FH19C-8S-0.5SH(10)
FH19C-8S-0.5SH(10)
    HRS(广濑)
    SMD,P=0.5mm,卧贴
    FPC/FFC连接器 间距:0.50mm 8Pin 翻盖式 卧贴
FH19C-8S-0.5SH(10) 数据手册
0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors FH19C Series/FH19SC Series FH19C – FPC/FFC thickness : 0.2±0.03mm Actuator color: Brown Actuator color: Black ■Features ● 0.9mm high (30 pos. shown) 1. Low-profile 0.5mm pitch FPC/FFC Connectors Miniaturization of portable equipment and personal mobile devices has created increased demand for a low profile, high density, and high reliability connectors. 17m m m *The design of this connector has been made thinner and smaller, with a height of 0.9mm and width of 3mm. *PCB footprint: Reduced approximately 48% (as compared with Hirose Electric's 0.5mm pitch FH12 Series connectors) *Connector weight: Reduced approximately 78% (as compared with Hirose Electric's 0.5mm pitch FH12 Series connectors) 0.9mm 3m Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH19SC – FPC/FFC thickness : 0.3±0.03mm ● Can be mounted over conductive traces 2. Conductive traces on the PCB can run under the connector All bottom surface of the connector is solid, without any exposure of the contact. 3. Proven Flip-Lock Actuator System assures easy and reliable operation Rotating actuator permits easy insertion and reliable connection with the FPC & FFC. Tactile sensation confirms complete mechanical locking of the actuator and the electrical connection. 4. Accepts 0.2mm & 0.3mm thick FPC/FFC No exposed contacts on the bottom of the connector. The connector will also terminate with 0.2mm thick Flat Flexible Cable (FFC). 5. Board placement with automatic equipment Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 5000 connectors. Enclosed construction (No exposed contacts) Metal fittings (Leadless) ● Metal Fittings (Leadless Type) No protrusions on the sides allows close side-by-side board placement. ● Actuator Temporary Hold Mechanism 6. Wide range of contact counts The contact positions available range from 4 to 50. 7. Satisfies Halogen-free requirements All materials and substances used in this product comply with the Halogen-free standards. * Defined according to IEC61249-2-21 Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm max Actuator stays open during insertion of the FPC/FFC. 2019.4e 1 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Product Specifications Operating temperature range -55ç to +85ç (Note 2) Operating humidity range Relative humidity 90% max. (No condensation) Current rating 0.5A (Note 1) Rating Voltage rating 50V AC Recommended Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC, FFC Storage temperature range -10ç to +50ç (Note 3) Storage humidity range Relative humidity 90% max. (No condensation) FH19C Series Thickness : = 0.2 ± 0.03mm Gold plated FH19SC Series Thickness : = 0.3 ± 0.03mm Gold plated Item Specification 1. Insulation resistance 500Mø min. 2. Withstanding voltage No flashover or insulation breakdown 100mø max. 3. Contact resistance *Including FPC/FFC conductor resistance 100V DC 150V AC/1 minute Conditions 4. Durability Contact resistance : 100mø max. (insertion/ withdrawal) No damage, cracks, or parts dislocation. 20 cycles 1mA 5. Vibration No electrical discontinuity of 1μs or more. Contact resistance : 100mø max. No damage, cracks, or parts dislocation. Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions 6. Shock No electrical discontinuity of 1μs. min. Contact resistance : 100mø max. No damage, cracks, or parts dislocation. Acceleration of 981m/s2, 6ms duration, sine halfwave waveform, 3 cycles in each of the 3 axis. 7. Humidity (Steady state) Contact resistance : 100mø max. Insulation resistance : 100Mø min. No damage, cracks, or parts dislocation. 