DATASHEET
AXP209
Enhanced single Cell Li-Battery and Power System Management IC
X-Powers
© 2010 X-Powers Limited - All rights reserved
AXP209
目录
1.概述(Summary)............................................................................................................................................ 3
2.特性(Feature) ................................................................................................................................................ 4
3.典型应用(Typical Application) ................................................................................................................. 5
4.极限参数(Absolute Maximum Ratings) ............................................................................................... 6
5.电气特性(Electrical Characteristics) ....................................................................................................... 6
6.典型特性(Typical Characteristics)........................................................................................................... 9
7.管脚定义(Pin Description)....................................................................................................................... 12
8.功能框图(Functional Block Diagram).................................................................................................. 14
9.控制和操作(Control and Operating) .................................................................................................... 15
9.1 工作模式和复位(Power On/Off & Reset) ...................................................................................... 15
9.2 电源通路管理(IPS)............................................................................................................................... 17
9.3 自适应 PWM 充电器(Adaptive PWM Charger) ........................................................................... 19
9.4 备用电池(Backup Batttery) .............................................................................................................. 22
9.5 多路电源输出(Multi-Power Outputs)............................................................................................. 23
9.6 默认电压/启动时序的设置(Default Voltage/Timing Setting) .................................................... 24
9.7 信号采集系统(Signal Capture)......................................................................................................... 25
9.8 多功能管脚说明(Multi-Function Pin Description) ...................................................................... 25
9.9 定时器(Timer)...................................................................................................................................... 25
9.10 解密(Decryption) ............................................................................................................................. 26
9.11 HOST 接口及中断(TWSI and IRQ)................................................................................................. 26
9.12 寄存器(Registers) .............................................................................................................................. 28
10.封装(Package) .......................................................................................................................................... 45
VQ.QW WPPIQPWE CC
Confidential
Page 2/45
AXP209
1.概述(Summary)
AXP209 是高度集成的电源系统管理芯片,针对单芯锂电池(锂离子或锂聚合物)且需要多路电源转换
输出的应用,提供简单易用而又可以灵活配置的完整电源解决方案,充分满足目前日益复杂的应用处理
器系统对于电源精确控制的要求。
AXP209 集成了一个自适应的 USB-Compatible 的 PWM 充电器,2 路降压转换器(Buck DC-DC
converter),5 路线性稳压器(LDO),电压/电流/温度等多路 12-Bit ADC,以及 4 路可配置的 GPIO。为保
证电源系统安全稳定,AXP209 还整合了过/欠压(OVP/UVP)、过温(OTP)、过流(OCP)等保护电路。
AXP209 的智慧电能平衡(Intelligent Power Select, IPS™)电路可以在 USB 以及外部交流适配器、锂电
池和应用系统负载之间安全透明的分配电能,并且在只有外部输入电源而没有电池(或者电池过放/损坏)
的情况下也可以使应用系统正常工作。
AXP209 具有外部适配器和 USB 以及电池等三输入能力,支持可充电备用电池。
AXP209 提供了一个两线串行通讯接口:Two Wire Serial Interface (TWSI),应用处理器可以通过这个接
口去打开或关闭某些电源输出,设置它们的电压,访问内部寄存器和多种测量数据(包括 Fuel Gauge)。高
精度(1%,主要由 BIAS 电阻的 1%精度决定)的电量测量数据方便消费者更清楚的实时掌握电能使用状
况,给消费者带来前所未有的设备电能使用体验。
AXP209 提供 6mm x 6mm 48-pin QFN 封装。
应用产品
z
z
z
z
z
管脚定义
手持式移动设备
智能移动电话, PMP/MP4, 数
码相机, 数字摄像机, 手持导
航设备 GPS, PDA, 手持数字
广播电视接收机
移动互联网设备 xPad,MID
数码相框,便携 DVD 播放器,
超便携移动电脑 UMPC and
UMPC-like,学习机
应 用 处 理 器 电 路 系 统
Application Processor systems
其它电池和多电源应用系统
VQ.QW WPPIQPWE CC
Confidential
Page 3/45
AXP209
2.特性(Feature)
• 电源管理 (IPS)
o 宽输入电压范围:
2.9V~6.3V (AMR:-0.3V~11V)
o 可配置的高效智慧电能平衡“IPS™”系统
o 自适应 USB(支持 USB3.0)或交流适配器
限压限流 (4.4V/900mA/500mA/100mA)
o 电池通路的等效内阻小于 75mΩ
• 全集成 PWM 充电器 (PWM Charger)
o 最大充电电流可达 1.8A
o 支持电池温度监测
o 全面支持 USB 充电(含 3.0),符合规范
要求
o 充电精度高,误差小于 0.5%
o 支持 4.1V/4.15V/4.2V/4.36V 等多种电池
o 自动进行充电流程控制
o 可直接驱动 LED 指示充电状态
o 根据系统负载情况自动调节充电电流
• 备用电池 (Backup Battery)
o 可接受备用电池输入供给 RTC 模块
o 支持备用电池充电,可设置充电电流
• 2 路同步降压转换器 (DC-DC)
o DC-DC2:可在 0.7-2.275V 之间调节,
25mV/step, 驱动能力 1.6A, 支持 VRC
o DC-DC3:可在 0.7-3.5V 之间调节,
25mV/step, 驱动能力 1.2A
• 5 路线性稳压器 (LDO)
o LDO1:30mA,始终有效
o LDO2:低噪声 LDO,1.8V~3.3V 可调节,
100mV/step, 驱动能力 200mA
o LDO3:0.7-3.5V 可调节, 25mV/step, 驱
动能力 200mA
o LDO4:低噪声 LDO,1.8V~3.3V 可调节,
o LDO5:低噪声 LDO, 1.8-3.3V 可调节,
100mV/step, 驱动能力 50mA
• 定时器 (Timer)
o 7bit Timer,定时范围 1~127 分钟
o Timer 中断输出
注:VRC,Voltage Ramp Control,电压斜
率控制。
VQ.QW WPPIQPWE CC
• 信号采集系统 (Signal Capture)
o 内建 12 路 12 Bit ADC
o 接受 2 路外部信号输入
o 提供电池和外部输入电源的电流电压数
据
o 内建高精度库仑计及 Fuelgauge 系统
o 提供丰富的电源管理信息,如瞬时耗电
(mA or mW),剩余电池电量(% or mAh),
充电状态(%) 和剩余电池使用时间或充
电时间等
o 两级低电警告及保护
o 提供芯片温度数据
• 应用处理器接口 (Host Interface)
o Host 可以通过 TWSI 接口进行数据交换
o 可以灵活配置的中断及休眠管理
o 灵活的管脚功能设置,多路 GPIO 可分别
设置为 IO、ADC 等功能
