DB201S THRU DB207S
SINGLE PHASE 2.0AMP SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
Features
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Designed for surface mount application
Plastic material-UL flammability 94V-0
DB-S
MIL-STD-202, Method 208
· Polarity: as marked on case
· Mounting position: Any
· Marking: type number
0.402(10.2)
0.378(9.6)
0.0059(0.15)
0.0098 (0.25)
0.291(7.4)
0.240(6.1)
· Case:DB-S, molded plastic
· Terminals: plated leads solderable per
0.256(6.5)
Mechanical Data
0.329(8.35 )
0.313( 7.95)
0.098(2.50 )
0.083(2.10)
· Lead Free: For RoHS / Lead Free Version,
0.205(5.2)
0.197(5.0)
Maximum Ratings and Electrical Characteristics
Dimiensions in inches and (milimeters )
Rating at 25℃ ambient temperature unless otherwise specified.
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
0.311(7.9)
0.043(1.1)
0.035(0.9 )
MAX 0.0078 (0.2)
SYMBOL DB201S DB202S DB203S DB204S DB205S DB206S DB207S UNITS
VRRM
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRWM
RMS Reverse Voltage
VRMS
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
VDC
IO
2.0
A
Non-Repetitive Peak Forward Surge Current 8.3ms
Single half sine-wave superimposed on rated load
(JEDEC Method)
IFSM
60
A
Forward Voltage per element
VFM
1.1
V
Peak Reverse Current
@TA=25℃
At Rated DC Blocking Voltage @TA=125℃
IR
5.0
500
uA
Typical Junction Capacitance per leg (Note 2)
CJ
25
pF
RθJA
40
RθJL
15
TJ,TSTG
-55to+150
Average Rectified Output Current (Note 1)@TA=40℃
@IF=2.0A
Typical Thermal Resistance per leg
Operating and Storage Temperature Range
2
Note:1. Mounted on glass epoxy PC board with 1.3mm solder pad.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.
REV.08
1 of 2
℃/W
DB201S THRU DB207S
Fig. 2 Typical Forward Characteristics (per leg)
IF, INSTANTANEOUS FORWARD CURRENT (A)
I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A)
Fig. 1 Output Current Derating Curve
2
1.99 5
1
0.5
Resistive or Inductive Load
80
120
10
1.0
0.1
TA = 25°C
Pulse Width = 300µs
0.01
0.2
160
TA, AMBIENT TEMPERATURE (°C)
40
TA = 25°C
Single Half Sine-Wave
Pulse Width =8.3ms
(JEDEC Method)
10
NUMBER OF CYCLES AT 60 Hz
REV.08
0.8
1.0
1.2
1.4
1.6
Fig. 4 T ypical Reverse Characteristics (per element)
IR, INSTANTANEOUS REVERSE CURRENT (µA)
IFSM, PEAK FORWARD SURGE CURRENT (A)
60
1.0
0.6
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 3 Maximum Peak Forward Surge Current (per leg)
100
TJ = 125°C
10
1.0
TJ = 25°C
0.1
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
2 of 2
很抱歉,暂时无法提供与“DB207S”相匹配的价格&库存,您可以联系我们找货
