1.5KE130A
1.5KE130A
    CREATEKMICRO(达晶微)
    DO-201AD
1.5KE130A 数据手册
1.5KE Series CREATEK Microelectronics Power TVS in DO-201AD Features ■ 1500Watts peak pulse power (10/1000μs) ■ Class passivated junction ■ High accuracy, 5% tolerance ■ Uni and Bidirectional unit ■ Low clamping voltage ■ Low Leakage current ■ Very fast response time Applications Mechanical Data ■ ■ ■ Case: DO-201AD (plastic package). Lead free; RoHS compliant ■ Computers Molding Compound Flammability Rating: UL 94 V-0 ■ Industrial equipments Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals ■ Other VCC bus and I/O interfaces ■ Telecom systems ■ Consumer electronic applications Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Peak power dissipation with a 10/1000us waveform (1) (Fig. 1) Peak pulse current with a 10/1000us waveform (1) Steady state power dissipation at TL =75℃, lead lengths 0.375" (9.5mm)(2) Peak forward surge current 8.3ms single half sine-wave (3) Maximum instantaneous forward voltage @ 50A for (4) unidirectional only Typical thermal resistance junction-to-lead Typical thermal resistance junction-to-ambient Symbols Value Unit PPPM 1500 W IPPM See Next Table A PM(AV) 6.5 W IFSM 200 A VF 3.5/5.0 V RθJL 20 ℃/W RθJA 75 ℃/W Operating junction and storage temperature range -55 to +150 TJ ,TSTG Notes:1.Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig. 2 ℃ 2. Mounted on copper pad area of 1.6 x 1.6” (40 x 40mm) per Fig. 5 3.. Meas ed on 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum 4.. VF=3.5 V for devices of V(BR) < 220V, and VF=5.0 Volt max. for devices of V(BR)>220V Rev. 1.0, 23-May-2012 www.crea-tek.com 1 1.5KE Series CREATEK Microelectronics Electrical Characteristics (TA=25℃, Unless otherwise specified.) Device type UNI Breakdown voltage (1) V (BR) (Volts) Test current at IT (mA) Stand-off voltage VWM (Volts) Maximum reverse leakage at VWM (4) ID (μA) Maximum peak pulse current (2) IPPM (A) Maximum clamping voltage at IPPM VC (Volts) Maximum temperature coefficient of VBR (% /℃) 10.5 0.057 BI Min. Max. 1.5KE6.8A 1.5KE6.8CA 6.45 7.14 10 5.80 1000 143 1.5KE7.5A 1.5KE7.5CA 7.13 7.88 10 6.40 500 133 11.3 0.061 1.5KE8.2A 1.5KE8.2CA 7.79 8.61 10 7.02 200 124 12.1 0.065 1.5KE9.1A 1.5KE9.1CA 8.65 9.55 1.0 7.78 50 112 13.4 0.068 1.5KE10A 1.5KE10CA 9.50 10.5 1.0 8.55 10 103 14.5 0.073 1.5KE11A 1.5KE11CA 10.5 11.6 1.0 9.40 5.0 96.2 15.6 0.075 1.5KE12A 1.5KE12CA 11.4 12.6 1.0 10.2 5.0 89.8 16.7 0.078 1.5KE13A 1.5KE13CA 12.4 13.7 1.0 11.1 5.0 82.4 18.2 0.081 1.5KE15A 1.5KE15CA 14.3 15.8 1.0 12.8 1.0 70.8 21.2 0.084 1.5KE16A 1.5KE16CA 15.2 16.8 1.0 13.6 1.0 66.7 22.5 0.086 1.5KE18A 1.5KE18CA 17.1 18.9 1.0 15.3 1.0 59.5 25.2 0.088 1.5KE20A 1.5KE20CA 19.0 21.0 1.0 17.1 1.0 54.2 27.7 0.090 1.5KE22A 1.5KE22CA 20.9 23.1 1.0 18.8 1.0 49.0 30.6 0.092 1.5KE24A 1.5KE24CA 22.8 25.2 1.0 20.5 1.0 45.2 33.2 0.094 1.5KE27A 1.5KE27CA 25.7 28.4 1.0 23.1 1.0 40.0 37.5 0.096 1.5KE30A 1.5KE30CA 28.5 31.5 1.0 25.6 1.0 36.2 41.4 0.097 1.5KE33A 1.5KE33CA 31.4 34.7 1.0 28.2 1.0 32.8 45.7 0.098 1.5KE36A 1.5KE36CA 34.2 37.8 1.0 30.8 1.0 30.1 49.9 0.099 1.5KE39A 1.5KE39CA 37.1 41.0 1.0 33.3 1.0 27.8 53.9 0.100 1.5KE43A 1.5KE43CA 40.9 45.2 1.0 36.8 1.0 25.3 59.3 0.101 1.5KE47A 1.5KE47CA 44.7 49.4 1.0 40.2 1.0 23.1 64.8 0.101 1.5KE51A 1.5KE51CA 48.5 53.6 1.0 43.6 1.0 21.4 70.1 0.102 1.5KE56A 1.5KE56CA 53.2 58.8 1.0 47.8 1.0 19.5 77.0 0.103 1.5KE62A 1.5KE62CA 58.9 