YL CONNECTOR
4.5mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
Panel lock
• Current rating: 10 A AC, DC max. (7 A when retainers are mounted)
• Voltage rating: 300 V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 7 mΩ max.
After environmental tests/ 10 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25 mm2
• Applicable panel thickness: 0.7 to 2.0 mm
Inner lock
Retainer
Housing lance
Note: The current rating varies depending on the number of circuits and the wire
size used in each connector. The table below lists the current rating as a
function of the number of circuits and the wire size.
Current unit: A
Circuits
The retainer features added protection
against non-insertion or disconnection.
• Housing lance
• Secondary retainers
• Inner-housing lock
• Panel lock construction
Standards ––––––––––––––––––––
Wire size (AWG)
#16
#18
#20
#22
#24
#26
1
10
7
5
4
3
2
2
10
7
5
4
3
2
3
9
6
4
4
3
2
4
9
6
4
4
3
2
6
8
5
3
3
2
2
8
7
4
3
3
2
2
9
6
4
3
3
2
2
12
6
3
2
2
2
2
15
5
3
2
2
2
1
16
5
3
2
2
2
1
21
5
3
2
2
2
1
Note: Secondary retainers cannot be used with AWG #16 wires.
Recognized E60389
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
1
2 R9351052
Certified LR20812
Panel Layout and Assembly layout
A
B
35.1
38.7 (including retainer)
10.8
16.6
20.5
21.8
3.2
9.5
15.3
9.8
A
C
Single row
2・3
2-row 4・6・8・12・16
3-row 9・12・15・21
Dimensions (mm)
A
B
D
Circuits
E
Type
Panel
thickness
Cir- Receptacle (mm)
cuits housing
Model No. Dimensions
(mm)
2
YLR-02V
3
YLR-03V
4
YLR-04V
6
YLR-06V
8
YLR-08V
9
YLR-09V
YLR-12V
12
YLR-12VA
15
YLR-15V
16
YLR-16V
21
YLR-21V
0.7 to 2.0
0.7 to 0.8
0.9 to 1.3
1.4 to 2.0
D±0.1 E±0.1 D±0.1 E±0.1
D±0.1 E±0.1
A
B
C
10.7
16.8
7.1
4.4
1.35
5.0
1.05
5.6
0.75
15.3
21.3
7.1
4.4
1.35
5.0
1.05
5.6
0.75
10.7
16.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
15.3
21.3
12.9
7.1
2.9
7.7
2.6
8.3
2.3
19.8
25.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
15.3
21.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
19.8
25.8
18.2
7.1
5.55
7.7
5.25
8.3
4.95
28.9
34.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
24.4
30.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
37.9
43.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
33.5
39.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
Note: 1. Punch holes in the panel according to the figures and table shown
above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or
more holes.
3. The connector must be inserted from the same side as the hole is
punched.
B
1
YL CONNECTOR
Contact
Applicable wire
Model No.
2
Pin contact
Pin contact
AWG #
Insulation O.D.
(mm)
26∼20
1.3∼2.5
0.5 ∼1.25
20∼16
2.0∼3.4
*0.3+0.3∼
0.5+0.5
*22+22∼
20+20
mm2
Socket contact
SYM-01T-P0.5A SYF-01T-P0.5A 0.13∼0.5
Q'ty/
reel
4,000
19.5
SYM-41T-P0.5A SYF-41T-P0.5A
4.4
2
0.5
1.1
SYM-01T-P0.5A
5,000
*1.5+1.5∼
2.0+2.0
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. Contact JST for special products.
2. Retainers cannot be used with electric wire whose insulation O.D.
exceeds 2.7mm and AWG #16.
¨V .
