F0603HI2000V032T
F0603HI2000V032T
    AEM
    一次性保险丝(熔断) 2A 32V
F0603HI2000V032T 数据手册
Rev. Feb. 16 SolidMatrix® Surface Mount Fuses HI Series (High Inrush), 0603 Size Features:      Clearing Time Characteristics: % of Current Rating High inrush current withstanding capability Ceramic Monolithic structure Silver fusing element and silver termination with nickel and tin plating Symmetrical design with marking on both sides (optional) Operating temperature range: -55°C to +125°C (with derating) Shape and Dimensions: Clearing time at 25°C Unit Inch mm L 0.063 ± 0.006 1.60 ± 0.15 100% 4 hours min. W 0.031 ± 0.006 0.80 ± 0.15 200% 1 second min. 60 seconds max. T 0.031 ± 0.006 0.80 ± 0.15 1000% (1-5A) 0.0002 seconds min. 0.02 seconds max. B 0.014 ± 0.006 0.36 ± 0.15 Agency Approval: L W Recognized Under the Components Program of UL. File Number: E232989. T Patents: B Patent numbers “US6,034,589”, “US6,602,766”, “US7,268,661 B2”, “ZL00134544.3”, “ZL02114719.1”, “ZL200410104280.7”, “ZL201020551360.8”, “ZL201010299185.2”, “ZL201220030614.0”, “ZL201210020693.1”. Ordering Information: Nominal Cold DCR(Ω)1 Nominal I2t (A2s)2 Marking (Optional)3 32 0.210 0.08 E 1.5 32 0.101 0.11 G F0603HI2000V032T 2.0 32 0.057 0.24 I F0603HI2500V032T 2.5 32 0.042 0.56 J F0603HI3000V032T 3.0 32 0.030 0.72 K F0603HI3500V032T F0603HI4000V032T 3.5 4.0 32 32 0.022 0.018 1.10 2.08 L M F0603HI4500V032T 4.5 32 0.014 2.63 T F0603HI5000V032T 5.0 32 0.013 3.25 N F0603HI6000V032T 6.0 32 0.010 4.00 O F0603HI7000V032T 7.0 32 0.008 5.00 P F0603HI8000V032T 8.0 32 0.006 7.00 R Part Number Current Rating (A) Voltage Rating (VDC) F0603HI1000V032T 1.0 F0603HI1500V032T 1. Measured at ≤ 10% rated current and 25 oC ambient. Interrupting Ratings 50 A at rated voltage 80 A at rated voltage 2. Melting I2t at 1000% of current rating. 3. Green Marking Character Code. Website: www.aemchina.com & www.aemcomponents.com 22 Rev. Feb. 16 SolidMatrix® Surface Mount Fuses HI Series (High Inrush), 0603 Size 8.0 A 7.0 A 6.0 A 5.0 A 4.5 A 4.0 A 3.5 A 3.0 A 2.5 A 2.0 A 1.5 A 1.0 A Average Pre-arcing Time Curves: 100 Pre-arcing Time (s) 10 1 0.1 0.01 0.001 1 10 100 Current (A) 23 Website: www.aemchina.com & www.aemcomponents.com 1000 Rev. Feb. 16 SolidMatrix® Surface Mount Fuses HI Series (High Inrush), 0603 Size Average I2t vs. t Curves: 10000 8.0 A 7.0 A 6.0 A 5.0 A 1000 4.5 A 4.0 A 3.5 A 3.0 A 2.5 A I2t (A2s) 100 2.0 A 1.5 A 1.0 A 10 1 0.1 0.01 0.001 0.01 0.1 1 10 100 Time (s) Website: www.aemchina.com & www.aemcomponents.com 24
F0603HI2000V032T 价格&库存
很抱歉,暂时无法提供与“F0603HI2000V032T”相匹配的价格&库存,您可以联系我们找货
F0603HI2000V032T
    • 5+0.62187
    • 50+0.49745
    • 150+0.43524
    • 500+0.38859
    • 2500+0.35133
    库存:7329
