5KP40CA
5KP40CA
    BORN(伯恩半导体)
    AXIAL_8.6X8.6MM_TM
    5KP40CA
5KP40CA 数据手册
5KP Series Transient Voltage Suppressors 5KPxxA(CA) ROHS DESCRIPTION: The 5KP series of high current uni/bi-directional transient suppressors are designed for A.C. line protection and high power DC bus clamping applications. These devices offer uni/bi-directional port protection from 5.0 volts to 250 volts. They provide a clamping voltage lower than the avalanche voltage. Therefore, any voltage rise due to increased current conduction is contained to a minimum, providing the best possible protection level. They can also be connected in series and/or parallel to create very high capacity protection solutions. FEATURES:     Low zener impedance. Excellent clamping capability. JEDEC R-6/P-600 Molded Plastic. Repetition rate (duty cycle): 0.01%. Symbol  Color band denoted cathode except bidirectional.  High temperature soldering: 260℃/10s at terminals.  Glass passivated chip junction in R-6/P600 package.  5000W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Peak pulse power dissipation on 10/1000μs waveform Peak pulse current of on 10/1000μs waveform Steady state power dissipation at TL=75℃ Operating junction and Storage temperature range Peak forward surge current, 8.3ms single half sine-wave 1/5 Symbol Value Unit PPP 5000 W IPP See next table A PM(AV) 8 W TSTG, TJ -55 to +150 ℃ IFSM 400 A 5KP Series Transient Voltage Suppressors 5KPxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A 5KP5.0A 5KP5.0CA 5.0 150 6.40 7.00 10 9.2 544.0 5KP6.0A 5KP6.0CA 6.0 100 6.67 7.37 10 10.3 486.0 5KP6.5A 5KP6.5CA 6.5 50 7.22 7.98 10 11.2 448.0 5KP7.0A 5KP7.0CA 7.0 20 7.78 8.60 10 12.0 417.0 5KP7.5A 5KP7.5CA 7.5 10 8.33 9.21 1 12.9 388.0 5KP8.0A 5KP8.0CA 8.0 10 8.89 9.83 1 13.6 367.0 5KP8.5A 5KP8.5CA 8.5 10 9.44 10.40 1 14.4 347.0 5KP9.0A 5KP9.0CA 9.0 10 10.00 11.10 1 15.4 325.0 5KP10A 5KP10CA 10.0 5 11.10 12.30 1 17.0 294.0 5KP11A 5KP11CA 11.0 5 12.20 13.50 1 18.2 275.0 5KP12A 5KP12CA 12.0 2 13.30 14.70 1 19.9 252.0 5KP13A 5KP13CA 13.0 2 14.40 15.90 1 21.5 233.0 5KP14A 5KP14CA 14.0 1 15.60 17.20 1 23.2 216.0 5KP15A 5KP15CA 15.0 1 16.70 18.50 1 24.4 205.0 5KP16A 5KP16CA 16.0 1 17.80 19.70 1 26.0 193.0 5KP17A 5KP17CA 17.0 1 18.90 20.90 1 27.6 181.0 5KP18A 5KP18CA 18.0 1 20.00 22.10 1 29.2 172.0 5KP20A 5KP20CA 20.0 1 22.20 24.50 1 32.4 155.0 5KP22A 5KP22CA 22.0 1 24.40 26.90 1 35.5 141.0 5KP24A 5KP24CA 24.0 1 26.70 29.50 1 38.9 129.0 5KP26A 5KP26CA 26.0 1 28.90 31.90 1 42.1 119.0 5KP28A 5KP28CA 28.0 1 31.10 34.40 1 45.4 110.0 5KP30A 5KP30CA 30.0 1 33.30 36.80 1 48.4 103.0 5KP33A 5KP33CA 33.0 1 36.70 40.60 1 53.3 93.9 5KP36A 5KP36CA 36.0 1 40.00 44.20 1 58.1 