0.5 Head 40 mm min. 20 pitches min. φ 13±0.2 400 mm min. Direction of feed 21.4±1 (1,2,4,6 bits) 29.4±1 (8,10 bits) φ 254±2 80.1 20.1 O N 7.5±0.1 40.1 (Conforms to JIS C 0806) Installation example (CHS-01A) 3 2±0.1 7.5±0.1 12±±0.1 40.1 O N Direction of feed 0.3±0.1 Installation example (CHS-02A) 16 O2 bits 1.75±0.1 Direction of feed φ 1.5 +0.1 0 (Unit : mm) 0.3±0.1 16 φ +0.1 1.5 0 1.75±0.1 O1 bit 3 CHS SLIDE SWITCHES (HALF PITCH) O4 bits 7.5±0.1 O N (Unit : mm) 0.3±0.1 Installation example (CHS-04A) 16 12±0.1 4±0.1 2±0.1 φ 1.5 +0.1 0 1.75±0.1 (Conforms to JIS C 0806) 3 Direction of feed 12±0.1 4±0.1 φ 1.5 +0.1 0 2±0.1 1.75±0.1 O6 bits 0.3±0.1 Installation example 7.5±0.1 O N 16 (CHS-06A) 3 Direction of feed 12±0.1 4±0.1 2±0.1 0.3±0.1 Installation example (CHS-08A) 11.5±0.1 24 φ 1.5 +0.1 0 1.75±0.1 O8 bits O N 3 Direction of feed φ 1.5 +0.1 0 0.3±0.1 (CHS-10A) Installation example (CHS-10A) 11.5±0.1 12±0.1 4±0.1 2±0.1 1.75±0.1 O10 bits 24 O N Direction of feed 3 CHS SLIDE SWITCHES (HALF PITCH) OPacking quantities of magazines are different depending on the bit number of the switches. Please order the multiple numbers of the specific packing quantities. (e.g. 70 pcs., 140 pcs., 210 pcs., etc., in case of 4 bits version) Pieces in package : 4 bits, 70pcs./stick 6 bits, 50pcs./stick 8 bits, 40pcs./stick 10 bits, 30pcs./stick OMagazine dimensions (Unit : mm) 10.4±0.3 3.9±0.3 ※ The magazine is common to A and B terminal pin. Installation example (B type) OThe smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. OBoxing of bulk in a plastic bag is performed with 50 pcs. (standard 200 pcs.) per box. Magazine length : 500 — 2 mm long
CHS-04A
1. 物料型号:CHS系列滑动开关,有不同的封装类型和引脚数量。
2. 器件简介:符合RoHS标准,遵循EIAJ SOP标准外形尺寸(B型),设计有低剖面2.5毫米,有12种不同的1、2、4、6、8或10位型号,有鸥翼形或J形钩可供选择。
3. 引脚分配:提供了详细的引脚分配图和说明,包括盖、滑块、外壳、滑动接触点、固定接触点和端子引脚。
4. 参数特性:包括操作温度范围、存储温度范围、密封性、净重、操作力、停止力、焊接性、剪切(粘附力)、基板弯曲和拉脱强度等。
5. 功能详解:描述了开关的内部结构、部件编号、封装类型和包装形式,如胶带包装、散装等。
6. 应用信息:虽然文档中没有直接提到应用信息,但从开关的特性可以推断,它们适用于需要小型化和可靠性的电子设备。
7. 封装信息:提供了详细的封装尺寸和公差,以及推荐的PCB焊盘尺寸。
CHS-04A 价格&库存
很抱歉,暂时无法提供与“CHS-04A”相匹配的价格&库存,您可以联系我们找货
