VL812
VL812
    VIA(威盛)
    QFN-76-EP(9x9)
    VL812是一款支持USB 3.0标准的4端口集线器控制器,具有集成电压调节器,支持多种充电模式。
VL812 数据手册
VL812 USB 3.0 Hub Controller (B2) Data Sheet VL812 (B2) USB 3.0 Hub Controller December 31, 2013 Revision 1.03 VIA Labs, Inc. www.via-labs.com 7F, 529-1, Zhongzheng Rd., Xindian District, New Taipei City 231 Taiwan Tel: (886-2) 2218-1838 Fax: (886-2) 2218-8924 Email: sales@via-labs.com.tw -1- VL812 USB 3.0 Hub Controller (B2) Revision History Rev Date Initial Note 0.85 4/17/2012 TS First External Release 0.95 11/29/2012 TS Added Ordering Information for Gold Wire 1.00 2/6/2013 TS Revised for B2 Silicon Revision. Removed 3 Power Domain Implementation. Updated USB-IF Hub Certification and Windows 8 Support 1.01 3/14/13 TS Updated 5V Switching Regulator Spec 1.02 10/7/2013 TS Updated IC Reflow Profile Chart 1.03 12/31/2013 TS Fixed Incorrect Pin Descriptions for #50, 51, 52, 53 -2- VL812 USB 3.0 Hub Controller (B2) Contents Revision History ....................................................................................................................... 2 Contents ................................................................................................................................. 3 List of Figures .......................................................................................................................... 3 Product Features ...................................................................................................................... 4 VL812 System Overview ........................................................................................................... 5 Pinout..................................................................................................................................... 7 Pin List ................................................................................................................................... 8 Pin Descriptions ....................................................................................................................... 9 Signal Type Definition ................................................................................................... 9 USB 3.0 Interface ......................................................................................................... 9 USB 2.0 Interface ....................................................................................................... 10 Analog Command Block .............................................................................................. 10 Side Band signal and Miscellaneous............................................................................ 11 Test Pin ...................................................................................................................... 11 Power and Ground ...................................................................................................... 10 Electrical Specification ............................................................................................................ 12 Timing Requirements for SPI Flash ........................................................................................... 13 General Reflow Profile Guidelines. ............................................................................................ 15 Package Mechanical Specifications............................................................................................ 16 Package Top Side Marking & Ordering Information ..................................................................... 17 List of Figures Figure Figure Figure Figure Figure Figure Figure 1 2 3 4 5 6 7 – VL812 Block Diagram ................................................................................................ 