BRIGHT LED ELECTRONICS CORP.
SINCE 1981
Specification for Approval
SAMPLES
ATTACHED AREA
DEVICE NUMBER: BL-HKC36P-TRB
CUSTOMER:
PAGE
DATE
2015/1/23
1
2
3
4
5
1.0 1.0 1.0 1.0 1.0
6
7
8
CONTENTS
1.0 1.0 1.0
Initial Released
FOR CUSTOMER’S APPROVAL STAMP OR SIGNATURE
APPROVED
PURCHASE
佰鴻工業股份有限公司
MANUFACTURE
QUALITY
ENGINEERING
ISSUED
APPROVED
PREPARED
張
占
任
2015.01.23
2015.01.23
2015.01.23
孝 嚴
旭
穎
新北市板橋區和平路 19 號 3 樓
3F., No.19, He Ping Road,
Ban Qiao Dist., New Taipei City,
Taiwan
Tel: +886-2-29591090
BL-HKC36P-TRB
SINCE 1981
● Features:
●Package Dimensions:
1. Emitted Color : Super Yellow
2. Lens Appearance : Water Clear
3. Mono-color type.
4. 1.6x0.8x0.6mm(0603) standard package
5. Suitable for all SMT assembly methods.
6. Compatible with infrared and vapor phase
reflow solder process.
7. Compatible with automatic placement
equipment.
8. This product doesn’t contain restriction
Substance, comply ROHS standard.
NOTES:
1.All dimensions are in millimeters (inches).
2.Tolerance is ± 0.10mm (0.004”) unless otherwise specified.
3.Specifications are subject to change without notice.
● Applications:
1.
Automotive: Dashboards, stop lamps,
turn signals.
2.
Backlighting: LCDs, Key pads advertising.
3.
Status indicators: Comsumer & industrial
electronics.
4. General use.
● Absolute Maximum Ratings(Ta=25℃)
Parameter
Symbol
Rating
Unit
Power Dissipation
Pd
52
mW
Forward Current
IF
mA
Peak Forward Current *1
IFP
100
mA
Reverse Volage
VR
5
V
Operating Temperature
Topr
-40℃~85℃
Storage Temperature
Tstg
-40℃~85℃
Soldering Temperature
Tsol
See Page6
* 1 Condition for IFp is pulse of 1/10 duty and 0.1msec width.
Ver.1.0 Page 1 of 8
BL-HKC36P-TRB
SINCE 1981
● Electrical and optical characteristics(Ta=25℃)
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
Vf
IF=20mA
2.2
2.6
V
Luminous Intensity
Iv
IF=20mA
63
120
mcd
Reverse Current
IR
VR=5V
100
µA
Peak Wave Length
λp
IF=20mA
590
nm
Dominant Wave Length
λd
IF=20mA
584
594
nm
Spectral Line Half-width
Δλ
IF=20mA
15
nm
Viewing Angle
2θ1/2
IF=20mA
120
deg
● Typical Electro-Optical Characteristics Curves
Fig.2 Forward current derating curve
Fig.1 Relative intensity vs. wavelength
vs. ambient temperature
1.0
30
Forward current(mA)
Relative radiant intensity
25
0.5
15
10
5
590
Wavelength (nm)
60
100
3.0
2.5
30
(Normalized @ 20mA)
Relative luminous intensity
40
2.0
1.5
1.0
0.5
2
3
4
5
Forward voltage(V)
-20
40
A mbient temperature Ta( C)
Fig.6 Radiation diagram
Fig.5 Relative luminous intensity vs. forward current
10
1.5
Relative luminous intensity (@20mA)
80
Fig.4 Relative luminous intensity vs.
ambient temperature
Fig.3 Forward current vs. forward voltage
50
Forward current (mA)
40
1.0
0.5
40
1.0
0.9
50
0.8
60
70
0.7
80
90
40
50
0.5
0.3
0.1
0.2
0.4
0.6
Ver.1.0 Page 2 of8
BL-HKC36P-TRB
SINCE 1981
● Tapping and packaging specifications(Units: mm)
Quantity:1000-4000PCS
CATHODE
8.0 ± 0.3
ANODE
USER DIRECTION OF FEED
● Package Method:(unit:mm)Vacuum
12 bag/box
4000 pcs/reel
200
Bar Code Label
245
220
220
Aluminum Foil Bag
185
645
6 box/carton
210
470
Ver.1.0 Page 3 of 8
BL-HKC36P-TRB
SINCE 1981
● Bin Limits
I n t e n s i t y B i n L i m i ts ( A t 2 0 m A )
BIN CODE
Min. (mcd)
Max. (mcd)
P
63
94
Q
94
140
R
140
210
S
210
317
To l e r a n c e f o r e a c h B i n l i m i t i s ± 1 5 % .
C o l o r B i n L i m i ts ( A t 2 0 m A )
BIN CODE
Min. (nm)
Max. (nm)
3
584
586
4
586
588
5
588
590
6
590
592
7
592
594
To l e r a n c e f o r e a c h B i n l i m i t i s ± 1 n m .
V F B i n L i m i ts ( A t 2 0 m A )
BIN CODE
Min.(v)
Max.(v)
B
1.8
2.0
C
2.0
2.2
D
2.2
2.4
E
2.4
2.6
To l e r a n c e f o r e a c h B i n l i m i t i s ± 0 . 0 5 V.
