AR05DTBW2002
AR05DTBW2002
    VIKING(光颉)
    高精度、低温漂贴片电阻 0805
AR05DTBW2002 数据手册
【AR Series】 Thin Film Precision Chip Resistor Thin Film Precision Chip Resistor (AR Series) ■Features -Advanced thin film technology -Very tight tolerance down to ±0.01% -Extremely low TCR down to ±2PPM/°C -Wide resistance range 1ohm ~ 3Mega ohm -Miniature size 0201 available ■Applications -Medical Equipment -Testing / Measurement Equipment -Printer Equipment -Automatic Equipment Controller -Converters -Communication Device, Cell Phone, GPS, PDA ■Construction L D1 W 3 4 5 6 T 9 D2 871 1 Alumina Substrate 4 Edge Electrode (NiCr) Bottom Electrode (Ag) 2 5 Barrier Layer (Ni) 3 Top Electrode (Ag) 6 External Electrode (Sn) 2 7 Resistor Layer (NiCr) 8 Overcoat (Epoxy) 9 Marking ■Dimensions Unit: mm Type Size (Inch) L W T D1 D2 AR01 AR02 AR03 AR05 AR06 AR13 AR10 AR12 0201 0402 0603 0805 1206 1210 2010 2512 0.58±0.05 1.00±0.05 1.55±0.10 2.00±0.15 3.05±0.15 3.10±0.15 4.90±0.15 6.30±0.15 0.29±0.05 0.50±0.05 0.80±0.10 1.25±0.15 1.55±0.15 2.40±0.15 2.40±0.15 3.10±0.15 0.23±0.05 0.30±0.05 0.45±0.10 0.55±0.10 0.55±0.10 0.55±0.10 0.55±0.10 0.55±0.10 0.12±0.05 0.20±0.10 0.30±0.20 0.30±0.20 0.42±0.20 0.40±0.20 0.60±0.30 0.60±0.30 0.15±0.05 0.20±0.10 0.30±0.20 0.40±0.20 0.35±0.25 0.55±0.25 0.50±0.25 0.50±0.25 Weight (g) (1000pcs) 0.14 0.54 1.83 4.71 9.02 10 23.61 38.06 ■Part Numbering AR 03 T T B Y 1001 N Product Type Dimensions (L×W) Resistance Tolerance Packaging Code TCR (PPM/°C) Power Rating Resistance Marking Code 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 13: 1210 10: 2010 12: 2512 T: ±0.01% A: ±0.05% B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% www.viking.com.tw T: Taping Reel B: Bulk : Standard Y: 1/16W X: 1/10W W: 1/8W M: 1/6W P: 1/5W V: 1/4W O: 1/3W U: 1/2W Q: 3/4W T: 1W X: ±2 O:±3 S: ±5 B: ±10 N: ±15 C: ±25 D: ±50 For detail questions, contact : sales@viking.com.tw 1 0010: 1Ω 4R70: 4.7Ω 1001: 1KΩ 1004: 1MΩ : Standard Marking for E96 / E24 N: No Marking Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor ■Derating Curve Power ratio(%) 100 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Standard Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage AR01 (0201) 1/32W -55 ~ +155°C 15V 30V Resistance Range ±0.05% ±0.1% ±0.25% ±0.5% ±1% 49.9Ω - 4.99KΩ - 49.9Ω - 33KΩ AR02 (0402) 1/16W -55 ~ +155°C 25V 50V 49.9Ω - 12KΩ 10Ω - 255KΩ 4.7Ω – 511KΩ AR03 (0603) 1/16W -55 ~ +155°C 50V 100V 4.7Ω -332KΩ 4.7Ω - 1MΩ 1Ω - 1MΩ AR05 (0805) 1/10W -55 ~ +155°C 100V 200V 4.7Ω -1MΩ 4.7Ω - 2MΩ 1Ω - 2MΩ AR06 (1206) 1/8W AR13 (1210) 1/4W -55 ~ +155°C 150V 300V 4.7Ω - 1MΩ 4.7Ω - 2.49MΩ AR10 (2010) 1/4W AR12 (2512) 1/2W -55 ~ +155°C 150V 300V 4.7Ω - 1MΩ 4.7Ω - 3MΩ TCR (PPM/°C) ±25 ±50 ±25 ±50 ±25 ±50 ±25 ±50 1Ω - 2.49MΩ ±25 ±50 1Ω - 3MΩ ±25 ±50 Lower Resistance:1~10Ω ■Special Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage Resistance Range ±0.01% ±0.05% ±0.1% ±0.25% 49.9Ω - 4.99KΩ AR02 (0402) 1/16W -55 ~ +155°C 25V 50V 49.9Ω - 12KΩ - 49.9Ω - 4.99KΩ 49.9Ω - 60KΩ 49.9Ω -69.8KΩ 24.9Ω - 15KΩ AR03 (0603) 1/16W -55 ~ +155°C 50V 100V - 24.9Ω - 15KΩ 24.9Ω 100KΩ 4.7Ω332KΩ 4.7Ω - 511KΩ 24.9Ω - 30KΩ AR05 (0805) 1/10W -55 ~ +155°C 100V 200V - 24.9Ω - 30KΩ 24.9Ω 200KΩ 4.7Ω – 1MΩ 24.9Ω - 49.9KΩ AR06 (1206) 1/8W -55 ~ +155°C 150V 300V - 24.9Ω - 49.9KΩ 24.9Ω 499KΩ 4.7Ω - 1MΩ 24.9Ω - 49.9KΩ AR13 (1210) 1/ 4W -55 ~ +155°C 150V 300V - 24.9Ω - 49.9KΩ 24.9Ω 499KΩ 4.7Ω - 1MΩ 24.9Ω - 100KΩ AR10 (2010) 1/4W -55 ~ +155°C 150V 300V - 24.9Ω - 100KΩ 24.9Ω 499KΩ 4.7Ω - 1MΩ 24.9Ω - 100KΩ AR12 (2512) 1/2W -55 ~ +155°C 150V 300V - 24.9Ω - 100KΩ 24.9Ω 499KΩ www.viking.com.tw ±0.5% 4.7Ω - 1MΩ For detail questions, contact : sales@viking.com.tw 2 ±1% TCR (PPM/°C) ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 ±2 ±3 ±5 ±10 ±15 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor ■High Power Rating Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Max. Operating Overload Voltage Voltage Resistance Range ±0.01% ±0.05% ±0.1% ±0.25% ±0.5% 24.9Ω - 15KΩ - 24.9Ω - 15KΩ AR03 (0603) 1/10W -55 ~ +155°C 75V 150V 4.7Ω - 332KΩ 24.9Ω 100KΩ 1/6W -55 ~ +155°C 100V 150V 4.7Ω - 332KΩ 4.7Ω -1MΩ 10Ω - 332KΩ - 24.9Ω - 30KΩ - 24.9Ω - 30KΩ AR05 (0805) 1/8W -55 ~ +155°C 150V 300V 4.7Ω -511KΩ 24.9Ω 200KΩ 4.7Ω - 1MΩ 4.7Ω -511KΩ 4.7Ω 1MΩ 1/4W -55 ~ +155°C 150V 300V 1Ω - 1MΩ 10Ω - 499KΩ - 24.9Ω - 49.9KΩ - 24.9Ω - 49.9KΩ AR06 (1206) 1/4W 1/3W -55 ~ +155°C -55 ~ +155°C 200V 200V 400V 4.7Ω - 1MΩ - 10Ω ~1MΩ 24.9Ω – 49.9KΩ AR13 (1210) 1/ 3W -55 ~ +155°C 200V - 24.9Ω – 49.9KΩ 400V 24.9Ω 499KΩ 4.7Ω - 1MΩ 24.9Ω - 49.9KΩ AR10(2010) - 24.9Ω - 49.9KΩ 1/3W -55 ~ +155°C 200V 400V 24.9Ω 499KΩ 3/4W -55 ~ +155°C 200V 400V 1W -55 ~ +155°C 200V 400V 4.7Ω - 1MΩ 24.9Ω - 2KΩ 4.7Ω – 2KΩ 1Ω – 2KΩ AR12(2512) - 4.7Ω – 100Ω ±2 ±3 ±5 ±10 ±15 ±25 ±50 ±25 ±50 ±2 ±3 ±5 ±10 ±15 ±25 ±50 ±25 ±50 ±2 ±3 ±5 400V 24.9Ω 499KΩ ±1% TCR (PPM/°C) 1Ω – 100Ω ±10 ±15 ±25 ±50 ±25 ±50 ±2 ±3 ±5 ±10 ±15 ±25 ±50 ±2 ±3 ±5 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±25 ±50 Operating Voltage=√(P*R) or Max. operating voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. overload voltage listed above, whichever is lower. Viking is capable of manufacturing the optional spec based on customer’s requirement. (Lower Resistance:1~10Ω ; High Power Rating) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 3 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor ■Environmental Characteristics Requirement Item Tol. ≦ 0.05% MIL-STD-202 Method 304 +25/-55/+25/+125/+25°C Temperature Coefficient of Resistance As Spec. (T.C.R.) ΔR±0.05% Short Time Overload JIS-C-5201-1 5.5 RCWV*2.5 or Max. overload voltage whichever is lower