65.1 1.0 53.0 1.0 17.6 85.0 0.104 1.5KE68A 1.5KE68CA 64.6 71.4 1.0 58.1 1.0 16.3 92.0 0.104 1.5KE75A 1.5KE75CA 71.3 78.8 1.0 64.1 1.0 14.6 104 0.105 1.5KE82A 1.5KE82CA 77.9 86.1 1.0 70.1 1.0 13.3 113 0.105 1.5KE91A 1.5KE91CA 86.5 95.5 1.0 77.8 1.0 12.0 125 0.106 1.5KE100A 1.5KE100CA 95.0 105 1.0 85.5 1.0 10.9 137 0.106 1.5KE110A 1.5KE110CA 105 116 1.0 94.0 1.0 9.9 152 0.107 1.5KE120A 1.5KE120CA 114 126 1.0 102 1.0 9.1 165 0.107 1.5KE130A 1.5KE130CA 124 137 1.0 111 1.0 8.4 179 0.107 1.5KE150A 1.5KE150CA 143 158 1.0 128 1.0 7.2 207 0.106 1.5KE160A 1.5KE160CA 152 168 1.0 136 1.0 6.8 219 0.108 1.5KE170A 1.5KE170CA 162 179 1.0 145 1.0 6.4 234 0.108 1.5KE180A 1.5KE180CA 171 189 1.0 154 1.0 6.1 246 0.108 Rev. 1.0, 23-May-2012 www.crea-tek.com 2 1.5KE Series CREATEK Microelectronics Device type Breakdown voltage (1) V (BR) (Volts) Test current at IT (mA) Stand-off voltage VWM (Volts) Maximum reverse leakage at VWM (4) ID (μA) Maximum peak pulse current (2) IPPM (A) Maximum clamping voltage at IPPM VC (Volts) Maximum temperature coefficient of VBR (% /℃) UNI BI Min. Max. 1.5KE200A 1.5KE200CA 190 210 1.0 171 1.0 5.5 274 0.108 1.5KE220A 1.5KE220CA 209 231 1.0 185 1.0 4.6 328 0.108 1.5KE250A 1.5KE250CA 237 263 1.0 214 1.0 4.4 344 0.110 1.5KE300A 1.5KE300CA 285 315 1.0 256 1.0 3.6 414 0.110 1.5KE350A 1.5KE350CA 333 368 1.0 300 1.0 3.1 482 0.110 1.5KE400A 1.5KE400CA 380 420 1.0 342 1.0 2.7 548 0.110 1.5KE440A 1.5KE440CA 418 462 1.0 376 1.0 2.5 602 0.110 1.5KE480A 1.5KE480CA 456 504 1.0 408 1.0 2.3 658 0.110 1.5KE510A 1.5KE510CA 485 535 1.0 434 1.0 2.1 698 0.110 1.5KE530A 1.5KE530CA 503.5 556.5 1.0 450 1.0 2.1 725 0.110 1.5KE540A 1.5KE540CA 513 567 1.0 459 1.0 2.0 740 0.110 1.5KE550A 1.5KE550CA 522.5 577.5 1.0 467 1.0 2.0 760 0.110 Notes:1. V(BR) measured after IT applied for 300μs, IT=square wave pulse or equivalent 2. Surge current waveform per Fig. 3 and derate per Fig. 2 3. For bidirectional types with VR of 10 volts and less, the ID limit is doubled 4. All terms and symbols are consistent with ANSI/IEEE CA62.35 5. For parts without A, the VBR is±10% Typical Characteristics (Tamb = 25 °C unless otherwise specified) 100 10 1.0 0.1 0.1us Fig.2 Pulse Derating Curve Peak Pulse Power(PPP) or Current(IPPM) Derating in Percentage,% PPPM-Peak Pulse Power (kW) Fig.1 Peak Pulse Power Rating Curve 1.0us 10us 100us Td- Pulse Width (sec) Rev. 1.0, 23-May-2012 1.0ms 10ms 100 75 50 25 0 0 25 50 75 100 125 150 TA-Ambient Temperature(℃) 175 200 www.crea-tek.com 3 1.5KE Series CREATEK Microelectronics Fig.3 Pulse Waveform 150 Fig.4 Typical Junction Capacitance TJ=25℃ Pulse Width(td) Is defined as the point Where the peak current Peak Value Decays to 50% of IPPM IPPM 10000 Half Value IPPM(IPPM/2) 10/1000μs Waveform as defined by R.E.A 50 td 0 Capacitance (pF) 100 Unidirectional Bidirectional VR=0 1000 VR=Rated Stand-off Voltage 100 CJ. IPPM-Peak Pulse Current, % IRSM tr =10μs TJ=25℃ F=1.0MHz Vsig=50mVp-p 10 0 1.0 2.0 3.0 4.0 5 10 t-Time(ms) 200 8 60HZ Resistive or Inductive Load Peak Forward Surge Current (A) PM(AV) Steady State Power Dissipation(W)) 500 Fig.6 Max. Non-Repetitive Peak Forward Surge Currer Unidirectional Only Fig.5 Steady State Power Derating Curve 6 1.6×1.6×0.40” (40×40×1mm) Copper Heat Sinks 4 L = 0.375” (9.5mm) 2 Lead Lengths 100 TJ= TJmax 8.3ms Single Half Sine-Wave (JEDEC Method) 10 0 0 25 50 75 100 125 150 175 200 10 1 TL-Lead Temperature(℃) 100 