● B IN: x
x
x
VF BIN CODE
Color BIN CODE
Intensity BIN CODE
Ver.1.0 Page 4 of 8
BL-HKC36P-TRB
SINCE 1981
● Reliability Test
Classification
Endurance
Test
Test Item
Reference Standard
MIL-STD-750D:1026
Operation Life MIL-STD-883D:1005
JIS-C-7021
:B-1
High
Temperature MIL-STD-202F:103B
High Humidity JIS-C-7021
:B-11
Storage
High
MIL-STD-883:1008
Temperature
JIS-C-7021
:B-10
Storage
Low
Temperature JIS-C-7021
:B-11
Storage
Temperature
Cycling
MIL-STD-202F:107D
MIL-STD-750D:1051
MIL-STD-883D:1010
JIS-C-7021
:A-2
Test Conditions
Result
Ta: Under room temperature
Test time:1,000hrs
IF=Product Recommended IF
Ta:85±5℃
RH:90%-95%
Test time:240hrs
Ta:100±5℃
Test time:1,000hrs
0/32
0/32
Ta: -40±5℃
Test time=1,000hrs
0/32
Ta:-35±5 ℃ ~25±5 ℃ ~85±5 ℃ ~25±5
30min 5min
30min
5min
MIL-STD-202F:107D(1980) Ta:-40±5℃ ~+85±5℃
Thermal Shock MIL-STD-750D:1051(1995) 10min
10 min
Environmental
MIL-STD-883D:1011(1991) Time: 20min/cycle
10cycle
Test
MIL-STD-883:2003
Ta:230±5℃
Wetting
MIL-STD-202F:208D
Time:5±0.5s
balance
MIL-STD-883D:2003
Solder
Resistance
MIL-STD-202F:210A
MIL-STD-883D:1011
JIS-C-7021
:A-1
0/32
Ta:260±10℃
Time:10±1s
0/32
0/32
0/32
0/32
● Judgment criteria of failure for the reliability
Measuring items
Forward voltage
Reverse current
Luminous intensity
Note:
Symbol
VF ( V)
IR(uA)
Iv ( mcd )
Measuring conditions
IF=20mA
VR=5V
IF=20mA
Judgement criteria for failure
Initial Level*1.1
Over U*2
Initial Level*0.7
1.U means the upper limit of specified characteristics.
2. Measurment shall be taken between 2 hours and after the test pieces have been returned
to normal ambient conditions after completion of each test.
Ver.1.0 Page 5 of 8
BL-HKC36P-TRB
SINCE 1981
●IR-Reflow Soldering
RAMP-UP
3°c/s max
Max260°C Max 10sec.
255°C
245°C
TEMPERATURE(°c)
240°C
217°C
200°C
30 sec. Max
150°C
RAMP-UP
3°c/s max
RAMP-DOWN
6°c/s max
60-120sec.
60-120sec.
TIME(sec.)
1.
Avoid any external stress applied to the resin while the LEDs are at
high temperature, especially during soldering .
2.
Avoid rapid cooling or any excess vibration during temperature ramp-down process
3.
Although the soldering condition is recommended above,
soldering at the lowest possible temperature is feasible for the LEDs
Ver.1.0 Page 6of 8
BL-HKC36P-TRB
SINCE 1981
●Dip Soldering
TEMPERATURE( °C)
300
Max:260℃,5sec.
Suggest:2~3sec.
250
200
150
100
Fluxing
50
30
Preheat
10
40
50
60
70
80
90
100
110
120
TIME(sec.)
1. Please avoid any external stress applied to the lead-frames and
epoxy while the LEDs are at high temperature,especially during soldering
2. DIP soldering and hand soldering should not be done more than one time.
3. After soldering, avoid the epoxy lens from mechanical shock or
vibration until the LEDs are back to room temerature.
4. Avoid rapid cooling during temperature ramp-down process
5. Although the soldering condition is recommended above,
● IRON
Soldering
300℃ Within 3 sec.,One time only.
Ver.1.0 Page 7of 8
BL-HKC36P-TRB
SINCE 1981
● Notes for designing:
Care must be taken to provide the current limiting resistor in the circuit so as to drive the BRIGHT
LEDs within the rated figures. Also, caution should be taken not to overload BRIGHT LEDs with
instantaneous voltage at the turning ON and OFF of the circuit.
When using the pulse drive care must be taken to keep the average current within the rated figures.
Also, the circuit should be designed so as be subjected to reverse voltage when turning off the
BRIGHT LEDs.
● Storage:
In order to avoid the absorption of moisture, it is recommended to solder BRIGHT LEDs as soon as
possible after unpacking the sealed envelope.
If the envelope is still packed, to store it in the environment as following:
(1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max.
(2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or
equivalent soldering process must be:
a. Completed within 168 hours.
b. Stored at less than 30% RH.
(3) Devices require baking before mounting, if:
(2) a or (2) b is not met.
(4) If baking is required, devices must be baked under below conditions:
48 hours at 60℃±3℃.
● Package and Label of Products:
(1) Package: Products are packed in one bag of 4000 pcs (one taping reel) and a label is attached
on each bag.
(2) Label:
BRIGHT LED LOGO
B
Part No.
Quantity
BIN.
Sealing Date
x
xx
xx
Year Month
xx
Day
Manufacture Location
Ver.1.0 Page 8 of 8
很抱歉,暂时无法提供与“BL-HKC36P-TRB”相匹配的价格&库存,您可以联系我们找货
