THGBMJG7C1LBAIL
THGBMJG7C1LBAIL
    KIOXIA(铠侠)
    FBGA-153
    E-MMC模块 停产
THGBMJG7C1LBAIL 数据手册
THGBMJG7C1LBAIL TOSHIBA Memory e-MMC Module 16GB THGBMJG7C1LBAIL y INTRODUCTION FEATURES THGBMJG7C1LBAIL Interface ina r THGBMJG7C1LBAIL is 16GB density of e-MMC Module product housed in 153 ball BGA package. This unit is utilized advanced TOSHIBA NAND flash device(s) and controller chip assembled as Multi Chip Module. THGBMJG7C1LBAIL has an industry standard MMC protocol for easy use. THGBMJG7C1LBAIL has the JEDEC/MMCA Version 5.1 interface with 1-I/O, 4-I/O and 8-I/O mode. Pin Connection P-WFBGA153-1113-0.50 (11.5mm x 13mm, H0.8mm max. package) 14 NC NC NC NC NC 13 NC NC NC NC NC 12 NC NC NC NC NC 11 NC NC NC 10 NC NC NC VSF VSF RFU VSS 9 NC NC NC VSF 8 NC NC NC RFU 6 5 4 3 2 NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC VCC RFU NC NC RFU VCC NC NC NC VSS NC NC NC Top View RFU NC NC VSS RFU NC NC RFU VSS DAT7 VCCQ VCC RFU CLK NC VSSQ DAT2 DAT6 NC DAT1 DAT5 VSSQ NC index DAT0 DAT4 NC NC NC NC RFU NC NC NC NC NC NC DAT3 VDDi NC NC NC NC NC NC NC NC NC VSSQ NC NC NC NC NC NC NC NC NC NC NC NC NC NC NC A B C D E F G H J K L M N P RFU VCC VSS DS VSS CMD VSSQ VCCQ RST_n VCCQ VCCQ VSSQ NC VCCQ Pin Number Name Pin Number Name Pin Number Name Pin Number Name A3 DAT0 C2 VDDi J5 VSS N4 VCCQ Pre 1 NC lim 7 NC A4 DAT1 C4 VSSQ J10 VCC N5 VSSQ A5 DAT2 C6 VCCQ K5 RST_n P3 VCCQ A6 VSS E6 VCC K8 VSS P4 VSSQ B2 DAT3 E7 VSS K9 VCC P5 VCCQ B3 DAT4 F5 VCC M4 VCCQ P6 VSSQ B4 DAT5 G5 VSS M5 CMD B5 DAT6 H5 DS M6 CLK B6 DAT7 H10 VSS N2 VSSQ NC: No Connect, shall be connected to ground or left floating. RFU: Reserved for Future Use, shall be left floating for future use. VSF: Vendor Specific Function, shall be left floating. © 2019 Toshiba Memory Corporation 1 January 31st, 2019 THGBMJG7C1LBAIL Part Number Part Number Density Package Size THGBMJG7C1LBAIL 16GB 11.5mm x 13mm x 0.8mm(max) NAND Flash Type Weight 1 x 128Gbit 15nm 0.17g typ. ina r Temperature y Available e-MMC Module Product – Part Number Characteristics Operating temperature Storage temperature Min Max Unit -25 85 °C -40 85 °C Note: Avoid locations where e-MMC devices may be exposed to water (wet, rain, dew condensation, etc). Performance X8 mode/ Sequential access(4MByte access size) Part Number Density NAND Flash Type Interleave Operation Frequency /Mode 52MHz/SDR 16GB 1 x 128Gbit 15nm 52MHz/DDR lim THGBMJG7C1LBAIL Non Interleave Typ. Performance [MB/s] VCCQ Read Write 1.8V 45 45 3.3V 45 45 1.8V 90 45 3.3V 90 45 HS200 1.8V 180 45 HS400 1.8V 220 45 Power Supply VCC = 2.7V to 3.6V VCCQ = 1.7V to 1.95V / 2.7V to 3.6V Operating Current (RMS) The measurement for max RMS current is done as average RMS current consumption over a period of 100ms. Density NAND Flash Type Pre Part Number THGBMJG7C1LBAIL 16GB © 2019 Toshiba Memory Corporation 1 x 128Gbit 15nm 2 Interleave Operation Frequency /Mode ICCQ ICC 1.8V 95 40 3.3V 110 40 1.8V 115 45 3.3V 140 45 HS200 1.8V 170 55 HS400 1.8V 215 55 52MHz/SDR Non Interleave VCCQ Max Operating Current [mA] 52MHz/DDR January 31st, 2019 THGBMJG7C1LBAIL Part Number Density THGBMJG7C1LBAIL 16GB NAND Flash Type 1 x 128Gbit 15nm Interleave Operation Non Interleave y Sleep Mode Current ICCQS [μA] ICCQS+ICCS [μA] Typ. Note 1 Max. Note 2 Typ. Note 1 Max. Note 2 100 510 120 585 Product Architecture ina r Note 1: The conditions of typical values are 25°C and VCCQ = 3.3V or 1.8V. Note 2: The conditions of maximum values are 85°C and VCCQ = 3.6V or 1.95V. The diagram in Figure 1 illustrates the main functional blocks of the THGBMJG7C1LBAIL. Specification of the CREG and recommended values of the CVCC, and CVCCQ in the Figure 1 are as follows. Parameter Symbol VDDi capacitor value CREG VCC capacitor value CVCC VCCQ capacitor value CVCCQ Unit Min. Typ. Max. μF 0.10 - 2.2 Note 1 Except HS400 μF 1.00 - 2.2 Note 1 HS400 μF - 2.2 + 0.1 - μF - 2.2 + 0.1 - Remark lim Note 1: Toshiba Memory recommends that the value should be usually applied as the value of CREG. Package VCC (3.3V) CVCC VCCQ (1.8V / 3.3V) x11 Pre MMC I/F (1.8V / 3.3V) CORE LOGIC Figure 1 © 2019 Toshiba Memory Corporation NAND Control signal NAND I/O I/O BLOCK CREG REGULATOR NAND I/O BLOCK VDDi MMC I/O BLOCK CVCCQ NAND THGBMJG7C1LBAIL Block Diagram 3 January 31st, 2019 THGBMJG7C1LBAIL PRODUCT SPECIFICATIONS Package Dimensions y P-WFBGA153-1113-0.50 (11.5mm x 13mm, H0.8mm max. package) Pre lim ina r Unit: mm © 2019 Toshiba Memory Corporation 4 January 31st, 2019 THGBMJG7C1LBAIL Density Specifications Part Number Interleave Operation User Area Density [Bytes] SEC_COUNT in Extended CSD 16GB THGBMJG7C1LBAIL Non Interleave 15,758,000,128 0x01D5A000 y Density Register Informations OCR Register OCR bit ina r Note: User area density shall be reduced if enhanced user data area is defined. VDD Voltage window Value [6:0] Reserved 000 0000b 1.70-1.95 V 1b [14:8] 2.0-2.6 V 000 0000b [23:15] 2.7-3.6 V 1 1111 1111b [28:24] Reserved 0 0000b [30:29] Access Mode 10b [7] ( card power up status bit (busy) ) Note [31] Note: This bit is set to LOW if the Device has not finished the power up routine. CID Register [127:120] [119:114] [113:112] [111:104] [103:56] [55:48] [47:16] [15:8] [7:1] Width Value MID 8 0001 0001b Reserved - 6 0b Device/BGA CBX 2 01b OEM/Application ID OID 8 0b Product name PNM 48 0x30 31 36 47 42 30 (016GB0) Product revision PRV 8 0x00 Product serial PSN 32 Serial number Manufacturing date MDT 8 see-JEDEC Specification CRC7 checksum CRC 7 CRC7 Not used, always ‘1’ - 1 1b Manufacturer ID Pre [0] Field Name lim CID-slice © 2019 Toshiba Memory Corporation 5 January 31st, 2019 THGBMJG7C1LBAIL CSD Register Name Field Width Cell Type Value y CSD-slice CSD structure CSD_STRUCTURE 2 R 0x3 [125:122] System specification version SPEC_VERS 4 R 0x4 [121:120] Reserved - 2 R 0x0 [119:112] Data read access-time 1 TAAC [111:104] Data read access-time 2 in CLK cycles (NSAC * 100) 8 R 0x27 NSAC 8 R 0x00 [103:96] Max. bus clock frequency TRAN_SPEED 8 R 0x32 [95:84] Device command classes CCC 12 R 0x8F5 [83:80] Max. read data block length READ_BL_LEN 4 R 0x9 [79:79] Partial blocks for read allowed READ_BL_PARTIAL 1 R 0x0 [78:78] Write