1.5KE200 Waveform: 8×20 Impulse 1.5KE130 △VC=VC-VBR 20 Fig.8 Incremental Clamping Voltage Curve (Bidirectional) 1.5KE100 10 1.5KE75 1.5KE39 2.0 1.5KE33 1.5KE6.8 1.5KE9.1 1.5KE18 1.5KE12 1.0 0.2 1 2.0 10 20 IPP, Peak Pulse Current (A) Rev. 1.0, 23-May-2012 Waveform: 8×20 Impulse 20 1.5KE200C △VC=VC-VBR 10 1.5KE75C 1.5KE39C 2.0 1.5KE30C 1.5KE15C 1.5KE11C 1.5KE7.5C 1.0 0.2 0.1 0.1 0.5 △VC. Incremental Clamping Voltage 100 100 Number of Cycles at 60HZ Fig.7 Incremental Clamping Voltage Curve (Unidirectional) △VC. Incremental Clamping Voltage 100 VBR. Breakdown Voltage (V) 50 0.5 1 2.0 10 20 50 IPP, Peak Pulse Current (A) www.crea-tek.com 4 1.5KE Series CREATEK Microelectronics Fig.9 Instantaneous Forward Voltage Characteristics Curve Fig.10 Breakdown Voltage Temperature Coefficient Curve 1000 θV Temperature Coefficien (mV/℃) Forward Current 100 10 1 Pulse Width=300us 1% Duty Cycle TJ=25℃ 0.1 100 Unidirectional Bidirectional 10 1 0 0.4 0.8 1.2 1.6 2.0 Instantaneous Forward Current (A) 5 10 20 50 100 200 500 VBR, Breakdown Voltage (V) Fig.11 Typical Transient Thermal Impedance Thermal Impedance Transient Thermal Impedance (℃/W) 100 10 1 0.1 0.001 0.01 0.1 1 10 100 1000 tp-Pulse Duration (sec) Rev. 1.0, 23-May-2012 www.crea-tek.com 5 1.5KE Series CREATEK Microelectronics Package Dimensions D C A A B C D A B Dimensions Milimeters Min Max 25.4 9.5 7.2 1.2 1.3 5.3 4.8 Part number system 1.5KE XXX C A 5% Voltage tolerance (without A, 5% Voltage tolerance) Bi-direction (without C, Uni-direction) Voltage Product Series Ordering information Order code Package Packaging option Base quantity Packaging specification 1.5KExxA(CA) DO-201AD Tape and BOX 1000pcs EIA STD RS-481 Revision history Date Revision 23-May-2012 1.0 Rev. 1.0, 23-May-2012 Changes Initial release www.crea-tek.com 6 1.5KE Series CREATEK Microelectronics CAUTION / WARNING Information in this document is believed to be accurate and reliable. However, CREATEK does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Users should independently evaluate the suitability of and test each product selected for their own applications, and CREATEK assumes no liability whatsoever relating to the choice, selection or use of the CREATEK products and services described herein. CREATEK reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. Information in this document supersedes and replaces all information previously supplied. Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an CREATEK product can reasonably be expected to result in personal injury, death or severe property or environmental damage. CREATEK accepts no liability for inclusion and/or use of CREATEK products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Resale of CREATEK products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by CREATEK for the CREATEK product or service described herein and shall not create or extend in any manner whatsoever, any liability of CREATEK. CREATEK expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. CREATEK only obligations are those in the CREATEK Standard Terms and Conditions of Sale and in no case will CREATEK be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice t © Copyright 2009,CREATEK Microelectronics ® is a registered trademark of CREATEK Microelectronics All rights reserved Rev. 1.0, 23-May-2012 www.crea-tek.com 7
1.5KE130A 价格&库存
很抱歉,暂时无法提供与“1.5KE130A”相匹配的价格&库存,您可以联系我们找货
