LTV-244
LTV-244
    LITE-ON(光宝)
    OC-16P_10.28X4.4MM_SM
    特性:电流传输比(CTR):在IF = ±1mA、VCE = 5V时,最小为20%。 高输入输出隔离电压:(viso = 3,750Vms)。 采用双传输模塑技术。 UL1577、VDE DIN EN...
LTV-244 数据手册
Photocoupler Product Data Sheet LTV-244 Spec No.: DS70-2010-0081 Effective Date: 12/27/2014 Revision: A LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto Photocouplers LTV-2X4 series 1. DESCRIPTION 1.1 Features  Current transfer ratio (CTR) : MIN. 20% at IF = ±1mA, VCE = 5V)  High input-output isolation voltage. (Viso=3,750Vrms)  Employs double transfer mold technology UL 1577 VDE DIN EN60747-5-5 (VDE 0884-5) , CSA CA5A FIMKO ■ RoHS Compliance: All materials be used in device are followed EU RoHS directive (No.2002/95/EC).  ESD pass HBM 6000V/MM2000V  MSL class1 1.2 Applications  Hybrid substrates that require high density mounting.  Programmable controllers  System appliances, measuring instruments 2. PACKAGE DIMENSIONS 2.1 LTV-214 Notes : 1. 3-digit date code. 2. Rank shall be or shall not be marked. 3. VDE mark only appears on devices ordered “V” option. 1/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 2.2 Photocouplers LTV-2X4 series LTV-224 Notes : 1. 3-digit date code. 2. Rank shall be or shall not be marked. 3. VDE mark only appears on devices ordered “V” option. 2/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 2.3 Photocouplers LTV-2X4 series LTV-244 Notes : 1. 3-digit date code. 2. Rank shall be or shall not be marked. 3. VDE mark only appears on devices ordered “V” option. 3/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 3. TAPING DIMENSIONS 3.1 P/N : LTV-214 3.2 P/N : LTV-214-TP1 Description Symbol Description Symbol Tape wide W Pitch of sprocket holes P0 Tape wide Dimension in mm (inches) Dimension in mm (inch) W Pitch of sprocket holes Distance of compartment Distance of compartment Distance of compartment to compartment Distance of compartment to compartment P0 12±0.3 (0.47) 4±0.1 (0.15) F F P2 5.5±0.1 (0.217) P2 P1 2±0.1 (0.079) P1 8±0.1 (0.315) 4/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 3.3 P/N :LTV-224 Description Symbol Dimension in mm (inch) Tape wide W 12±0.3 (0.47) Pitch of sprocket holes P0 4±0.1 (0.15) F 5.5±0.1 (0.217) P2 2±0.1 (0.079) P1 8±0.1 (0.315) Distance of compartment Distance of compartment to compartment 5/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 3.4 P/N : LTV-244 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.47) Pitch of sprocket holes P0 4±0.1 (0.15) Distance of compartment Distance of compartment to compartment F 7.5±0.1 (0.217) P2 2±0.1 (0.079) P1 12±0.1 (0.315) 3.5 Quantities per Reel Package Type LTV-214 LTV-224 LTV-244 Quantities (pcs) 3000 2000 2000 6/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 4. RATING AND CHARACTERISTICS 4.1 Absolute Maximum Ratings at Ta=25°C Rating Parameter Symbol Unit 214 224 244 Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 65 mW Pulse Forward Current IFSM 1 A Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Collector Power Dissipation PC 150 100 mW Total Power Dissipation Ptot 200 170 mW Isolation Voltage Viso 3750 Operating Temperature Topr -55 ~ +110 o C Storage Temperature Tstg -55 ~ +150 o C Soldering Temperature Tsol 260(10s) o C Input Output 1. 