3. *Marked products are not approved by TU
2.8
Socket contact
4.4
2
SYM-01T-P0.5A
1.1
SYF-01T-P0.5A
MKS-L
AP-K2N
SYM-41T-P0.5A
1.8
Applicator
Crimping
machine Crimp applicator
Contact
14.2
*MKS-SC-YL
SC/SYF/M-01-05 APLSC SYF/M01-05
MKS-L
SYF-41T-P0.5A
Crimp applicator with dies
Dies
MK/SYF/M-01-05 APLMK SYF/M01-05
MK/SYF/M-41-05 APLMK SYF/M41-05
*MKS-SC-YL
SC/SYF/M-41-05 APLSC SYF/M41-05
Note: *Strip-crimp applicator
Contact position location numbers
Contact position numbers are stamped
Retainer
Receptacle housing
Retainer
Plug housing
3
2
2
3
2
1
1
4
4
8
L JST
3
7
12
11
10
L JST
8
9
3
7
6
2
5
21
17
16
15
19
11
10
9
8
12
13
14
1
7
6
7
15
6
14
5
13
4
12
3
11
2
10
9
L JST
15
14
13
12
11
1
15
14
13
10
9
8
12
1
11
9
7
2
6
10
4
3
3
11
2
4
1
12
7
6
5
4
3
2
1
5
8
16
1
5
1
14
13
12
11
10
9
8
10
9
8
7
6
5
4
10
7
1
8
6
15
14
6
5
4
3
2
1
21
18
17
16
15
5
4
3
2
1
4
5
11
6
12
16
15
14
13
12
11
10
9
4
1
5
1
8
7
6
5
4
3
2
1
3
2
L JST
7
2
11
10
9
8
7
6
8
7
6
5
4
3
2
1
2
9
12
11
10
9
8
7
1
3
16
L JST
4
17
10
6
5
4
3
2
1
L JST
5
18
11
3
9
6
19
12
15
7
15
14
13
12
11
8
16
3
12
1
4
3
2
1
L JST
4
8
5
9
2
8
7
6
5
13
5
13
L JST
2
9
6
14
3
10
10
7
L JST
11
15
4
8
12
12
11
10
9
16
15
14
13
12
11
10
9
2
6
3
6
2
5
L JST
4
2
L JST
3
3 6
2 5
1 4
2
8
13
L JST
7
21
14
2
3
1
3 6 9
2 5 8
1 4 7
9
7
8
2
7
8
2 4
1 3
1
3
6
9
9 6 3
8 5 2
7 4 1
4
3
2
1
5
4
8
7
6
5
6 3
5 2
4 1
6
5
4
3
2
1
4
10
L JST
5
1
11
4
7
1
1
6
8
L JST
5
4
12
2
2
6
5
3
3
7
2
6
4
9
8
3
5
L JST
L JST
6
12
11
10
9
8
7
L JST
1
1
1
1
1
2
1
L JST
3
1
L JST
L JST
2
L JST
1
4 2
3 1
2
4
3
2
1
3
2
2
1
L JST
L JST
1
Plug housing
L JST
Receptacle housing
4
3
2
1
8
7
6
5
4
3
2
1
8
7
6
5
12
11
10
9
7
6
5
4
3
2
1
14
13
12
11
10
9
8
21
18
17
16
15
YL CONNECTOR
Housing
Material: Housing...PA 66, UL94V-0, white
Retainer...Glass-filled PA 66, UL94V-0, ivory
26.6
3.0
20.9
3.35
500
6.0
YLP-02V
Q´ty/
bag
YLS-02V
Q´ty/
bag
L JST
26.6
L JST
500
500
8.5
3.5
20.9
8.3
3.0
1
3.1
YLR-02VF
6.0
1,000
2.9
2
L JST
10.3
1,000
2.9
2
10.3
8.5
500
Q´ty/
bag
6.7
7A
(10A)
Q´ty/
bag
3.8
L JST
3.0
YLR-02V
300V
YLS-01V
1
6.7
2
Retainer
Q´ty/
bag
2
(10A)
YLP-01V
1
300V
Q´ty/
bag
L JST
1
7A
5.8
YLR-01VF
Plug housing (for socket contact)
5.8
Receptacle housing (for pin contact)
10.3
Voltage Current
Circuits rating rating
1
6.7
3.1
26.6
YLR-03V
3.0
Q´ty/
bag
YLP-03V
Q´ty/
bag
2
YLR-03VF
1
500
12.8
26.6
14.8
3.1
3
6.7
6A
(9A)
L JST
3.0
1
300V
Q´ty/
bag
2
L JST
14.8
3
3
YLS-03V
(commonly used for
3-circuit housing and
6-circuit housing)
500
1,000
8.5
3.5
6.0
2.9
2
L JST
14.8
3
20.9
1
6.7
3.1
26.6
RoHS compliance
Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.)