96 hours at temperature of 40ç and humidity of 90 to 95% 8. Temperature cycle Contact resistance : 100mø max. Insulation resistance : 100Mø min. No damage, cracks, or parts dislocation. Temperature : -55ç/ +15ç to +35ç / +85ç / +15ç to +35ç Time : -30 / 2 to 3 / +30 / 2 to 3(Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance. Reflow : At the recommended temperature profile Manual soldering : 350ç±5ç for 5 seconds Note 1 : When passing the current through all of the contacts, use 70% of the current rating. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation.Information ■Materials / Finish Part Material Insulator LCP Contacts Metal fittings Phosphor bronze Phosphor bronze Finish Color: Beige Color: Brown (FH19C Series) Color: Black (FH19SC Series) Gold plated Pure tin reflow plated Remarks UL94V-0 ------------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 19 C - 30S - 0.5 SH (10) 1 2 3 4 5 1 Series name : FH 5 Contact pitch : 0.5mm 2 Series No. : 19 6 Terminal type 3 FPC thickness : 0.2mm FPC/FFC thickness : 0.3mm C : SC : 4 No. of contacts : 4 to 50 6 7 SH : SMT horizontal mounting type 7 Material and plating specifications : FH19C : (10)...Gold plating with nickel barrier 5,000pieces/reel (99)...Gold plating with nickel barrier 500pieces/reel FH19SC : (09)...Gold plating with nickel barrier 5,000pieces/reel (99)...Gold plating with nickel barrier 500pieces/reel 2 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Connector Dimension [FH19C Series] 3 A±0.15 B 0.5 +0.15 0 (0.15) 2.5±0.15 (1) 0.15 G 0.9±0.1(Including contact terminal leads) G ∞Number of contacts 0.5 Polarizing mark indicator (0.5) Number of contacts indicator (130°) (1.6) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A (0.15) (C : FPC insertion slot dimension) 2 1 0.15MAX D±0.1 0.15MAX (1.3) 1 2 S 2.15±0.2 Notes 1 The coplanarity of each terminal lead and metal fitting is within 0.1mm. 2 The contact terminal lead position indicates the dimension from the bottom surface of the insulator body. 3 Difference between terminal contact to be max. 0.1mm. 4 Packaged on tape and reel only. Check packaging specification. 5 Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. 6 After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Contacts A B C D FH19C-04S-0.5SH(**) 580-0410-1 ** 4 4 1.5 2.57 3.35 FH19C-05S-0.5SH(**) 580-0418-3 ** 5 4.5 2 3.07 3.85 FH19C-06S-0.5SH(**) 580-0409-2 ** 6 5 2.5 3.57 4.35 FH19C-07S-0.5SH(**) 580-0411-4 ** 7 5.5 3 4.07 4.85 FH19C-08S-0.5SH(**) 580-0404-9 ** 8 6 3.5 4.57 5.35 FH19C-09S-0.5SH(**) 580-0403-6 ** 9 6.5 4 5.07 5.85 FH19C-10S-0.5SH(**) 580-0412-7 ** 10 7 4.5 5.57 6.35 FH19C-12S-0.5SH(**) 580-0413-0 ** 12 8 5.5 6.57 7.35 FH19C-13S-0.5SH(**) 580-0405-1 ** 13 8.5 6 7.07 7.85 FH19C-15S-0.5SH(**) 580-0406-4 ** 15 9.5 7 8.07 8.85 FH19C-17S-0.5SH(**) 580-0408-0 ** 17 10.5 8 9.07 9.85 FH19C-20S-0.5SH(**) 580-0402-3 ** 20 12 9.5 10.57 11.35 FH19C-21S-0.5SH(**) 580-0414-2 ** 21 12.5 10 11.07 11.85 FH19C-24S-0.5SH(**) 580-0407-7 ** 24 14 11.5 12.57 13.35 FH19C-27S-0.5SH(**) 580-0401-0 ** 27 15.5 13 14.07 14.85 FH19C-30S-0.5SH(**) 580-0400-8 ** 30 17 14.5 15.57 16.35 FH19C-34S-0.5SH(**) 580-0419-6 ** 34 19 16.5 17.57 18.35 FH19C-40S-0.5SH(**) 580-0416-8 ** 40 22 19.5 20.57 21.35 FH19C-50S-0.5SH(**) 580-0417-0 ** 50 27 24.5 25.57 26.35 Note1 : Embossed tape reel packaging (5,000 pieces/reel, 500 pieces/reel). Order by number of reels. 