DHP252010HF-R33M
DHP252010HF-R33M
    TAI-TECH(台庆)
    SMD
    功率电感 SMD
DHP252010HF-R33M 数据手册
P1 TAI-TECH Power Inductor DHP252010HF-R33M ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 16/06/24 新 發 行 楊祥忠 詹偉特 孔妍暄 備 註 www.tai-tech.com.tw P2 TAI-TECH Power Inductor DHP252010HF-R33M 1. Features 1. This specification applies Low Profile Power Inductors. 2. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Series A(mm) B(mm) C(mm) D(mm) DHP252010HF 2.5 -0.1/+0.2 2.0 -0.1/+0.2 1.0Max 0.75 ref. 1.00 ref. Halogen Pb Halogen-free Pb-free E(mm) Units: mm 3. Part Numbering DHP 252010 HF A B - C R33 M D E F A: Series B: Dimension C: Lead Free Material D: Inductance R33=0.33uH E: Inductance Tolerance M=±20% F:Control S/N 4. Specification TAI-TECH Part Number DHP252010HF-R33M Inductance Tolerance Test Frequency (uH) (%) (Hz) 0.33 ±20 1V/1M DCR (Ω) typ. DCR (Ω) Max. I sat (A) typ. I sat (A) Max. I rms (A) typ I rms (A) MAX 0.025 0.033 6.00 5.50 4.80 4.30 Note: Isat:Based on inductance change (△L/L0:≦30%)@ ambient temp. 25℃ Irms:Based on temperature rise (△T:40℃.)Max www.tai-tech.com.tw P3 TAI-TECH DHP252010HF-R33M AHP252010AF-R33 0.6 Inductance(uH) 0.45 0.3 0.15 0 0 1.5 3 4.5 6 DCcurrent(mA) 5. Material List No. Description Specification a. Core Metal Core b. Glue Epoxy with magnetic powder c Termination Tin (Pb Free) d Wire Enameled Copper Wire Appearance of exposed wire tolerance limit : 1. Width direction(dimension a):Acceptable when a≦w/2 Nonconforming when a>w/2 2. Length direction(dimension b):Dimension b is not specified. 3. The total area of exposed wire occurring to each sides is not greater than 50% of coating resin area, and is acceptable. www.tai-tech.com.tw P4 TAI-TECH 6. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test HP4284A,CH11025,CH3302,CH1320,CH1320S Inductance Refer to standard electrical characteristics list. DCR LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation DC Current (Isat) will cause L0 Saturation Current (Isat) △L≦30% typical. to drop △L(%)(keep quickly). Heat Rated Current (Irms) will cause the coil temperature rise △T(℃) without core loss. Heat Rated Current (Irms) Approximately △T≦40℃ 1.Applied the allowed DC current(keep 1 min.). 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature: 125±2℃(Inductor) Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Moisture Resistance Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 www.tai-tech.com.tw P5 TAI-TECH Item Performance Test Condition Type Peak value (g's) Normal duration (D) (ms) Wave form Velocity change (Vi)ft/sec SMD 50 11 Half-sine 11.3 Lead 50 11 Half-sine 11.3 Shock Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. Bending Soderability RDC:within ±15% of initial value and shall not exceed the specification value More than 95% of the terminal electrode should be covered with solder。 Shall be mounted on a FR4 substrate of the following dimensions: >=0805:40x100x1.2mm =0805:1.2mm 0805:1kg ,
DHP252010HF-R33M 价格&库存
很抱歉,暂时无法提供与“DHP252010HF-R33M”相匹配的价格&库存,您可以联系我们找货
DHP252010HF-R33M
    • 20+0.25694
    • 200+0.20304
    • 600+0.17313
    库存:1532