1. AC For 1 Minute, Vrms R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 7/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 4.2 ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C Parameter Symbol Min. Typ. Max. Unit Test Condition Forward Voltage VF — 1.2 1.4 V IF=±20mA Terminal Capacitance Ct — 60 — pF V=0, f=1KHz Collector Dark Current ICEO — — 100 nA VCE=20V, IF=0 BVCEO 80 — — V IC=0.1mA, IF=0 BVECO 7 — — V IE=10A, IF=0 VCE(sat) — — 0.4 V IF±8mA, IC=2.4mA Riso 51010 11011 —  Input Collector-Emitter Output Breakdown Voltage Emitter-Collector Breakdown Voltage Collector-Emitter Saturation Voltage Isolation Resistance 40 ~ 60% R.H. TRANSFER CHARACTERISTICS DC500V, Floating Capacitance Cf — 0.8 1 pF 40 ~ 60% R.H. V=0, f=1MHz Response Time (Rise) tr — 3 18 s VCE=10V, IC=±2mA Response Time (Fall) tf — 4 18 s RL=100, f=100Hz 8/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 5. RANK TABLE OF CURRENT TRANSFER RATIO CTR Model No. CTR Rank Min Max 0 20 400 A 50 250 Condition IF=±1mA, VCE=5V, Ta=25oC LTV-214 LTV-224 LTV-244 CTR  IC IF AK 100 200 B 100 400 GR 100 300 0 20 400 IF=±5mA, VCE=5V, Ta=25oC IF=±1mA, VCE=5V, Ta=25oC A5 100 300 GB 100 400 IF=±5mA, VCE=5V, Ta=25oC  100% 9/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 6. CHARACTERISTICS CURVES Figure 1. Collector Power Dissipation vs. Ambient Temperature Figure 2. Forward Current vs. Ambient Temperature 160 50 120 LTV-214 LTV-224 Forward Current, I F (mA) Collector Power Dissipation, Pc(mW) 60 140 100 80 LTV-244 60 40 20 40 30 20 10 0 -25 0 25 50 75 100 0 125 -25 Ambient Temperature,Ta(℃) 0 25 50 75 100 Ambient Temperature,Ta (℃) Figure 3. Forward Current vs. Forward Voltage Figure 4. Forward Voltage Temperature Coefficient vs. Forward Current -3.2 Forward Current ( mA ) Ta=110℃ 75℃ 50℃ 25℃ 0℃ -30℃ Forward Voltage Temperature Coeffcient △VF / △Ta (mV/oC) 100 -55℃ 10 -2.8 -2.4 -2.0 -1.6 -1.2 -0.8 1 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 -0.4 Forward Voltage ( Volts ) 0.1 1 10 100 Forward Current, IF (mA) Figure 5. Pulse Forward Current vs. Duty Cycle Ratio Figure 6. Pulse Forward Current vs. Pulse Forward 1000 Voltage Pulse width < = 100 s o Ta= 25 C Pulse Forward Current, IFP ( mA ) I (mA) Pulse Forward Current FP 10000 1000 100 10 100 10 Pulse Widths ≦ 10 us Repetitive Frequency = 100Hz Ta = 25 ℃ 1 0.0001 0.001 0.01 Duty Ratio 0.1 1 0.5 1 1.5 2 2.5 Pulse Forward Voltage, VFP(V ) 10/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 3 Photocouplers LTV-2X4 series Figure 7. Collector-Emitter Saturation Voltage vs. Forward Figure 8. Collector Current vs. Collector-Emitter Current Voltage 50 5 50mA Collector Currrent, Ic ( mA) 4 3.5 7mA 10mA 5mA 0.5mA 2.5 3mA 3 1mA Collect-Emitt Voltage, VCE (V) 4.5 2 1.5 1 40 30mA 20mA 30 PC(Max)=150mV 20 10mA 10 IF=5mA 0.5 0 0 0 2 4 6 8 10 12 14 16 18 20 0 5 10 Collector-Emitter Voltage, VCE ( V ) Forward Current, I F (mA) Figure 9. Collector Current vs. Small Collector-Emitter Figure 10. Normalized CTR vs. Forward Current Voltage 50 10 Normalized to IF = 1mA, VCE = 5V TA =25oC 50mA 40 35 30mA Normalaized CTR Collector Currrent, Ic ( mA) 45 30 25 20mA 20 10mA 15 10 1 5mA 5 I F=2mA 0.1 0.1 0 0 0.5 1 1 10 IF - Forward Current - mA 100 Collector-Emitter Voltage, V CE ( V ) Figure 11. Collector