SR5200M
SR5200M
    MOSPECSEMICONDUCTOR(统懋)
    DO-201AD
    SR5200M
SR5200M 数据手册
MOSPEC SR5200 Schottky Barrier Rectifiers SCHOTTKY BARRIER RECTIFIERS Using the Schottky Barrier principle with a Refractory metal capable of high temperature operation metal. proprietary barrier technology allows for reliable operation up to 150℃ junction temperature. Typical application are in switching Mode Power Supplies such as adaptors, DC/DC converters free-wheeling and polarity protection diodes. 5.0 AMPERES 200 VOLTS Features *Low Forward Voltage. *Low Switching noise. *High Current Capacity *Guarantee Reverse Avalanche. *Guard-Ring for Stress Protection. *Low Power Loss & High efficiency. *150℃ Operating Junction Temperature *Low Stored Charge Majority Carrier Conduction. *Plastic Material used Carries Underwriters Laboratory *Moisture Sensitivity Level: MSL-1 *Flammability Classification 94V-O *Pb free *In compliance with EU RoHs directives *The marking is indicated by part no. with. “M”. ex:SR5200M DO-201AD MAXIMUM RATINGS Characteristic Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectifier Forward Current Non-Repetitive Peak Surge Current (Surge applied at rate load conditions halfware, single phase, 60Hz) Operating and Storage Junction Temperature Range Symbol SR5200 Unit VRRM VRWM VR 200 V VR(RMS) 140 V IO 5.0 A 150 A IFSM DIM TJ , TSTG -65 to +150 Characteristic Symbol SR5200 Unit Maximum Instantaneous Forward Voltage ( IF =5.0 Amp.) VF 0.95 V Maximum Instantaneous Reverse Current ( Rated DC Voltage, TC = 25℃ ) ( Rated DC Voltage, TC = 125℃ ) IR 0.01 10 mA RθJC 55 ℃/W CP 320 PF Maximum Thermal Resistance Junction to case Typical Junction Capacitance ( Reverse Voltage of 4 volts & f=1 MHz ) RA-D-0885 Ver.A MIN MAX A 5.00 5.60 B 25.40 --- C 8.50 9.50 D 1.18 1.22 ℃ ELECTRICAL CHARACTERISTICS MILLIMETERS CASE--Transfer molded plastic POLARITY--Cathode indicated polarity band MOSPEC SR5200 INSTANTANEOUS FORWARD CURRENT (Amp.) FIG-2 TYPICAL FORWARD CHARACTERISTICS CASE TEMPERATURE (℃) FORWARD VOLTAGE (Volts) FIG-3 TYPICAL REVERSE CHARACTERISTICS FIG-4 TYPICAL JUNCTION CAPACITANCE Tj=125 o JUNCTION CAPACITANCE (PF) INSTANTANEOUS REVERSE CURRENT (mA.) AVERAGE FORWARD RECTIFIED CURRENT (Amp.) FIG-1 FORWARD CURRENT DERATING CURVE o Tj=75 c o Tj=25 c PERCENT OF RATED REVERSE VOLTAGE (﹪) PEAK FORWARD SURGE CURRENT (Amp.) FIG-5 PEAK FORWARD SURGE CURRENT NUMBER OF CYCLES AT 60 Hz RA-D-0885 Ver.A REVERSE VOLTAGE (Volts) Notice MOSPEC reserves the rights to make changes of the content herein the document anytime without notification. MOSPEC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Please refer to MOSPEC website for the last document. MOSPEC disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially incurred. Application shown on the herein document are examples of standard use and operation. Customers are responsible for comprehending suitable use in particular applications. MOSPEC makes no representation or warranty that such application will be suitable for the specified use without further testing or modification. The information contained herein is presented only as a guide for the applications of our products. No responsibility is assumed by MOSPEC for any infringements of patents or other rights of the third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MOSPEC or others. These MOSPEC products are intended for usage in general electronic equipment. Please make sure to consult with MOSPEC before you use these MOSPEC products in equipment which require specialized quality and/or reliability, and in equipment which could have major impact to the welfare of human life ( atomic energy control, aeronautics , traffic control, combustion control, safety devices etc.)
SR5200M 价格&库存
很抱歉,暂时无法提供与“SR5200M”相匹配的价格&库存,您可以联系我们找货