5 – VL812 Pin Diagram ................................................................................................... 7 – Illustration of SPI Flash Interface Timing – (1)............................................................ 14 – Illustration of SPI Flash Interface Timing – (2)............................................................ 14 – Reflow ................................................................................................................... 15 – Mechanical Specification – QFN 76L 9x9x0.85 mm Package .......................................... 16 –Package Top Side Marking ......................................................................................... 17 -3- VL812 USB 3.0 Hub Controller (B2) Product Features VL812 Super-Speed USB Hub Controller USB 3.0 Compliant – Compliant to Universal Serial Bus 3.0 Specification Rev 1.0, including Hub errata – Compliant to Universal Serial Bus Specification Revision 2.0 – Supports simultaneous Super-speed(SS), high-speed (HS), full-speed (FS) traffic, and low-speed (LS) traffic – Four down-stream ports, one up-stream port – In-house USB PHY employs advanced CMOS process for low power consumption – Supports USB Low-Power States such as Ux states, Selective Suspend, LPM Integrated Voltage Regulators – Able to generate all required chip-power from 5V input – 5V to 1.2V Switching DC-DC Regulator – 5V to 3.3V LDO Regulator – External Power Support – 3.3V, 1.2V External Input Simplified Sideband Signal Support – Supports gang mode over current detection on down-stream ports – Supports individual mode for power enable and over current detection on 1 port for battery charging function – Supports Dual LED status indicators with automatic or manual control via GPIO per down-stream port (Typically Green & Amber) Comprehensive USB Battery Charging Support – Supports USB Battery Charging Specification v1.2 (SDP, CDP, DCP) – Adds Support for Vendor Specific Charging Modes eg. Apple, RIM, etc. – Supports YD/T 1591-2009 – Supports “Sleep Charging” (DCP + Apple Mode) – Support charging on 1 down-stream port, depending on configuration Physical – QFN 76L green package (9x9x0.85 mm) Certification – Earned USB 2.0 USB-IF certification – Earned USB 3.0 USB-IF certification TID# 330000022 – Passed Windows 8 WHCK Testing Applications – Standalone USB hub – Desktop front panel hub/Integrated Monitor/TV hub – Notebook/Ultrabook Docking Station / Port Replicator – USB hub compound device with keyboard, mouse, display, etc. Platform and Operating System Support – General support across all major OS and platforms that offer USB such as PC, MAC, Linux, etc. – FW Update over USB – USB hub function is dependent upon the USB Host Controller – No proprietary driver needed, even for Battery Charging Function Misc – – – Optimized for Low Power consumption PLL embedded with external 25MHz crystal Support external SPI flash for firmware upgrade -4- VL812 USB 3.0 Hub Controller (B2) VL812 System Overview VIA Lab’s VL812 is an advanced 4-port USB 3.0 Hub controller featuring fully-integrated voltage regulators, low power consumption, and comprehensive USB Charging support. The integrated 5V DC-DC switching regulator enables VL812 to be powered directly from 5V USB VBus, reducing BOM cost while offering high power efficiency. The custom in-house USB PHY supports USB power management and gives VL812 excellent signal integrity characteristics and improved backwards compatibility. VL812 also features a flexible firmware architecture, providing a framework for custom functions in addition to in-field updates. VL812 based hub devices work under Windows, Mac OS X, and various Linux kernels without additional drivers. Since USB 3.0 hubs do not require