PS20U100CT
PS20U100CT
    PINGWEI(平伟)
    PS20U100CT
PS20U100CT 数据手册
PS20U100CT&PS20U100FCT PS20U100CT&PS20U100FCT 20.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-220AB PS20U100CT ITO-220AB PS20U100FCT MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS20U100CT&PS20U100FCT Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 100 V 70 V 100 V Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TC =100°C Per Leg Total device Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Operation Junction Temperature and Storage Temperature A 20.0 IFSM 150.0 A CJ TJ, TSTG 300 pF -55 to +150 °C Per Leg Typical Junction Capacitance (Note 1) 10.0 IF(AV) ELECTRICAL CHARACTERISTICS- (Per Leg) (TC=25℃ unless otherwise noted) Parameter Maximum Forward Voltage Symbol at 5.0A DC VF at 10.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C IR @TA =100°C Typ Max 0.53 ---- 0.65 0.72 ---- 0.2 ---- 10.0 Units V mA THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol PS20U100CT PS20U100FCT Units Typical Thermal Resistance (Note 2) R(JC) 2.0 3.0 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS20U100CT&PS20U100FCT RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 20.0 10.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 10 1 .1 200 TJ=25 ℃ Pulse Width=300 μ s 1% Duty Cycle .4 .2 CASE TEMPERTURE,( ℃ ) 0.6 1.0 0.8 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 8.3ms Single Half Sine-Wave (JEDEC Method) 150 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 100 50 0 1.0 T J=25 ℃ 0.1 .01 1 10 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140 PS20U100CT&PS20U100FCT PACKAGE OUTLINE DIMENSIONS TO-220AB L I Dim A B C H C D G A E F G PIN 1 2 3 H I J D E K L J F P TO-220AB Min Max .573(14.55) .603(15.32) ―― .412(10.5) .103(2.62) .113(2.87) .140(3.56) .160(4.06) .510(13.0) .560(14.3) .027(0.68) .037(0.94) .148(3.74) .154(3.91) .230(5.84) .270(6.86) .175(4.44) .185(4.86) .100(2.54) .110(2.79) .014(0.35) .025(0.64) .045(1.14) .055(1.40) .095(2.41) .105(2.67) Dimensions in inches and (millimeters) ITO-220AB B L G I C H A PIN 1 2 D 3 E J F P K ITO-220AB Min Max A .571(14.5) .610(15.5) B .383(9.72) .406(10.3) C .110(2.80) .126(3.20) D .133(3.38) .162(4.10) E .512(13.0) .551(14.0) F .028(0.70) .035(0.90) G .114(2.90) .138(3.50) H .268(6.80) .291(7.40) I .162(4.10) .185(4.70) J .102(2.60) .110(2.80) K .018(0.45) .026(0.65) L .097(2.46) .113(2.86) P .890(2.25) .113(2.85) Dim Dimensions in inches and (millimeters) 3
PS20U100CT 价格&库存
很抱歉,暂时无法提供与“PS20U100CT”相匹配的价格&库存,您可以联系我们找货
