SMDJ Series
DOWOSEMI
Working Voltage: 5.0 to 440 V
Peak Pulse Power: 3000 W
Surface Mount
Transient Voltage Suppressors
Features
SMDJ Series
东沃电子
SMC/ DO-214AB
Glass passivated chip
3000 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
DO
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
WO
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000μs waveform(1)
(1)
Peak pulse current wih a 10/1000μs waveform
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sine(2)
wave unidirectional only
Maximum instantaneous forward voltage at 100A for
(3)
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
3000
IPP
See Next Table
PD
6.5
UNIT
W
A
W
IFSM
300
A
VF
3.5/5.0
V
TJ, TSTG
55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“SMDJ28CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.18541
- 50+0.92416
- 150+0.81216
- 500+0.67241
- 3000+0.64131
- 6000+0.60405
- 国内价格
- 1+2.62440
- 10+2.08440
- 30+1.84680
- 100+1.55520
- 500+1.33920
- 1000+1.25280