86.1 5KP40A 5KP40CA 40.0 1 44.40 49.10 1 64.5 77.6 5KP43A 5KP43CA 43.0 1 47.80 52.80 1 69.4 72.1 5KP45A 5KP45CA 45.0 1 50.00 55.30 1 72.7 68.8 5KP48A 5KP48CA 48.0 1 53.30 58.90 1 77.4 64.7 5KP51A 5KP51CA 51.0 1 56.70 62.70 1 82.4 60.7 2/5 5KP Series Transient Voltage Suppressors 5KPxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A 5KP54A 5KP54CA 54.0 1 60.00 66.30 1 87.1 57.5 5KP58A 5KP58CA 58.0 1 64.40 71.20 1 93.6 53.5 5KP60A 5KP60CA 60.0 1 66.70 73.70 1 96.8 51.7 5KP64A 5KP64CA 64.0 1 71.10 78.60 1 103.0 48.6 5KP70A 5KP70CA 70.0 1 77.80 86.00 1 113.0 44.3 5KP75A 5KP75CA 75.0 1 83.30 92.10 1 121.0 41.4 5KP78A 5KP78CA 78.0 1 86.70 95.80 1 126.0 39.7 5KP85A 5KP85CA 85.0 1 94.40 104.0 1 137.0 36.5 5KP90A 5KP90CA 90.0 1 100.0 111.0 1 146.0 34.3 5KP100A 5KP100CA 100.0 1 111.0 123.0 1 162.0 30.9 5KP110A 5KP110CA 110.0 1 122.0 135.0 1 177.0 28.3 5KP120A 5KP120CA 120.0 1 133.0 147.0 1 193.0 26.0 5KP130A 5KP130CA 130.0 1 144.0 159.0 1 209.0 24.0 5KP150A 5KP150CA 150.0 1 167.0 185.0 1 243.0 20.6 5KP160A 5KP160CA 160.0 1 178.0 197.0 1 259.0 19.3 5KP170A 5KP170CA 170.0 1 189.0 209.0 1 275.0 18.2 5KP180A 5KP180CA 180.0 1 200.0 221.0 1 292.0 17.5 5KP190A 5KP190CA 190.0 1 211.0 233.0 1 310.0 16.5 5KP200A 5KP200CA 200.0 1 224.0 247.0 1 329.2 15.5 5KP210A 5KP210CA 210.0 1 237.0 263.0 1 349.5 14.6 5KP220A 5KP220CA 220.0 1 246.0 272.0 1 371.1 13.7 5KP250A 5KP250CA 250.0 1 277.0 306.0 1 425.0 12.0 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current 3/5 5KP Series Transient Voltage Suppressors 5KPxxA(CA) ROHS RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP VC VBR VR IT IR VC VBR VR V V IR IT VF IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 VR VBR VC 80 Peak value 60 Half value 40 50 20 td 0 0 t(ms) 1.0 2.0 3.0 4.0 0 0 25 50 TA(℃) 75 100 125 150 175 SOLDERING PARAMETERS Reflow Condition -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ tp 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ 4/5 TP Critical Zone TL to TP Ramp-up -Time (Min to Max) (ts) Reflow FIG.5: Reflow condition TL tL TS(max) Temperature Pre Heat Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) ts 25 time to peak temperatue (t 25℃ to peak) Time 5KP Series Transient Voltage Suppressors 5KPxxA(CA) ROHS MARKING & ORDERING INFORMATION 5KP XX C A (1) (2) (3) (4) (1)Series:5000 watts series (2)Reverse Stand-off Voltage (3)Bi-directional (4)5% VBR Voltage tolerance Cathode Band 5KPxxxCA Product Type PACKAGE MECHANICAL DATA Dimensions A B Ref. A C D Min. 5/5 Millimeters Inches Max. Min. Max. 25.40 - 0.370 8.60 9.40 0.048 0.052 1.20 1.40 0.340 0.360 8.60 9.10 A 1.000 B 0.339 C D -
5KP40CA 价格&库存
很抱歉,暂时无法提供与“5KP40CA”相匹配的价格&库存,您可以联系我们找货