2. Contact JST for Glow Wire compliant connectors.
3
YL CONNECTOR
Housing
Voltage Current
YLR-04V
3.0
Q´ty/
bag
YLS-02V
Q´ty/
bag
2
4
10.3
YLP-04V
Retainer
L JST
3
1
(9A)
8.3
3
6A
10.3
4
26.6
2
3.1
L JST
3.0
1
300V
Q´ty/
bag
12.5
4
YLR-04VF
8.5
500
20.9
1,000
2.9
11.8
2
4
L JST
10.3
500
3.5
3
1
12.5
3.1
26.6
YLR-06V
YLP-06V
Q´ty/
bag
6
3
5
2
L JST
14.8
3.0
Q´ty/
bag
YLS-03V
(commonly used for
6-circuit housing)
Q´ty/
bag
4
3.0
1
3.1
26.6
500
12.8
2
5
YLR-06VF
14.8
(8A)
4
300V
500
1
6
L JST
3
6
12.5
5A
1,000
8.5
6
3
5
2
L JST
14.8
20.9
3.5
2.9
11.8
4
1
L JST
12.5
3.1
26.6
YLR-08V
YLP-08V
Q´ty/
bag
YLS-08V
Q´ty/
bag
8
4
7
3
6
2
L JST
19.3
3.0
Q´ty/
bag
5
250
19.0
2
6
5
YLR-08VF
19.3
26.6
L JST
3.1
4A
(7A)
500
1
300V
3
7
4
8
3.0
1
12.5
8
1,000
8
4
7
3
6
2
20.9
3.5
11.8
2.9
L JST
19.3
8.5
5
1
12.5
3.1
26.6
YLR-09V
YLP-09V
Q´ty/
bag
3.5
1
14.8
9
L JST
8
7
6
1
4
7
3.0
3
2
5
5
500
8.5
17.7
3.1
26.6
20.9
RoHS compliance
4
2
3
8
250
4
6
4A
(6A)
L JST
300V
9
9
14.8
3.0
Q´ty/
bag
17.0
Q´ty/
bag
YL CONNECTOR
Housing
Circuits Voltage Current
rating rating
YLR-12VA
Q´ty/
bag
YLP-12VA
Retainer
Q´ty/
bag
YLS-12V
Q´ty/
bag
3.0
3.1
26.3
L JST
28.3
3
5
11
4
9
4
10
5
10
3
9
6
11
200
1,000
1
1
7
7
2
8
200
2
8
12
6
12
3.5
L JST
28.3
3.0
8.5
2.9
3A
(6A)
YLR-12V
Q´ty/
bag
Q´ty/
bag
Q´ty/
bag
3.0
3.1
19.3
12
11
L JST
10
5
5
9
200
1
200
Q´ty/
bag
Q´ty/
bag
1
9
2
8
3
6
7
4
7
6
8
10
L JST
11
4
3.5
12
19.3
YLP-12V
3
300V
11.8
2
12
20.9
26.6
12.5
3.0
8.5
17.7
26.6
YLR-15V
Q´ty/
bag
3.0
23.8
15
14
13
10
9
8
12
6
11
11
7
7
2
12
6
200
1
1
L JST
5
3
4
8
3
4
13
200
2
5
9
23.8
10
L JST
3A
(5A)
YLP-15V
3.5
14
300V
17.0
3.1
15
15
20.9
Q´ty/
bag
17.0
YLP-16V
Q´ty/
bag
YLS-16V
Q´ty/
bag
11
3
10
2
100
L JST
37.0
200
1,000
1
1
9
9
4
7
15
12
6
14
5
5
13
6
4
12
7
8
16
3.5
2
10
8
13
L JST
14
3A
(5A)
15
300V
37.3
3.0
3.1
16
16
20.9
37.3
YLR-16V
26.6
3
11
3.0
8.5
17.7
3.0
8.5
12.5
26.6
20.9
11.8
2.9
RoHS compliance
5
YL CONNECTOR
Housing
YLR-21V
Q´ty/
bag
3.0
2
8
1
3.0
17.7
26.6
20.9
RoHS compliance
17.0
L JST
32.8
18
17
9
16
3
15
10
8.5
6
Q´ty/
bag
21
7
14
6
13
5
12
4
4
11
11
3
5
10
12
15
9
6
16
2
13
17
100
1
7
32.8
14
18
L JST
19
3A
(5A)
Q´ty/
bag
3.5
300V
YLP-21V
Retainer
3.1
21
21
8
rating rating
200
很抱歉,暂时无法提供与“SYM-01T-P0.5A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1563+0.525321563+0.06829
- 2500+0.509612500+0.06625
- 国内价格 香港价格
- 5000+0.295865000+0.03846
- 国内价格
- 1+1.49160
- 2500+1.11870
- 5000+0.74580
- 国内价格
- 100+0.25720
- 1000+0.21070
- 5000+0.18490
- 10000+0.11520
