BC516
BC516
    ST(先科)
    TO92-3
    达林顿三极管 PNP Vceo=30V Ic=500mA PD=500mW
BC516 数据手册
BC516 PNP Silicon Darlington Transistor Collector Base Emitter 1. Collector 2. Base 3. Emitter TO-92 Plastic Package Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage -VCBO 40 V Collector Emitter Voltage -VCEO 30 V Emitter Base Voltage -VEBO 10 V Collector Current (DC) -IC 500 mA Peak Collector Current -ICM 800 mA Total Power Dissipation Ptot 500 mW Junction Temperature Tj 150 O Storage Temperature Range TS - 55 to + 150 O C C Characteristics at Ta = 25 OC Parameter DC Current Gain at -VCE = 2 V, -IC = 20 mA Collector Base Cutoff Current at -VCB = 30 V Emitter Base Cutoff Current at -VEB = 10 V Collector Base Breakdown Voltage at -IC = 100 µA Collector Emitter Breakdown Voltage at -IC = 1 mA Emitter Base Breakdown Voltage at -IE = 10 µA Collector Emitter Saturation Voltage at -IC = 100 mA, -IB = 0.1 mA Base Emitter Saturation Voltage at -IC = 100 mA, -IB = 0.1 mA Base Emitter On Voltage at -VCE = 5 V, -IC = 10 mA Transition Frequency at -VCE = 5 V, -IC = 10 mA Symbol Min. Max. Unit hFE 30000 - - -ICBO - 100 nA -IEBO - 100 nA -V(BR)CBO 40 - V -V(BR)CEO 30 - V -V(BR)EBO 10 - V -VCE(sat) - 1 V -VBE(sat) - 1.5 V -VBE(on) - 1.4 V fT 125 - MHz SEMTECH ELECTRONICS LTD. (Subsidiary of Sino-Tech International Holdings Limited, a company listed on the Hong Kong Stock Exchange, Stock Code: 724) ® Dated : 07/01/2008
BC516
1. 物料型号:BC516,PNP型达林顿晶体管。 2. 器件简介:BC516是一种PNP型达林顿晶体管,封装在TO-92塑料封装中,具有3个引脚:集电极、基极和发射极。 3. 引脚分配:1-集电极,2-基极,3-发射极。 4. 参数特性:包括绝对最大额定值,如集电极-基极电压、集电极-发射极电压、发射极-基极电压、直流集电极电流、峰值集电极电流、总功耗、结温和存储温度范围。 5. 功能详解:文档提供了在室温25°C下的特性,包括直流电流增益、集电极-基极截止电流、发射极-基极截止电流、集电极-基极击穿电压、集电极-发射极击穿电压、发射极-基极击穿电压、集电极-发射极饱和电压、基极-发射极饱和电压、基极-发射极导通电压和转换频率。 6. 应用信息:文档来自SEMTECH ELECTRONICS LTD.,是Sino-Tech International Holdings Limited的子公司,后者在香港证券交易所上市,股票代码为724。文档还包含了ISO认证信息。
BC516 价格&库存
很抱歉,暂时无法提供与“BC516”相匹配的价格&库存,您可以联系我们找货
BC516
  • 10+0.37325
  • 100+0.29808
  • 300+0.26050
  • 1000+0.23177
  • 5000+0.20920
  • 10000+0.19797
库存:236
