SS210BF
SS210BF
    JINGDAO(晶导微电子)
    SMBF
    SS210BF
SS210BF 数据手册
山东晶导微电子有限公司 SS22BF THRU SS220BF Jingdao Microelectronics Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200V Forward Current - 2.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Simplified outline SMBF and symbol MECHANICAL DATA • Case: SMBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 57 mg / 0.002oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS22BF SS24BF SS26BF SS28BF SS210BF SS212BF SS215BF SS220BF Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) 2.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 50 A Max Instantaneous Forward Voltage at 2 A VF Maximum DC Reverse Current T a = 25°C T a =100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance(1) Cj 220 110 pF Typical Thermal Resistance (2) RθJA 75 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C at Rated DC Reverse Voltage Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 0.85 0.95 V (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.01 SMBF-S-SS22BF~SS220BF-2A200V Page 1 of 3 山东晶导微电子有限公司 SS22BF THRU SS220BF Jingdao Microelectronics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =75°C 10 2 SS22BF/SS26BF T J =25°C 10 0 0 60 80 T J =25°C 10 1.0 SS22BF/SS24BF SS26BF/SS28BF SS210BF/SS212BF SS215BF/SS220BF 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 200 100 20 SS22BF~SS26BF SS28BF~SS220BF 10 1.8 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1000 Instaneous Forward Voltage (V) 60 10 Junction Capacitance ( pF) T J =25°C 20 100 Fig.4 Typical Junction Capacitance 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) SS28BF-SS220BF 10 1 Case Temperature (°C) 100 Number of Cycles at 60Hz 2017.01 T J =100°C 10 3 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 SS22BF THRU SS220BF Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMBF ∠ALL ROUND C A ∠ALL ROUND D E A V M g Top View mil Bottom View g A C D E HE e max 1.3 0.26 4.4 3.7 5.5 2.2 min 1.1 0.18 4.2 3.5 5.1 1.9 max 51 10 173 146 216 86 min 43 7 165 138 200 75 UNIT mm g pad e E A pad HE 1.0 9° 40 Marking The recommended mounting pad size Type number 3.0(118) 1.8(71) 2.54(100) 1.8(71) Unit:mm(mil) 2017.01 ∠ 701034A0 Marking code SS22BF S22B SS24BF S24B SS26BF S26B SS28BF S28B SS210BF S210B SS212BF S212B SS215BF S215B SS220BF S220B Page 3 of 3
SS210BF 价格&库存
很抱歉,暂时无法提供与“SS210BF”相匹配的价格&库存,您可以联系我们找货