o 内置可配置计时器
o 提供 12 组寄存器,可用于系统关机时的
数据保存
• 系统管理(System Management)
o 支持软复位和硬复位
o 支持软关机和硬关机
o 支持外部触发源唤醒
o 支持输出电压监测、自诊断功能
o 输出 PWROK,用于系统复位或关机指示
o 外部电源检测(插入/移除/驱动能力不足)
o 所有输入输出都支持软启动
o 过/欠压保护 (OVP/UVP)
o 过流保护 (OCP)
o 过温保护 (OTP)
o 支持 OTG VBUS 电源状态设置/监测
• 高整合度(Fully Integration)
o 内部产生高精度参考电压(0.5%)
o 内置 MOSFET
o 可定制时序和输出电压
• 解密模块 (Decryption)
o 128bit OTP 密码存储
o 动态实时解密算法
Confidential
Page 4/45
AXP209
VQ.QW WPPIQPWE CC
Confidential
Page 5/45
AXP209
Symbol
Description
Value
Units
ACIN
Input Voltage 输入电压
-0.3 to 11
V
VBUS
Input Voltage 输入电压
-0.3 to 11
V
TJ
Operating Temperature Range 工作温度
-40 to 130
Ts
Storage Temperature Range 储运温度
-40 to 150
TLEAD
Maximum Soldering Temperature (at leads,10sec)
锡焊温度
300
VESD
Maximum ESD stress voltage,Human Body Model
抗静电能力
>4000
V
PD
Internal Power Dissipation
内部功率消耗耐受
2100
mW
VIN =5V, BAT=3.8V, TA= 25℃
SYMBOL
DESCRIPTION
CONDITIONS
MIN
TYP
MAX
UNITS
ACIN
VIN
ACIN Input Voltage
3.8
IOUT
VOUT Current Available Before
Loading BAT
VUVLO
ACIN Under Voltage Lockout
VOUT
IPS Output Voltage
RACIN
Internal
Ideal
Resistance
500mV Voltage Drop
6.3
2500
mA
3.8
2.9
Diode
V
On
PIN to PIN, ACIN to
IPSOUT
V
5.0
V
170
mΩ
6.3
V
900
mA
VBUS
VIN
VBUS Input Voltage
3.8
IOUT
Loading BAT
500
VUVLO
VBUS Under Voltage Lockout
3.8
VOUT
IPS Output Voltage
RVBUS
Internal
Ideal
Resistance
2.9
Diode
On
PIN to PIN, VBUS to
IPSOUT
V
5.0
V
300
mΩ
Battery Charger
VTRGT
BAT Charge Target Voltage
ICHRG
ITRKL
4.2
+0.5%
Charge Current
1200
1800
Trickle Charge Current
10%
VQ.QW WPPIQPWE CC
-0.5%
Confidential
V
mA
ICHRG
Page 6/45
AXP209
mA
VTRKL
Trickle
Voltage
Charge
Threshold
ΔVRECHG
Recharge
Voltage
TTIMER1
Charger
Safety
Termination Time
Timer
TTIMER2
Charger
Safety
Termination Time
IEND
End of Charge
Current Ratio
Battery
3.0
V
-100
mV
Trickle Mode
40
Min
Timer
CC Mode
480
Min
Indication
CV Mode
10%
15%
ICHRG
mA
Threshold
Threshold
Voltage
Relative to VTARGET
Backup Battery
VTRGT
Backup Battery Charge Target
Voltage
2.5
3.0
3.1
V
ICHRG
Backup Battery Charge Current
50
200
400
uA
IBackup
Current
Battery
10
15
uA
when
use
Backup
Cold
Temperature
Threshold Voltage
Fault
NTC
VTL
VTH
Hot Temperature Fault Threshold
Voltage
VTE
NTC Disable Threshold Voltage
Charge
Discharge
Charge
Discharge
Falling Threshold
Hysteresis
2.112
3.226
0.397
0.282
V
3.264
V
3.264
0.2
V
Ideal Diode
Rds(on)
On Resistance(BAT to IPSOUT)
SYMBOL
DESCRIPTION
CONDITIONS
MIN
TYP
75
mΩ
MAX
UNITS
Off Mode Current
IBATOFF
OFF Mode Current
BAT=3.8V
27
μA
ISUSPEND
USB VBUS suspend Mode
current
BAT=3.8V,
VBUS=5V,
N_VBUSEN=1
86
μA
Logic
VIL
Logic Low Input Voltage
0.3
V
VIH
Logic High Input Voltage
2
V
3.3
V
TWSI
VCC
Input Supply Voltage
ADDRESS
TWSI Address
0x68
fSCK
Clock Operating Frequency
400
tf
Clock Data Fall Time
VQ.QW WPPIQPWE CC
2.2Kohm Pull High
Confidential
1200
kHZ
60
ns
Page 7/45
AXP209
tr
Clock Data Rise Time
2.2Kohm Pull High
100
ns
Oscillator Frequency
Default
1.5
MHz
ILIM2
PMOS Switch Current Limit
PWM Mode
2300
mA
IDC2OUT
Available Output Current
PWM Mode
VDC2OUT
Output Voltage Range
DCDC
fOSC
DCDC2
0.7
1800
mA
2.275
V
DCDC3
ILIM3
PWM Mode
IDC3OUT
PWM Mode
VDC3OUT
SYMBOL
DESCRIPTION
CONDITIONS
VLDO1
Output Voltage
ILDO1=1mA
ILDO1
Output Current
1400
mA
1000
0.7
mA
V
3.5
MIN
TYP
MAX
-1%
1.3
3.3
1%
UNITS
LDO1
V
30
mA
LDO2
VLDO2
Output Voltage
ILDO2
Output Current
PSRR
Power Supply Rejection Ratio
eN
ILDO2=1mA
1.8
3.3
V
200
mA
ILDO2=60mA,1KHz
TBD
dB
Output Noise,20-80KHz
Vo=3V , Io=150mA
28
VLDO3
Output Voltage
ILDO3=1mA
ILDO3
Output Current
PSRR
eN
μVRMS
LDO3
0.7
3.5
V
200
mA
ILDO3=10mA, 1KHz
TBD
dB
Vo=1.8V , Io=150mA
TBD
μVRMS
VLDO3
Output Voltage
ILDO3=1mA
ILDO3
Output Current
PSRR
eN
LDO4
1.8
3.3
V
200
mA
ILDO3=10mA, 1KHz
TBD
dB
Vo=1.8V , Io=150mA
18
VLDO5
Output Voltage
I LDO5=1mA
ILDO5
Output Current
PSRR
I LDO5=10mA,1KHz
eN
Vo=1.8V, Io=30mA
μVRMS
LDO5
VQ.QW WPPIQPWE CC
Confidential
1.5
3.3
V
50
mA
TBD
dB
18
μVRMS
Page 8/45
AXP209
DC-DC
DC-DC
VQ.QW WPPIQPWE CC
Efficiency
Load
vs.
Load(3.8Vin)
Transient(Typical)
Confidential
Page 9/45
AXP209
DC-DC
VREF
VQ.QW WPPIQPWE CC
vs
Ripple
Temperature
Confidential
Page 10/45
AXP209
VTRGT
Off
VQ.QW WPPIQPWE CC
Mode
vs
Temperature
Current
Confidential
vs
VBAT
Page 11/45
AXP209
Num
Name
Type
Condition
Function Description
1
SDA
IO
Data pin for serial interface,normally it connect a 2.2K
resistor to 3.3V I/O power
2
SCK
I
it is the Clock pin for serial interface,normally it connect
a 2.2K resistor to 3.3V I/O power
3
GPIO3
IO
4
N_OE
I
5
GPIO2
IO
6
N_VBUSEN
I
VBUS to IPSOUT Selection
GND:IPSOUT select VBUS
High:IPSOUT do not select VBUS
7
VIN2
PI
DCDC2 input source
8
LX2
IO
Inductor Pin for DCDC2
9
PGND2
G
NMOS Ground for DCDC2
10
DCDC2
I
DC-DC2 feedback pin
11
LDO4
O
Output Pin of LDO4
12
LDO2
O
Output Pin of LDO2
VQ.QW WPPIQPWE CC
REG9EH[7]
GPIO 3
Power output on/off switch
GND:on; IPSOUT:off
REG92H[2:0]
GPIO 2
Confidential
Page 12/45
AXP209
13
LDO24IN
PI
Input to LDO2 and LDO4
14
VIN3
PI
DCDC3 input source
15
LX3
IO
Inductor Pin for DCDC3
16
PGND3
G
NMOS GND for DCDC3
17
DCDC3
I
Feed back to DCDC3
18
GPIO1
IO
19
GPIO0
REG93H[2:0]
IO
GPIO 1
ADC Input
GPIO 0
REG90H[2:0]
Low noise LDO/Switch
ADC Input
EXTEN
O
External Power Enable
21
APS
PI
Internal Power Input
22
AGND
G
Analog Ground
23
BIAS
IO
External 200Kohm 1% resistor
24
VREF
O
Internal reference voltage
25
PWROK
O
Power Good Indication OutPut
26
VINT
PO
Internal logic power, 2.5V
27
LDO1SET
I
It set the LDO1 default voltage.
