KAN0641-0431B-L
KAN0641-0431B-L
    GANGYUAN(港源)
    SMD
    KAN0641-0431B-L
KAN0641-0431B-L 数据手册
ISO14001: 2004 ISO9001: 2008 PRODUCT 产品名称: ITEM: 产品型号: TYPE: SPECIFICATION 轻 触 开 关 TACT SWITCH KAN0641-系列 制 订: DRAWN: 刘叶泉 审 批: APPD: 徐晓丽 发布日期: DATE: 2013. 9.20 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A A.Specification & meanings The name of the tact switch is composed by type and specification,the particular meaning of the type、specification and code is as follows. KAN0641- Press force(refer to chart 3) Stem color(refer to chart 2) Product height(refer to chart 1) 1、 Product height: It is denoted by three figures; For examples,“075”expresses the product which the total height is 7.5mm,as chart 1 shows: Code Product height 043 4.3 050 5 060 6 07 7 073 7.3 080 8 Code 090 095 Product height 9 9.5 2、Stem color: It is expressed by a figure, as chart 2 shows: Black 1 Color Code Red 2 White 3 Blue 4 Yellow 5 Green 6 Gray 7 Grayish 8 3、Operating force: An English letter expresses it, unite: Newton (N),as chart 3 shows: Operating force Code Press force Return force Spec A B C 1.0 1.6 2.6 1.0±0.3 1.6±0.5 2.6±0.5 0.2min 0.4min 0.6min Examples: “KAN0641N-0316B” denotes the tact switch with 6×6 base,Contact post is cover,the height is 3.1mm,the stem is Green , the operating force is 1.6N. APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 1 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 1、 概述 GENERAL 1.2 适用范围 APPLICATION 此规格书适用于机械式轻触开关的相关要求 This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT) 1.3 工作温度范围 Operating Temperature Range -20℃~70℃(在标准大气压、标准湿度条件下) -20℃~70℃(Normal humidity, normal air pressure) 1.4 贮藏温度范围 Storage Temperature Range -30℃~80℃(在标准大气压、标准湿度条件下) -30℃~80℃(Normal humidity, normal air pressure) 1.5 测试条件 Test Conditions 在没有其它特定的条件下,应该在以下的条件下进行测试和测量: Unless otherwise specified, tests and measurement shall be made in the following standard conditions: 常温…………………………………5℃~35℃ Normal temperature………………5℃~35℃ 标准湿度……………………………相对湿度 25%~85% Normal humidity…………………relative humidity 25%~85% 标准大气压…………………………86KPa~106Kpa Normal air pressure…………………86Kpa~106Kpa 在制造过程中,测试和测量应该在以下的条件下进行: If any doubt arise from the judgment, tests shall be conducted at the following conditions: 温度…………………………………20℃±2℃ Temperature………………………20℃±2℃ 相对湿度……………………………65%±5% Relative humidity………………65%±5% 环境气压…………………………86KPa~106Kpa Air pressure…………………………86KPa~106Kpa APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 2 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 2、 详细说明 Detailed specification 2.1 外观:应无影响、降低产品性能的缺陷; Appearance: There should be no defects that affect the serviceability of product. 2.2 结构尺寸和安装尺寸:应符合装配图要求; Style and dimension: shall conform to the assemble drawings. 2.3 操作形式:有触觉反应的操作 Type of actuating: Tactile feedback. 2.4 开关结构:单回路单输出(具体的触点结构在装配图中已绘出); Contact arrangement: 1 pole, 1 throw (Details of contact arrangement are given in the assembly drawings.) 2.5 开关工作额定值:DC 12V,50mA(有效值) Ratings: 12V DC, 50mA (effective value) 3.电气性能: ELECTRICAL SPECIFICATION 项 目 ITEM 1 接触电阻 Contact Resistance 2 绝缘电阻 Insulation Resistance 3 介质耐压 Dielectric voltage proof APPROVE BY 试 验 条 件 要求 TEST CONDITIONS REQUIREMENTS 在以 5V 10mA 的直流电源或不低于 1KHz 的 交流电源的电路中,以一个等于 2 倍按力的静负荷 施加于手柄中心 Applying a static load of 2 times operating ≤100mΩ force to the center of the stem, measurements shall be made by 5V DC 10mA or more than 1KHZ AC small-current contact resistance meter. 在端子之间施加 DC 100V /1min 的条件下,测 量端子之间底座、盖板的电阻值 Measurement shall be made following ≥100MΩ application of 100V DC potential, across terminals, and across terminals and cover, for one minute. 无击穿、无飞弧 在端子之间施加 250V AC(50HZ 或 60HZ)/1min There should 250V AV (50HZ or 60HZ) shall be applied be no breakdown across terminals, for one minute. and flashover 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 3 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 项目 ITEM 触点弹力 Bounce GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 试 验 条 件 TEST CONDITIONS 要求 REQUIREMENTS 按照正常使用时的力度轻按手柄中心(每秒 3~4 次), 在导通和断开过程中测试开关弹力 Lightly striking the center of the stem at a rate encountered in normal use (3 to 4 times per second), and bounce shall be tested at “ON” and “OFF” 开关 Switch 4 10V DC 10KΩ “导通” “ ON” ON-3msec.max OFF-8msec.max 示波器 Oscillograph “ 断开” “OFF” 4.