block misalignment WRITE_BLK_MISALIGN 1 R 0x0 [77:77] Read block misalignment READ_BLK_MISALIGN 1 R 0x0 [76:76] DSR implemented DSR_IMP 1 R 0x0 [75:74] Reserved - 2 R 0x0 [73:62] Device size C_SIZE 12 R 0xFFF [61:59] Max. read current @ VDD min. VDD_R_CURR_MIN 3 R 0x7 [58:56] Max. read current @ VDD max. VDD_R_CURR_MAX 3 R 0x7 [55:53] Max. write current @ VDD min. VDD_W_CURR_MIN 3 R 0x7 [52:50] Max. write current @ VDD max. VDD_W_CURR_MAX 3 R 0x7 [49:47] Device size multiplier C_SIZE_MULT 3 R 0x7 [46:42] Erase group size ERASE_GRP_SIZE 5 R 0x1F [41:37] Erase group size multiplier ERASE_GRP_MULT 5 R 0x1F [36:32] Write protect group size WP_GRP_SIZE 5 R 0x07 [31:31] Write protect group enable WP_GRP_ENABLE 1 R 0x1 [30:29] Manufacturer default ECC DEFAULT_ECC 2 R 0x0 [28:26] Write speed factor R2W_FACTOR 3 R 0x1 [25:22] Max. write data block length WRITE_BL_LEN 4 R 0x9 [21:21] Partial blocks for write allowed WRITE_BL_PARTIAL 1 R 0x0 [20:17] Reserved - 4 R 0x0 [16:16] Content protection application CONTENT_PROT_APP 1 R 0x0 [15:15] File format group FILE_FORMAT_GRP 1 R/W 0x0 [14:14] Copy flag (OTP) COPY 1 R/W 0x0 [13:13] Permanent write protection PERM_WRITE_PROTECT 1 R/W 0x0 [12:12] Temporary write protection TMP_WRITE_PROTECT 1 R/W/E 0x0 [11:10] File format FILE_FORMAT 2 R/W 0x0 [9:8] ECC code ECC 2 R/W/E 0x0 Pre lim ina r [127:126] [7:1] CRC CRC 7 R/W/E CRC [0] Not used, always ‘1’ - 1 - 0x1 © 2019 Toshiba Memory Corporation 6 January 31st, 2019 THGBMJG7C1LBAIL Extended CSD Register Cell Size (Bytes) Type 6 - All ‘0’ 1 R 0x00 1 R 0x01 1 R 0x01 BKOPS_SUPPORT 1 R 0x01 MAX_PACKED_READS 1 R 0x3F MAX_PACKED_WRITES 1 R 0x3F DATA_TAG_SUPPORT 1 R 0x01 TAG_UNIT_SIZE 1 R 0x03 TAG_RES_SIZE 1 R 0x00 CONTEXT_CAPABILITIES 1 R 0x7F LARGE_UNIT_SIZE_M1 1 R 0x00 EXT_SUPPORT 1 R 0x03 SUPPORTED_MODES 1 R 0x01 FFU_FEATURES 1 R 0x00 OPERATION_CODES_TIMEOUT 1 R 0x00 FFU_ARG 4 R 0xFFFFFFFF BARRIER_SUPPORT 1 R 0x01 177 - All ‘0’ Name Field Value y CSD-slice Reserved - [505] Extended Security Commands Error EXT_SECURITY_ERR [504] Supported Command Sets S_CMD_SET [503] HPI features HPI_FEATURES [502] Background operations support [501] Max_packed read commands [500] Max_packed write commands [499] Data Tag Support [498] Tag Unit Size [497] Tag Resource Size [496] Context management capabilities [495] Large Unit size [494] Extended partitions attribute support [493] Supported modes [492] FFU features [491] Operation codes timeout [490:487] FFU Argument [486] Barrier support [485:309] Reserved [308] CMD Queuing Support CMDQ_SUPPORT 1 R 0x01 [307] CMD Queuing Depth CMDQ_DEPTH 1 R 0x1F [306] Reserved - 1 - 0x00 4 R All ’0’ ina r [511:506] lim - Number of FW sectors correctly programmed [301:270] Vendor proprietary health report VENDOR_PROPRIETARY _HEALTH_REPORT 32 R All ‘0’ [269] Device life time estimation type B DEVICE_LIFE_TIME_EST_TYP_B 1 R 0x00 [268] Device life time estimation type A DEVICE_LIFE_TIME_EST_TYP_A 1 R 0x01 [267] Pre EOL information PRE_EOL_INFO 1 R 0x01 [266] Optimal read size OPTIMAL_READ_SIZE 1 R 0x08 [265] Optimal write size OPTIMAL_WRITE_SIZE 1 R 0x08 [264] Optimal trim unit size OPTIMAL_TRIM_UNIT_SIZE 1 R 0x01 [263:262] Device version DEVICE_VERSION 2 R 0x01 [261:254] Firmware version FIRMWARE_VERSION 8 R 0x03 [253] Power class for 200MHz, DDR at VCC=3.6V PWR_CL_DDR_200_360 1 R 0xCC [252:249] Cache size CACHE_SIZE 4 R 0x00001000 [248] Generic CMD6 timeout GENERIC_CMD6_TIME 1 R 0x0A [247] Power off notification(long) timeout POWER_OFF_LONG_TIME 1 R 0x32 [246] Background operations status BKOPS_STATUS 1 R 0x00 [245:242] Number of correctly programmed sectors CORRECTLY _PRG_SECTORS_NUM 4 R 0x00000000 [241] 1st INI_TIMEOUT_AP 1 R 0x1E Pre [305:302] NUMBER_OF_FW_SECTORS_C ORRECTLY_PROGRAMMED initialization time after partitioning © 2019 Toshiba Memory Corporation 7 January 31st, 2019 THGBMJG7C1LBAIL Name Field Cache Flushing Policy CACHE_FLUSH_POLICY [239] Power class for 52MHz, DDR at 3.6V PWR_CL_DDR_52_360 [238] Power class for 52MHz, DDR at 1.95V PWR_CL_DDR_52_195 [237] Power class for 200MHz, at VCCQ =1.95V, VCC = 3.6V PWR_CL_200_195 [236] Power class for 200MHz, at VCCQ=1.3V, VCC = 3.6V [235] Minimum Write Performance for 8bit at 52MHz in DDR mode Minimum Read Performance for 8bit [234] at 52MHz in DDR mode Reserved [232] TRIM Multiplier [231] Secure Feature support [230] Secure Erase Multiplier [229] Secure TRIM Multiplier [228] Boot information [227] Reserved [226] Boot partition size [225] Access size [224] High-capacity erase unit size [223] High-capacity erase timeout [222] Value 1 R 0x01 1 R 0x66 1 R 0xBB 1 R 0xBB PWR_CL_200_130 1 R 0xBB MIN_PERF_DDR_W_8_52 1 R 0x00 MIN_PERF_DDR_R_8_52 1 R 0x64 - 1 - 0x00 TRIM_MULT 1 R 0x01 SEC_FEATURE_SUPPORT 1 R 0x55 SEC_ERASE_MULT 1 R 0xF3 SEC_TRIM_MULT 1 R 0xF7 BOOT_INFO 1 R 0x07 - 1 R 0x00 1 R 0x20 ACC_SIZE 1 R 0x08 HC_ERASE_GRP_SIZE 1 R 0x08 ERASE_TIMEOUT_MULT 1 R 0x11 Reliable write sector count REL_WR_SEC_C 1 R 0x01 [221] High-capacity write protect group size HC_WP_GRP_SIZE 1 R 0x01 [220] Sleep current (VCC) S_C_VCC 1 R 0x07 [219] Sleep current (VCCQ) S_C_VCCQ 1 R 0x09 [218] Production state awareness timeout PRODUCTION_STATE _AWARENESS_TIMEOUT 1 R 0x0A [217] Sleep/awake timeout S_A_TIMEOUT 1 R 0x14 [216] Sleep Notification Timeout SLEEP_NOTIFICATION_TIME 1 R 0x10 [215:212] Sector Count SEC_COUNT 4 R 0x01D5A000 [211] Sector Write Protection Information SECURE_WP_INFO 1 R 0x01 [210] Minimum Write Performance for 8bit at 52MHz MIN_PERF_W_8_52 1 R 0x00 [209] Minimum Read Performance 8bit at 52MHz MIN_PERF_R_8_52 1 R 0x78 [208] Minimum Write Performance for 8bit at 26MHz, for 4bit at 52MHz MIN_PERF_W_8_26_4_52 1 R 0x00 [207] Minimum Read Performance for 8 bit at 26MHz, for 4bit at 52MHz MIN_PERF_R_8_26_4_52 1 R 0x46 [206] Minimum Write Performance for 4bit at 26MHz MIN_PERF_W_4_26 1 R 0x00 [205] Minimum Read Performance for 4bit at 26MHz MIN_PERF_R_4_26 1 R 0x1E Pre BOOT_SIZE_MULTI lim [233] Cell Type ina r [240] Size (Bytes) y CSD-slice © 2019 Toshiba Memory Corporation 8 January 31st, 2019 THGBMJG7C1LBAIL Name Field [204] Reserved - [203] Power class for 26MHz at 3.6V PWR_CL_26_360 [202] Power class for 52MHz at 3.6V PWR_CL_52_360 [201] Power class for 26MHz at 1.95V PWR_CL_26_195 [200] Power class for 52MHz at 1.95V PWR_CL_52_195 [199] Partition switching timing [198] Out-of-interrupt busy timing [197] I/O Driver Strength [196] Device Type [195] Reserved [194] CSD structure version [193] Reserved [192] Extended CSD revision [191] Command Set [190] Reserved [189] Command set revision [188] Reserved Cell Type Value 1 - 0x00 1 R 0x55 1 R 0x55 1 R 0xBB 1 R 0xBB PARTITION_SWITCH_TIME 1 R 0x0A OUT_OF_INTERRUPT_TIME 1 R 0x0A DRIVER_STRENGTH 1 R 0x1F DEVICE_TYPE 1 R 0x57 - 1 - 0x00 CSD_STRUCTURE 1 R 0x02 - 1 - 0x00 ina r Note 1 Size (Bytes) y CSD-slice EXT_CSD_REV 1 R 0x08 CMD_SET 1 R/W/E_P 0x00 - 1 - 0x00 CMD_SET_REV 1 R 0x00 - 1 - 0x00 POWER_CLASS 1 R/W/E_P 0x00 - 1 - 0x00 HS_TIMING 1 R/W/E_P 0x00 Power class [186] Reserved [185] High-speed interface timing [184] Strobe Support STROBE_SUPPORT 1 R 0x01 [183] Bus width mode BUS_WIDTH 1 W/E_P 0x00 [182] Reserved - 1 - 0x00 [181] Erased memory content ERASED_MEM_CONT 1 R 0x00 [180] Reserved - 1 - 0x00 [179] Partition configuration PARTITION_CONFIG 1 R/W/E & R/W/E_P 0x00 [178] Boot config protection BOOT_CONFIG_PROT 1 R/W & R/W/C_P 0x00 [177] Boot bus Conditions BOOT_BUS_CONDITIONS 1 R/W/E 0x00 [176] Reserved - 1 - 0x00 [175] High-density erase group definition ERASE_GROUP_DEF 1 R/W/E_P 0x00 [174] Boot write protection status registers BOOT_WP_STATUS 1 R 0x00 R/W & R/W/C_P 0x00 Pre lim [187] [173] Boot area write protection register BOOT_WP 1 [172] Reserved - 1 - 0x00 0x00 [171] User area write protection register USER_WP 1 R/W, R/W/C_P & R/W/E_P [170] Reserved - 1 - 0x00 [169] FW configuration FW_CONFIG 1 R/W 0x00 © 2019 Toshiba Memory Corporation 9 January 31st, 2019 THGBMJG7C1LBAIL Name Field RPMB Size RPMB_SIZE_MULT [167] Write reliability setting register WR_REL_SET [166] Write reliability parameter register WR_REL_PARAM [165] Start Sanitize operation SANITIZE_START [164] Manually start BKOPS_START background operations Cell Type Value 1 R 0x20 1 R/W 0x1F 1 R 0x15 1 W/E_P 0x00 1 W/E_P 0x00 0x00 ina r [168] Size (Bytes) y CSD-slice [163] Enable background operations handshake BKOPS_EN 1 R/W & R/W/E [162] H/W reset function RST_n_FUNCTION 1 R/W 0x00 [161] HPI management HPI_MGMT 1 R/W/E_P 0x00 [160] Partitioning Support PARTITIONING_SUPPORT 1 R 0x07 [159:157] Max Enhanced Area Size Note 2 MAX_ENH_SIZE_MULT 3 R 0x000757 [156] Partitions attribute PARTITIONS_ATTRIBUTE 1 R/W 0x00 [155] Partitioning Setting PARTITION_SETTING_COMPLET ED 1 R/W 0x00 [154:143] General Purpose Partition Size Note 3 GP_SIZE_MULT 12 R/W 0x00 [142:140] Enhanced User Data Area Size Note 4 ENH_SIZE_MULT 3 R/W 0x00 [139:136] Enhanced User Data Start Address ENH_START_ADDR 4 R/W 0x00 [135] Reserved - 1 - 0x00 [134] Bad Block Management mode 1 R/W 0x00 1 R/W/E 0x00 lim SEC_BAD_BLK_MGMNT Production state awareness Note 6 [132] Package Case Temperature is controlled Note 1 TCASE_SUPPORT 1 W/E_P 0x00 [131] Periodic Wake-up Note 1 PERIODIC_WAKEUP 1 R/W/E 0x00 [130] Program CID/CSD in DDR mode support PROGRAM_CID_CSD_DDR_SUP PORT 1 R 0x01 [129:128] Reserved - 2 - All ‘0’ [127:64] Vendor Specific Fields VENDOR_SPECIFIC_FIELD 64 - - [63] Native sector size NATIVE_SECTOR_SIZE 1 R 0x01 [62] Sector size emulation USE_NATIVE_SECTOR 1 R/W 0x00 [61] Sector size DATA_SECTOR_SIZE 1 R 0x00 [60] 1st initialization after disabling sector size emulation INI_TIMEOUT_EMU 1 R 0x0A [59] Class 6 commands control CLASS_6_CTRL 1 R/W/E_P 0x00 [58] Number of addressed group to be Released DYNCAP_NEEDED 1 R 0x00 [57:56] Exception events control EXCEPTION_EVENTS_CTRL 2 R/W/E_P 0x00 [55:54] Exception events status EXCEPTION_EVENTS_STATUS 2 R All ‘0’ [53:52] Extended partitions attribute Note 1 EXT_PARTITIONS_ATTRIBUTE 2 R/W 0x00 [51:37] Context configuration CONTEXT_CONF 15 R/W/E_P 0x00 [36] Packed command status PACKED_COMMAND_STATUS 1 R 0x00 [35] Packed command failure index PACKED_FAILURE_INDEX 1 R 0x00 POWER_OFF_NOTIFICATION 1 R/W/E_P 0x00 CACHE_CTRL 1 R/W/E_P 0x00 Pre [133] PRODUCTION_STATE _AWARENESS Note 5 [34] Power Off Notification [33] Control to turn the Cache ON/OFF © 2019 Toshiba Memory Corporation 10 January 31st, 2019 THGBMJG7C1LBAIL Size (Bytes) Cell Type Value 1 W/E_P 0x00 1 R/W 0x00 1 R/W/E_P 0x00 1 W/E_P 0x00(not support. Return switch error) 2 - All ‘0’ FFU_STATUS 1 R 0x00 PRE_LOADING_DATA_SIZE 4 R/W/E_P 0x00757000 MAX_PRE_LOADING_DATA _SIZE 4 R 0x00757000 Name Field Flushing of the cache FLUSH_CACHE [31] Control to turn the Barrier ON/OFF BARRIER_CTRL [30] Mode config MODE_CONFIG [29] Mode operation codes MODE_OPERATION_CODES [28:27] Reserved - [26] FFU status Note 6 ina r [32] y CSD-slice [25:22] Pre loading data size [21:18] Max pre loading data size [17] Product state awareness enablement Note 6 PRODUCT_STATE _AWARENESS_ENABLEMENT 1 R/W/E &R 0x03 [16] Secure Removal Type SECURE_REMOVAL_TYPE 1 R/W & R 0x39 [15] Command Queue Mode Enable CMDQ_MODE_EN 1 R/W/E_P 0x00 [14:0] Reserved - 15 - All ‘0’ Note 1: Although these fields can be re-written by host, TOSHIBA Memory e-MMC does not support. Note 2: Max Enhanced Area Size (MAX_ENH_SIZE_MULT [159:157]) has to be calculated by following formula. Max Enhanced Area = MAX_ENH_SIZE_MULT x HC_WP_GRP_SIZE x HC_ERASE_GRP_SIZE x 512kBytes 4 ∑ Enhanced general partition size(i) + Enhanced user data area ≤ Max enhanced area lim i=1 Note 3: General Purpose Partition Size (GP_SIZE_MULT_GP0 - GP_SIZE_MULT_GP3 [154:143]) has to be calculated by following formula. General_Purpose_Partition_X Size = (GP_SIZE_MULT_X_2 x 216 + GP_SIZE_MULT_X_1 x 28 + GP_SIZE_MULT_X_0 x 20 ) x HC_WP_GRP_SIZE x HC_ERASE_GRP_SIZE x 512kBytes Note 4: Enhanced User Data Area Size (ENH_SIZE_MULT [142:140]) has to be calculated by following formula. Enhanced User Data Area x Size = (ENH_SIZE_MULT_2 x 216 + ENH_SIZE_MULT_1 x 28 + ENH_SIZE_MULT_0 x 20 ) x HC_WP_GRP_SIZE x HC_ERASE_GRP_SIZE x 512kBytes Pre Note 5: Toshiba Memory recommends to issue the Power Off Notification before turning off the device, especially when cache is on or AUTO_EN(BKOPS_EN[163]:bit1) is set to ‘1b’. © 2019 Toshiba