ESD5325E-6/TR
ESD5325E-6/TR
    WILLSEMI(韦尔)
    SOT23-6L
    单向TVS 5V 6V截止 峰值浪涌电流:6A@8/20US
ESD5325E-6/TR 数据手册
ESD5325E ESD5325E 4-Lines, Uni-directional, Low Capacitance http//:www.sh-willsemi.com Transient Voltage Suppressors Descriptions The ESD5325E is a low capacitance TVS (Transient Voltage Suppressor) array designed to protect high speed data interfaces. It has been specifically designed to protect sensitive electronic components which are connected to data SOT23-6L and transmission lines from over-stress caused by ESD (Electrostatic Discharge). 5 The ESD5325E incorporates four pairs of low capacitance steering diodes plus a TVS diode. 1 3 4 6 The ESD5325E may be used to provide ESD protection up to ±30kV (contact discharge) according to IEC61000-4-2, and withstand peak pulse current up to 6A (8/20μs) according to 2 IEC61000-4-5. Circuit diagram The ESD5325E is available in SOT23-6L package. Standard products are Pb-free and Halogen-free. I/O VDD I/O 6 5 4 Features  Reverse stand-off voltage: 6V max. (VDD to GND)  Transient protection for each line according to IEC61000-4-2 (ESD): 5325 TAYW ±30kV (contact discharge) IEC61000-4-5 (surge): 6A (8/20μs)  Low capacitance: CI/O - GND =1.0pF typ. 1 2 3 I/O GND I/O  Ultra-low leakage current: IR
ESD5325E-6/TR
物料型号:ESD5325E
器件简介:ESD5325E是一款低电容TVS(瞬态电压抑制器)阵列,专为保护高速数据接口设计。它通过IEC61000-4-2标准的±30kV接触放电和IEC61000-4-5标准的6A(8/20μs)峰值脉冲电流测试,以保护敏感电子元件免受ESD引起的过应力损害。
引脚分配:该器件采用SOT23-6L封装,具有4对低电容导向二极管加一个TVS二极管。
参数特性: - 反向电压:最大6V(VDD到GND) - 低电容:典型值1.0pF(I/O到GND) - 超低漏电流:典型值小于1nA - 低钳位电压:12.5V(@16A峰值脉冲电流,TLP测试)
功能详解:ESD5325E提供每条线路的ESD保护,符合IEC61000-4-2标准,可承受高达±30kV的接触放电。同时,它采用固态硅技术,具有低钳位电压和动态电阻,适用于高速数据传输线路的保护。
应用信息:适用于USB 2.0、显卡、DVI、IEEE 1394、显示器和平板显示器、10/100以太网、笔记本电脑等。
封装信息:标准产品无铅无卤素,采用SOT23-6L封装,3000/卷的卷带包装方式。
ESD5325E-6/TR 价格&库存
很抱歉,暂时无法提供与“ESD5325E-6/TR”相匹配的价格&库存,您可以联系我们找货
