SMBJ12CA
SMBJ12CA
    STARSEA(星海)
    SMB(DO-214AA)
SMBJ12CA 数据手册
SMBJ5.0 THRU SMBJ170CA SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Breskdown voltage: 5.0-170 Volts Peak pulse power: 600 Wallts FEATURE DO-214AA 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) Optimzed for LAN protection applications Ideal for ESD protection of data lines in accordance with IEC 1000-4-2(IEC801-2) Ideal for EFT protection of data lines in accordance with IEC1000-4-4(IEC801-2) Plastic package has Underwriters Laboratory Flammability Classification 94V-0 Glass passivated junction 600w peak pulse power capability Excellent clamping capability Low incremental xurge resistance Fast response time:typically less than 1.0ps from 0v to V(BR) min High temperature soldering guaranteed: 265 C/10S at terminals 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) MECHANICAL DATA 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) Case: JEDEC DO-214AA molded plastic body over passivated junction Terminals: Solder plated , solderable per MIL-STD 750, method 2026 Polarity: Color band denotes cathode except for bidirectional types Mounting Position: Any Weight: 0.003 ounce,0.093 grams DEVICES FOR BIDIRECTIONAL APPLICATIONS For bidirectional use suffix C or CA for types SMBJ5.0 thru SMBJ170 (e.g. SMBJ5.0C,SMBJ170CA) Electrical characteristics apply in both directions. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Peak pulse power dissipation with a 10/1000µs wavetorm(NOTE 1,2,FIG.1) Peak forward surge current (Note 1,2,3) Peak pulse current with a 10/1000µs waveform(NOTE 1) Steady state power dissapation (Note 3) Maximum instantaneous forward voltage at 50A(Note 3,4) unidirectional only Operating junction and storage temperature range SYMBOLS VALUE UNITS PPPM IFSM IPPM PM(AV) VF TSTG,TJ Minimum 600 100.0 See Table 1 5.0 3.5/5.0 -55 to + 150 Watts Amps Amps Watts Volts C Notes: 1.Non-repetitive current pulse,per Fig.3 and derated above TA=25 C per Fig.2 2.Mounted on 5.0mm2 copper pads to each terminal 3.Measured on 8.3ms single half sine-wine.For uni-directional devices only. 4.VF=3.5V on SMB-5.0 thru SMB-90 devices and VF=5.0V on SMB-100 thru SMB-170 devices DN:S06L02A0 STAR SEA ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device SMBJ5.0 SMBJ5.0A SMBJ6.0 SMBJ6.0A SMBJ6.5 SMBJ6.5A SMBJ7.0 SMBJ7.0A SMBJ7.5 SMBJ7.5A SMBJ8.0 SMBJ8.0A SMBJ8.5 SMBJ8.5A SMBJ9.0 SMBJ9.0A SMBJ10 SMBJ10A SMBJ11 SMBJ11A SMBJ12 SMBJ12A SMBJ13 SMBJ13A SMBJ14 SMBJ14A SMBJ15 SMBJ15A SMBJ16 SMBJ16A SMBJ17 SMBJ17A SMBJ18 SMBJ18A SMBJ20 SMBJ20A SMBJ22 SMBJ22A SMBJ24 SMBJ24A SMBJ26 SMBJ26A SMBJ28 SMBJ28A SMBJ30 SMBJ30A DN:S06L02A0 Working Peak Reverse Voltage VWM(Volts) 5.0 5.0 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 8.0 8.0 8.5 8.5 9.0 9.0 10.00 10.00 11.00 11.00 12.00 12.00 13.00 13.00 14.00 14.00 15.00 15.00 16.00 16.00 17.00 17.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 Breakdown Voltage V(BR)(NOTE1) (Volts) at IT MIN MAX 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.0 10.0 11.1 11.1 12.2 12.2 13.3 13.3 14.4 14.4 15.6 15.6 16.7 16.7 17.8 17.8 18.9 18.9 20.0 20.0 22.2 22.2 24.4 24.4 26.7 26.7 28.9 28.9 31.1 31.1 33.3 33.3 7.81 7.08 8.15 7.37 8.82 7.98 9.51 8.60 10.3 9.21 10.9 9.83 11.5 10.4 12.2 11.1 13.6 12.3 14.9 13.5 16.3 14.7 17.6 15.9 19.1 17.2 20.4 18.5 21.8 19.7 23.1 20.9 24.4 22.1 27.1 24.5 29.8 26.9 32.6 29.5 35.3 31.9 38.0 34.4 40.7 36.8 Test Current IT(mA) 10 10 10 10 10 10 10 10 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Maximum Maximum Maximum Reverse Clamping Peak Pulse Voltage at Reverse Current Leakage a VWM(NOTE5) IPPM Vc IPPM(NOTE 2) ID(µA) (Volts) (Amps) 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 62.5 65.2 52.6 58.3 48.8 53.6 45.1 50.0 42.0 46.5 40.0 44.1 37.7 41.7 35.5 39.0 31.9 35.3 29.9 33.0 27.3 30.2 25.2 27.9 23.3 25.9 22.3 24.6 20.8 23.1 19.7 21.7 18.6 20.5 16.8 18.5 15.2 16.9 14.0 15.4 12.9 14.3 12.0 13.2 11.2 12.4 800 800 800 800 500 500 200 200 100 100 50.0 50.0 10.0 10.