3 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors [FH19SC Series] 3 A±0.15 0.5 (0.15) 2.5±0.15 (1) 0.15 G +0.15 0 G ∞Number of contacts 0.5 0.93±0.1(Including contact terminal leads) B A Polarizing mark indicator (0.5) 5 (130°) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1.6) Number of contacts indicator (0.15) (C : FPC insertion slot dimension) 2 1 0.15MAX D±0.1 0.15MAX (1.3) 1 2 S 2.15±0.2 Notes 1 2 3 4 5 6 7 The coplanarity of each terminal lead and metal fitting is within 0.1mm. The contact terminal lead position indicates the dimension from the bottom surface of the insulator body. Difference between terminal contact to be max. 0.1mm. Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. The contacts are protruding. 0.03mm max. from the housing top surface. Packaged on tape and reel only. Check packaging specification. After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Contacts A B C D FH19SC-12S-0.5SH(**) 580-0512-1 ** 12 8 5.5 6.57 7.35 FH19SC-13S-0.5SH(**) 580-0518-8 ** 13 8.5 6 7.07 7.85 FH19SC-14S-0.5SH(**) 580-0509-7 ** 14 9 6.5 7.57 8.35 FH19SC-15S-0.5SH(**) 580-0503-0 ** 15 9.5 7 8.07 8.85 FH19SC-16S-0.5SH(**) 580-0521-2 ** 16 10 7.5 8.57 9.35 FH19SC-17S-0.5SH(**) 580-0504-3 ** 17 10.5 8 9.07 9.85 FH19SC-18S-0.5SH(**) 580-0519-0 ** 18 11 8.5 9.57 10.35 FH19SC-20S-0.5SH(**) 580-0502-8 ** 20 12 9.5 10.57 11.35 FH19SC-21S-0.5SH(**) 580-0505-6 ** 21 12.5 10 11.07 11.85 FH19SC-22S-0.5SH(**) 580-0506-9 ** 22 13 10.5 11.57 12.35 FH19SC-24S-0.5SH(**) 580-0511-9 ** 24 14 11.5 12.57 13.35 FH19SC-26S-0.5SH(**) 580-0510-6 ** 26 15 12.5 13.57 14.35 FH19SC-27S-0.5SH(**) 580-0516-2 ** 27 15.5 13 14.07 14.85 FH19SC-28S-0.5SH(**) 580-0513-4 ** 28 16 13.5 14.57 15.35 FH19SC-30S-0.5SH(**) 580-0500-2 ** 30 17 14.5 15.57 16.35 FH19SC-32S-0.5SH(**) 580-0514-7 ** 32 18 15.5 16.57 17.35 Note1 : Embossed tape reel packaging (5,000 pieces/reel, 500pieces/reel) . Order by number of reels. 4 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Recommended PCB Land and Metal Mask Dimensions [Common to FH19C & FH19SC Series] Recommended metal mask thickness : 0.10mm. H (3) (0.15) (0.2) (0.15) 0.8±0.05 (0.05) J±0.1 K±0.1 (A) ■Recommended FPC, FFC Dimensions [Common to FH19C & FH19SC Series] L±0.05 2R0 0.35±0.03(FPC) 0.3±0.03(FFC) 0.5±0.03 FH19C Series FH19SC Series 0.2±0.03 0.3±0.03 (X) 3.5 min. (Stiffener) 3.5 min. (Stiffener) B±0.03 .2 0.5±0.07 2.5±0.3 (Exposed traces) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.3±0.05 (0.15) (0.15) 0.5 (2.5) 0.8±0.05 B ∞Number of contacts 0.3±0.05 (Land) 0.1 H 0.25±0.05 (Metal mask) Note 1 : Stiffener dimension should be 3.5mm min., and X dimension should be 0.5mm for improved flexibility of FPC. Unit : mm No. of Contacts 4 5 6 7 8 9 10 12 13 14 15 16 17 18 A 4.0 4.5 5.0 5.5 6.0 6.5 7.0 8.0 8.5 9.0 9.5 10.0 10.5 11.0 B 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.5 6.0 6.5 7.0 7.5 8.0 8.5 J 3.1 3.6 4.1 4.6 5.1 5.6 6.1 7.1 7.6 8.1 8.6 9.1 9.6 10.1 K 3.9 4.4 4.9 5.4 5.9 6.4 6.9 7.9 8.4 8.9 9.4 9.9 10.4 10.9 L 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.5 7.0 7.5 8.0 8.5 9.0 9.5 Unit : mm No. of Contacts 20 21 22 24 26 27 28 30 32 34 40 50 A 12.0 12.5 13.0 14.0 15.0 15.5 16.0 17.0 18.0 19.0 22.0 27.0 B 9.5 10.0 10.5 11.5 12.5 13.0 13.5 14.5 15.5 16.5 19.5 24.5 J 11.1 11.6 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 21.1 26.1 K 11.9 12.4 12.9 13.9 14.9 15.4 15.9 16.9 17.9 18.9 21.9 26.9 L 10.5 11.0 11.5 12.5 13.5 14.0 14.5 15.5 16.5 