D115-DSS115
D115-DSS115
    PINGWEI(平伟)
    D115-DSS115
D115-DSS115 数据手册
DSS115 DSS115 1.0 AMP. SURFACE MOUNT GENERAL PURPOSE SCHOTTKY BARRIER RECTIFIERS SOD-123FL FEATURES ·For surface mounted application ·High current capability ·Low forward voltage drop ·Low power loss, high efficiency ·High surge current capability ·High temperature soldering guaranteed: 250℃/10 seconds at terminals. MECHANICAL DATA ·Case: JEDEC SOD-123FL,molded plastic over passivated chip ·Terminals:Solder Plated, solderable per MIL-STD-750, Method 2026 ·Polarity: Color band denotes cathode end ·Weight: 0.006 ounces, 0.02 gram ·Mounting position: Any Dimensions in millimeters MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%. Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward rectified Current at TL =90°C Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) SYM BOL marking 150 V 105 V 150 V 1.0 A IFSM 30.0 A VF 0.95 V Maximum DC Reverse Current @TA =25°C Typical thermal resistance (Note 2) Storage Temperature Range Operation Temperature Range IR @TA =100°C Typical Junction Capacitance (Note 1) units D115 VRRM VRMS VDC IF(AV) Maximum Instantaneous forward Voltage at 1.0 A DC at rated DC blocking voltage DSS115 CJ R(JA) TSTG TJ Note: 1. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c. 2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas -1- 0.05 5.0 mA 28 pF 180 °C /W -55 to +150 °C -55 to +150 °C DSS115 RATING AND CHARACTERISTIC CURVES (DSS115) FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE Single Phase Half Wave 60Hz Resistive or inductive Load TJ=25℃ Pulse Width=300μ s 1% Duty Cycle .2 LEAD TEMPERTURE,( ) .4 .6 .8 1.0 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT ℃ PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz -2- DSS115 Marking and packaging illustration 1、Marking SYMBOL D115 A B B A Explanation Color Band Denotes Cathode Product Name 2、Packaging d Top cover tape thickness 0.10mm(0.004") max.thick W1 Embossed carrier tape °MAX A °MAX Embossed cavity SPECIFICATIONS mm(inch) SYMBOL PACKAGE SOD-123FL ITEM Carrier width A 2.1(0.083)Max Carrier length B 4.0(0.157)Max Sprocket hole d ø1.55(0.061)Typ Reel outer diameter D 177.8(7)Typ Reel inner diameter D1 50.0(1.969)Min Feed hole diameter D2 13.0(0.512)Typ Sprocket hole position J 1.75(0.069)Typ Punch hole position H 3.50(0.138)Typ Carrier depth K 1.60(0.063)Typ Punch hole pitch P 4.00(0.157)Typ Sprocket hole pitch P0 4.00(0.157)Typ Embossment center P1 2.00(0.079)Typ Overall tape thickness T 0.25(0.098)Typ Tape width W 8.15(0.321)Typ Reel width W1 10.5(0.413)Min -3-
D115-DSS115 价格&库存
很抱歉,暂时无法提供与“D115-DSS115”相匹配的价格&库存,您可以联系我们找货