Memory Corporation 11 January 31st, 2019 THGBMJG7C1LBAIL y Note 6: - Pre loading data size = PRE_LOADING_DATA_SIZE x Sector Size Pre-loading data size should be multiple of 4KB and the pre-loading data should be written by multiple of 4KB chunk size, aligned with 4KB address. This is because the valid data size will be treated as 4KB when host writes data less than 4KB. - If the host continues to write data in Normal state (after it wrote PRE_LOADING_DATA_SIZE amount of data) and before soldering, the pre-loading data might be corrupted after soldering. Pre lim ina r - If a power cycle is occurred during the data transfer, the amount of data written to device is not clear. Therefore in this case, host should erase the entire pre-loaded data and set again PRE_LOADING_DATA_SIZE[25:22], PRODUCTION_STATE_AWARENESS[133], and PRODUCT_STATE_AWARENESS_ENABLEMENT[17]. © 2019 Toshiba Memory Corporation 12 January 31st, 2019 THGBMJG7C1LBAIL ELECTRICAL CHARACTERISTICS y DC Characteristics Absolute Maximum Ratings Parameter Supply voltage 1 Supply voltage 2 Voltage Input General Parameter ina r The absolute maximum ratings of a semiconductor device are a set of specified parameter values, which must not be exceeded during operation, even for an instant. If any of these rating would be exceeded during operation, the device electrical characteristics may be irreparably altered and the reliability and lifetime of the device can no longer be guaranteed. Moreover, these operations with exceeded ratings may cause break down, damage, and/or degradation to any other equipment. Applications using the device should be designed such that each maximum rating will never be exceeded in any operating conditions. Before using, creating, and/or producing designs, refer to and comply with the precautions and conditions set forth in this document. Symbol Test Conditions Min Max Unit VCC - -0.5 4.1 V VCCQ - -0.5 4.1 V VIO - -0.5 VCCQ+0.5(≤4.1) V Symbol Test Conditions Min Max Unit - - -0.5 VCCQ+0.5 V Input Leakage Current (before initialization sequence Note 1 and/or the internal pull up resistors connected) - - -100 100 μA Input Leakage Current (after initialization sequence and the internal pull up resistors disconnected) - - -2 2 μA Output Leakage Current (before initialization sequence) - - -100 100 μA Output Leakage Current (after initialization sequence) - - -2 2 μA Peak voltage on all lines All Outputs lim All Inputs Note 1: Initialization sequence is defined in Power-Up chapter of JEDEC/MMCA Standard Power Supply Voltage Parameter Pre Supply voltage 1 Supply voltage 2 Symbol Test Conditions Min Max Unit VCC - 2.7 3.6 V 1.7 1.95 V VCCQ 2.7 3.6 V Note 1: Once the power supply VCC or VCCQ falls below the minimum guaranteed voltage (for example, upon sudden power fail), the voltage level of VCC or VCCQ shall be kept less than 0.5 V for at least 1ms before it goes beyond 0.5 V again. Note 2: The host and device I/O power (VCCQ) shall be provided from same power supply. © 2019 Toshiba Memory Corporation 13 January 31st, 2019 THGBMJG7C1LBAIL Supply Current Symbol Min Interleave Operation Mode VCCQ Icc Iccq Icc 1.8V   95 15 3.3V   110 15 Operation (RMS) Non Interleave 1.8V   115 20 3.3V   140 20 DDR HS200 1.8V   170 35 mA HS400 1.8V   215 40 mA 1.8V   60 40 3.3V   65 40 1.8V   65 45 3.3V   70 45 HS200 1.8V   75 55 mA HS400 1.8V   80 55 mA SDR IWOP Non Interleave DDR mA mA Pre lim Write mA mA ina r IROP Unit Iccq SDR Read Max y Parameter © 2019 Toshiba Memory Corporation 14 January 31st, 2019 THGBMJG7C1LBAIL Internal resistance and Device capacitance Single device capacitance Internal pull up resistance DAT1 – DAT7 Symbol Test Conditions CDEVICE - RINT - V VCCQ Input high level VOH VIH Max Unit - 6 pF 10 150 kΩ ina r Bus Signal Levels Min y Parameter Output high level undefined VIL Input low level VOL VSS Output low level t Open-Drain Mode Bus Signal Level Parameter Min Max Unit VOH VCCQ - 0.2  V Note 1 VOL  0.3 V IOL = 2 mA lim Output HIGH voltage Symbol Output LOW voltage Conditions Note 1: Because VOH depends on external resistance value (including outside the package), this value does not apply as device specification. Host is responsible to choose the external pull-up and open drain resistance value to meet VOH Min value. Push-Pull Mode Bus Signal Level (High-Voltage) Symbol Min Max Unit Output HIGH voltage VOH 0.75 * VCCQ  V IOH = -100 μA @ VCCQ min Output LOW voltage VOL  0.125 * VCCQ V IOL = 100 μA @ VCCQ min Input HIGH voltage VIH 0.625 * VCCQ VCCQ + 0.3 V Input LOW voltage VIL VSS - 0.3 0.25 * VCCQ V Pre Parameter Conditions Push-Pull Mode Bus Signal Level (Dual-Voltage) Parameter Symbol Min Max Unit Output HIGH voltage VOH VCCQ - 0.45  V IOH = -2mA Output LOW voltage VOL  0.45 V IOL = 2mA Input HIGH voltage VIH 0.65 * VCCQ VCCQ + 0.3 V Input LOW voltage VIL VSS - 0.3 0.35 * VCCQ V © 2019 Toshiba Memory Corporation 15 Conditions January 31st, 2019 THGBMJG7C1LBAIL Driver Types Definition y In JEDEC, Driver Type-0 is defined as mandatory for e-MMC HS200&HS400 Device. While four additional Driver Types (1, 2, 3 and 4) are defined as optional, to allow the support of wider Host loads. The Host may select the most appropriate Driver Type of the Device (if supported) to achieve optimal signal integrity performance. ina r Driver Type-0 is targeted for transmission line, based distributed system with 50Ω nominal line impedance. Therefore, it is defined as 50Ω nominal driver. The nominal line impedance should be kept as 50Ω even if Driver Type would be changed. For HS200, when tested with CL = 15pF Driver Type-0 shall meet all AC characteristics and HS200 Device output timing requirements. The test circuit defined in section 10.5.4.3 of JEDEC/MMCA Standard 5.1 is used for testing of Driver Type-0. For HS400, when tested with the reference load defined in page 27 HS400 reference load figure, Driver Type-0 or Driver Type-1 or Driver Type-4 shall meet all AC characteristics and HS400 Device output timing requirements. Driver Type TOSHIBA e-MMC Nominal Impedance (Driver strength) Approximated driving capability compared to Type-0 0 Supported 50 Ω (18mA) x1 1 