17.5 20.5 25.5 5 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■FH19C & FH19SC Series FPC/FFC Construction (Recommended Specifications) 1. Using Single-sided FPC FPC : Flexible Printed Circuit Material Name Covering layer film Material Polyimide 1 mil thick Cover adhesive Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (25) (25) (25) 3 3 35 35 Surface treatment Copper foil Cu Base adhesive Thermosetting adhesive 25 25 Base film Polyimide 1 mil thick 25 25 Reinforcement material adhesive Thermosetting adhesive 30 30 75 175 193 293 1oz Polyimide FH19C : 3mil FH19SC : 7mil Total FPC : Flexible Printed Circuit Material Name Covering layer film Cover adhesive Material Polyimide 1 mil thick Thickness (μm) FH19C FH19SC (25) (25) (25) (25) 3 3 15 15 18 18 Surface treatment Nickel under plated 1 to 5μm / Gold plated 0.2μm Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 18 Base film Polyimide 25 25 Base adhesive 18 18 Copper foil Cu 18 18 Cover adhesive Thermosetting adhesive 25 25 Polyimide 1 mil thick 25 25 Reinforcement material adhesive Thermosetting adhesive 25 50 25 100 197 297 Covering layer film 1/2oz 1 mil thick 1/2oz Polyimide Stiffener FH19C : 1mil FH19SC : 4mil Total 3. Using FFC (Flexible Flat Cable) (25) Nickel under plated 1 to 5μm / Gold plated 0.2μm Stiffener 2. Using Double-sided FPC Thickness (μm) FH19C FH19SC FFC : Flexible Flat Cable Material Name Material Polyester film Adhesive Polyester thermoplastic type (Nickel under plated / Gold plated), soft copper film Adhesive Polyester Polyester Thickness (μm) FH19C FH19SC (12) (12) (30) (30) 35 35 30 30 12 12 Adhesive Polyester 30 30 Stiffener Polyester 100 188 Total 207 295 * Practical tolerance of thickness dimension is ±20μm (i.e., 187 to 227μm). 4. Precautions 1. This specification is a recommendation for the construction of the FH19C/FH19SC Series FPC and FFC (t=0.2/0.3±0.03). 2. For details about the construction, please contact the FPC/FFC manufacturers. 6 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Packaging Specifications [Common to FH19C & FH19SC Series] ● Embossed Carrier Tape Dimensions 8±0.1 (3.3) (4.3) Unreeling direction Flat surface for placement with automatic equipment (1) ) ●Reel Dimensions (Ø1 3 (Ø80) (R : INSIDE) (Ø380) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Q) Ø1 .5 (0.3) M±0.3 1.75±0.1 2±0.15 + 0. 0 1 4±0.1 N±0.1 (1.7) (T : OUTSIDE) End cection Mounting cection Embossed carrier tape Blank cection (10 pockets min.) Lead cection (400mm min.) Blank cection Top cover tape (10 pockets min.) Unit : mm No. of Contacts 4 5 6 7 8 9 10 12 13 14 15 16 17 18 M 16 16 16 16 16 16 16 16 16 16 16 24 24 24 N 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 Q 4.3 4.8 5.3 5.8 6.3 6.8 7.3 8.3 8.8 9.3 9.8 10.3 10.8 11.3 R 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 T 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 Unit : mm No. of Contacts 20 21 22 24 26 27 28 30 32 34 40 50 M 24 24 24 24 24 24 24 24 32 32 44 44 N 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 20.2 Q 12.3 12.8 13.3 14.3 15.3 15.8 16.3 17.3 18.3 19.3 22.3 27.3 R 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 45.4 T 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 49.4 Note : Embossed tape 32mm or wider will have perforated feed holes on two sides. 