机械性能: MECHANICAL SPECIFICATION 1 按力 Operating Force APPROVE BY 开关垂直于操作方向放置,在开关驱动件顶端中心逐渐施 力,测量开关导通所需的最大力度。 Placing the switch such that the direction of switch operation is vertical and then gradually increasing the load applied to the center of the stem, the maximum load required for the switch to come to a stop shall be measured. 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY refer to chart 3 胡海燕 2013.9.18 Page 4 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 项目 ITEM PRODUCT REVISION KAN0641 TACT SWITCH A 试 验 条 件 TEST CONDITIONS 最大行程 Full Travel 要求 REQUIREMENTS 开关垂直于操作方向放置,以一个等于 2 倍按力的静负荷 施加在开关驱动件顶端中心,测量顶端移动的距离。 Placing the switch such that the direction of switch operation is vertical and then applying static load of 2times operating force to the center of the stem; the travel distance for the switch to come to a stop shall be measured. 2 0.25±0.1mm 开关垂直于操作方向放置,在开关驱动件顶端中心下降至 全行程后,测量顶端向自由位置转换的力度。 The sample switch is installed such that the direction of switch operation is vertical and upon depressing the stem in its center to the whole travel distance, the force of the stem to return to its free position shall be measured. 3 回弹力 Return Force 4 停止强度 Stop Strength 5 手柄拔出 强度 Stem Strength 6 耐焊接热 Soldering heat resistance APPROVE BY GYE’S P/N 开关垂直于操作方向放置,从操作方向向驱动件施加 30N 的静负荷持续 1min。 Placing the switch such that the direction of switch operation is vertical, and then a static load of 30N shall be applied in the direction of stem operation for a period of 1 min. refer to chart 3 无机械和电气损坏 There shall be no sign of damage mechanically and electrically. 开关垂直于操作方向放置,反方向实施最大操作力,并测 量手柄的行程范围。 Placing the switch such that the direction of switch operation is vertical, and then the maximum force to withstand a pull applied opposite to the direction of stem operation shall be measured. 样品应放在常温及标准湿度的环境中 1 小时后,根据下面 的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurement are made: 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 20N.min. 无机械和电气损坏 PRPARE BY 胡海燕 2013.9.18 Page 5 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER 6 7 CUSTOMER’S P/N 项目 ITEM 耐焊接热 Soldering heat resistance 可焊性 Solderability GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 试 验 条 件 TEST CONDITIONS (1) 要求 REQUIREMENTS 温度和浸焊时间: 260±5℃,5s±1s Temperature and Immersion time: 260±5℃, 5s±1s There shall be no sign of damage mechanically and electrically. 在以下设定条件下进行测量: Measurements shall be made following the test set forth below: (1) 焊接温度:255±5℃ Solder temperature : 255±5℃ (2) 浸入时间:2s±0.5s Immersion time: 2s±0.5s 对于其它步骤参考《GB 5095.6—86》试验 12a The other steps please refer to《GB 5095.6-86》 TEST 12a 除边缘外涂层应均匀覆 盖 90%以上 Except for the edge, the coating should cover a minimum 90% 5、极限电气性能: ENVIRONMENTAL SPECIFICATION 1 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be 低温测试 left in normal temperature and humidity conditions for Resistance to 1 h before measurements are made: low (1) 温度:—30±2℃ temperature Temperature :-30±2℃ (2) 时间:96h Time: 96h APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 PRPARE BY 胡海燕 2013.9.18 Page 6 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER 项目 ITEM 高温测试 Heat resistance 2 3 CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 试 验 条 件 TEST CONDITIONS 要求 REQUIREMENTS 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:80±2℃ temperature:80±2℃ (2) 时间:96h time: 96h 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 1cycle 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行 5 次循环的温度周期性测试: 测试期间样品应保持干燥 After 5 cycles of following conditions, the sample shall be allowed to stand under normal temperature and humidity conditions for 1 h. and measurements shall 接触电阻:≤200mΩ resistance: 温度周期性测试 be made. During the test waterdrops shall be Contact removed. ≤200mΩ Change of temperature 项目 3,4.1,4.2,4.3 Temperature Time Item 3,4.1,4.2,4.3 -10±2℃ 2(hour) APPROVE BY 徐晓丽 2013.9.20 -10~65℃ 1 65±2℃ 2 65~-10℃ 1 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 7 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 