2SA970
2SA970
    BLUEROCKET(蓝箭电子)
    TO92-3
    TO-92 塑封封装 PNP 半导体三极管。
2SA970 数据手册
2SA970 Rev.E Mar.-2016 描述 / DATA SHEET Descriptions TO-92 塑封封装 PNP 半导体三极管。Silicon PNP transistor in a TO-92 Plastic Package.  特征 / Features 低噪声,高直流电流增益,高击穿电压。 Low noise, high DC current gain, high breakdown voltage. 用途 / Applications 用于低噪声音频放大。 Low noise audio amplifier applications. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:Base PIN 2:Collector 放大及印章代码 / hFE Classifications & Marking hFE Classifications Symbol hFE Range http://www.fsbrec.com PIN 3:Emitter GR BL 200~400 350~700 1/6 2SA970 Rev.E Mar.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Collector to Base Voltage VCBO -120 V Collector to Emitter Voltage VCEO -120 V Emitter to Base Voltage VEBO -5.0 V Collector Current - Continuous IC -100 mA Emitter Current – Continuous IE 100 mA Collector Power Dissipation PC 300 mW Junction Temperature Tj 150 ℃ Tstg -55~150 ℃ Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Collector to Emitter Breakdown Voltage 符号 Symbol 测试条件 Test Conditions 最小值 典型值 最大值 Min Typ Max VCEO IC=-1.0mA IB=0 Collector Cut-Off Current ICBO VCB=-120V IE=0 -0.1 μA Emitter Cut-Off Current IEBO VEB=-5.0V IC=0 -0.1 μA DC Current Gain Collector to Emitter Saturation Voltage Base to Emitter Voltage hFE VCE=-6.0V IC=-2.0mA VCE(sat) IC=-10mA IB=-1.0mA VBE VCE=-6.0V IC=-2.0mA -0.65 V fT VCE=-6.0V IC=-1.0mA 100 MHz VCB=-10V f=1.0MHz VCE=-6.0V f=10Hz VCE=-6.0V f=1.0KHz VCE=-6.0V f=1.0KHz IE=0 4.0 pF Transition Frequency Collector Output Capacitance Noise Figure http://www.fsbrec.com Cob NF IC=-0.1mA Rg=10KΩ IC=-0.1mA Rg=10KΩ IC=-0.1mA Rg=100Ω -120 单位 Unit V 200 700 -0.3 V 6.0 2.0 dB 3.0 2/6 2SA970 Rev.E Mar.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 2SA970 Rev.E Mar.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 2SA970 Rev.E Mar.-2016 印章说明 / DATA SHEET Marking Instructions BR A970 GR **** 说明: BR:    为公司代码 A970:  为型号代码 GR:    为 hFE 分档代码 ****:  为生产批号代码,随生产批号变化。 Note: BR: Company Code. A970: Product Type Code. GR:   ****: http://www.fsbrec.com  hFE Classifications Symbol Lot No. Code,code change with Lot No. 5/6 2SA970 Rev.E Mar.-2016 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 散件包装 Units 包装数量 Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Dimension Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 包装尺寸 Inner Box 盒 (unit:mm3) Outer Box 箱 1,000 10 10,000 5 50,000 135×190 237×172×102 560×245×195 1,000 10 10,000 10 100,000 135×190 237×172×102 560×245×375 Units/tape 只/纸带 Tape/Inner Box 纸带/盒 Rows/Inner Box 纸带层/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Inner Box 盒 3,000 1 120 10 30,000 328×230×42 / AMMO Package Type 封装形式 使用说明 Time:10±1 sec / BULK TO-92 TO-92 Temp:270±5℃ / Packaging SPEC. Package Type 封装形式 编带包装 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 (unit:mm3) Outer Box 箱 小箱 480×346×235, 大箱 547×407×268 / Notices http://www.fsbrec.com 6/6
2SA970 价格&库存
很抱歉,暂时无法提供与“2SA970”相匹配的价格&库存,您可以联系我们找货
2SA970
  • 1+0.66550
  • 200+0.22110
  • 1500+0.13970
  • 3000+0.11000
库存:622
2SA970
  • 20+0.28134
  • 200+0.22950
  • 600+0.20358
库存:18