Supported 33 Ω (27mA) x1.5 2 Supported 66 Ω (14mA) x0.75 3 Supported 100 Ω (9mA) x0.5 4 Supported 40 Ω (23mA) x1.2 Remark Default Driver Type Recommendation at HS400 under the condition of JEDEC standard reference load. Recommendation at HS400 under the condition of JEDEC standard reference load. lim Note: Nominal impedance is defined by I-V characteristics of output driver at 0.9V when VCCQ = 1.8V. Pre *The most suitable setting for user’s operating environment should be selected. At HS400, Toshiba Memory recommends Driver Type-1 and Type-4. This is because they meet all AC characteristics and Device output timing requirements under the condition of JEDEC standard reference load. © 2019 Toshiba Memory Corporation 16 January 31st, 2019 THGBMJG7C1LBAIL Bus Timing tWH tISU Data 50% VCCQ tTLH max(VIL) ina r tIH Input min(VIH) tWL 50% VCCQ CLK y tPP tTHL Invalid min(VIH) Data max(VIL) tOSU tODLY tOH min(VOH) Invalid Data Output Data max(VOL) Data must always be sampled on the rising edge of the clock Device Interface Timings (High-speed interface timing) Parameter Clock CLK Note 1 Symbol Min Max Unit Remark fpp 0 52 Note 3 MHz CL ≤ 30pF Tolerance: +100kHz Clock frequency Identification Mode (OD) fOD 0 400 kHz Tolerance: +20kHz Clock high time tWH 6.5  ns CL ≤ 30pF tWL 6.5  ns CL ≤ 30pF Clock rise time Note 4 tTLH  3 ns CL ≤ 30pF Clock fall time tTHL  3 ns CL ≤ 30pF Input set-up time tISU 3  ns CL ≤ 30pF Input hold time tIH 3  ns CL ≤ 30pF tODLY  13.7 ns CL ≤ 30pF tOH 2.5  ns CL ≤ 30pF trise  3 ns CL ≤ 30pF tfall  3 ns CL ≤ 30pF Clock low time lim Clock frequency Data Transfer Mode (PP) Note 2 Inputs CMD, DAT (referenced to CLK) Outputs CMD, DAT (referenced to CLK) Pre Output Delay time during Data Transfer Output hold time Signal rise time Note 5 Signal fall time Note 1: CLK timing is measured at 50% of VCCQ. Note 2: This product shall support the full frequency range from 0 MHz - 26 MHz, or 0 MHz - 52 MHz. Note 3: Device can operate as high-speed interface timing at 26MHz clock frequency. Note 4: CLK rise and fall times are measured by min (VIH) and max (VIL). Note 5: Inputs CMD, DAT rise and fall times area measured by min (VIH) and max (VIL), and outputs CMD, DAT rise and fall times are measured by min (VOH) and max (VOL). © 2019 Toshiba Memory Corporation 17 January 31st, 2019 THGBMJG7C1LBAIL Device Interface Timings (Backward-compatible interface timing) Symbol Min Max Clock frequency Data Transfer Mode (PP) Note 3 fpp 0 26 MHz Clock frequency Identification Mode (OD) fOD 0 400 kHz Clock high time tWH 10  ns Clock rise time Note 4 Clock fall time Inputs CMD,DAT (referenced to CLK) Input set-up time Input hold time Outputs CMD,DAT (referenced to CLK) Output set-up time Note 5 Output hold time Note 5 Remark Note 1 CL ≤ 30pF CL ≤ 30pF ina r Clock CLK Note 2 Clock low time Unit y Parameter tWL 10  ns CL ≤ 30pF tTLH  10 ns CL ≤ 30pF tTHL  10 ns CL ≤ 30pF tISU 3  ns CL ≤ 30pF tIH 3  ns CL ≤ 30pF tOSU 11.7  ns CL ≤ 30pF tOH 8.3  ns CL ≤ 30pF lim Note 1: The e-MMC must always start with the backward-compatible interface timing. The timing mode can be switched to high-speed interface timing by the host sending the SWITCH command (CMD6) with the argument for high-speed interface select. Note 2: CLK timing is measured at 50% of VCCQ. Note 3: For compatibility with e-MMCs that support the v4.2 standard or earlier, host should not use >26MHz before switching to high-speed interface timing. Note 4: CLK rise and fall times are measured by min (VIH) and max (VIL). Note 5: tOSU and tOH are defined as values from clock rising edge. However, the e-MMC device will utilize clock falling edge to output data in backward compatibility mode. Therefore, it is recommended for hosts either to set tWL value as long as possible within the range which will not go over tCK - tOH(min) in the system or to use slow clock frequency, so that host could have data set up margin for the device. Toshiba e-MMC device utilize clock falling edge to output data in backward compatibility mode. Host should optimize the timing in order to have data set up margin as follows. tWL Pre CLK tODLY Output tOS tOH Invalid Data tOSU (min) = tWL(min) Figure 2 © 2019 Toshiba Memory Corporation 18 tODLY(max 8ns) Output timing January 31st, 2019 THGBMJG7C1LBAIL Bus Timing for DAT signals for during 2x data rate operation y These timings applies to the DAT[7:0] signals only when the device is configured for dual data mode operation. In this dual data mode, the DAT signals operates synchronously of both the rising and the falling edges of CLK. The CMD signal still operates synchronously of the rising edge of CLK and therefore complies with the bus timing specified in High-speed interface timing or Backward-compatible interface timing. CLK ina r tPP 50% VCCQ 50% VCCQ tIHddr tISUddr min(VIH) max(VIL) tIHddr tISUddr min(VIH) Input DATA DATA DATA Invalid max(VIL) tODLYddr(max) tODLYddr(max) tODLYddr(min) tODLYddr(min) DATA DATA min(VOH) DATA lim Output Invalid max(VOL) In DDR mode data on DAT[7:0] lines are sampled on both edges of the clock (not applicable for CMD line). High-speed dual data rate interface timings Parameter Min Max Unit Remark 45 55 % Includes jitter, phase noise tTLH  3 ns CL ≤ 30pF tTHL  3 ns CL ≤ 30pF Input set-up time tISUddr 3  ns CL ≤ 20pF Input hold time tIHddr 3  ns CL ≤ 20pF tODLY  13.7 ns CL ≤ 20pF Output hold time tOH 2.5  ns CL ≤ 20pF Signal rise time tRISE  3 ns CL ≤ 20pF Signal fall time tFALL  3 ns CL ≤ 20pF Input CLK Note 1 Clock duty cycle Clock rise time Pre Clock fall time Symbol Input CMD (referenced to CLK-SDR mode) Output CMD (referenced to CLK-SDR mode) Output delay time during data transfer © 2019 Toshiba Memory Corporation 19 January 31st, 2019 THGBMJG7C1LBAIL Symbol Min Max Input set-up time tISUddr 2.5  ns CL ≤ 20pF Input hold time tIHddr 2.5  ns CL ≤ 20pF Input DAT (referenced to CLK-DDR mode) Output DAT (referenced to CLK-DDR mode) Signal rise time (all signals) Note 2 Signal fall time (all signals) Remark tODLYddr 1.5 7 ns CL ≤ 20pF tRISE  2 ns CL ≤ 20pF tFALL  2 ns CL ≤ 20pF ina r Output delay time during data transfer Unit y Parameter Pre