additional drivers, VL811+ is also compatible with non-x86 devices and platforms that support USB hub functions such as smart phones, tablets, and set-top boxes. It is well suited for all USB hub applications such as stand alone USB hubs, Notebook/Ultrabook docking stations/port-replicators, desktop PC front panel, motherboard on-board hub, and USB hub compound devices. With well-planned pinout and a high level of integration, VL812 based devices enjoy easy layout and simplified BOM. Sideband signal pins are available for showing power enable, over current, GPIO, and LED status control. The SPI interface supports external EEPROM/Flash ROM which can be updated over USB. VL812 is available in QFN 76L green package (9x9x0.85 mm) to fit small form-factor designs. Figure 1 – VL812 Block Diagram -5- VL812 USB 3.0 Hub Controller (B2) Rapid Charging over USB in Detail 3 Concepts of Rapid Charging over USB:  Rapid Charging over USB enables charging of devices at rates in excess of baseline USB standards. The current limit of USB 2.0 is 500mA for configured devices, and the current limit of USB 3.0 is 900mA for configured devices. Depending on the device, Rapid Charging implementations typically feature current limits between 1000mA to 2000mA.  It is the Host/Hub’s responsibility to advertise Rapid Charging capabilities, and it is the Device’s responsibility to recognize and determine the Rapid Charging capabilities of the Host/Hub port it is connected to. Since Rapid Charging over USB allows charging at rates in excess of USB spec, this detection mechanism is necessary to ensure safe and reliable operation, and can prevent situations where a device requests more current than what a host/hub port can supply. Also, this implies that Rapid Charging will only occur when both Host/Hub and Device supports it.  The rate at which a device charges is dependant upon the device. This means that the device must determine the host/hub port’s capabilities to determine which charging mode to use. Also, the rate at which a device charges can vary depending on the status of the device. For example, some devices only charge at their maximum rate when the battery is nearly depleted. When the battery is nearly full, they may switch to a trickle-charge mode. The Host/Hub rapid-charging port has no control over this behavior. Supported USB Charging Modes SDP – Standard Downstream Port This is a typical USB 2.0 or USB 3.0 port and does not explicitly support Rapid USB Charging. SDP is constrained to the current limits as defined in the USB 2.0 or USB 3.0 spec which are 500mA and 900mA respectively. While the actual current limit is enforced by the polyfuse or power-switch providing current-limiting functionality for the downstream port, most USB devices will not draw more than 500mA or 900mA under USB 2.0 or USB 3.0 modes. CDP – Charging Downstream Port CDP is defined in the USB Battery Charging Specification 1.2 and enables devices that are able to correctly recognize CDP to simultaneously function as a USB device while drawing up to 1.5A for Rapid Charging when connected to the downstream port of a USB Host or Hub that advertises CDP capability. DCP – Dedicated Charging Port DCP is defined in the USB Battery Charging Specification 1.2 and has been in use on an unofficial basis prior to the official USB Battery Charging Specification. DCP is a dedicated charging mode, so when a device is charging under DCP, regular USB operations such as data transfer to the device are not supported. Special Modes Various vendors such as Apple, RIM, Motorola, etc may employ different detection mechanisms compared to other USB devices and thus, may enter Rapid Charging under the previously mentioned charging modes. VL811+ supports an