SMBJ14A
SMBJ14A
    SEMIWARE(赛米微尔)
    SMB
SMBJ14A 数据手册
SMBJ5.0~440(C)A Transient Voltage Suppressors DESCRIPTION The SMBJ series is designed specifically to protect sensi ve electronic equipment from voltage transients induced by lightning and other transient voltage events. FEATURES > Low profile package > Ideal for automated placement > Available in uni-direc onal and Bi-direc onal > 600W peak pulse power capability with a 10/1000 μs waveform > For surface mounted applica ons to op mize board space > Excellent clamping capability > Very fast response me > Low incremental surge resistance DO-214AA(SMB) PACKAGE Bi-direc onal APPLICATIONS Anode Cathode Uni-direc onal TVS devices are ideal for the protec on of I/O Interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applica ons. MAXIMUM RATINGS AND CHARACTERISTICS Ra SCHEMATIC SYMBOL ngs at 25 oC ambient temperature unless otherwise specified. SY M B O L VA L U E UNITS Peak Pulse Power Dissipa on on 10/1000us waveform (Note1,Note2). PPPM 600 Wa s Peak Pulse Current of on 10/1000us waveform(Note1). IPPM See Table Amps P M (AV) 5.0 Wa s Maximum Instantaneous Forward Voltage at 50A for Unidirec onal Only (Note 4) VF 3.5/5.0 Volts Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (J E D E C Method) (Note 3). I FS M 100 Amps R AT I N G Steady State Power Dissipa on at T A =50℃ (Note2). NOTES: 1. Non-repe ve current pulse, T A = 25℃. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle=4 pulses per minutes maximum. 4. V F
SMBJ14A 价格&库存
很抱歉,暂时无法提供与“SMBJ14A”相匹配的价格&库存,您可以联系我们找货
SMBJ14A
库存:2765