28
LDO1
O
LDO1 output,for Host RTC block
29
DC3SET
I
It set the DCDC3 default voltage
30
BACKUP
IO
Backup battery pin
31
VBUS
PI
USB VBUS input
32,33
ACIN
PI
Adapter input
34,35
IPSOUT
IO
Main Battery
36
CHGLED
O
charger status indication
37
TS
I
Battery Temperature sensor input or an external ADC
input
38,39
BAT
PO
System power source
40
LDO3IN
O
LDO3 input source
41
LDO3
I
Output Pin of LDO3
42
BATSENSE
I
Current sense port1
43
CHSENSE
O
Current sense port2
44
VIN1
PI
DCDC1 input source
45
LX1
IO
Inductor Pin for DCDC1
46
PGND1
G
NMOS Ground for DCDC1
47
PWRON
I
Power On-Off key input,Internal 100k pull high to APS
48
IRQ/
WAKEUP
IO
IRQ output or wakeup
49
EP
G
Exposed Pad, need to connect to system ground
VQ.QW WPPIQPWE CC
Confidential
Page 13/45
AXP209
IPSOUT
APS
VBUS
BAT
ACIN
IPS
N_VBUSEN
LDO1
LDO1
LDO1SET
BACKUP
LDO24IN
LX1
VIN1
PGND1
CHGLED
PWM
Charger
LDO2
LDO2
LDO4
LDO4
LDO3
LDO3
BATSENSE
LDO3IN
CHSENSE
DC-DC2
DCDC2
LX2
VIN2
PGND2
DC-DC3
DCDC3
LX3
VIN3
PGND3
DC3SET
PWRON
Control Logic
N_OE
IRQ
SCK
SDA
Serial Interface
TS
Bat
Temperature
Monitor
BIAS
VREF
VINT
Reference
Voltage
VQ.QW WPPIQPWE CC
GPIO3
GPIO2
GPIO1
GPIO0/LDOio0
EXTEN
Register
12 bit ADC
Current Monitor
Voltage Monitor
Temperature Monitor
Confidential
Output voltage
monitor/LBO
PWROK
AGND
EP
Page 14/45
AXP209
当 AXP209 工作时,TWSI 接口 SCK/SDA 管脚上拉到系统 IO 电源,则 Host 可以通过此接口对 AXP209
的工作状态进行灵活的调整和监视,并可获得丰富的信息。
注:“Host”指的是应用系统的主处理器。
注:如下所指“外部电源”包含 ACIN 及 VBUS 输入。
按键(PEK)
AXP209 的 PWRON 管脚到 GND 之间可以连接一个按键,作为独立的开关机键 Power Enable Key(PEK)
或休眠/唤醒按键。AXP209 可以自动识别这个按键的“长按”和“短按”并做出相应的反应。
几个开机源(Power on Source)
1, ACIN、VBUS 及电池接入。
2, N_OE 由高变低。
3, PEK。
开机(Power On)
N_OE 为低时,当符合要求的主电源(ACIN 或 VBUS>3.8V,电池电压高于关机电压)接入时,AXP209
会自动开机(外部电源接入时是否自动开机可根据外部需求改写)。
而在 N_OE 为低且处于关机状态下,开机动作需要通过 PEK 操作来完成。
在有外部电源或电池的情况下,N_OE 由高到低的变化也会导致 AXP209 开机。
AXP209 可以由 PEK(按键时间超过“ONLEVEL”)开机。在实际应用中,Host 的定时(Alarm)输出信
号也可以连接到 PWRON—与 PEK 并联,Alarm 信号有效(低电平)时相当于 PEK 按下,也可以将 AXP209
开机。
开机后,DC-DC 和 LDO 将按照设定的时序顺序软启动,启动完成后可由 Host 通过 TWSI 打开/关闭
相应电源。
关机(Power Off)
PEK“长按”时间大于 IRQLEVEL 时,在 PEK 中断服务程序中,Host 可将“寄存器 REG32H[7]”
写入“1”来通知 AXP209 进入关机状态。AXP209 进入关机状态时会关掉除 LDO1 之外的所有电源输出。
在下列情况下,AXP209 会自动关机:
1, 输入电压过低,低电保护;
2, 负载过大引起电源的输出电压过低,过负载保护;
VQ.QW WPPIQPWE CC
Confidential
Page 15/45
AXP209
3, 输入电压过高,过压保护(具体细节参见“电源通路管理”章节);
4, N_OE 由低到高变化,等待超过设定的时间(默认 2S);
5, PEK 大于 OFFLEVEL 时(默认 6S)系统自动关闭除 LDO1 以外的其它输出(可以省去 Reset 按键);
AXP209 的自动保护机制,可以避免应用系统异常时发生被供电器件的不可逆转损坏,从而保护整个
系统。
休眠和唤醒(Sleep and wakeup)
在开机的情况下,如果系统需要进入 Sleep 模式,并将其中某一路或几路电源输出关闭或改变至其它
电压,则可由 REG31H[3]控制,决定是否由 PEK 按键信号、GPIO0、GPIO1、GPIO2、GPIO3 的上升下
降沿(至于是上升沿还是下降沿或者是双沿,可通过 REG90H[7:6]、REG92H[7:6]、REG93H[7:6]以及
REG95H[7:6]设定)触发 wakeup,让 PMU 将各路输出电源电压恢复到默认状态,各路被关闭或改变的电
源依次按照规定的上电时序重新打开。
注意:PEK IRQ(REG42H[1])、GPIO0 INPUT Edge IRQ(REG44H[0])、GPIO1 INPUT Edge IRQ
(REG44H[1])、GPIO2 INPUT Edge IRQ(REG44H[2])、GPIO3 INPUT Edge IRQ(REG44H[3])必须为
Enable,以便通过 IRQ PIN 通知主处理器退出 Sleep 状态。
如下为 Sleep 和 wakeup 模式下其控制流程。
将 REG31H[3]写
1 打开唤醒功能,
PMU 记 录 此 时
REG12H 的设置
关机相应电源或
是调节电压
Sleep 并 等 待
Wakeup 发生
N
Wakeup?
