Surface Mount Fuses
0603Size> Slow Blow> S0603-S Series
File No:JS-S0603-S-00
Revision:F
Page:1 of 6
General
• Slow Blow
• 1.6mm×0.8mm physical size
• Thick film manufacturing method, ceramic
substrate, silver fusing element
• -50℃~125℃ operating temperature
• Excellent environmental integrity
• RoHS compliant
• Halogen-free
Agency / Certificate Information
Agency
File Number
Ampere Range
JDYX2.E319512
1A~8A
JDYX8.E319512
1A~8A
Application
• Battery pack
• PC related equipment and peripherals (Hard
driver, Printer, etc.)
• Portable devices (Mobile phone, PDA battery
charger, etc.)
• Digital camera (Digital still camera)
• Game equipment
• LCD monitor, LCD modules
• Wireless base station
Ordering Information
Current
Part Number Marking
Rating
(A)
S0603-S-1.0A
H
1.0
S0603-S-1.5A
K
1.5
S0603-S-2.0A
N
2.0
S0603-S-2.5A
O
2.5
S0603-S-3.0A
P
3.0
S0603-S-3.5A
R
3.5
S0603-S-4.0A
S
4.0
S0603-S-5.0A
T
5.0
S0603-S-6.0A
6
6.0
S0603-S-7.0A
U
7.0
S0603-S-8.0A
8
8.0
Measured at≤10% rated current and 25℃
Voltage
Rating
Interrupting
Rating
50A/32V DC
32V DC
35A/32V DC
50A/32V DC
Max
Cold
DCR*(Ω)
0.260
0.104
0.054
0.036
0.027
0.022
0.016
0.0105
Typical
I2T**
(A2S)
0.0746
0.1125
0.1752
0.4001
0.7329
0.9758
2.1722
3.3128
0.0075
0.0070
0.0065
8.4692
7.2324
8.2048
2
Melting I T at 10 times of rated current
NANJING SART SCIENCE&TECHNOLOGY DEVELOPMENT CO.,LTD OR ANT TECHNOLOGY COMPANY LIMITED.(A WHOLLY OWNED SUBSIDIARY)
Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China
TEL:086-25-84354852
FAX:086-25-83241791
www.sartfuse.com
Surface Mount Fuses
Revision:E
Page:2 of 6
Catalo
Catalog Symbol
S
0603—S—1.0A
“1.0A” Ampere Rating: 1A
“ S” Electrical Characteristic: S = Slow blow
“0603” Size Number
“ S” Symbol of SART
Shape & Dimensions: (mm)
Dimensions
H
L(mm)
T(mm)
B(mm)
1.60±0.15 0.80±0.15 0.40±0.10 0.30±0.20
Recommended
Land
Patterns:
(mm)
Recommended
Land
Patterns
D
W(mm)
A
Materials:
Materials
Components
Substrate
Terminations
C
Element
Material
Ceramic
Silver over-plated
with tin (100%)
Silver or Silver /
Palladium
B
Dimensions A(mm)
B(mm)
C(mm)
D(mm)
Spec
1.00±0.20 3.00±0.50 1.40±0.20 1.00±0.30
TEL:086-25-84354852
FAX:086-25-83241791
www.sartfuse.com
Surface Mount Fuses
Revision:E
Page:3 of 6
I2T vs Time Curve
TimeCurrent
Current
Curve
Time
Curve:
Electrical Characteristics
Ampere Rating
% of Current
Rating
Opening
Time
1A-8A
100%
>4 hours
1A-8A
200%
≤60 sec
1A-3A
1000%
>0.3ms
3.5A-6A
1000%
>0.6ms
7A-8A
1000%
>1.0ms
• The current carrying capacity will be
affected by ambient temperature which
was showed in the figure.
•This current derating curve is for fusing
characteristics.
Example,
Work Temp:80℃,
Temp derating factor = 91%
I actual = I normal / 0.91
Temp derating factor %
Temperature Derating Curve
Temperature in degrees ℃
TEL:086-25-84354852
FAX:086-25-83241791
www.sartfuse.com
Surface Mount Fuses
Revision:E
Page:4 of 6
Reliability Test:
Reliability
Test
Characteristics
Voltage Drop
Time/Current
Test condition / Methods
Requirement
Test Reference
100% In; Temperature in fuse was
stabilized
Deviation between the
mean value:0.3ms
>0.6ms
>1.0ms
Refer to SART
Spec
Endurance Test
100% In, 1h on,15min off, 100 cycles;
followed by 1h at 125%In
│△R│
很抱歉,暂时无法提供与“S0603-S-3.5A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44216
- 100+0.35435
- 300+0.31040
- 1000+0.27746