auto detection mechanism that provides charging for the majority of devices. -6- VL812 USB 3.0 Hub Controller (B2) Pinout Figure 2 – VL812 Pin Diagram -7- VL812 USB 3.0 Hub Controller (B2) Pin List Table 1 – VL812+ Pin List Pin Pin Name Pin Pin Name 1 SSREXT 39 LX 2 VCCA33SSM 40 DC12FB 3 SSTX3+ 41 VSUS33 4 SSTX3- 42 USBHPE2B# 5 VCCA12SSRX3 43 USBHPE1# 6 SSRX3+ 44 USBHOC2# 7 SSRX3- 45 USBHOC1# 8 VCCA33SS34 46 COREPWRDN# 9 USBHP3+ 47 EXTPWRON 10 USBHP3- 48 VDD 11 SSTX4+ 49 VSUS33 12 SSTX4- 50 USBHGRN4 13 VCCA12SSRX4 51 USBHGRN3 14 SSRX4+ 52 USBHGRN2 15 SSRX4- 53 USBHGRN1 16 USBHP4+ 54 RESET# 17 USBHP4- 55 SMCLK 18 DC33FB 56 SMDAT 19 VCC5I 57 TESTEN 20 VCC12I 58 VDD 21 DC10FB 59 SSTX1+ 22 SSTX0- 60 SSTX1- 23 SSTX0+ 61 VCCA12SSRX1 24 VCCA12SSRX0 62 SSRX1+ 25 SSRX0- 63 SSRX1- 26 SSRX0+ 64 USBHP1+ 27 VCCA33SS0 65 USBHP1- 28 USBDP+ 66 SSTX2+ 29 USBDP- 67 SSTX2- 30 VDD 68 VCCA12SSRX2 31 VBUSDET 69 SSRX2+ 32 USBHMBR4 70 SSRX2- 33 USBHMBR3 71 VCCA33SS12 34 USBHMBR2 72 USBHP2+ 35 USBHMBR1 73 USBHP2- 36 VSUS33 74 VCCA12SSM 37 DC12FB 75 SSXI 38 VCC5I 76 SSXO -8- VL812 USB 3.0 Hub Controller (B2) Pin Descriptions Signal Type Definition Name Type Signal Description Input I A logic input-only signal Output O A logic output only signal Input/Output I/O A logic bi-directional signal Power PWR A power pin Ground GND A ground pin Pin Name Pin # I/O SSTX0+ 23 SSTX0- 22 USB 3.0 UP Port Differential Transmit Data - SSRX0+ 26 USB 3.0 UP Port Differential Receive Data + SSRX0- 25 VCCA12SSRX0 24 SSTX1+ 59 USB 3.0 Interface Signal Description USB 3.0 UP Port Differential Transmit Data + USB 3.0 UP Port Differential Receive Data PWR Analog 1.2V USB 3.0 DP1 Port Differential Transmit Data + SSTX1- 60 USB 3.0 DP1 Port Differential Transmit Data - SSRX1+ 62 USB 3.0 DP1 Port Differential Receive Data + SSRX1- 63 USB 3.0 DP1 Port Differential Receive Data - VCCA12SSRX1 61 SSTX2+ 66 PWR USB 3.0 DP2 Port Differential Transmit Data + Analog 1.2V SSTX2- 67 USB 3.0 DP2 Port Differential Transmit Data - SSRX2+ 69 USB 3.0 DP2 Port Differential Receive Data + SSRX2- 70 USB 3.0 DP2 Port Differential Receive Data - VCCA12SSRX2 68 PWR VCCA33SS12 71 PWR SSTX3+ 3 Analog 1.2V Analog 3.3V USB 3.0 DP3 Port Differential Transmit Data + SSTX3- 4 USB 3.0 DP3 Port Differential Transmit Data - SSRX3+ 6 USB 3.0 DP3 Port Differential Receive Data + SSRX3- 7 USB 3.0 DP3 Port Differential Receive Data - VCCA12SSRX3 5 PWR VCCA33SS34 8 PWR SSTX4+ 11 Analog 1.2V Analog 3.3V USB 3.0 DP4 Port Differential Transmit Data + SSTX4- 12 USB 3.0 DP4 Port Differential Transmit Data - SSRX4+ 14 USB 3.0 DP4 Port Differential Receive Data + SSRX4- 15 VCCA12SSRX4 13 PWR Analog 1.2V VCCA33SSM 2 PWR USB 3.0 Master Block Analog 3.3V USB 3.0 DP4 Port Differential Receive Data - -9- VL812 USB 3.0 Hub Controller (B2) USB 2.0 Interface Pin Name Pin # I/O USBDP+ 28 USB 2.0 UP Bus Data Plus (D+) USBDP- 29 USB 2.0 UP Bus Data Minus (D–) VCCA33SS0 27 USBHP1+ 64 USB 2.0 DP1 Bus Data Plus (D+) USBHP1- 65 USB 2.0 DP1 Bus Data Minus (D–) USBHP2+ 72 USB 2.0 DP2 Bus Data Plus (D+) USBHP2- 73 USB 2.0 DP2 Bus Data Minus (D–) USBHP3+ 9 USB 2.0 DP3 Bus Data Plus (D+) USBHP3- 10 USB 2.0 DP3 Bus Data Minus (D–) USBHP4+ 16 USB 2.0 DP4 Bus Data Plus (D+) USBHP4- 17 USB 2.0 DP4 Bus Data Minus (D–) PWR Signal Description Analog 3.3V Analog Command Block Pin Name Pin # SSXI 75 25M crystal input SSXO 76 25M crystal output VCCA12SSM 74 SSREXT 1 Power and Ground Pin Name Pin # GND EPAD VDD 30,48,58 VSUS33 36,41,49 VCC5I 19 DC33FB 18 VCC12I 20 DC10FB 21 VCC5I 38 DC12FB 37, 40 LX 39 I/O PWR Signal Description Analog 1.2V Connect to reference resistor for Super speed mode I/O GND PWR PWR PWR PWR GND FLOAT PWR PWR PWR Signal Description Ground 1.2V Core power 3.3V suspend power 5V Input for 5-3.3V