7 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Recommended Temperature Profile [For FH19C & FH19SC Series] MAX 250ç 250 230ç Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature(ç) 200 HRS test condition Solder method Solder composition : Reflow, IR/hot air : Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., 200ç Ltd.’s Part 150 Number : M705-221CM5-3210.5) 150ç Test board : Glass epoxy 45mm∞100mm∞1.6mm thick Land dimensions Metal mask : 0.3mm∞0.8mm : 0.25mm∞0.8mm∞0.1mm 100 50 25ç (60 sec.) 90 sec. to 120 sec. (60 sec.) This temperature profile is based on the above conditions. Soldering In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness 0 Start Preheating Time (Seconds) and board size/thickness. Consult tour solder paste and equipment manufacturer for specific recommendations. 8 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors ■Connector Operation and Precautions Operation 1. FPC/FFC Termination procedure. Connector installed on the board. Precautions 1) Do not apply excessive force or use any type of tool to operate the actuator. Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) Lift up the actuator. Use thumb or index finger. 2) The connector will assure reliable performance when the actuator is open to 130° maximum. Do not exceed this angle, as this may cause permanent damage to the connector. 2) Assure that the FPC/FFC is fully inserted parallel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) 3) Rotate down the actuator until firmly closed. It is critical that the inserted FPC/FFC is not moved and remains fully inserted. Should the FPC/FFC be moved, open the actuator and repeat the process, starting with Step 1 above. 3) Insert the FPC/FFC straight into the insertion opening. Failing to follow this precaution can lead to damaging the FPC/FFC and altering its connectivity. ing open tion r e s in ·FFC FPC 4) When you insert the FPC into the insertion opening, do not apply excessive pressure or scrape the FPC on the bottom of the opening. Doing so can lead to deformities of the contacts and can hinder the performance of the connector. 2. FPC/FFC Removal 1) Lift up the actuator. 2) Carefully remove the FPC/FFC. 5) Application of excessive force to the inserted FPC/FFC may cause damage to connector and may affect the reliability of electrical connection. If specific application requires continuous or repeated pull or bend of the inserted FPC/FFC, assure that the forces are NOT transmitted directly to the connector. 9 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 10 FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 11 Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH19C & FH19SC Series●0.5mm Pitch, 0.9mm Height, FPC/FFC Connectors 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2019. Contents are subject to change without notice for the purpose of improvements.
FH19C-8S-0.5SH(10) 价格&库存
很抱歉,暂时无法提供与“FH19C-8S-0.5SH(10)”相匹配的价格&库存,您可以联系我们找货
FH19C-8S-0.5SH(10)
  • 5000+6.365865000+0.82460
  • 10000+6.0622810000+0.78528
库存:28714
FH19C-8S-0.5SH(10)
  • 5+1.53771
  • 50+1.22343
  • 150+1.08875
  • 500+0.92070
  • 2500+0.81465
库存:4667
FH19C-8S-0.5SH(10)
    库存:5000
    FH19C-8S-0.5SH(10)
    • 1+10.846231+1.40497
    • 10+9.1633110+1.18697
    • 25+8.7913225+1.13879
    • 50+8.6042550+1.11456
    • 100+8.23034100+1.06612
    • 250+7.48243250+0.96924
    • 500+6.73420500+0.87232
    • 1000+5.985951000+0.77539
    • 2500+5.424752500+0.70270
    库存:28714
    FH19C-8S-0.5SH(10)
    • 1+11.646101+1.50858
    • 10+9.8778610+1.27953
    • 25+9.2533225+1.19863
    • 50+8.8107350+1.14130
    • 100+8.38999100+1.08680
    • 250+7.86415250+1.01869
    • 500+7.48862500+0.97004
    • 1000+7.131061000+0.92373
    • 2500+6.746892500+0.87396
    库存:28714