lim Note 1: CLK timing is measured at 50% of VCCQ. Note 2: Inputs DAT rise and fall times are measured by min (VIH) and max (VIL), and outputs DAT rise and fall times are measured by min (VOH) and max (VOL). © 2019 Toshiba Memory Corporation 20 January 31st, 2019 THGBMJG7C1LBAIL Bus Timing Specification in HS200 mode y HS200 Clock Timing Host CLK Timing in HS200 mode shall conform to the timing specified in following figure and Table. CLK input shall satisfy the clock timing over all possible operation and environment conditions. CLK input parameters should be measured while CMD and DAT lines are stable high or low, as close as possible to the Device. The maximum frequency of HS200 is 200MHz. Hosts can use any frequency up to the maximum that HS200 mode allows. VIH CLOCK INPUT VT VIL VSS tTLH ina r tPERIOD VCCQ tTHL Note 1: VIH denote VIH(min.) and VIL denotes VIL(max.). Note 2: VT = 50% of VCCQ, indicates clock reference point for timing measurements. Min Max tPERIOD 5  tTLH, tTHL  0.2 * tPERIOD Duty Cycle 30 70 Unit Remark ns 200MHz (max.), between rising edges ns tTLH, tTHL < 1ns (max.) at 200MHz, CDEVICE=6pF, The absolute maximum value of tTLH, tTHL is 10ns regardless of clock frequency. % lim Symbol HS200 Device Input Timing VCCQ CLOCK INPUT tPERIOD VT VSS tIH tISU VCCQ VIH VIH VALID WINDOW VIL Pre CMD.DAT[7-0] INPUT VIL VSS Note 1: tISU and tIH are measured at VIL(max) and VIH(min). Note 2: VIH denote VIH(min) and VIL denotes VIL(max). Symbol Min Max Unit tISU 1.40  ns CDEVICE ≤ 6pF tIH 0.8  ns CDEVICE ≤ 6pF © 2019 Toshiba Memory Corporation 21 Remark January 31st, 2019 THGBMJG7C1LBAIL HS200 Device Output Timing y tPH parameter is defined to allow device output delay to be longer than tPERIOD. After initialization, the tPH may have random phase relation to the clock. The Host is responsible to find the optimal sampling point for the Device outputs, while switching to the HS200 mode. While setting the sampling point of data, a long term drift, which mainly depends on temperature drift, should be considered. The temperature drift is expressed by ΔTPH. Output valid data window (tVW) is available regardless of the drift (ΔTPH) but position of data window varies by the drift. CLOCK INPUT VT VSS ina r tPERIOD VCCQ tPH tVW VCCQ VOH VOH CMD.DAT[7-0] OUTPUT VOL VALID WINDOW VOL VSS Note: VOH denotes VOH(min) and VOL denotes VOL(max). tPH ΔTPH tVW Min Max Remark Note 1 Unit UI Device output momentary phase from CLK input to CMD or DAT lines output. Does not include a long term temperature drift. ps Delay variation due to temperature change after tuning. Total allowable shift of output valid window (tVW ) from last system Tuning procedure. ΔTPH is 2600ps for ΔT from -25 °C to 125 °C during operation. UI tVW =2.88ns at 200MHz Using test circuit in following figure including skew among CMD and DAT lines created by the Device. Host path may add Signal Integrity induced noise, skews, etc. Expected tVW at Host input is larger than 0.475UI. lim Symbol 0 2 -350 (ΔT = -20 °C) +1550 (ΔT = 90 °C ) 0.575  Note 1: Unit Interval (UI) is one bit nominal time. For example, UI=5ns at 200 MHz. Pre Meas. Location Driver CL=15pF Note 1: CL is total equivalent lumped capacitance for each Driver. Note 2: CL incorporates device die load, device package load and equivalent lumped load external to the device. Note 3: In distributed transmission lines only part of the line capacitance considered as load for the Driver. © 2019 Toshiba Memory Corporation 22 January 31st, 2019 THGBMJG7C1LBAIL ΔTPH = -350ps ΔTPH = 1550ps Sampling point VALID WINDOW VALID WINDOW VALID WINDOW ina r Sampling point after tuning y ΔTPH consideration Sampling point after junction heated to +90 ℃ Sampling point after junction cooled to -20 ℃ Pre lim Implementation Guide: Host should design to avoid sampling errors that may be caused by the ΔTPH drift. It is recommended to perform tuning procedure while Device wakes up, after sleep. One simple way to overcome the ΔTPH drift is by reduction of operating frequency. © 2019 Toshiba Memory Corporation 23 January 31st, 2019 THGBMJG7C1LBAIL Bus Timing Specification in HS400 mode y HS400 Input Timing The CMD input timing for HS400 mode is the same as CMD input timing for HS200 mode. tPERIOD VCCQ VSS VCCQ tCKDCD ina r CLOCK INPUT VT tCKMPW tISU VIH DAT[7-0] INPUT tCKMPW tCKDCD tISU tIH tIH VIH VALID WINDOW VIL VSS VIL VALID WINDOW Note: VT = 50% of VCCQ, indicates clock reference point for timing measurements. Input CLK Symbol Min Max Unit Remark lim Parameter tPERIOD 5  ns SR 1.125  V/ns Duty cycle distortion tCKDCD 0.0 0.3 ns Allowable deviation from an ideal 50% duty cycle. With respect to VT Includes jitter, phase noise Minimum pulse width tCKMPW 2.2  ns With respect to VT tISUddr 0.4  ns CDEVICE ≤ 6 pF With respect to VIH /VIL tIhddr 0.4  ns CDEVICE ≤ 6 pF With respect to VIH /VIL SR 1.125  V/ns With respect to VIH /VIL Cycle time data transfer mode Slew rate 200 MHz(max), between rising edges With respect to VT With respect to VIH /VIL Input DAT (referenced to CLK) Input set-up time Input hold time Pre Slew rate © 2019 Toshiba Memory Corporation 24 January 31st, 2019 THGBMJG7C1LBAIL HS400 Device Output Timing y The Data Strobe is used to read data in HS400 mode. The Data Strobe is toggled only during data read or CRC status response. tPERIOD VCCQ tDSDCD tDSMPW tDSMPW ina r Data Strobe VT tDSDCD VSS tRQH tRQ VCCQ VOH DAT[7-0] OUTPUT VOH VALID WINDOW VOL VSS VOL VALID WINDOW Note: VT = 50% of VCCQ, indicates clock reference point for timing measurements. Data Strobe Symbol Min Max Unit Remark lim Parameter tPERIOD 5  ns SR 1.125  V/ns Duty cycle distortion tDSDCD 0.0 0.2 ns Allowable deviation from the input CLK duty cycle distortion(tCKDCD) With respect to VT Includes jitter, phase noise Minimum pulse width tDSMPW 2.0  ns With respect to VT tRQ  0.4 ns With respect to VOH /VOL and HS400 reference load tRQH  0.4 ns With respect to VOH /VOL and HS400 reference load SR 1.125  V/ns With respect to VOH /VOL and HS400 reference load Cycle time data transfer mode Slew rate 200 MHz(max), between rising edges With respect to VT With respect