Y
电源恢复至默认
输出电压值
VQ.QW WPPIQPWE CC
Confidential
Page 16/45
AXP209
系统复位功能和输出监控功能 (PWROK)
AXP209 的 PWROK 可以作为应用系统的复位信号。在 AXP209 的开机过程中,PWROK 输出低电平,
当各路电源的输出电压稳定达到预设值后,PWROK 会被拉高,从而实现应用系统的上电复位。
在应用系统正常工作过程中,AXP209 一直监视各路输出的电压和负载状况,并且在过负载或是欠电
压的情况下,PWROK 立刻输出低电平,复位应用系统,防止误动作以及可能的数据错误。
9.2 电源通路管理(IPS)
AXP209 的电源输入可以来自锂电池 BAT、USB VBUS 输入、外部电源 ACIN(比如交流适配器 AC
Adapter),IPS 根据外部电源和锂电池的状态来选择适合的电能分配方式。
o 当仅接入锂电池,无外部电源输入时,使用锂电池供电;
o 当接入外部电源时(VBUS 或 ACIN),优先使用外部电源供电;
o 电池连接的情况下,外部电源移除时,立刻“无缝”转用锂电池供电;
o 当 VBUS 和 ACIN 两者同时接入时,优先使用 ACIN 供电,并且对锂电池充电;
o 若此时 ACIN 驱动能力不足够时,将适时打开 VBUS 通路,实现 ACIN/VBUS 共同供电;
o 如果驱动能力仍然不足,则将减小充电电流直至 0,继而用电池补充供电;
由此可极大提升系统对于外部不同驱动能力输入电源的兼容性,无需厂家提供特殊定制的适配器。
参见如下图示:
如上图所示,当 ACIN 负载能力不足时,IPSOUT 电压下降,BAT 由原来的被充电转为放电与 ACIN
一起配合提供负载电流。
VQ.QW WPPIQPWE CC
Confidential
Page 17/45
AXP209
Host 可以通过 TWSI 访问 AXP209 的内部寄存器来设置 IPS 的参数和读取其反馈的信息。
限压/限流模式和直通模式
为了不影响 USB 通讯,VBUS 通路默认工作在“VBUS 限压模式”。在此模式下,AXP209 会将 VBUS
电压维持在一个可设置的参考电压 VHOLD 之上,以满足 USB 规范。VHOLD 默认为 4.4V,可在寄存器
Reg30H[5:3]调整。
如果系统对从 USB VBUS 吸取的电流大小有限制需求,则提供一个限流模式可供选择(参见寄存器
REG30H[1]),限流值可选 900mA/500mA/100mA(寄存器 Reg30H[0])。
如果系统只是使用 USB 供电而不介意 USB 通讯,或者使用 USB 电源适配器,可以通过修改寄存器
REG30H[6]将 AXP209 设置成“VBUS 直通模式”,此时 AXP209 会优先满足应用系统的用电需求。当 USB
Host 驱动能力太弱或系统耗电太强而使 VBUS 电压低于 VHOLD,AXP209 将发出 IRQ,告知 Host VBUS
供电能力弱,指示 USB 通信可能会受到影响,后续动作可由 Host 软件决定。
外部电源插入时 AXP209 的反应
AXP209 可以自动检测外部电源的插入动作。当 AXP209 检测到外部电源插入后,会自动判断外部电
源是否可用,并将结果设置在相应的寄存器中,同时发出 IRQ,通知 Host。
关于外部电源的寄存器状态位及含义如下表所示:
寄存器的状态位
含义
寄存器 REG00H[7]
指示外部适配器电源 ACIN 是否存在
寄存器 REG00H[6]
指示外部适配器电源 ACIN 是否可用
寄存器 REG00H[5]
指示外部电源 VBUS 是否存在
寄存器 REG00H[4]
指示外部电源 VBUS 是否可用
寄存器 REG00H[3]
指示接入外部电源 VBUS 时,VBUS 的电压是否高于 VHOLD
寄存器 REG00H[1]
指示外部电源 ACIN/VBUS 是否在 PCB 上短接
寄存器 REG00H[0]
指示系统是否由 ACIN/VBUS 触发开机
“指示接入外部电源 VBUS 时,VBUS 的电压是否高于 VHOLD”这个标志位,可以让 Host 在收到 IRQ7
时(指 VBUS 供电能力弱),判断 VBUS 是因为系统负载接入而被拉低还是因为外部电源本身电压就低于
VHOLD,从而方便 Host 软件决定是继续工作在限压模式还是改为直通模式。
是否选用 VBUS 作为输入电源
AXP209 是否选用 VBUS 作为输入电源,将由 N_VBUSEN 和寄存器 REG30H[7]来决定:
N_VBUSEN
REG30H[7]
输入电源
含义
Low
VBUS
VBUS 有效且无 ACIN 时选用
Low
1
VBUS
VBUS 有效时可以 VBUS 作为输入电源
VQ.QW WPPIQPWE CC
Confidential
Page 18/45
AXP209
High
1
VBUS
High
ACIN/BAT
不选用 VBUS
低电警告和低电保护(自动关机)
AXP209 可以设置低电警告电压 VWARNING 和自动关机电压 VOFF,并将系统电源与其比较。一旦发现
系统电源低于 VWARNING,就发出 IRQ19/IRQ20。如果 APS 低于 VOFF,AXP209 自动进入关机模式,关闭
除 LDO1 之外的所有输出。
VWARNING 具有两档设定:LEVEL1/LEVEL2,应用程序可为两档报警定义不同的提示,比如 Level1
用于提示电量不足、Level2 提示即将关机。
VWARNING 和 VOFF 默认值分别可在寄存器 REG3AH、REG3BH 和 REG31H[2:0]设置。
过压保护
当外部电源电压超过 6.3V 时,AXP209 发出 IRQ1/4,提示外部电源过压。当外部电源超过 7V,AXP209
自动关机。
AXP209 集成了一个恒流/恒压 PWM 充电器,可以自动控制充电周期,内置的安全时钟可以自动停
止充电而无需处理器的干预。此充电器可以根据系统的功耗自动调整充电电流,还带有电池检测、涓流
充电和激活功能,内置的温度检测电路可以在温度过高或过低时自动减小充电电流。
由于集成该 PWM 充电器,在系统耗电较大又需要给电池快速充电时,相对传统的线性充电器模块,
极大的提升了效率,从而减少能耗,系统温升得到大幅改善。
自适应充电过程的启动
充电器默认处于使能状态(可以通过设置寄存器来关闭,参见“寄存器 REG33H”)。当外部电源接入
后,AXP209 首先判断外部电源是否可用于充电,当符合外部电源可用的条件,且此时充电功能被打开,
则 AXP209 自动开始充电过程,向 Host 发出 IRQ,表示充电过程开始。同时,CHGLED 管脚输出低电平,
可以驱动外部发光二极管指示充电状态。
充电过程电压电流示意图
VQ.QW WPPIQPWE CC
Confidential
Page 19/45
AXP209
VTRGT
ICHRG
VTRKL
ITRKL
两个标志电压
VTRGT,充电目标电压。VTRGT 可由寄存器设置,默认为 4.2V(参见“寄存器 REG33H[6:5]”)。同时,
在外部电源电压较低时,AXP209 会自动调节充电目标电压。
VRCH,自动再充电电压。VRCH=VTRGT-0.1V。
充电电流
充电电流可以通过寄存器 REG33H[3:0]设置,默认值为 500mA 或者 1200mA。
充电流程
如果电池电压低于 3.0V,充电器自动进入预充电模式,充电电流为预设值的 1/10。如果 40 分钟内(这
个时间可调整,参见“寄存器 REG34H”),电池电压仍不能达到 3.0V,充电器自动进入电池激活模式。
具体细节参见“电池激活模式”。
电池电压一旦高过 3.0V,充电器开始进入恒流模式。如果充电电流小于预设值的 65%时,系统发出
IRQ17 以此通知“外部电源驱动能力不足,此时充电电流没有达到设定值,从而会延长充电时间,若想
更快充满电,建议更换更强电源或关掉耗电大的功能”。
当电池电压达到目标电压 VTRGT 后,充电器从恒流模式进入恒压模式,充电电流减小。
当充电电流低于预设值的 10%或 15%时(可设,参见“寄存器 REG33H”),充电周期结束,充电停
