MCW-0530-2R2-N1
MCW-0530-2R2-N1
    HOTLAND(合泰盟方)
MCW-0530-2R2-N1 数据手册
    方         合 Low profile:Thickness max.3.0mm 盟 合 泰 Thin type of on-board power supply module for         盟 方 泰 合   方 盟 泰 合   方 ④ Inductance Value:2R2=2.2µH; 方 ⑤ The Material Code; 盟 泰 合 泰 盟 ⑥ Material Type; 合 29   ⑤ ⑥   N 1  ④ 盟 泰 合     泰 合 -    ③ 2R2   -   0530 方 方 盟 2,5   盟 Suggested pad layout Dimensions are in mm 泰 合   ②     - ③ Dimensions(unit:mm):5.0x5.0x3.0 泰   方 盟 方 方 盟 泰 合   (C)2.0±0.3   盟 方 泰 合       6 heating current depending on which value is lower.   (F)1.0±0.3 3 The rated current as listed is either the saturation current or the ①   合 (D)3.0Max 合       方 盟 泰 合       cooling provision all affect the part temperature.Part temperature MC W (E)0~0.15 盟 泰 泰 盟 合     方   盟 泰 合 component.PWB trace size and thickness, airflow and other 泰 盟 方 (B)5,2±0.2   方 方 盟 泰 合       125℃ under the worst case operating conditions.Circuit design, should be verified in the end application. 方       (A)5.4±0.35 The part temperature (ambient + temp rise ) should not exceed       合 合 Voltage regulator VRM for server Operat between temperature range -55℃ to +125℃   泰 盟 泰 DC/DC converters for laptop motherboards/CPU Isat :DC current (A) that will cause L0 to drop approximately 30% ② Mold Categories:W;   ※ Application Idc: DC current (A) that will cause an approximate △T of 40℃ ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards ※ Dimensions in inches (unit:mm) Test Condition:100KHz,1.0Vrms         Low loss and low resistance All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (1MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-0530-XXX-N1 Series
MCW-0530-2R2-N1 价格&库存
很抱歉,暂时无法提供与“MCW-0530-2R2-N1”相匹配的价格&库存,您可以联系我们找货