to VOH/VOL and HS400 reference load Output DAT (referenced to Data Strobe) Output skew Output hold skew Pre Slew rate © 2019 Toshiba Memory Corporation 25 January 31st, 2019 THGBMJG7C1LBAIL HS400 Device Command Output Timing tPERIOD VCCQ y The Data Strobe is used to response of any command in HS400 mode. tDSDCD VT tDSMPW tDSMPW ina r Data Strobe tDSDCD VSS tRQ_CMD VCCQ VOH CMD OUTPUT VOL VSS tRQH_CMD VALID WINDOW Note: VT = 50% of VCCQ, indicates clock reference point for timing measurements. Parameter Symbol Min Max Unit tPERIOD 5  ns Data Strobe Cycle time data transfer mode Remark 200 MHz(max), between rising edges With respect to VT 1.125  V/ns Duty cycle distortion tDSDCD 0.0 0.2 ns Allowable deviation from the input CLK duty cycle distortion(tCKDCD) With respect to VT Includes jitter, phase noise Minimum pulse width tDSMPW 2.0  ns With respect to VT tRQ_CMD  0.4 ns With respect to VOH /VOL and HS400 reference load Output hold skew (CMD) tRQH_CMD  0.4 ns With respect to VOH /VOL and HS400 reference load Slew rate SR 1.125  V/ns With respect to VOH /VOL and HS400 reference load lim SR Slew rate With respect to VOH/VOL and HS400 reference load CMD Response (referenced to Data Strobe) Pre Output skew (CMD) © 2019 Toshiba Memory Corporation 26 January 31st, 2019 y THGBMJG7C1LBAIL Driver Measurement Point Z0 = 50 Ohm Td = 350 ps CREFERENCE = 4pF ina r Device I/O Reference Load Figure 3 HS400 Capacitance HS400 reference load The Data Strobe is used to read data in HS400 mode. The Data Strobe is toggled only during data read or CRC status response. Parameter Pull-up resistance for CMD Pull-up resistance for DAT0-7 Pull-down resistance for Data Strobe Internal pull up resistance DAT1-DAT7 Single Device capacitance Symbol Min RCMD Typ. 4.7 RDAT 10 RDS 10 Rint 10 CDEVICE Max Unit 100 Note 1 kΩ 100 Note 1 kΩ 100 Note 1 kΩ 150 kΩ 6 pF Remark Pre lim Note 1: Recommended maximum value is 50 kΩ for 1.8 V interface supply voltages. © 2019 Toshiba Memory Corporation 27 January 31st, 2019 THGBMJG7C1LBAIL Overshoot/Undershoot Specification VCCQ Unit y 1.70V - 1.95V Maximum peak amplitude allowed for overshoot area. (See Figure Overshoot/Undershoot definition) Maximum area above VCCQ (See Figure Overshoot/Undershoot definition) Maximum area below VSSQ (See Figure Overshoot/Undershoot definition) Maximum Amplitude V CCQ Volts (V) VSSQ 0.9 V Max 0.9 V ina r Maximum peak amplitude allowed for undershoot area. (See Figure Overshoot/Undershoot definition) Max Maximum Amplitude Max 1.5 V-ns Max 1.5 V-ns Overshoot Area Undershoot Area Time (ns) Figure 4 lim H/W Reset Operation Overshoot/Undershoot definition CLK *1 RST_n tRSTW tRSCA tRSTH Host can issue boot initiation or CMD1 Pre Device starts a reset sequence at the RST_n rising edge Do not care *1: Device will detect the rising edge of RST_n signal to trigger internal reset sequence. H/W Reset Timings Symbol tRSTW Parameter RST_n pulse width tRSCA RST_n to Command time tRSTH RST_n high period (interval time) Min Max Unit 1  μs 200 Note 1 1  μs  μs Note 1: 74 cycles of clock signal required before issuing CMD1 or CMD0 with argument 0xFFFFFFFA. Note 2: During the device internal initialization sequence right after power on, device may not be able to detect RST_n signal, because the device may not complete loading RST_n_ENABLE bits of the extended CSD register into the controller yet. © 2019 Toshiba Memory Corporation 28 January 31st, 2019 THGBMJG7C1LBAIL Power-up sequence y Supply voltage VCC min VCCQ max VCCQ min 0.5V ina r VCC max time VCCQ Power up time tPRUL VCC Power up time VCCQ Power up time tPRUH tPRUL Figure 5 Power-up parameter Parameter Symbol Min Max Remark tPRUH 5 μs 35 ms - tPRUL 5 μs 25 ms - lim Supply power-up for 3.3V Power up sequence Pre Supply power-up for 1.8V © 2019 Toshiba Memory Corporation 29 January 31st, 2019 THGBMJG7C1LBAIL Functional restrictions y - Pre loading data size is limited to MAX_PRE_LOADING_DATA_SIZE[21-18] regardless of using Production State Awareness function. - MAX_PRE_LOADING_DATA_SIZE[21-18] value will change when host sets Enhanced User area Partition. Reliability Guidance -Write/Erase Endurance ina r This reliability guidance is intended to notify some guidance related to using raw NAND flash. Although random bit errors may occur during use, it does not necessarily mean that a block is bad. Generally, a block should be marked as bad when a program status failure or erase status failure is detected. The other failure modes may be recovered by a block erase. ECC treatment for read data is mandatory due to the following Data Retention and Read Disturb failures. Write/Erase endurance failures may occur in a cell, page, or block, and are detected by doing a status read after either an auto program or auto block erase operation. The cumulative bad block count will increase along with the number of write/erase cycles. lim -Data Retention The data in memory may change after a certain amount of storage time. This is due to charge loss or charge gain. After block erasure and reprogramming, the block may become usable again. Also write/erase endurance deteriorates data retention capability. The figure below shows a generic trend of relationship between write/erase endurance and data retention. -Read Disturb A read operation may disturb the data in memory. The data may change due to charge gain. Usually, bit errors occur on other pages in the block, not the page being read. After a large number of read cycles (between block erases), a tiny charge may build up and can cause a cell to be soft programmed to another state. After block erasure and reprogramming, the block may become usable again. Pre Considering the above failure modes, Toshiba Memory recommends following usage: - Please avoid any excessive iteration of resets and initialization sequences (Device identification mode) as far as possible after power-on, which may result in read disturb failure. The resets include hardware resets and software resets. e.g.1) Iteration of the following command sequence, CMD0 - CMD1 --The assertion of CMD1 implies a count of internal read operation in Raw NAND. CMD0: Reset command, CMD1: Send operation command e.g.2) Iteration of the following commands, CMD30 and/or CMD31 CMD30: Send status of write protection bits, CMD31: Send type of write protection © 2019 Toshiba Memory Corporation 30 January 31st, 2019 THGBMJG7C1LBAIL January 31st, 2019 - Released as preliminary revision Pre lim ina r Rev.0.1 y Document Revision History © 2019 Toshiba Memory Corporation 31 January 31st, 2019 THGBMJG7C1LBAIL RESTRICTIONS ON PRODUCT USE y Toshiba Memory Corporation and its subsidiaries and affiliates are collectively referred to as “TOSHIBA”. Hardware, software and systems described in this document are collectively referred to as “Product”. • TOSHIBA reserves the right to make changes to the information in this document and related Product without notice. • This document and any information herein may not be reproduced without prior written permission from TOSHIBA. Even with TOSHIBA's written permission, reproduction is permissible only if reproduction is without alteration/omission. ina r • Though TOSHIBA works continually to improve Product's quality and reliability, Product can malfunction or fail. Customers are responsible for complying with safety standards and for providing adequate designs and safeguards for their hardware, software and systems which minimize risk and avoid situations in which a malfunction or failure of Product could cause loss of human life, bodily injury or damage to property, including data loss or corruption. Before customers use the Product, create designs including the Product, or incorporate the Product into their own applications, customers must also refer to and comply with (a) the latest versions of all relevant TOSHIBA information, including without limitation, this document, the specifications, the data sheets and application notes for Product and the precautions and conditions set forth in the " Reliability Information” in Toshiba Memory Corporation’s website and (b) the instructions for the application with which the Product will be used with or for. Customers are solely responsible for all aspects of their own product design or applications, including but not limited to (a) determining the appropriateness of the use of this Product in such design or applications; (b) evaluating and determining the applicability of any information contained in this document, or in charts, diagrams, programs, algorithms, sample application circuits, or any other referenced documents; and (c) validating all operating parameters for such designs and applications. TOSHIBA ASSUMES NO LIABILITY FOR CUSTOMERS' PRODUCT DESIGN OR APPLICATIONS. • PRODUCT IS NEITHER INTENDED NOR WARRANTED FOR USE IN EQUIPMENTS OR SYSTEMS THAT REQUIRE EXTRAORDINARILY HIGH LEVELS OF QUALITY AND/OR RELIABILITY, AND/OR A MALFUNCTION OR FAILURE OF WHICH MAY CAUSE LOSS OF HUMAN LIFE, BODILY INJURY, SERIOUS PROPERTY DAMAGE AND/OR SERIOUS PUBLIC IMPACT ("UNINTENDED USE"). Except for specific applications as expressly stated in this document, Unintended Use includes, without limitation, equipment used in nuclear facilities, equipment used in the aerospace industry, lifesaving and/or life supporting medical equipment, equipment used for automobiles, trains, ships and other transportation, traffic signaling equipment, equipment used to control combustions or explosions, safety devices, elevators and escalators, and devices related to power plant. IF YOU USE PRODUCT FOR UNINTENDED USE, TOSHIBA ASSUMES NO LIABILITY FOR PRODUCT. For details, please contact your TOSHIBA sales representative or contact us via our website. • Do not disassemble, analyze, reverse-engineer, alter, modify, translate or copy Product, whether in whole or in part. • Product shall not be used for or incorporated into any products or systems whose manufacture, use, or sale is prohibited under any applicable laws or regulations. lim • The information contained herein is presented only as guidance for Product use. No responsibility is assumed by TOSHIBA for any infringement of patents or any other intellectual property rights of third parties that may result from the use of Product. No license to any intellectual property right is granted by this document, whether express or implied, by estoppel or otherwise. • ABSENT A WRITTEN SIGNED AGREEMENT, EXCEPT AS PROVIDED IN THE RELEVANT TERMS AND CONDITIONS OF SALE FOR PRODUCT, AND TO THE MAXIMUM EXTENT ALLOWABLE BY LAW, TOSHIBA (1) ASSUMES NO LIABILITY WHATSOEVER, INCLUDING WITHOUT LIMITATION, INDIRECT, CONSEQUENTIAL, SPECIAL, OR INCIDENTAL DAMAGES OR LOSS, INCLUDING WITHOUT LIMITATION, LOSS OF PROFITS, LOSS OF OPPORTUNITIES, BUSINESS INTERRUPTION AND LOSS OF DATA, AND (2) DISCLAIMS ANY AND ALL EXPRESS OR IMPLIED WARRANTIES AND CONDITIONS RELATED TO SALE, USE OF PRODUCT, OR INFORMATION, INCLUDING WARRANTIES OR CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, ACCURACY OF INFORMATION, OR NONINFRINGEMENT. • Do not use or otherwise make available Product or related software or technology for any military purposes, including without limitation, for the design, development, use, stockpiling or manufacturing of nuclear, chemical, or biological weapons or missile technology products (mass destruction weapons). Product and related software and technology may be controlled under the applicable export laws and regulations including, without limitation, the Japanese Foreign Exchange and Foreign Trade Law and the U.S. Export Administration Regulations. Export and re-export of Product or related software or technology are strictly prohibited except in compliance with all applicable export laws and regulations. Pre • Please contact your TOSHIBA sales representative for details as to environmental matters such as the RoHS compatibility of Product. Please use Product in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. TOSHIBA ASSUMES NO LIABILITY FOR DAMAGES OR LOSSES OCCURRING AS A RESULT OF NONCOMPLIANCE WITH APPLICABLE LAWS AND REGULATIONS. © 2019 Toshiba Memory Corporation 32 January 31st, 2019
THGBMJG7C1LBAIL 价格&库存
很抱歉,暂时无法提供与“THGBMJG7C1LBAIL”相匹配的价格&库存,您可以联系我们找货
THGBMJG7C1LBAIL
  • 152+93.75953152+12.16092
