MBRX120
MBRX120
    MDD(辰达半导体)
    SOD-123
    停产 电压:20V 电流:1A
MBRX120 数据手册
MBRX120 THRU MBRX160 SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Reverse Voltage - 20 to 60 Volts Forward Current - 1.0 Amperes SOD-123 FEATURES Lead Free Finish/RoHS Compliant (Note1)("P"Suffix designates Compliant. See ordering information) Extremely Low Thermal Resistance 1.80(.071) 1.40(.055) 3.86(0.152) 2.84(0.112) 3.56(0.145) 2.54(0.100) For Surface Mount Application Low Forward Voltage Case Material: Molded Plastic. UL Flammability Classification Rating 94V-0 and MSL rating 1 .71(0.028) .50(0.020) .15(.006) 1.35(.053) MAX .94(.037) MECHANICAL DATA .25(.010) MIN Dimensions in millimeters and (inches) Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case Marking: MBRX120:X2, MBRX130:X3, : MBRX140:X4, MBRX160:X6 MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=90 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TJ =25 C at rated DC blocking voltage Typical junction capacitance (NOTE 1) Operating junction temperature range Storage temperature range SYMBOLS MBRX120 VRRM VRMS VDC MBRX140 MBRX160 UNITS 30 21 30 40 28 40 60 42 60 VOLTS VOLTS VOLTS I(AV) 1.0 Amps IFSM 20.0 Amps VF 0.5 0.55 0.72 Volts IR 0.3 mA CJ 30 -50 to +125 -50 to +150 pF TJ, TSTG Note: 1. High Temperature Solder Exemption Applied, see EU Directive Annex 7. 2014-03 01版 20 14 20 MBRX130 C C RATINGS AND CHARACTERISTIC CURVES MBRX120 THRU MBRX160 Figure 1 Typical Forward Characteristics MBRX130~140 MBRX120 Ta= MBRX160 Ta= Ta= Ta= Ta= Ta= Amps Ta= Amps Ta= Amps Ta= Volts Instantaneous Forward Current -VS Instantaneous Forward Voltage Volts Instantaneous Forward Current -VS Instantaneous Forward Voltage Volts Instantaneous Forward Current -VS Instantaneous Forward Voltage Figure 2 Junction Capacitance 100 60 40 20 pF TJ=25°C 10 6 4 2 1 .1 2014-03 01版 .2 .4 1 Volts 2 4 10 20 40 100 200 400 1000 RATINGS AND CHARACTERISTIC CURVES MBRX120 THRU MBRX160 Figure 4 Peak Forward Surge Current Figure 3 Forward Derating Curve 60 1.2 50 1.0 40 .8 30 Amps .6 20 Amps 10 .4 0 .2 1 2 0 50 75 100 125 8 10 20 40 60 80 100 Cycles Single Phase, Half Wave 60Hz Resistive or Inductive Load 0 4 150 Peak Forward Surge Current - Amperesversus Number Of Cycles At 60Hz - Cycles 175 °C Average Forward Rectified Current - Amperesversus Ambient Temperature -°C FIG. 5 - TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES 100 10 TJ=125°C 1 0.1 TJ=75°C 0.01 TJ=25°C 0.001 0 2014-03 01版 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE, % http://www.microdiode.com
MBRX120 价格&库存
很抱歉,暂时无法提供与“MBRX120”相匹配的价格&库存,您可以联系我们找货