for 5 seconds ΔR±0.2% ΔR±0.2% for high power rating Insulation Resistance MIL-STD-202 Method 302 Apply 100VDC for 1 minute >1000 MΩ ΔR±0.05% Endurance ΔR±0.2% MIL-STD-202 Method 108A 70±2°C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” >7kΩ ΔR±0.5% ΔR±0.5% for high power rating ΔR±0.05% Damp Heat with Load MIL-STD-202 Method 103B 40±2°C, 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” ΔR±0.3% ΔR±0.5% for high power rating Bending Strength ΔR±0.05% Solderability 95% min. coverage Resistance to Soldering Heat ΔR±0.05% Dielectric Withstand Voltage By Type Thermal Shock ΔR±0.05% ΔR±0.25% ΔR±0.05% ΔR±0.2% Low Temperature Operation Test Method Tol. > 0.05% JIS-C-5201-1 6.1.4 Bending amplitude 3 mm for 10 seconds ΔR±0.2% MIL-STD-202 Method 208H 245±5°C for 3 seconds MIL-STD-202 Method 210E 260±5°C for 10 seconds ΔR±0.2% MIL-STD-202 Method 301 Max. overload voltage for 1 minute MIL-STD-202 Method 107G -55°C ~150°C, 100 cycles JIS-C-5201-1 7.1 1 hour, -65°C, followed by 45 minutes of RCWV ΔR±0.5% for high power rating RCWV(Rated continuous working voltage)= √(P*R) or Max. Operating voltage whichever is lower Storage Temperature: 25±3°C; Humidity < 80%RH ■Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260°C:10s (2) Time of wave soldering at maximum temperature point 260°C:10s (3) Time of soldering iron at maximum temperature point 410°C:5s www.viking.com.tw For detail questions, contact : sales@viking.com.tw 4 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor ▓Marking 0603 3digit marking 3digit marking for Example: 14C=13K7Ω 14C 68B=4K99Ω 13C=13K3Ω 68X=49.9Ω Marking Table Code E96 Code E96 Code E96 Code E96 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 Code A Multiplier 10 B 0 10 C 1 10 0603 3digit marking for E24 E24 10 11 12 0805~2512 4digit marking www.viking.com.tw 13 D 2 10 E 3 10 F 4 10 G 5 10 H 6 10 X 7 10 Y -1 10 Z -2 10 -3 Example: 101=100Ω 102=1KΩ 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 Example Resistance 100Ω 2.2KΩ 10KΩ 49.9KΩ 100KΩ marking 1000 2201 1002 4992 1003 For detail questions, contact : sales@viking.com.tw 5 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor ■Packaging Unit :mm Packing Quantity & Reel Specifications Type ØA ØB ØC W T Paper Tape (EA) Emboss Plastic Tape (EA) AR01 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 10,000 - AR02 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 10,000 - AR03 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - AR05 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - AR06 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - AR13 178.0±1.0 60.0±1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - AR10 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 AR12 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 Paper Tape