B0520LW/B0530W/B0540W
SCHOTTKY DIODE
SOD-123
FEATURES
1.80(.071)
1.40(.055)
3.86(0.152)
2.84(0.112)
3.56(0.145)
2.54(0.100)
Low forward voltage drop
Guard ring construction for transient protection
High conductance
Also available in lead free version
MECHANICAL DATA
.71(0.028)
.50(0.020)
.15(.006)
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Marking: B0520LW:SD, B0530W:SE, B0540W:SF
1.35(.053)
MAX
.94(.037)
.25(.010)
MIN
Dimensions in millimeters and (inches)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Maximum ratings and electrical characteristics, Single diode @TA=25C
PARAMETER
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC Blocking voltage
RMS Reverse voltage
Average rectified output current
Peak forward surge current
Power dissipation
Thermal resistance junction to ambient
Storage temperature
Voltage rate of change
SYMBOLS
B0520LW
B0530W
B0540W
UNITS
VRRM
VRWM
VR
40
VOLTS
VR(RMS)
14
21
500
5.5
410
244
-65 to +150
1000
28
IO
IFSM
Pd
RΘJA
TSTG
dv/dt
V
mA
A
mW
C/W
C
V/uS
Electrical ratings @TA=25C
PARAMETER
Minimum reverse breakdomn voltage
SYMBOLS B0520LW B0530W
B0540W
VBR
30
40
Forward voltage
Reverse current
Capacitance between terminals
Reverse recovery time
DN:S11G03A0
VF1
VF2
VF3
IR1
IR2
IR3
IR4
IR5
CT
trr
0.34
0.43
0.375
0.430
0.510
0.62
V
V
V
V
V
V
uA
uA
uA
uA
uA
pF
4
ns
75
Unit
10
130
Conditions
IR=250uA
IR=130uA
IR=20uA
IF=0.1A
IF=0.5A
IF=1.0A
VR=10V
VR=15V
VR=20V
VR=30V
VR=40V
VR=1V,f=1.0MHz
IF=IR=10mA
Irr=0.1XIR,RL=100
STAR SEA
RATINGS AND CHARACTERISTIC CURVES B0520LW/B0530W/B0540W
FIG. 2-TYPICAL FORWARD CHARACTERISTIC
IF,INSTANTANEOUS FWD CURRENT(A)
IO.AVERAGE RECTIFIED CURRENT(A)
FIG. 1- FORWARD CURRENT DERATING CVRVE
1.0
0.8
0.6
0.4
0.2
10
Tj=25 C
Pluse width=300us
2% duty cycles
B0540W
1.0
0.1
B0530W
B0520LW
25
50
75
100
125
TL,LEAD TEMPERATURE( C)
0.2
0.4
0.6
0.8
1.0
VF INSTANTANEOUS FORWARD VOLTAGE.(V)
FIG. 3-TYP. JUNCTION CAPACITANCE
VS REVERSE VOLTAGE
CJ, CAPACITANCE (pF)
1000
100
10
1.0
10
15
VR REVERSE VOLTAGE.(V)
DN:S11G03A0
STAR SEA
很抱歉,暂时无法提供与“B0520LW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23771
- 200+0.19224
- 600+0.16697
- 国内价格
- 1+0.61050
- 200+0.20350
- 1500+0.12650
- 3000+0.10098
