HER301-HER308
3.0 AMP. Glass Passivated High Efficient Rectifiers
DO-201AD/DO-27
Features
Glass passivated chip junction.
High efficiency, Low VF
High current capability
High reliability
High surge current capability
For use in low voltage, high frequency inventor, free
wheeling, and polarity protection application.
Mechanical Data
Case: Molded plastic
Epoxy: UL 94V0 rate flame retardant
Polarity: Color band denotes cathode
High temperature soldering guaranteed:
o
260 C/10 seconds/.375”,(9.5mm) lead
lengths at 5 lbs., (2.3kg) tension
Mounting position: Any
Dimensions in inches and (millimeters)
Weight: 1.2 grams
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol HER HER HER HER HER HER HER HER
Type Number
301
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current .375 (9.5mm) Lead Length
o
@T A = 55 C
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 3.0A
Maximum DC Reverse Current
o
@T A =25 C at Rated DC Blocking Voltage
o
@ T A =125 C
( Note 2 )
Typical Thermal Resistance (Note 3)
50
35
50
303
100
70
100
200
140
200
304
305
300
210
300
400
280
400
ht t p : //
600
420
600
307
308
Units
800 1000
560 700
800 1000
V
V
V
3.0
A
IFSM
125
A
1.0
1.3
Trr
Cj
R θJA
R θJL
1.7
V
75
35
uA
uA
nS
pF
10
200
IR
50
60
35
10
Operating & Storage Temperature Range
T J /T STG
-65 to +150
1. Reverse Recovery Test Conditions: IF =0.5A, IR =1.0A, IRR =0.25A
Notes:
2. Measured at 1 MHz and Applied Reverse Voltage of 4.0 V D.C.
3. Mount on Cu-Pad Size 16mm x 16mm on P.C.B
Revision:20170301-P1
306
I(AV)
VF
Maximum Reverse Recovery Time ( Note 1 )
Typical Junction Capacitance
V RRM
V RMS
V DC
302
www.lgesemi .c o m
o
C/W
o
C
mail:lge@lgesemi.com
HER301-HER308
RATINGS AND CHARACTERISTIC CURVES (HER301 THRU HER308)
6.0
1000
Single Phase
Half Wave 60Hz
Resistive or
Inductive Load
0.375" (9.5mm)
Lead Length
5.0
4.0
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
3.0
2.0
1.0
50
75
100
125
150
175
O
CASE TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT
100
Tj=125 0C
10
Tj=75 0C
1
Tj=25 0C
0.1
0.01
150
60
80
100
140
120
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
125
100
FIG.5- TYPICAL FORWARD CHARACTERISTICS
50
1
10
50
100
1000
NUMBER OF CYCLES AT 60Hz
175
FIG.4- TYPICAL JUNCTION CAPACITANCE
150
JUNCTION CAPACITANCE.(pF)
8.3ms Single Half Sine Wave
JEDEC Method
INSTANTANEOUS FORWARD CURRENT. (A)
PEAK FORWARD SURGE CURRENT. (A)
250
200
125
100
HE
75
HE
50
R3
R30
25
0.1
0.5
01G
1
6G
~H
ER
~HE
2
305
R30
G
10
HE
R3
05
G
1
HER301G-HER304G
0.1
HER306G-HER308G
8G
5
10
100 200
0.01
500 800
0.4
0.6
0.8
1.0
1.2
1.4
FORWARD VOLTAGE. (V)
REVERSE VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50
NONINDUCTIVE
10
NONINDUCTIVE
trr
+0.5A
50Vdc
(approx)
DUT
PULSE
GENERATOR
(NOTE 2)
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
ht t p : //
-0.25A
-1.0A
1cm
www.lgesemi .c o m
SET TIME BASE FOR
5/ 10ns/ cm
很抱歉,暂时无法提供与“HER303”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48147
- 100+0.38816
- 300+0.34150
- 1250+0.29474
- 5000+0.26676
- 10000+0.25272
