MBR20100GCT
MBR20100GCT
    PINGWEI(平伟)
    TO252
MBR20100GCT 数据手册
MBR20100GCT&MBR20100DCT MBR20100GCT&MBR20100DCT 20.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-252 MBR20100GCT TO-251 MBR20100DCT MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol MBR20100GCT&MBR20100DCT Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 100 V 70 V 100 V Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current Per Leg Total device at TC =100°C Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Operation Junction Temperature and Storage Temperature A 20.0 IFSM 150.0 A CJ TJ, TSTG 300 pF -55 to +150 °C Per Leg Typical Junction Capacitance (Note 1) 10.0 IF(AV) ELECTRICAL CHARACTERISTICS - (Per Leg) (TC=25℃ unless otherwise noted) Parameter Symbol Test conditions TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current IR TJ=25℃ TJ=125℃ IF=5A IF=10A IF=5A IF=10A VR=100V VR=100V Typ Max 0.70 ---- 0.77 0.85 0.59 ---- 0.66 0.78 ---- 0.1 ---- 10 Units V mA THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol MBR20100GCT MBR20100DCT Units Typical Thermal Resistance (Note 2) R(JC) 6.5 6.5 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 MBR20100GCT&MBR20100DCT RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 10.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 200 TJ=125℃ 10 TJ=25℃ 1 0.1 CASE TEMPERTURE,(℃) 0.2 0.6 0.4 0.8 INSTANEOUS FORWARD VOLTAGE,(V) 1.0 FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 150 8.3ms Single Half Sine-Wave (JEDEC Method) INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 100 100 50 0 1 10 100 NUMBER OF CYCLES AT 60Hz 2 10 1 TJ=125℃ 0.1 0.01 TJ=25℃ 0.001 0 20 40 60 80 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) 100 MBR20100GCT&MBR20100DCT PACKAGE OUTLINE DIMENSIONS TO-252 L B C I 2 N A B C H D A E F 3 PIN 1 G D H J E G F Dim M K I J K a L P P M N a TO-252 Min Max .230(5.85) .246(6.25) .250(6.35) .264(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .106(2.70) .138(3.50) .028(0.72) .033(0.84) .024(0.60) .041(1.05) .028(0.72) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) .081(2.05) .094(2.40) .000(0.00) .006(0.15) -.008(0.20) 0° 10° Dimensions in inches and (millimeters) TO-251 L B C N Dim I A B H PIN 1 2 C D A E 3 F D H J I E J F K P K L N P TO-251 Min Max .230(5.85) .246(6.25) .250(6.35) .266(6.75) .207(5.27) .218(5.54) .037(0.93) .045(1.14) .173(4.40) .205(5.20) .028(0.72) .033(0.84) .028(0.70) .043(1.10) .085(2.15) .096(2.45) .037(0.95) .047(1.20) .018(0.45) .026(0.65) .018(0.45) .024(0.60) -.008(0.20) .081(2.05) .094(2.40) Dimensions in inches and (millimeters) 3
MBR20100GCT 价格&库存
很抱歉,暂时无法提供与“MBR20100GCT”相匹配的价格&库存,您可以联系我们找货
