CZHR-09V-S
CZHR-09V-S
    JST
    P=1.5mm
    1X9P 1.5MM
CZHR-09V-S 数据手册
IDC style CZ connector Socket or Crimp style CZH connector Socket Specifications ––––––––––––––––––– CZF connector CZF / CZ connectors Current rating Voltage rating Temperature rise CZF / CZH connectors 2 A AC, DC (AWG #26) 100V AC, DC -25°C to +85°C (including temperature rise in applying electrical current) Contact resistance Initial value / 10 mΩ max. After environmental tests / 20 mΩ max. Insulation resistance Withstanding voltage The SMT top entry type headers that can be mated with the 1.5 mm pitch CZ connector socket are on the lineup. • Suction tape is not required because the flat area for picking up is provided to the connector. • This header can be accommodated to both the crimp style and the insulation displacement (ID) style sockets. 500 MΩ min. 500 VAC/minute UL10272 (Contact JST for other UL style wires.) AWG #28, # 26 Applicable wire Conductor AWG #28 to # 26 / 7-strands, tincoated annealed copper Insulation O.D. / 0.7 to 0.83 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 PC board layout and Assembly layout A±0.1 1.1min 4.7 4.7 0.45 min 1.5±0.05 0.9min when matng with CZ 5.1min when matng with CZH 0.9 6.2 6.8 Connector outline Recommended pattern layout Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 CZF connector SMT type header B A 4.5 Model No. 2 BM02B-CZFKS-TF BM03B-CZFKS-TF BM04B-CZFKS-TF BM05B-CZFKS-TF BM06B-CZFKS-TF BM08B-CZFKS-TF 3 4 5 6 6.2 Dimensions (mm) A B Circuits 8 Q'ty/ reel 1.5 6.0 1,150 3.0 7.5 1,150 4.5 9.0 1,150 6.0 10.5 1,150 7.5 12.0 1,150 10.5 15.0 1,150 Material and Finish Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, black Circuit No.1 RoHS compliance This product displays (LF)(SN) on a label. CZ connector socket Model No. Circuits Gray 02CZ-6H 03CZ-6H 04CZ-6H 05CZ-6H 06CZ-6H 08CZ-6H 2 3 4 B 5 4.4 A 6 Q'ty/ box 1.5 4.5 2,000 3.0 6.0 2,000 4.5 7.5 2,000 6.0 9.0 2,000 7.5 10.5 2,000 10.5 13.5 2,000 Material and Finish 2.7 4.1 HJST 8 Dimensions (mm) A B Yellow 02CZ-6Y 03CZ-6Y 04CZ-6Y 05CZ-6Y 06CZ-6Y 08CZ-6Y Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: Glass-filled PA 66, UL94V-0 Circuit No.1 (Triangle-mark indicates) 4.1 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02CZ-6H Y…yellow H…natural (grayish color) CZH connector contact Applicable wire mm2 AWG# Model No. SCZH-002T-P0.5 4.05 2.2 0.08∼ 0.13 1.1 Insulation O.D. (mm) Q'ty/reel 28∼26 0.8∼1.1 13,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 1.5 RoHS compliance Contact 1.1 Crimping machine Crimp applicator SCZH-002T-P0.5 AP-K2N MKS-L   ―   Applicator Dies Crimp applicator with dies MK/SCZH-002-05 APLMK SCZH002-05 ― ― CZH connector housing B A 3.7 Circuits Model No. 2 CZHR-02V-S CZHR-03V-S CZHR-04V-S CZHR-05V-S CZHR-06V-S CZHR-08V-S 3 4 1.5 5 6 1 Q'ty/ box 1.5 4.5 3.5 1,000 3.0 6.0 5.0 1,000 4.5 7.5 6.5 1,000 6.0 9.0 8.0 1,000 7.5 10.5 9.5 1,000 10.5 13.5 12.5 1,000 2 3 5 8 Dimensions (mm) A B C Material PBT, UL94V-0, natural (white) C 2.7 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. CZHR-02V-S S…natural (white) K…black H…gray Y…yellow 2 4
CZHR-09V-S 价格&库存
很抱歉,暂时无法提供与“CZHR-09V-S”相匹配的价格&库存,您可以联系我们找货
CZHR-09V-S
    • 1+0.898531+0.11639
    • 10+0.6106510+0.07910
    • 50+0.5321450+0.06893
    • 100+0.47980100+0.06215
    • 500+0.45363500+0.05876
    • 1000+0.444901000+0.05763
    • 2000+0.436182000+0.05650
    库存:955
    CZHR-09V-S
      库存:60000