Specifications Top Tape Bottom Tape ψ D0 E A F B T P1 Resistor Paper Tape P0 P2 W direction of unreeling Unit: mm Type A B W E F P0 P1 P2 ΦD0 T AR01 0.40±0.05 0.70±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.55±0.03 0.42±0.02 AR02 0.70±0.05 1.16±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.55±0.05 0.40±0.03 AR03 1.10±0.05 1.90±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.60±0.03 AR05 1.60±0.05 2.37±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.75±0.05 AR06 2.00±0.05 3.55±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.75±0.05 AR13 2.75±0.05 3.40±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.60±0.10 0.75±0.05 Peel force of top cover tape The peel speed shall be about 300mm/min±5% The peel force of top cover tape shall be between 8gf to 60gf www.viking.com.tw For detail questions, contact : sales@viking.com.tw 6 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor Emboss Plastic Tape Specifications Top Tape ψ D0 E A F B W ψ D1 1.4Min. T P1 Resistor P2 P0 direction of unreeling Emboss Tape Unit: mm Type A B W E F P0 P1 P2 ØD0 T AR10 2.85±0.10 5.45±0.10 12.0±0.10 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 AR12 3.40±0.10 6.65±0.10 12.0±0.10 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 Peel force of top cover tape The peel speed shall be about 300mm/min±5% The peel force of top cover tape shall be between 20gf to 80gf ■Recommend Land Pattern Unit: mm C B www.viking.com.tw A Type A B C AR01 0.25 0.30 0.40±0.2 AR02 0.50 0.50 0.60±0.2 AR03 0.80 1.00 0.90±0.2 AR05 1.00 1.00 1.35±0.2 AR06 2.00 1.15 1.70±0.2 AR13 2.00 1.15 2.50±0.2 AR10 3.60 1.40 2.50±0.2 AR12 4.90 1.60 3.10±0.2 For detail questions, contact : sales@viking.com.tw 7 Edition : REV.D7 Revision:28-Apr-2015 【AR Series】 Thin Film Precision Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version D3 Jan. 14, 2013 - DESCRIPTION - Add resistance range for Special Electrical and High Power Rating Electrical Specifications. - Adjust the mockup. Version D4 Apr. 10, 2013 - - Add "RCWV" description in Environment Characteristic Test Method. Version D5 Oct. 16, 2013 - - Increase the resistance range of AR05, TCR15 product. Version D6 Oct. 17, 2014 - - Correct the specification of top cover tape peel force. - Update the resistance range of AR05 (Standard) to 4.7Ω -1MΩ Version D7 Apr. 28, 2015 - - Add TCR ±2ppm and ±3ppm products specification. - Increase the resistance range of the products below: • AR02 and AR03 of Standard Electrical Specifications. • AR02, AR03 and AR05 of Special Electrical Specifications. - Correct the element of Top Electrode. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 8 Edition : REV.D7 Revision:28-Apr-2015
AR05DTBW2002 价格&库存
很抱歉,暂时无法提供与“AR05DTBW2002”相匹配的价格&库存,您可以联系我们找货
AR05DTBW2002
  • 5000+0.23000
库存:55000
