SHANGHAI
June 2008
MICROELECTRONICS CO., LTD.
SESD5L5V
ESD Protection Diode With Ultra-Low Capacitance
General Description
Revision:A
Features
The ESD5L5V is designed to protect voltage sensitive
z Ultra Low Capacitance 0.5 pF
components that require ultra-low capacitance from ESD
z Low Clamping Voltage
and transient voltage events.Excellent clamping capability,
z Small Body Outline Dimensions:
low capacitance, low leakage, and fastresponse time, make
z Stand-off Voltage: 5 V
these parts ideal for ESD protection on designs where
z Low Leakage
board space is at a premium. Because of its low
z Response Time is Typically < 1.0 ns
capacitance, it is suited for use in high frequency designs
z IEC61000-4-2 Level 4 ESD Protection
such as USB 2.0 high speed and antenna line applications.
z This is a Pb-Free Device
Complies with the following standards
IEC61000-4-2
Level 4
15 kV (air discharge)
8 kV(contact discharge)
MIL STD 883E - Method 3015-7 Class 3
25 kV HBM (Human Body Model)
Functional diagram
SOD-523
Maximum Ratings
Parameter
Symbol
Value
Unit
IEC 61000-4-2 (ESD) Contact
8
kV
ESD Voltage
Per Human Body Model
25
kV
Per Machine Model
400
V
Peak Pulse Power (tp = 8/20μs) @ TA=25℃
PD
100
W
Junction and Storage Temperature Range
TJ,TSTG
-55 to 150
TL
260
Lead Solder Temperature – Maximum (10 Second Duration)
ShangHai Sino-IC Microelectronics Co., Ltd.
1
SESD5L5V
Electrical Parameter
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
IT
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @
VRWM
Test Current
Breakdown Voltage @ IT
IF
Forward Current
VF
Forward Voltage @ IF
Electrical Characteristics (TA=25℃ unless otherwise noted, VF=0.9V Max. @ IF=10mA for all types)
Part Numbers
VBR
VF
IT
Min.
SESD5L5V
VRWM
IR
Max.
C
IF
Max.
(Note1)
V
mA
V
µA
V
mA
pF
6.0
1.0
5
1
1.0
10
0.9
1. Capacitance is measured at f=1MHz, VR=0V,TA=25℃.
2. VBR is measured with a pulse test current IT at an ambient temperature of 25°C.
3. For test procedure see Figures 3 and 4 and Application Note AND8307/D.
Typical Characteristics
Fig 1. Positive 8kV contact per IEC
61000-4-2-SESD5L5V
Fig 2. Negative 8kV contact per IEC
61000-4-2-SESD5L5V
2
SESD5L5V
Figure 3. IEC61000-4-2 Spec
Figure 4. Diagram of ESD Test Setup
SOD-523 Mechanical Data
3
SESD5L5V
Dim
Millimeters
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
A
1.10
1.20
1.30
0.043
0.047
0.051
B
0.70
0.80
0.90
0.028
0.032
0.035
C
0.50
0.60
0.70
0.020
0.024
0.028
D
0.25
0.30
0.35
0.010
0.012
0.014
J
0.07
0.14
0.20
0.0028
0.0055
0.0079
K
0.15
0.20
0.25
0.006
0.008
0.010
S
1.50
1.60
1.70
0.059
0.063
0.067
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402 33932403 33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
4
很抱歉,暂时无法提供与“SESD5L5V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.27648
- 200+0.22518
- 600+0.19667
- 3000+0.17248
- 9000+0.15758
- 21000+0.14958
