B20B-PUDSS-1
B20B-PUDSS-1
    JST
    插件,P=2mm
    线对板针座 2x10P 直插 间距:2mm
B20B-PUDSS-1 数据手册
PUD CONNECTOR 2.0 mm pitch/Disconnectable Crimp style connectors ● ● ● ● PUD CONNECTOR High reliability contact Superior operability Secure locking structure Polarizing key for mounting on PC board Specifications This is a board-to-wire connector with secure locking device that has been designed to 2.0 mm pitch, crimping style and double-row. In spite of realizing low insertion force, the stable electric connection is demonstrated against the condition such as vibration, pinching and dry circuit. It is possible to unfasten the locking even if the header is surrounded with a case wall within height of header because the tip of locking device in receptacle does not protrude from its area. ® • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/ DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: C  onductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® Recognized E60389 Certified LR20812 ® ® PC board layout and Assembly layout Side entry type (2) 8.3 φ1.6 +0.1 0 φ1.3 (14.1) 8.5 0.9 ±0.05 Circuit No.1 A ±0.05 2 ±0.05 2 ±0.05 Odd number circuits +0.1 0 +0.1 0 Connector outline φ0.7 2 +0.1 0 Even number circuits Odd number circuits Circuit No.1 7.7 ±0.05 Even number circuits (11) 3.4±0.05 φ0.7 (0.4) 2±0.05 1.2±0.05 2±0.05 (2.4) A±0.05 114_pud_z01 Connector outline (2.4) Top entry type (0.4) ® 2 10.1 (2) Note: 1 .T  he above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. H  ole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. SMT type (0.8) Odd number circuits Odd numberConnector circuits outline Circuit No.1 nnector outline Circuit No.1 1 min. 1 min. 8.8 (1.6) (12.3) (1.6) (12.3) 8.8 3 min. 5.7 ±0.1 3 min. 2 Even number circuits 1 min. 2 ±0.05 1 min. 3 min. 5.7 ±0.1 3 min. Even number circuits A ±0.05 ±0.05 (0.8) A ±0.05 Note: 1 .T  he above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 8.3 B A B A 2.0 1番極表示 PUD CONNECTOR 9.1 8.3 9.1 1番極表示 B A SPUD-001T-P0.5 SPUD-002T-P0.5 2.85 1番極表示 mm2 AWG # Insulation O.D. (mm) 0.13~0.33 26~22 0.95~1.5 0.08~0.22 28~24 0.76~1.5 Q't y/ reel 8,000 PUD CONNECTOR Material and Finish 1.35 Copper alloy, tin-plated (reflow treatment) 1.45 8.3 2.0 2.0 Applicable wire Model No. 7.5 8.3 9.1 Contact B A 2.0 1番極表示 RoHS2 compliance Contact 9.1 1.65 Crimping machine Crimp applicator SPUD-001T-P0.5 AP-K2N SPUD-002T-P0.5 MKS-L Applicator Dies Crimp applicator with dies MK/SPUD-002-05 APLMK SPUD002-05 MK/SPUD-001-05 APLMK SPUD001-05 Note: Contact JST for fully automatic crimping applicator. Housing B A 2 B A 8.3 Circuit No.1 mark 8.3 Circuit No.1 mark 2 9.1 9.1 8.3 2.0 1番極表示 8.3 B A Circuit No.1 mark 2 8.3 Circuit No.1 mark 2 9.1 B A 9.1 9.1 B A No. of circuits 8 10 B A 12 8.3 14 16 Circuit No.1 mark 2 18 20 22 9.1 ハウジング/12~18極/6 24 26 28 30 32 /20~30極/7 B A ハウジング/20~30極/7 8.3 2 Circuit No.1 mark 36 38 40 PUDP-08V-S PUDP-10V-S PUDP-12V-S PUDP-14V-S PUDP-16V-S PUDP-18V-S PUDP-20V-S 114_pud_z02 PUDP-22V-S PUDP-24V-S PUDP-26V-S PUDP-28V-S PUDP-30V-S PUDP-32V-S PUDP-34V-S PUDP-36V-S PUDP-38V-S PUDP-40V-S Dimensions (mm) A B Q'ty/ bag 6.0 10.0 1,000 8.0 12.0 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 1,000 22.0 26.0 1,000 24.0 28.0 1,000 26.0 30.0 500 28.0 32.0 500 30.0 34.0 500 32.0 36.0 500 34.0 38.0 500 36.0 40.0 500 38.0 42.0 500 Material and Finish 9.1 極/5 34 Model No. PBT, UL94V-0, natural 114_pud_z03 RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PUDP-08V-S S...natural Z...ivory E...blue R...red K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue 114_pud_z05 2 PUD CONNECTOR