Regulator 5-3.3V LDO Regulator Output Ground NC (Float) 5V Input for integrated 5-1.2V Regulator 5-1.2V DC-DC Switching Regulator Output LX for 5-1.2V DC-DC Switching Regulator - 10 - VL812 USB 3.0 Hub Controller (B2) Side Band signal and Miscellaneous Pin Name Pin # I/O Signal Description USBHMBR1 35 O USBHMBR2 34 O USBHMBR3 33 O USBHMBR4 32 O USBHGRN1 53 O DP1 Amber (Over Current) LED Indicator and SPISO share pin. For LED, output high when active and external 100Kohm pull low required. DP2 Amber (Over Current) LED Indicator and SPISI share pin. For LED, output high when active and external 100Kohm pull low required. DP3 Amber (Over Crrrent) LED Indicator / SPISCLK share pin. For LED, output high when active and external 100Kohm pull low required. DP4 Amber (Over Current) LED Indicator / SPICS# share pin. For LED, output high when active and external 100Kohm pull low required. DP1 Green (Port Connect) LED Indicator. Output high when active and external 100Kohm pull low required. USBHGRN2 52 O DP2 Green (Port Connect) LED Indicator. Output high when active and external 100Kohm pull low required. USBHGRN3 51 O DP3 Green (Port Connect) LED Indicator. Output high when active and external 100Kohm pull low required. USBHGRN4 50 O DP4 Green (Port Connect) LED Indicator. Output high when active and external 100Kohm pull low required. USBHPE1# 43 O USBHPE2B# 42 O USBHOC1# 45 I USBHOC2# 44 I EXTPWRON 47 I Power Enable for Gangmode Ports Low: Port Power On. High: Port Power Off. Power Enable for USB Charging Port Low: Port Power On. High: Port Power Off. DP1 Over Current Detect Low: Port Over Current High: Port Power Normal DP2 Over Current Detect Low: Port Over Current High: Port Power Normal Upstream Port VBUS Detection for Upstream port plug-in COREPWRDN# 46 O Core power down (Reserved for controlling external core power switch) VBUSDET 31 I 5V USB VBus Presence Detect RESET# 54 I System Reset Low: Reset High: Normal Operation Test Pin Pin Name TESTEN Pin # 57 I/O I SMCLK 55 I SMDAT 56 I/O Signal Description Test Mode Enable Do not connect for normal operation. Internal pull down. Low: Normal mode. High: Test mode. SMBus clock for debug only. It is not a standard SMBus interface. Open Drain SMBus data for debug only. It is not a standard SMBus interface. Open Drain - 11 - VL812 USB 3.0 Hub Controller (B2) Electrical Specification Absolute Maximum Rating Symbol Parameter Min Max Unit Note TSTG Storage Temperature -55 125 °C — V50 -0.5 5.5 V — -0.5 3.63 V — V12 5V Power Supply Voltage 3.3V Power Supply Voltage 1.2V Input Voltage -0.5 1.26 V — VIN Input voltage at I/O pins -0.5 V — VESD Electrostatic Discharge -2000 (≦ 3.63) and (≦ V33+0.3) 2000 V Human Body Model θjc Thermal resistance between junction and case  For 4-layer PCB: 9.1  For 2-layer PCB: 11.3 θja Thermal resistance between junction and ambient  For 4-layer PCB: 21.8  For 2-layer PCB: 56.8 °C/W PD Power dissipation — W V33 1.0 °C/W 2L & 4L PCB definitions follow JESD51-7 Note: Stress above conditions may cause permanent damage to the device. Functional operation of this device should be restricted to the conditions described. Note: About thermal factors, Ta is the concerned ambient temperature, and θca = θja - θjc TJ = θja * PD + Ta Tc = θca * PD + Ta Operating Conditions Symbol Parameter Min Max Unit Note TA Ambient Temperature 0 70 °C — Tj Junction Temperature 0 125 °C — 4.75 5.25 V — 3.0 3.6 V — V50 V33 5V Power Supply Voltage 3.3V Power Supply Voltage 1.2V Nominal V12 1.2V Input Voltage 1.14 1.25 V VIL Input Low Voltage — 0.8 V — VIH Input High Voltage 2.0 — V — VOL Output Low Voltage — 0.4 V IOL=4mA VOH Output High Voltage 2.4 — V IOH=4mA IIL Input Leakage Current — +/-10 µA 0
VL812 价格&库存
很抱歉,暂时无法提供与“VL812”相匹配的价格&库存,您可以联系我们找货
