SS32-320 SERIES
SCHOTTKY
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
ROHS
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
MECHANICAL DATA
Case : JEDEC DO-214AB molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity : Color band denotes cathode end
Mounting Position: Any
Weight : 0.007 ounce, 0.25 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=110 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical thermal resistance (NOTE 1)
Operating junction and storage temperature range
Note:
SS38 SS310 SS315 SS320
SYMBOLS
SS32
SS34
SS36
VRRM
VRMS
VDC
40
21
40
60
28
80
56
100
70
150
105
200
150
60
80
100
150
200
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amp
IFSM
150.0
Amps
VF
IR
RθJA
TJ,TSTG
0.70
0.55
0.85
0.95
Volts
10.0
0.2
2.0
mA
0.5
20.0
C/W
C
55
-65 to +150
1.P.C.B. mounted with 8.0x8.0mm copper pad areas
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 2
SS32-320 SERIES
SCHOTTKY
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
3.0
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
SS32-SS36
SS38-SS320
0.6
100
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
ROHS
80
60
40
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
50
75
100
125
150
175
AMBIENT TEMPERATURE, C
10
100
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
50
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
TJ=25 C
10.0
1
SS32-SS34
SS35-SS36
SS38-SS315
SS320
0.1
0.01
10
TJ=100 C
1
0.1
TJ=25 C
0.01
0.001
0.4
0.6
0.8
1.0
1.2
1.4
1.6
30
60
90
120
150
PERCENT OF PEAK REVERSE VOLTAGE,%
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
JUNCTION CAPACITANCE, pF
1000
TRANSIENT THERMAL IMPEDANCE,
C/W
2000
TJ=25 C
100
SS32-SS34
SS35-SS320
10
1
0.1
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
Rev 8: Nov 2014
100
0.01
0.1
1
10
100
t,PULSE DURATION,sec.
www.born-tw.com
Page 2 of 2
很抱歉,暂时无法提供与“SS36SMC”相匹配的价格&库存,您可以联系我们找货