Dark Current vs. Ambient Temperature Figure 12. Current Transfer Ratio vs. Forward Current 1.00E-05 Vce 48V Vce 24V 1.00E-06 Vce 10V ICEO 1.00E-07 Vce 5V 1.00E-08 1.00E-09 1.00E-10 CTR - Current Transfer Ratio - % 1000 10V 5V 100 VCE = 0.4V 10 1 1.00E-11 -55 -35 -15 5 25 Temperature 45 65 85 105 0.1 1 10 IF - Forward Current - mA 11/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 100 Photocouplers LTV-2X4 series Figure 13. Collector-Emitter Saturation Voltage vs. Figure 14. Collector Current vs. Ambient Temperature Ambient Temperature 100 I) ,A C o l l e c t o r C u r r eCn( tm Collector-Emitter Saturation Voltage (V) 0.18 0.16 0.14 IF=8mA IC=2.4mA 0.12 0.10 IF=20mA IC=1mA 0.08 IF=1mA IC=0.2mA 0.06 0.04 0.02 VCE = 5 V 25mA 10 20mA 1mA 1 IF = 0 . 5 m A 0.1 -60 0.00 -30 5 40 75 5mA -40 -20 110 0 20 40 60 80 100 120 A m b i e n t Te m p e r a t uAr(eoC) , T Ambinet Temperature, Ta (oC) Figure 15. Switching Time vs. Load Resistance Figure 16. Switching Time vs. Ambient Temperature 1000 100 tOFF Toff Switching time (us) Ts 10 Ton 1 ts 10 tON 1 T a = 25 ℃ Vcc = 5V RL = 1.9kΩ 0.1 1 10 100 Load Resistance, RL( KO) 0.1 -55 -20 0 25 50 A m b i e n t t e m p e r a t u r eoC)T a ( Figure 17. Frequency Response 0 RL=100Ω -2 VO ( db ) Switching Time ( µS ) 100 1KΩ -4 -6 Vcc=5V Ic=2mA o Ta=25 C -8 1 10 Frequency ( kHz ) 100 12/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 100 Photocouplers LTV-2X4 series 7. SWITCHING TIME TEST CIRCUIT RL Vcc IF VCE VCE 4.5VVcc 0.5V ts tON tOFF 8. TEMPERATURE PROFILE OF SOLDERING 8.1 IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin) 150˚C - Temperature Max (TSmax) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL) - Time (tL) Peak Temperature (TP) Ramp-up rate Ramp-down rate 217˚C 60 ~ 100 sec 260˚C 3˚C / sec max. 3~6˚C / sec 13/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 20 sec TP 260 C Temperature ( C) Ramp-up TL 217 C Tsmax 200 C Ramp-down 60-100 sec Tsmin 150 C tL (Soldering) 25 C Time (sec) 60 ~ 120 sec ts (Preheat) 8.2 Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature: 260+0/-5˚C Time: 10 sec. Preheat temperature:25 to 140˚C Preheat time: 30 to 80 sec. 14/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 Photocouplers LTV-2X4 series 8.3 Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature: 380+0/-5˚C Time: 3 sec max. 9. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit: mm P/N : LTV-214 P/N : LTV-224 P/N : LTV-244 15/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4 10. Notes: Photocouplers LTV-2X4 series  LiteOn is continually improving the quality, reliability, function or design and LiteOn reserves the right to make changes without further notices.  The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation.  For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives.  When requiring a device for any ”specific” application, please contact our sales in advice.  If there are any questions about the contents of this publication, please contact us at your convenience.  The contents described herein are subject to change without prior notice.  Immerge unit’s body in solder paste is not recommended. 16/16 Part no.: LTV-2X4 series BNC-OD-FC002/A4
LTV-244 价格&库存
很抱歉,暂时无法提供与“LTV-244”相匹配的价格&库存,您可以联系我们找货