止,充电结束时,AXP209 会发出 IRQ18,CHGLED 管脚停止指示充电状态。当电池电压重新低于 VRCH
时,会自动开始再充电,同时发出 IRQ17。
VQ.QW WPPIQPWE CC
Confidential
Page 20/45
AXP209
在非预充电模式下,如果在 480 分钟内(这个时间可以调整,参见“寄存器 REG34H”),充电周期没
有结束,充电器将自动进入电池激活模式。
电池激活模式
无论从预充电模式还是从恒流充电模式进入电池激活模式(计时器超时的情况下),AXP209 都会发出
IRQ10,表示电池可能损坏。
在电池激活模式,Charger 始终以较小的电流给电池充电,如果能够使电池电压达到 VRCH,则退出
激活模式,同时发出 IRQ11。
AXP209 在寄存器 REG01H 中指示充电器是否处于电池激活模式。
CHGLED
CHGLED 管脚用来指示充电状态和报警,它有四个状态:正在充电、不在充电、电池异常报警和外部
电源过压报警。CHGLED 是 NMOS Open Drain(漏极开路型)输出,可以通过一个限流电阻来直接驱动一
个发光二极管来显示这四种状态。但其具有如下表所示的两种工作方式:
REG34H[4]
状态
表现
正在充电
低电平
不在充电
高阻
电池异常
1Hz 闪烁
充电器进入电池激活模式,或者电池温度过高、过低
过压
4Hz 闪烁
外部电源输入电压过高
正在充电
1Hz 闪烁
不能充电
高阻
不在充电
低电平
过压
4Hz 闪烁
1
注释
无外部电源
外部电源输入电压过高,或者电池温度过高、过低
电池温度检测
在充电/使用过程中,AXP209 可以通过在 TS 管脚外接一个温敏电阻来监视电池的温度。电路示意如
下图:
VQ.QW WPPIQPWE CC
Confidential
Page 21/45
AXP209
BAT
10uF
TS
C2
NTC
GND
在上图中,VTH/VTL分别为高温和低温的门限设置,可分别通过寄存器REG38H/39H/3CH/3DH设置,
VTE=0.2V。建议温敏电阻选用25℃时为10Kohm、精度1%的NTC温敏电阻。AXP209将在TS管脚上送出
恒定电流,此电流可设置为20uA、40uA、60uA、80uA四种(参见寄存器REG84H),以适应不同的NTC电
阻。此电流流过温敏电阻,得到一个检测电压,AXP209通过ADC测出电压值并与设置值进行比较,从而
发出相应的IRQ或是暂停充电。
如果温敏电阻阻值过大或过小,可以在其通路上并联或是串联上额外的电阻,以便扩大其检测范围。
如果电池没有温敏电阻,可以把 TS 管脚接到地,此时 AXP209 自动禁止电池温度监测功能。
电池检测
AXP209 会自动检测电池是否存在,并在寄存器中标识(参见寄存器 REG01H)和发出 IRQ13、IRQ14。
电池检测功能可由 Host 控制打开或者关闭(参见寄存器 REG32H)。
AXP209 支持备用电池的使用和充电,当无主电源(BAT/ACIN/VBUS)存在时,LDO1 输入源选择备用
电池,其输出用于维持系统实时时钟等部分电路工作。
当主电源存在时,可通过设置 REG35H[7]对备用电池充电,其目标电压默认为 3.0V(可通过
REG35H[6:5]设置)、默认充电电流为 200uA(亦可通过 REG35H[1:0]设置)。
VQ.QW WPPIQPWE CC
Confidential
Page 22/45
AXP209
AXP209 的提供的多路输出电压及功能列表如下:
输出通路
类型
默认电压
应用举例
驱动能力
DCDC2
BUCK
可设置
1.25Vcore
1600 mA
DCDC3
BUCK
可设置
2.5Vddr
700 mA
LDO1
LDO
可设置
RTC
30 mA
LDO2
LDO
可设置
Analog/FM
200 mA
LDO3
LDO
可设置
1.3V PLL
200 mA
LDO4
LDO
可设置
1.8V HDMI
200 mA
LDO5
LDO
可设置
Vmic
50 mA
AXP209 包含 2 路同步降压型 DC-DC、5 路 LDO、多种启动时序及控制方式。DC-DC 的工作频率默
认为 1.5MHz,可以通过设置寄存器来调整,外围可使用小型电感和电容元件。2 个 DC-DC 都可以设置
成 PWM 模式或自动模式(由 AXP209 根据负载的大小自动切换),参见“寄存器 REG80H”。
DC-DC2/3
DCDC3 输出电压范围为 0.7-3.5V,DCDC2 输出电压为 0.7-2.275V,可由寄存器设置(参见“寄存器
REG23H 27H”)。
DCDC2/3 输出电容推荐使用 10uF X7R 以上小 ESR 陶瓷电容;当输出电压设置为 2.5V 以上时,推
荐使用 2.2uH 电感,在 2.5V 以下时,推荐使用 4.7uH 电感,其中电感饱和电流需大于此电源通路最大需
求电流的 50%以上。
如下是推荐电感电容列表:
电感
型号
电流规格
直流内阻
Murata LQH55PN2R2NR0
2100mA@2.2uH
30mOhm
Murata LQH55PN4R7NR0
1400mA@4.7uH
60mOhm
Murata LQH44PN2R2MP0
2000mA@2.2uH
49mOhm
Murata LQH44PN4R7MP0
1700mA@2.2uH
80mOhm
TDK VLF5010ST-2R2M2R3
2700mA@2.2uH
41mOhm
TDK VLF5014ST-4R7M1R7
1700mA@4.7uH
98mOhm
TDK SLF6045T-4R7N2R4-3PF
2400mA@4.7uH
27mOhm
型号
温度特性
容差
TDK C2012X5R0J475K
X5R/X7R
10%@4.7uF
TDK C2012X5R0J106K
X5R/X7R
10%@10uF
Murata GRM31E71A475K
X7R
10%@4.7uF
Murata GRM21E71A106K
X7R
10%@10uF
Murata GRM31E71A106K
X7R
10%@10uF
电容
VQ.QW WPPIQPWE CC
Confidential
Page 23/45
AXP209
LDO1
LDO1 永远开启,可以为应用系统的实时时钟电路(RTC)提供不间断的电源,其驱动能力为 30mA。
LDO2/3/4
LDO2/4 输出噪声低至 18uVrms,可以为应用系统的模拟电路提供电源。LDO3 可以为系统如 SRAM
或 PLL 等提供电源。驱动能力为 200mA。
LDO5
LDO5 也采用了低噪声的设计,输出驱动能力为 50mA。
软启动(Soft Start)
所有 DC-DC 和 LDO 都支持软启动的输出建立方式,避免启动时电流的突然变化对输入通路的冲击。
自诊断:负载监测与限流保护
所有 DC-DC 和 LDO 都有负载监测和限流功能,当负载电流超过其驱动能力时,各输出电压都会下
降,以保护内部电路。两个 DC-DC 输出电压低于设定电压的 85%时,AXP209 自动关机。同时系统内部
自动记录具体因哪一路输出电压过低导致关机(参见寄存器 REG46H[5:2])并发出相应的 IRQ。
所有 DC-DC 不需要外部的肖特基二极管和电阻分压反馈电路。如果应用中不需要用到某个 DC-DC,
只需要将对应的 LX 管脚悬空即可。
AXP209 可定制各路电源的默认电压、启动时序等。
启动时序:共包含 8 级启动,同时可设置每步启动时间间隔,可选范围为 1、4、16、32mS。
默认电压设置:每一路 DCDC/LDO 可设置范围包含了从最低电压到最高电压的选择。
LDO1SET PIN 用于设定 LDO1 的初始电压:
LDO1SET
LDO1SET 接地
LDO1SET 接 VINT
LDO1 电压
1.3V
3.3V
DC3SET PIN 用于设定 DC-DC3 的初始电压:
DC3SET
DC-DC3 电压
DC3SET 接地
DC3SET 接 APS
1.8V
3.3V/2.5V
DC3SET floating
1.2V/1.5V
关于此部分内容,请参见“默认配置说明”文档。
VQ.QW WPPIQPWE CC
Confidential
