AF2-2.00V125TM
AF2-2.00V125TM
    AEM
    一次性保险丝(熔断) 2A 125V
AF2-2.00V125TM 数据手册
Product Specification 产 品 规 格 书 Product Name : Fast Acting Surface Mount Fuses AEM Part Number : AF2-2.00V125TM Revision: 5 Date: 2011-6-28 AEM Components (Suzhou) Co., Ltd 458 Shenhu Road, Suzhou Industrial Park Jiangsu, P.R. China, 215122 TEL: 86-512-6258-0028 FAX: 86-512-6258-0018 www.aemchina.com *.The specification is the property of AEM Components (Suzhou) Co.Ltd and shall not be copied or used for commercial purposes without permission. *.此规格书归AEM科技(苏州)有限公司所有。未经许可,不得复制及用于其它商业用途。 Prepared by Checked by Approved by Accepted by customer Signature Page: 1/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 1 Operating Temperature Range -55℃ ~ +125℃ (with de-rating) 2 Ratings Current Rating (A) AEM Part Number AF2-2.00V125TM 2.00 Voltage Rating AC DC 250 125 Nominal Cold DCR (Ω)a 2 Nominal I t (A2s)b 0.042 2.75 a. Measured at ≤10% rated current and 25℃ ambient. b. Melting I2t at 0.001 second pre-arcing time 3 Clearing Time Characteristics % of current rating Clear-time at 25 ℃ 100% 4 hours ( min.) 200% 0.01 seconds ( min. ) 5 seconds ( max. ) 4 Interrupting Ratings: 2.00A UL: 50 A @ 125 VDC, 50 A @ 125 VAC,300 A @ 32 VDC 100 A @250 VAC (Pending) PSE (Pending): 50 A @ 125 VAC TUV (Pending): 100 A @250 VAC, 50 A@ 125 VDC 5 Marking(Optional): White marking character codes 2.00 A: I 6 Agency Approvals: 6.1 Recognized Under the Components Program of Underwriters Laboratories. File Number: E232989 6.2 PSE (Pending) 6.3 TUV (Pending) Page: 2/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 7 Shape and Dimensions: Inch (mm) Size L W T BW 2410 (6125) 0.240 ± 0.006 0.098 ± 0.006 0.085 ± 0.008 0.053 ± 0.015 (6.10 ± 0.15) (2.49 ± 0.15) (2.16 ± 0.20) (1.35 ± 0.38) 8 Product Identification AF2 2.00 V125 T M (1) (4) (5) (2) (3) (1) Series code: AF2 - Fast Acting (2) Current rating code: 2.00 - 2.00 A (3) Voltage rating code: V125 - 125 VDC (4) Package code: T - Tape & Reel B - Bulk (5) Marking code: M - with mark Page: 3/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 9. Time vs.Current Curve: AF2-2.00V125TM 100 Time (S) 10 1 0.1 0.01 0.001 0.1 1 10 100 1000 Current (A) Page: 4/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 10. I2t vs .t Curve: AF2-2.00V125TM 100000 10000 I2t (A2s) 1000 100 10 1 0.1 0.01 0.001 0.01 0.1 1 10 100 Time (s) Page: 5/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 11 Features 11.1 Fast acting at 200% overload 11.2 Excellent inrush current withstanding capability 11.3 Fiberglass enforced epoxy fuse body 11.4 Copper or copper alloy composite fuse link 11.5 Copper termination with nickel and tin plating 11.6 Halogen free, RoHS compliant and 100% lead-free 12 Typical Applications 12.1 Consumer electronics, e.g. LCD TVs, PDP, DVD, PCM etc. 12.2 Communication technology, e.g. telecom system, Networking, modem, router, changer, base station etc. 12.3 Office automation electronics 12.4 IT products, e.g. LCD monitors, notebooks, PC servers etc. 12.5 White goods, lighting 12.6 Industrial equipments 12.7 Medical equipments 12.8 Power supplies, e.g. DC/DC converters, backlight drivers etc. 13 Recommended PC Board Land Pattern Chip Size L INCH (mm) G INCH (mm) H INCH (mm) W INCH (mm) 2410 (6125) 0.270(6.86) 0.116 (2.95) 0.124 (3.15) 0.077 (1.96) Page: 6/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 14 Recommended Temperature Profile for Reflow Soldering 15 Temperature De-rating Guideline The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25℃, the fuse shall be “de-rated” according to the de-rating curve. Page: 7/10 Product Specification Fast Acting Surface Mount Fuses AEM Part Number: AF2-2.00V125TM 16 Special Measuring Equipment 16.1 Clearing Time Clearing time is measured with clearing time tester. 16.2 DC Resistance DC resistance is measured with Keithley 580/Keithley 2010. 16.3 Interrupting rating Interrupting rating is measured with short circuit tester. 17 Reliability Tests Reliability Test Test Condition and Requirement Reflow & Bend 3 reflows at 245°C followed by a 2 mm bend, 10% DCR change max., no mechanical damage Solderability 245ºC, 5 seconds, new solder coverage ≥95% Soldering Heat Resistance 260ºC, 10 seconds, 10% DCR change max., new solder coverage ≥75% Life 25ºC, 2000 hours, 80% rated current (75% for
AF2-2.00V125TM 价格&库存
很抱歉,暂时无法提供与“AF2-2.00V125TM”相匹配的价格&库存,您可以联系我们找货
AF2-2.00V125TM
    • 5+0.78362
    • 50+0.54711
    • 150+0.38000
    • 500+0.35116
    • 2000+0.33830
    • 4000+0.33059
    库存:1133