Through-hole type shrouded header Top entry type No. of circuits 8 8.3 B A 10 12 9.6 14 16 0.8 18 3.1 20 2 Circuit No.1 3.4 22 2 24 26 28 8.3 B A 30 32 34 9.6 36 0.8 38 3.1 40 Model No. Top entry type Without boss With boss B08B-PUDSS B08B-PUDSS-1 B10B-PUDSS B10B-PUDSS-1 B12B-PUDSS B12B-PUDSS-1 B14B-PUDSS B14B-PUDSS-1 B16B-PUDSS B16B-PUDSS-1 B18B-PUDSS B18B-PUDSS-1 B20B-PUDSS B20B-PUDSS-1 B22B-PUDSS B22B-PUDSS-1 B24B-PUDSS B24B-PUDSS-1 B26B-PUDSS B26B-PUDSS-1 B28B-PUDSS B28B-PUDSS-1 B30B-PUDSS B30B-PUDSS-1 B32B-PUDSS B32B-PUDSS-1 B34B-PUDSS B34B-PUDSS-1 B36B-PUDSS B36B-PUDSS-1 B38B-PUDSS B38B-PUDSS-1 B40B-PUDSS B40B-PUDSS-1 Circuit No.1 2 3.4 9.6 0.8 3.1 ex. 3.4 2 Side entry type 2 12.7 7.7 10.1 0.8 Circuit No.1 2 3 B A 0.8 2 12.7 7.7 10.1 8.5 Circuit No.1 2 3 0.8 2 12.7 7.7 10.1 8.5 B A 2 3 Circuit No.1 3,300 12.0 2,750 10.0 14.0 2,310 12.0 16.0 1,980 14.0 18.0 1,760 16.0 20.0 1,650 18.0 22.0 1,430 20.0 24.0 1,320 22.0 26.0 1,210 24.0 28.0 1,100 26.0 30.0 1,100 28.0 32.0 990 30.0 34.0 880 32.0 36.0 880 34.0 38.0 770 36.0 40.0 770 38.0 42.0 770 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 8.5 10.0 8.0 RoHS2 compliance This product displays (LF)(SN) on a label. Note: Color indication was changed. Berofe change; S...natural (ivory) , After change; S...natural 8.3 B A 6.0 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural 2 Dimensions Q'ty/ (mm) box A B Material and Finish 2 B A Side entry type With boss S08B-PUDSS-1 S10B-PUDSS-1 S12B-PUDSS-1 S14B-PUDSS-1 S16B-PUDSS-1 S18B-PUDSS-1 S20B-PUDSS-1 S22B-PUDSS-1 S24B-PUDSS-1 S26B-PUDSS-1 S28B-PUDSS-1 S30B-PUDSS-1 S32B-PUDSS-1 S34B-PUDSS-1 S36B-PUDSS-1 S38B-PUDSS-1 S40B-PUDSS-1 3 B08B-PUDSS-1S...natural Z...ivory E...blue R...red K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue PUD CONNECTOR B A BB 2 AA 22 8.8 8.8 8.8 SMT type shrouded header B BA A2 2 10極 10 8.8 12 8.8 14 Circuit No.1 CircuitNo.1 No.1 Circuit 16 18 10.8 10.8 10極 No. of circuits 10.8 10.8 10.8 10極 10極 10極 B 12・18極 12・18極 12・18極 2 24 22 2 A 28 30 32 34 10.8 10.8 10.8 BA 26 8.8 8.8 8.8 Circuit No.1 B 2 36 8.8 38 8.8 40 Circuit No.1 CircuitNo.1 No.1 Circuit ex. 2 22 20・24極 10.8 10.8 10.8 BA 2 A 2 400 16.0 400 12.0 18.0 400 14.0 20.0 400 16.0 22.0 400 18.0 24.0 400 20.0 26.0 400 22.0 28.0 400 24.0 30.0 400 26.0 32.0 400 28.0 34.0 400 30.0 36.0 400 32.0 38.0 400 34.0 40.0 400 36.0 42.0 400 38.0 44.0 400 BM-10B-PUDSS-TFCS...natural Z...ivory K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue 8.8 8.8 8.8 B 20・24極 14.0 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. B A BB AA 8.0 10.0 RoHS2 compliance This product displays (LF)(SN) on a label. Circuit No.1 20・24極 20・24極 20・24極 Q'ty/ reel Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Circuit No.1 BM10B-PUDSS -TFC BM12B-PUDSS -TFC BM14B-PUDSS -TFC BM16B-PUDSS -TFC BM18B-PUDSS -TFC BM20B-PUDSS -TFC BM22B-PUDSS -TFC BM24B-PUDSS -TFC BM26B-PUDSS -TFC BM28B-PUDSS -TFC BM30B-PUDSS -TFC BM32B-PUDSS -TFC BM34B-PUDSS -TFC BM36B-PUDSS -TFC BM38B-PUDSS -TFC BM40B-PUDSS -TFC Dimensions (mm) A B Material and Finish 10.8 10.8 12・18極 22 Circuit No.1 A BB AA 12・18極 20 Model No. 8.8 8.8 10.8 10.8 Circuit No.1 CircuitNo.1 No.1 Circuit B A BB AA Circuit No.1 2 22 2 2 8.8 8.8 10.8 10.8 Circuit No.1 CircuitNo.1 No.1 Circuit Circuit No.1 B Circuit No.1 B AB AA 2 8.8 8.8 8.8 22 B BA A 2 2 10.8 10.8 10.8 26・28極 10.8 10.8 10.8 B BA A 26・28極 8.8 8.8 8.8 Circuit No.1 8.8 8.8 Circuit No.1 CircuitNo.1 No.1 Circuit 10.8 10.8 26・28極 26・28極 26・28極 Circuit No.1 Circuit No.1 4
B20B-PUDSS-1 价格&库存
很抱歉,暂时无法提供与“B20B-PUDSS-1”相匹配的价格&库存,您可以联系我们找货
B20B-PUDSS-1
    • 1430+2.05459
    库存:1430