Page 24/45
AXP209
一般的电池电量监测器通常是通过测量电池电压来估算电池电量,而 AXP209 的多路 12Bit ADC 除
了可以测量电池电压之外,还可以测量电池电流和外部电源电压、电流,同时内部集成了电池充放电库
仑计。Host 可以根据这些数据更为准确的计算出电池电量,除此之外,还可以计算出系统的实时功耗、
电池剩余电量、电池充电进度、电池剩余使用时间及剩余充满时间等丰富的电源信息。
各路 ADC 的使能控制和采样速度可以通过寄存器 REG82H、83H、84H 来设置,采样结果存储在相
应的寄存器中,参见寄存器说明之 ADC 数据类。其中 GPIO[1:0]输入范围可通过寄存器 REG85H 设置。
电池电流方向是充电还是放电由寄存器 REG00H[2]来指示。
Channel
000H
STEP
FFFH
Battery Voltage
0mV
1.1mV
4.5045V
Bat discharge current
0mA
0.5mA
4.095A
Bat charge current
0mA
0.5mA
4.095A
ACIN volatge
0mV
1.7mV
6.9615V
ACIN current
0mA
0.625mA
2.5594A
VBUS voltage
0mV
1.7mV
6.9615V
VBUS current
0mA
0.375mA
1.5356A
Internal temperature
-144.7℃
0.1℃
264.8℃
APS voltage
0mV
1.4mV
5.733V
TS pin input
0mV
0.8mV
3.276V
GPIO0
0/0.7V
0.5mV
2.0475/2.7475V
GPIO1
0/0.7V
0.5mV
2.0475/2.7475V
GPIO[3:0]
可作为 GPIO[3:0]、ADC Input(监测外部信号)、LDO 等,具体参见 REG90H-96H 说明。
CHGLED
充电状态指示、过温过压等报警功能以及 GPO 功能,使用方式参见 REG32H 说明。
9.9 定时器(Timer)
AXP209 包含一个 7 bit 内部定时器,通过设置寄存器 REG8AH[6:0]可改变计时器值,REG8AH[6:0]
为全 0,定时器 Disable;REG8AH[6:0]=A,则定时器从 0 开始计数到 A,并置位 REG8AH[7],同时也可
VQ.QW WPPIQPWE CC
Confidential
Page 25/45
AXP209
发出定时器中断。对 REG8AH[7]写 1,可清除该标志位,并重新开始计时。只清除中断标志不会重新开
始计数。定时器定时最小步长为 1 分钟,定时范围为 1~127 分钟。
9.10 解密(Decryption)
AXP209 包含一个解密模块。Host 通过往 REG300-REG30F 写入待解密的数据,然后对寄存器
REGB8H[1]写 1,开始启动解密,AXP209 解密完成后会将状态位 REGB8[0]置 1,此时 Host 就可以从
REG31x 读回解密后的密码数据。再次启动解密时 AXP209 自动清除状态位。
图 1:Single Read and Write
VQ.QW WPPIQPWE CC
Confidential
Page 26/45
AXP209
图 2:Multi Read and Write
Host 可以通过 TWSI 接口访问 AXP209 的寄存器,其操作时序如上图所示,支持标准 100KHz 或
400KHz 频率,最高速度可达 1.2MHz,同时支持连读/写操作,设备地址为 69H(读)和 68H(写)。
在某些特定事件发生时,AXP209 通过拉低 IRQ 的中断机制来提醒 Host,并将中断状态保存在中断
状态寄存器中(参见寄存器 REG48H、寄存器 REG49H、寄存器 REG4AH、寄存器 REG4BH、寄存器
REG4CH),向相应的状态寄存器位写 1 则清除相应的中断,当无中断事件时,IRQ 输出拉高(通过外部上
拉 51K 电阻)。每个中断都可以通过中断控制寄存器来屏蔽(参见寄存器 REG40H、寄存器 REG41H、寄
存器 REG42H、寄存器 REG43H、寄存器 REG44H)。
位置
中断号
含义
位置
中断号
含义
寄存器 48H[7]
IRQ1
电源 ACIN 超压
寄存器 4AH[3]
IRQ20
DCDC3 电压过低
寄存器 48H[6]
IRQ2
电源 ACIN 插入
寄存器 4AH[2]
寄存器 48H[5]
IRQ3
电源 ACIN 移除
寄存器 4AH[1]
IRQ22
PEK 短按
寄存器 48H[4]
IRQ4
电源 VBUS 超压
寄存器 4AH[0]
IRQ23
PEK 长按
寄存器 48H[3]
IRQ5
电源 VBUS 插入
寄存器 4BH[7]
IRQ24
N_OE 开机
寄存器 48H[2]
IRQ6
电源 VBUS 移除
寄存器 4BH[6]
IRQ25
N_OE 关机
寄存器 48H[1]
IRQ7
VBUS 电压小于
VHOLD
寄存器 4BH[5]
IRQ26
VBUS 有效
寄存器 4BH[4]
IRQ27
VBUS 无效
寄存器 48H[0]
保留
保留
寄存器 49H[7]
IRQ8
电池接入
寄存器 4BH[3]
IRQ28
VBUS Session Valid
寄存器 49H[6]
IRQ9
电池移除
寄存器 4BH[2]
IRQ29
VBUS Session End
寄存器 49H[5]
IRQ10
进入电池激活模式
寄存器 4BH[1]
IRQ30
低电警告 LEVEL1
VQ.QW WPPIQPWE CC
Confidential
Page 27/45
AXP209
寄存器 49H[4]
IRQ11
退出电池激活模式
寄存器 4BH[0]
IRQ31
低电警告 LEVEL2
寄存器 49H[3]
IRQ12
正在充电
寄存器 4CH[7]
IRQ32
定时器中断
寄存器 49H[2]
IRQ13
充电完成
寄存器 4CH[6]
IRQ33
PEK 上升沿
寄存器 49H[1]
IRQ14
电池温度过高
寄存器 4CH[5]
IRQ34
PEK 下降沿
寄存器 49H[0]
IRQ15
电池温度过低
寄存器 4CH[4]
寄存器 4AH[7]
IRQ16
IC 内部过温
寄存器 4CH[3]
IRQ35
GPIO3 输入边沿触发
寄存器 4AH[6]
IRQ17
充电电流不足
寄存器 4CH[2]
IRQ36
GPIO2 输入边沿触发
寄存器 4AH[5]
IRQ18
DCDC1 电压过低
寄存器 4CH[1]
IRQ37
GPIO1 输入边沿触发
寄存器 4AH[4]
IRQ19
DCDC2 电压过低
寄存器 4CH[0]
IRQ38
GPIO0 输入边沿触发
保留
10 寄存器(Registers)
第 1 组,电源控制类
地址
寄存器描述
R/W
00
电源状态寄存器
R
01
电源模式/充电状态寄存器
R
02
OTG VBUS 状态寄存器
R
04-0F
数据缓存寄存器
R/W
00H
12
DC-DC2/3 & LDO2/3/4&EXTEN 控制寄存器
R/W
XXH
23
DC-DC2 电压设置寄存器
R/W
XXH
25
DC-DC2/LDO3 电压斜率参数设置寄存器
R/W
00H
27
DC-DC3 电压设置寄存器
R/W
XXH
28
LDO2/3 电压设置寄存器
R/W
XXH
30
VBUS-IPSOUT 通路设置寄存器
R/W
60H
31
VOFF 关机电压设置寄存器
R/W
X3H
32
关机、电池检测、CHGLED 控制寄存器
R/W
46H
33
充电控制寄存器 1
R/W
CXH
34
充电控制寄存器 2
R/W
41H
35
备用电池充电控制寄存器
R/W
22H
36
PEK 参数设置寄存器
R/W
5DH
37
DCDC 转换器工作频率设置寄存器
R/W
08H
38
电池充电低温报警设置寄存器
R/W
A5H
39
电池充电高温报警设置寄存器
R/W
1FH
3A
APS 低电 Level1 设置寄存器
R/W
68H
3B
APS 低电 Level2 设置寄存器
R/W
5FH
3C