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 STAR SEA ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device SMBJ33 SMBJ33A SMBJ36 SMBJ36A SMBJ40 SMBJ40A SMBJ43 SMBJ43A SMBJ45 SMBJ45A SMBJ48 SMBJ48A SMBJ51 SMBJ51A SMBJ54 SMBJ54A SMBJ58 SMBJ58A SMBJ60 SMBJ60A SMBJ64 SMBJ64A SMBJ70 SMBJ70A SMBJ75 SMBJ75A SMBJ78 SMBJ78A SMBJ85 SMBJ85A SMBJ90 SMBJ90A SMBJ100 SMBJ100A SMBJ110 SMBJ110A SMBJ120 SMBJ120A SMBJ130 SMBJ130A SMBJ150 SMBJ150A SMBJ160 SMBJ160A SMBJ170 SMBJ170A Working Peak Reverse Voltage VWM(Volts) 33.00 33.00 36.00 36.00 40.00 40.00 43.00 43.00 45.00 45.00 48.00 48.00 51.00 51.00 54.00 54.00 58.00 58.00 60.00 60.00 64.00 64.00 70.00 70.00 75.00 75.00 78.00 78.00 85.00 85.00 90.00 90.00 100.00 100.00 110.00 110.00 120.00 120.00 130.00 130.00 150.00 150.00 160.00 160.00 170.00 170.00 Breakdown Voltage V(BR)(NOTE 1) (Volts) at IT MIN MAX 36.7 36.7 40.0 40.0 44.4 44.4 47.8 47.8 50.0 50.0 53.3 53.3 56.7 56.7 60.0 60.0 64.4 64.4 66.7 66.7 71.1 71.1 77.8 77.8 83.3 83.3 86.7 86.7 94.4 94.4 100 100 111 111 122 122 133 133 144 144 167 167 178 178 189 189 44.9 40.6 48.9 44.2 54.3 49.1 58.4 52.8 61.1 55.3 65.1 58.9 69.3 62.7 73.3 66.3 78.7 71.2 81.5 73.7 86.4 78.6 95.1 86.0 102 92.1 106 95.8 115 104 122 111 136 123 149 135 163 147 176 159 204 185 218 197 231 209 Test Current IT(mA) 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Maximum Maximum Maximum Reverse Clamping Peak Pulse Voltage at Reverse Current Leakage a VWM(NOTE3) IPPM Vc IPPM(NOTE 2) ID(µA) (Volts) (Amps) 59.0 53.3 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103.0 93.6 107.0 96.8 114.0 103.0 125 113 134 121 139 126 151 137 160 146 179 162 196 177 214 193 231 209 268 243 287 259 304 275 10.2 11.3 9.3 10.3 8.4 9.3 7.8 8.6 7.5 8.3 7.0 7.8 6.6 7.3 6.2 6.9 5.8 6.4 5.6 6.2 5.3 5.8 4.8 5.3 4.5 5.0 4.3 4.8 4.0 4.4 3.8 4.1 3.4 3.7 3.1 3.4 2.8 3.1 2.6 2.9 2.2 2.5 2.1 2.3 2.0 2.2 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 NOTES: 1.V(BR)measured after IT applied for 300µs,IT=square wave pulse or equivalent 2.Surge current waveform per Fig.3 and derated per Fig.2 3.For bidirectional types having VWM of 10 volts and less,the ID limit is doubled 4.All items and symbols are consistent with ANSI/IEEE C62.35 DN:S06L02A0 STAR SEA FIG. 1-PEAK PULSE POWER RATING CURVE PppM,PEAK PULSE POWER,kw 100 NON-REPETITIVE PULSE WAVEFORM SHOWN in FIG.3 TA=25 C 10 1.0 0.2x0.2” (0.5x0.5mm) COPPER PAD AREAS 0.1 0.1µs 1.0µs 10µs 100µs 1.0ms 10ms td,PULSE WIDTH,sec. PEAK PULSE POWER(PppM)or CURRENT(IppM) DERATING IN PERCENTAGE,% RATINGS AND CHARACTERISTIC CURVES SMBJ5.0 THUR 170CA FIG. 2-PULSE DERATING CURVE 100 75 50 25 0.2x0.2” (0.5x0.5mm) COPPER PAD AREAS 0 0 25 50 75 100 125 150 175 TA, AMBIENT TEMPERATURE,( C) FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE UNIDIRECTIONAL FIG.3-PULSE WAVEFORM PULSE WIDTH (td) is DEFINED as the POINT WHERE the PEAK CURRENT DECAYS to 50% of IppM tr=10µsec 10,000 CJ,JINCTION CAPACITANCE,pF IppM,PEAK PULSE CURRENT,% 150 PEAK VALUE IppM 100 HALF VALUE IPPM 2 10/1000µsec WAVEFORM as DFINED by R.E.A 50 MEASURED at ZERO BIAS 1,000 MEASURED at STAND-OFF VOLTAGE,VwM 100 TJ=25 C f=1.0MHz Vsig=50mVp-p td 0 0 1.0 2.0 3.0 4.0 t,TIME,ms 10 1.0 10 100 200 V(BR),BREAKDOWN VOLTAGE,VOLTS PM(AV),STEADY STATE POWER DISSIPATION,WATTS 60Hz RESISTIVE OR INDUCTIVE LOAD 3.75 2.50 1.25 0.2x0.2” (0.5x0.5mm) COPPER PAD AREAS 0 0 25 50 75 100 125 TL,LEAD TEMPERATURE, C DN:S06L02A0 150 175 IFSM,PEAK FORWARD SURAGE CURRENT AMPERES FIG.5-STEADY STATE POWER DERATING CURVE 5.00 FIG.6-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT UNIDIRECTIONAL ONLY 100 80 80 40 TJ=TJmax. 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 20 0 1.0 10 100 NUMBER OF CYCLES AT 60Hz STAR SEA
SMBJ12CA 价格&库存
很抱歉,暂时无法提供与“SMBJ12CA”相匹配的价格&库存,您可以联系我们找货
