WRL-15484
WRL-15484
    SPARKFUNELECTRONICS
    Module
WRL-15484 数据手册
Name: SparkFun Artemis Module - Low Power Machine Learning BLE Cortex-M4F Single Line Description: The Artemis Module from SparkFun is the first FCC certified, open-source, Cortex-M4F with BLE 5.0 running up to 96MHz and with as low power as 6uA per MHz. SKU: WRL-15484 Description: The Artemis Module from SparkFun is a Cortex-M4F with BLE 5.0 running up to 96MHz and with as low power as 6uA per MHz (less than 5mW). This is the world's first module to bridge the market between hobbyists and consumer products. We've packaged all the power of a modern microcontroller into a module that is both extremely easy to use but is mass-market ready. The flexibility of the Artemis module starts with our [Arduino core] (https://github.com/sparkfun/Arduino_Apollo3). You can program and use the Artemis module just like you would an Uno or any other Arduino. Time to first blink is just 5 minutes away! We built the core from the ground up, making it fast and as lightweight as possible. Next is the module itself. Measuring 10x15mm the Artemis module has all the support circuitry you need to use the fantastic Apollo3 processor in your next project. We're proud to say the SparkFun Artemis module is the first open-source hardware module with the design files freely and easily available. We've carefully designed the module so that implementing Artemis into your design can be done with low-cost 2-layer PCBs and 8mil trace/space. Made in the USA at SparkFun's Boulder production line, the Artemis module is designed for consumergrade products. This truly differentiates the Artemis from its Arduino brethren. Ready to scale your product? The Artemis will grow with you beyond the Uno footprint and Arduino IDE. Additionally, the Artemis has an advanced HAL (hardware abstraction layer) allowing users to push the modern CortexM4F architecture to its limit. The SparkFun Artemis Module is fully F CC/IC/CE certified and is available in full tape and reel quantities. With 1M flash and 384k RAM, you'll have plenty of room for your code. The Artemis module runs at 48MHz with a 96MHz turbo mode available and with Bluetooth to boot! Features: ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 1M Flash / 384k RAM 48MHz / 96MHz turbo available 6uA/MHz (operates less than 5mW at full operation) 48 GPIO - all interrupt capable 31 PWM channels Built-in BLE radio and antenna 10 ADC channels with 14-bit precision with up to 2.67 million samples per second effective continuous, multi-slot sampling rate 2 channel differential ADC 2 UARTs 6 I2C Buses 6 SPI Buses 2/4/8-bit SPI bus PDM Interface I2S Interface Secure 'Smart Card' interface FCC/IC/CE Certified Dimensions: 10mm x 15mm Documents: ● Schematic ● Eagle Files ● Designing with the SparkFun Artemis ● Artemis Development with Arduino ● Arduino Core ● Artemis Info Page ● GitHub Hardware Repo
WRL-15484 价格&库存
很抱歉,暂时无法提供与“WRL-15484”相匹配的价格&库存,您可以联系我们找货