电池放电低温报警设置寄存器
R/W
FCH
3D
电池放电高温报警设置寄存器
R/W
16H
80
DCDC 工作模式设置寄存器
R/W
E0H
82
ADC 使能设置寄存器 1
R/W
83H
VQ.QW WPPIQPWE CC
Confidential
默认值
Page 28/45
AXP209
83
ADC 使能设置寄存器 2
R/W
80H
84
ADC 采样率设置,TS pin 控制寄存器
R/W
32H
85
GPIO [1:0]输入范围设置寄存器
R/W
X0H
86
GPIO1 ADC IRQ 上升沿门限设置
R/W
FFH
87
GPIO1 ADC IRQ 下降沿门限设置
R/W
00H
8A
定时器控制寄存器
R/W
00H
8B
VBUS 监测设置寄存器
R/W
00H
8F
过温关机控制寄存器
R/W
01H
地址
寄存器描述
R/W
默认值
90
GPIO0 控制寄存器
R/W
07H
91
LDO5 输出电压设置寄存器
R/W
A0H
92
GPIO1 控制寄存器
R/W
07H
93
GPIO2 控制寄存器
R/W
07H
94
GPIO[2:0]信号状态寄存器
R/W
00H
95
GPIO3 控制寄存器
R/W
00H
地址
寄存器描述
R/W
默认值
40
IRQ 使能控制寄存器 1
R/W
D8H
41
IRQ 使能控制寄存器 2
R/W
FFH
42
IRQ 使能控制寄存器 3
R/W
3BH
43
IRQ 使能控制寄存器 4
R/W
C1H
44
IRQ 使能控制寄存器 5
R/W
00H
48
IRQ 状态寄存器 1
R/W
00H
49
IRQ 状态寄存器 2
R/W
00H
4A
IRQ 状态寄存器 3
R/W
00H
4B
IRQ 状态寄存器 4
R/W
00H
4C
IRQ 状态寄存器 5
R/W
00H
第 2 组,GPIO 控制类
第 3 组,中断控制类
第 4 组,ADC 数据类
地址
寄存器描述
R/W
56[7:0]
ACIN 电压 ADC 数据高 8 位
R
57[3:0]
ACIN 电压 ADC 数据低 4 位
R
58[7:0]
ACIN 电流 ADC 数据高 8 位
R
59[3:0]
ACIN 电流 ADC 数据低 4 位
R
5A[7:0]
VBUS 电压 ADC 数据高 8 位
R
5B[3:0]
VBUS 电压 ADC 数据低 4 位
R
5C[7:0]
VBUS 电流 ADC 数据高 8 位
R
VQ.QW WPPIQPWE CC
Confidential
Page 29/45
AXP209
5D[3:0]
VBUS 电流 ADC 数据低 4 位
R
5E[7:0]
AXP209 内部温度监测 ADC 数据高 8 位
R
5F[3:0]
AXP209 内部温度监测 ADC 数据低 4 位
R
62[7:0]
TS 输入 ADC 数据高 8 位,默认监测电池温度
R
63[3:0]
TS 输入 ADC 数据低 4 位,默认监测电池温度
R
64[7:0]
GPIO0 电压 ADC 数据高 8 位
R
65[3:0]
GPIO0 电压 ADC 数据低 4 位
R
66[7:0]
GPIO1 电压 ADC 数据高 8 位
R
67[3:0]
GPIO1 电压 ADC 数据低 4 位
R
70[7:0]
电池瞬时功率高 8 位
R
71[7:0]
电池瞬时功率中 8 位
R
72[7:0]
电池瞬时功率低 8 位
R
78[7:0]
电池电压高 8 位
R
79[3:0]
电池电压低 4 位
R
7A[7:0]
电池充电电流高 8 位
R
7B[3:0]
电池充电电流低 4 位
R
7C[7:0]
电池放电电流高 8 位
R
7D[4:0]
电池放电电流低 5 位
R
7E[7:0]
系统 IPSOUT 电压高 8 位
R
7F[3:0]
系统 IPSOUT 电压低 4 位
R
注:电池供电功率计算方法为
Pbat = 2 * 寄存器值 * 电压 LSB * 电流 LSB / 1000。
其中,电压 LSB 为 1.1mV,电流 LSB 为 0.5mA,计算结果单位为 mW。
地址
寄存器描述
R/W
默认值
B0
电池充电库仑计数据寄存器[31:24]
R/W
00H
B1
电池充电库仑计数据寄存器[23:16]
R/W
00H
B2
电池充电库仑计数据寄存器[15:8]
R/W
00H
B3
电池充电库仑计数据寄存器[7:0]
R/W
00H
B4
电池放电库仑计数据寄存器[31:24]
R/W
00H
B5
电池放电库仑计数据寄存器[23:16]
R/W
00H
B6
电池放电库仑计数据寄存器[15:8]
R/W
00H
B7
电池放电库仑计数据寄存器[7:0]
R/W
00H
B8
库仑计及加密模块控制寄存器
R/W
00H
B9
电量计量结果寄存器
R/W
00H
库仑计算方法:C= 65536 * 电流 LSB *(充电库仑计值-放电库仑计值) / 3600 / ADC 采样率。
其中:ADC 采样率参考 REG84H 的设置;电流 LSB 为 0.5mA;计算结果单位为 mAh。
VQ.QW WPPIQPWE CC
Confidential
Page 30/45
AXP209
10.1 REG 00H:输入电源状态
Bit
R/W
7
ACIN 存在指示
0:ACIN 不存在;1:ACIN 存在
R
6
指示 ACIN 是否可用
R
5
VBUS 存在指示
0:VBUS 不存在;1:VBUS 存在
R
4
指示 VBUS 是否可用
R
3
指示 VBUS 接入在使用之前是否大于 VHOLD
R
2
指示电池电流方向
0:电池在放电;1:电池被充电
R
1
指示 ACIN 和 VBUS 输入是否在 PCB 被短接
R
指示启动源是否为 ACIN 或 VBUS
0:启动源非 ACIN/VBUS; 1:启动源为 ACIN/VBUS
R
10.2 REG 01H:电源工作模式以及充电状态指示
Bit
R/W
7
指示 AXP209 是否过温
0:未过温; 1:过温
R
6
充电指示
0:未充电或充电已完成; 1:正在充电
R
5
电池存在状态指示
0:无电池连接到 AXP209; 1:电池已经连接到 AXP209
R
4
保留,不可更改
R
3
指示电池是否进入激活模式
0:未进入电池激活模式; 1:已进入电池激活模式
R
2
指示充电电流是否小于期望电流
0:实际充电电流等于期望电流; 1:实际充电电流小于期望电流
R
保留,不可更改
R
1-0
10.3 REG 02H:USB OTG VBUS 状态指示
Bit
7-3
R/W
保留,不可更改
2
指示 VBUS 是否有效,1 表示有效
R
1
指示 VBUS Session A/B 是否有效,1 表示有效
R
指示 Session End 状态,1 表示有效
R
VQ.QW WPPIQPWE CC
Confidential
Page 31/45
AXP209
10.4 REG 04-0FH:数据缓存
注:只要外部电源、电池或备用电池某一路电源存在,此数据就会一直保存,不受开关机影响。
10.5 REG 12H:电源输出控制
默认值:XXH
Bit
R/W
默认值
RW
X
RW
X
RW
X
RW
X
7
保留,不可更改
6
LDO3 开关控制
5
保留,不可更改
4
DC-DC2 开关控制
3
LDO4 开关控制
RW
X
2
LDO2 开关控制
RW
X
1
DC-DC3 开关控制
RW
X
EXTEN 开关控制
RW
X
R/W
默认值
RW
X
R/W
默认值
0:关闭; 1:打开
0:关闭; 1:打开
10.6 REG 23H:DC-DC2 输出电压设置
默认值:XXH
Bit
7-6
保留,不可更改
5-0
DC-DC2 输出电压设置
0.7-2.275V,25mV/step
Vout=[0.7+(Bit5-0)*0.025]V
10.7 REG 25H:DC-DC2/LDO3 动态电压调节参数设置
默认值:00H
Bit
7-4
保留,不可更改
3
LDO3 VRC 使能控制
0:打开; 1:关闭
RW
DC-DC2 VRC 使能控制
0:打开; 1:关闭
RW
LDO3 VRC 电压上升斜率控制
0: 25mV/15.625us=1.6mV/us
