NJM4580CG(TE2)
NJM4580CG(TE2)
    JRC(⽇本无线)
    SOP-8
    NJM4580C 是一款双运算放大器,专为改善音调控制而设计,适用于音频应用。它具有无噪声、高增益带宽、高输出电流和低失真率的特点,不仅非常适合用于音频前置放大器和有源滤波器的声学电子部件,还适用于工...
NJM4580CG(TE2) 数据手册
NJM4580C DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION NJM4580C is the dual operational amplifier, specially designed for improving the tone control, which is suitable for the audio application. Featuring noiseless, higher gain bandwidth, high output current and low distortion ratio, and it is most suitable not only for acoustic electronic parts of audio pre-amp and active filter, but also for the industrial measurement tools. It is also suitable for the head phone amp at higher output current, and further more, it can be applied for the handy type set operational amplifier of general purpose in application of low voltage single supply type which is properly biased of the low voltage source. ■ PACKAGE OUTLINE ■ FEATURES ● Operating Voltage ±2V to ±18V ● Low Input Noise Voltage 5nV/√ Hz typ. at f=1kHz ● Gain Bandwidth Product 15MHz typ. ● Low Distortion 0.0005 typ. ● Slew Rate 5V/μs typ. ● Bipolar Technology ● Package Outline SOP8, SSOP8 ● Internal ESD protection Human body model (HBM) ±2000V typ. ■ PIN CONFIGURATION NJM4580CV (SSOP8) NJM4580CG (SOP8) (Top View) 1 2 3 8 7 A B 4 6 5 PIN FUNCTION 1.A OUTPUT 2.A -INPUT 3.A +INPUT 4.V 5.B +INPUT 6.B -INPUT 7.B OUTPUT + 8.V NJM4580CG NJM4580CV ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) + V -INPUT +INPUT OUTPUT - V ver. 04 -1- NJM4580C ■ABSOLUTE MAXIMUM RATINGS (Ta=25ºC, unless otherwise noted.) PARAMETER RATING UNIT V /V ±18 V Differential Input Voltage (Note1) (Note2) VID ±36 V Input Voltage (Note2) VIC ±18 V Power Dissipation PD SOP : 550 (Note3) SSOP : 350 (Note3) Supply Voltage SYMBOL + - 820(Note4) 440(Note4) mW Operating Temperature Range Topr - 40~+85 ºC Storage Temperature Range Tstg - 65~+125 ºC (Note1) Differential voltage is the voltage difference between +INPUT and -INPUT. (Note2) For supply voltage less than ±15V, the absolute maximum rating is equal to the supply voltage. The normal operation will establish when any input is within the Common Mode Input Voltage Range of electrical characteristics. ( Note3) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting ( Note4) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting ■ RECOMMENDED OPERATING CONDITIONS (Ta=25ºC) PARAMETER Supply Voltage SYMBOL + CONDITION MIN. TYP. MAX. UNIT ±2 - ±18 V MIN. TYP. MAX. UNIT - 0.3 3 mV - V /V - ■ ELECTRICAL CHARACTERISTICS (V+/V =±15V, Ta=25ºC, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITION Input Offset Voltage VIO RS≤10kΩ Input Offset Current IIO - 5 200 nA Input Bias Current IB - 100 500 nA Input Resistance RIN - 0.5 - MΩ Large Signal Voltage Gain AV RL≥2kΩ, VO=±10V 90 110 - dB Maximum Output Voltage VOM RL≥2kΩ ±12 ±13.5 - V Common Mode Input Voltage Range VICM ±12 ±13.5 - V Common Mode Rejection Ratio CMR RS≤10kΩ 80 110 - dB Supply Voltage Rejection Ratio SVR RS≤10kΩ 80 110 - dB - 6 9 mA Supply Current ICC Slew Rate SR RL≥2kΩ - 5 - V/μs Gain Bandwidth Product GBP f=10kHz - 15 - MHz Total Harmonic Distortion THD AV=20dB, VO=5V, RL=2kΩ,f=1kHz - 0.0005 - % Equivalent Input Noise Voltage1 VNI RIAA, RS=2.2kΩ, 30kHz LPF - 0.8 - μVrms Equivalent Input Noise Voltage2 en f=1kHz - 5 - nV/√ Hz -2- ver. 04 NJM4580C ■ TYPICAL CHARACTERISTICS Gain/Phase vs. Frequency Gain/Phase vs. Frequency - + 50 50 Gain 40 40 0 Ta=25ºC Ta=85ºC 10 0 -30 -60 Ta=-40ºC -10 -90 Ta=25ºC -20 Voltage Gain [dB] 20 -120 Ta=85ºC -30 -40 10k 100k 1M Frequency [Hz] 10M 20 -180 100M 0 -10 -40 10k 0 Ta=85ºC -5 Ta=25ºC -150 100k 1M 10M Frequency [Hz] -180 100M Maximum Output Voltage vs. Load Resistance Maximum Output Voltage [V] Ta=85ºC CL=10pF CL=680pF - V /V =±15V, Gv=open Ta=-40ºC 5 -90 -120 CL=330pF + Ta=25ºC -60 CL=100pF 15 +VOM Maximum Output Voltage [V] CL=100pF - 10 -10 -30 CL=680pF -30 V /V =±15V 15 0 CL=330pF 10 Maximum Output Voltage vs. Output Current + Phase -20 -150 1k Gain 30 Ta=-40ºC Phase Phase [deg] Voltage Gain [dB] 30 - V /V =±15V, Gv=40dB, RL=2kΩ, Ta=25ºC Phase [deg] + V /V =±15V, Gv=40dB, RL=2kΩ, CL=10pF -VOM +VOM 10 Ta=85ºC 5 Ta=25ºC Ta=-40ºC 0 Ta=-40ºC -5 Ta=25ºC Ta=85ºC -10 -VOM -VOM Ta=-40ºC -15 -15 1 10 Output Current [mA] 100 100 THD+N vs. Output Voltage + + 1 0.01 THD+N [%] THD+N [%] 100k THD+N vs. Output Voltage - V /V =±15V, GV=20dB, RL=2kΩ, Ta=25ºC 0.1 1k 10k Load Resistance[Ω] f=20kHz 0.1 - V /V =±2V, GV=20dB, RL=2kΩ, Ta=25°C f=20Hz f=1kHz f=20kHz 0.001 f=1kHz f=20Hz 0.0001 0.1 ver. 04 1 Output Voltage [Vrms] 10 0.01 0.01 0.1 Output Voltage [Vrms] 1 -3- NJM4580C ■ TYPICAL CHARACTERISTICS Maximum Output Voltage Swing vs. Frequency + + 25 20 15 10 5 0 - V /V =±15V, GV=40dB, RF=2kΩ 30 Equivalent Input Noise Voltage [nV/Hz] 30 Maximum Output Voltage Swing VOPP [Vpp] Voltage Noise vs. Frequency - V /V =±15V, RL=2kΩ, Ta=25ºC 25 20 15 10 5 0 1k 10k 100k Frequency[Hz] 1M 10M 1 Supply Current vs. Supply Voltage 10 100 1k Frequency [Hz] RL=open 8 8 Ta=25ºC 6 7 Ta=-40ºC Supply Current [mA] Supply Current [mA] 7 5 4 3 Ta=85ºC 2 1 + - V /V =±18V 6 + - V /V =±15V 5 4 + - V /V =±2V 3 2 1 0 0 0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 + Supply Voltage V /V [V] -50 Input Offset Voltage vs. Temperature + 2 - V /V =±2V + - V /V =±15V 1 0 + - V /V =±18V -1 -2 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Offset Voltage vs. Supply Voltage 3 Input Offset Voltage [mV] 3 Input Offset Voltage [mV] 100k Supply Current vs. Temperature RL=open 2 Ta=25ºC Ta=-40ºC 1 0 Ta=85ºC -1 -2 -50 -4- 10k -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] 0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 + Supply Voltage V /V [V] ver. 04 NJM4580C ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage + + V /V =±15V 2 Ta=-40ºC Ta=85ºC 1 0 Ta=25ºC -1 -2 -15 -10 -5 0 5 10 Common-Mode Input Voltage [V] 2 Ta=25ºC 0 -1 + + - + - V /V =±2V 200 150 100 + - V /V =±18V 50 Large Signal Voltage Gain [dB] Input Bias Current [nA] 300 0 115 110 105 100 95 90 85 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 CMR vs. Temperature + + 110 105 100 95 90 85 80 - V /V =±9V±18V 120 Supply Voltage Rejection Ratio [dB] 115 0 25 50 75 100 125 150 Ambient Temperature [ºC] SVR vs. Temperature - V /V =±15V, VCM=-12.2V~12.2V 120 Common-Mode Rejection Ratio [dB] - V /V =±15V, RL=2kΩ to GND 80 -50 115 110 105 100 95 90 85 80 -50 ver. 04 2.0 Large Signal Voltage Gainvs. Temperature 120 350 V /V =±15V Ta=-40ºC -2 -2.0 -1.5 -1.0 -0.5 0 0.5 1.0 1.5 Common-Mode Input Voltage [V] 15 VICM=0V 250 Ta=85ºC 1 Input Bias Current vs. Temperature 400 V /V=-±2V 3 Input Offset Voltage [mV] 3 Input Offset Voltage [mV] Input Offset Voltage vs. Common-Mode Input Voltage - -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -5- NJM4580C ■ TYPICAL CHARACTERISTICS Maximum Output Voltage vs. Temperature 15 12 + +VOM - V /V =±18V + - V /V =±15V 9 6 + - V /V =±2V 3 0 -3 + - V /V =±2V -6 -9 + + - V /V =±15V - V /V =±18V -VOM -12 RL=2kΩ to GND 18 Maximum Output Voltage [V] 18 Maximum Output Voltage [V] Maximum Output Voltage vs. Supply Voltage Gv=open, RL=2kΩ, RL to GND 12 6 Ta=25ºC Ta=-40ºC 0 Ta=85ºC -6 -12 -15 -18 -18 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 + Supply Voltage V /V [V] Pulse Response + - Voltage [0.5V/div] V /V =±15V, RL=2kΩ, Ta=25ºC Vin CL=10pF CL=330pF CL=680pF Time [1μs/div] -6- ver. 04 NJM4580C ■PACKAGE OUTLINE UNIT : mm SOP8 6.0±0.2 3.9±0.1 4.9±0.1 0.175±0.075 0.1 S 0.42±0.07 0.25 M 0.22±0.03 1.55±0.2 1.27 0.825±0.425 0°~ 7° S SSOP8 +0.3 3.50 - 0.1 0 ~ 10º 0.5±0.2 4.4±0.2 6.4±0.3 5 8 1 4 0.65 +0.1 0.15 - 0.05 0.1±0.1 1.15±0.1 0.9MAX 0.1 0.22±0.1 ver. 04 0.1 M [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -7-