项目 ITEM GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 试 验 条 件 TEST CONDITIONS 要求 REQUIREMENTS 4 湿温测试 Moisture resistance 5 6 硫化试验 Sulfuration resistance 盐雾试验 Salt Mist APPROVE BY 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:60±2℃ temperature: 60±2℃ (2) 相对湿度:90%~95% relative humidity:90% to 95% (3) 时间:96h time: 96h 样品应放在常温及标准湿度的环境中 1 小时并重复 2~ 3 次后,根据下面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for1 h1 and repeat two to three times before measurements are made: (1) H2S 气体浓度:3ppm±1ppm H2S gas concentration: 3ppm±1ppm (2) 时间:72h Time: 72h (3) 温度:40±2℃(90~95%RH) temperature: 40±2℃(90~95%RH) 在以下设定条件下进行测量: The switch shall be checked after following test: (1)温度:35℃±2℃ temperature: 35℃±2℃ (2)盐溶液浓度:5±1%(质量百分比) salt solution : 5±1%(solids by mass) (3)时间:8h±1h Time: 8h±1 hour 实 验 后 的 盐 沉 积 物 后 水 冲 掉 After test,salt deposit shall be removed by running water. 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 金属件上没有腐蚀斑点 No remarkable corrosion shall be recognized in metal part. PRPARE BY 胡海燕 2013.9.18 Page 8 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 6、极限机械性能: ENDURANCE SPECIFICATION 项目 ITEM 工作寿命 Operation life 1 REVISION KAN0641 TACT SWITCH A 要求 REQUIREMENTS 根据下面的测试要求进行测试: Measurement shall be made following the test set forth below: (1)DC 12V,50mA 带负载 DC 12V, 50 mA resistive load (2) 按动速率:2~3 次/秒 Rate of operation: 2 to 3 times/s (3) 按力:按力的 1.5~2 倍 (4) Operating Force: Operating Force1.5~2 倍 (5) 平均无故障寿命:Average fault-free life: B C 振动 Vibration PRODUCT 试 验 条 件 TEST CONDITIONS A 2 GYE’S P/N 1.0 1.6 2.6 100000 次 80000 次 60000 次 接 触 电 阻 ≤200mΩContact resistance≤200mΩ 触点弹力≤10ms Contact bounce≤10ms 按 力 : 初 值 的 ±30% Operating Force: initial value±30% 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 根据以下给定条件进行测试: Measurement shall be made following the test set forth below: (1) 振动频率范围:10~55~10Hz Vibration frequency range: 10 to 55 to 10Hz (2) 振幅(峰-峰):1.5mm 项目 3,4.1,4.2,4.3 Amplitude: 1.5mm Item 3,4.1,4.2,4.3 (3) 振动方向:包括手柄行程方向在内的三个相互垂 直的方向 Direction of vibration:Three mutually perpendicular direction including the direction of stem travel (4) 测试时间:每次 2hours . Duration: Each 2hours. 7.焊接条件: SOLDERING CONDITIONS: 请按以下条件进行焊接: (1) 焊锡温度:≤350℃ 手工焊接 (2) 连续焊接时间:≤3 s 7.1 Hand soldering Please practice according to below conditions: (1) Soldering temperature: 350℃ Max. (2) Continuous soldering time: 3 s Max. APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 9 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 推 荐 条 件 Recommended conditions 项目 ITEM 回流焊时 Conditions for reflow 7.2 说明: 1.1 开关浸焊后,注意不要用溶剂清洗。 After switches were soldered,please be careful not to clean switches with solvent. 1.2 在使用烙铁的情况下,焊锡温度应在 380℃以下、3 秒以内。 In the case of using solding iron, solding conditions shall be 380℃ max and 3 sec.max. 1.3 浸焊后,注意不要在顶部施加负荷。 Right after switches were soidered;please be careful not to load to on the knobs of switches. 2 设计中应注意的事项( Design instructions): 2.1 印刷基板的安装孔尺寸参见产品图。 Follow recommended P.W.B. piercing plan in outside drawing page. 3 注意点(Note): 3.1 注意不要施加超负荷的压力或晃动开关 Please be cautions not to give excessive static load or shock to swiches. 3.2 开关浸焊后,印刷基板注意不要叠放。 Please be careful not to pile up P.W.B.after switches were soldered 3.3 保管时尤其应注意避开高湿高温和有腐蚀性气体的环境。如需要长时间保存,请不要打开包装箱。 Preservation under high temperature and high high humidity or corrosive gas should be avoided Especially . When you need to preserve for a long period ,do not open the carton . APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 10 of 11 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0641 TACT SWITCH A 电路图 General tolerance:±0.1mm NO. NAME MATERIAL NATIONALITY QTY. FINISHING 1 TERMINAL Brass China 1 Silver plating 2 CASE PPA China 1 brown/Black 3 CONTACT F.Ag/Cu Japan 1 Contact side silver plating 4 COVER SPCC China 1 CuSn plating 5 STEM PPA Japan 1 Customer Demand APPROVE BY 徐晓丽 2013.9.20 CHECKED BY 刘叶泉 2013.9.20 PRPARE BY 胡海燕 2013.9.18 Page 11 of 11
KAN0641-0431B-L 价格&库存
很抱歉,暂时无法提供与“KAN0641-0431B-L”相匹配的价格&库存,您可以联系我们找货
KAN0641-0431B-L
    • 10+0.29376
    • 100+0.23156
    • 300+0.20045
    • 1000+0.17712
    库存:958