1: 25mV/31.250us=0.8mV/us
RW
DC-DC2 VRC 电压上升斜率控制
RW
VQ.QW WPPIQPWE CC
Confidential
Page 32/45
AXP209
10.8 REG 27H:DC-DC3 输出电压设置
默认值:XXH
Bit
7
6-0
R/W
默认值
RW
X
R/W
默认值
保留,不可更改
DC-DC3 输出电压设置
0.7-3.5V, 25mV/step
Vout=[0.7+(Bit6-0)*0.025]V
10.9 REG 28H:LDO2/4 输出电压设置
默认值:XXH
Bit
7-4
LDO2 输出电压设置
1.8-3.3V, 100mV/step
Vout=[1.8+(Bit7-4)*0.1]V
RW
X
3-0
LDO4 输出电压设置
1.25 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.5 2.7
2.8 3.0 3.1 3.2 3.3
RW
X
R/W
默认值
RW
RW
X
R/W
默认值
10.10 REG 29H:LDO3 输出电压设置
默认值:XXH
Bit
7
6-0
LDO3 模式选择:
0:LDO 模式,电压由[6:0]设置
1:开关模式,电压由 LDO3IN 决定
LDO3 输出电压设置 Bit6-Bit0
10.11 REG 30H:VBUS-IPSOUT 通路管理
默认值:6XH
Bit
7
VBUS 可用时 VBUS-IPSOUT 通路选择控制信号
0:由 N_VBUSEN pin 决定是否打开此通路
1:VBUS-IPSOUT 通路可以被选择打开,不管 N_VBUSEN 的状态
RW
VBUS VHOLD 限压控制
0:不限压; 1:限压
RW
1
RW
100
RW
2
1-0
VHOLD 设置
VHOLD= [4.0+(Bit5-3)*0.1]V
保留,不可更改
VBUS 限流控制打开时限流选择
VQ.QW WPPIQPWE CC
Confidential
Page 33/45
AXP209
00:900mA ; 01:500mA; 10:100mA; 11:not limit
10.12 REG 31H:VOFF 关机电压设置
默认值:X3H
Bit
7-4
3
2-0
R/W
默认值
RW
011
R/W
默认值
RW
RW
1
保留,不可更改
Sleep 模式下 PEK 或 GPIO 边沿唤醒功能使能设置:
0:关闭
1:打开
此 bit 写完后自动清 0,因此每次进 Sleep 模式前需再次写 1
VOFF 设置
VOFF=[2.6+(Bit2-0)*0.1]V
Default: 2.9V
10.13 REG 32H:关机设置、电池检测以及 CHGLED 管脚控制
默认值:46H
Bit
7
关机控制
此位写 1 会关闭 AXP209 的输出
6
电池监测功能设置位: 0:关闭;
1:打开
5-4
CHGLED 管脚功能设置
00: 高阻
01: 25% 1Hz 闪烁
10: 25% 4Hz 闪烁
11: 输出低电平
RW
00
3
CHGLED 管脚控制设置
0: 由充电功能控制
1: 由寄存器 REG 32H[5:4]控制
RW
输出关闭时序控制
0: 同时关闭
1: 与启动时序相反
RW
N_OE 由低变高后 AXP209 关机延
迟时间
00: 128mS; 01: 1S;
10: 2S;
11: 3S
RW
10
R/W
默认值
充电功能使能控制位
0:关闭, 1:打开
RW
1
充电目标电压设置
RW
10
1-0
10.14 REG 33H:充电控制 1
默认值:CXH
Bit
7
6-5
VQ.QW WPPIQPWE CC
Confidential
Page 34/45
AXP209
00:4.1V; 01:4.15V; 10:4.2V; 11:4.36V
4
充电结束电流设置
0:充电电流小于 10%设置值时结束充电
1:充电电流小于 15%设置值时结束充电
RW
充电电流设置
Icharge= [300+(Bit3-0)*100]mA
RW
X
R/W
默认值
RW
RW
1
RW
RW
01
R/W
默认值
备用电池充电使能控制
0:关闭;1:打开
RW
备用电池充电目标电压设置
00:3.1V;01:3.0V;10:3.6V;11:2.5V
RW
01
4-2
保留,不可更改
1-0
备用电池充电电流设置
RW
10
R/W
默认值
3-0
10.15 REG 34H:充电控制 2
默认值:45H
Bit
7
预充电超时设置 Bit1
6
预充电超时设置 Bit0
5
保留
4
CHGLED 模式选择
0:充电时常亮
1:充电时闪烁
3-2
保留,不可更改
1-0
恒流模式下超时设置 Bit1-0
00: 40 min; 01: 50min;
10: 60min; 11: 70min
00: 6Hours; 01: 8Hours;
10: 10Hours; 11: 12Hours
10.16 REG 35H:备用电池充电控制
默认值:22H
Bit
7
00: 50uA;01: 100uA;10: 200uA; 11:
400uA
10.17 REG 36H:PEK 按键参数设置
默认值:9DH
Bit
VQ.QW WPPIQPWE CC
Confidential
Page 35/45
AXP209
7-6
开机时间设置
00: 128mS; 01: 3S; 10: 1S; 11: 2S.
RW
01
5-4
长按键时间设置
00: 1S; 01: 1.5S;10: 2S; 11: 2.5S.
RW
01
3
按键时长大于关机时长时自动关机功能设置
0:关闭; 1:打开
RW
1
2
电源启动完成后 PWROK 信号延时
0:8mS; 1:64mS
RW
1
RW
01
R/W
默认值
RW
1000
R/W
默认值
RW
A5H
R/W
默认值
RW
1FH
R/W
默认值
RW
68H
1-0
00: 4S; 01: 6S; 10: 8S; 11: 10S.
关机时长设置
10.18 REG 37H:DC-DC 工作频率设置
默认值:08H
Bit
7-4
保留,不可更改
3-0
DC-DC 开关频率设置
每一级改变 5%,默认值 1.5MHz
F=[1+/- (Bit3-0)*5%)]*1.5MHz
10.19 REG 38H:VLTF-charge 电池充电低温门限设置
默认值:A5H
Bit
7-0
充电时电池低温门限设置,M
M*10H,当 M=A5H 时对应 2.112V;可
对应电压 0V~3.264V
VLTF-charge = M *10H * 0.0008V
10.20 REG 39H:VHTF-charge 电池充电高温门限设置
默认值:1FH
Bit
7-0
充电时电池高温门限设置,N
N*10H,当 N=1FH,对应 0.397V;可
对应电压 0V~3.264V
VHTF-charge = N *10H * 0.0008V
10.21 REG 3AH: 系统 IPSOUT Vwarning Level1
默认值:68H
Bit
7-0
VQ.QW WPPIQPWE CC
Confidential
Page 36/45
AXP209
10.22 REG 3BH: 系统 IPSOUT Vwarning Level2
默认值:5FH
Bit
7-0
R/W
默认值
RW
5FH
R/W
默认值
RW
FCH
R/W
默认值
RW
16H
R/W
默认值
RW
RW
R/W
默认值
REG3AH、REG3BH对应的电压设置为如下关系(假设寄存器值为n):
Vwarning = 2.8672 + 1.4mV * n * 4
10.23 REG 3CH:VLTF-discharge 电池放电低温门限设置
默认值:FCH
Bit
7-0
M*10H,当 M=FCH 时对应 3.226V;可
对应电压 0V~3.264V
放电时电池低温门限设置,M
VLTF-discharge = M *10H * 0.0008V
10.24 REG 3DH:VHTF-discharge 电池放电高温门限设置
默认值:16H
Bit
7-0
N*10H,当 N=16H,对应 0.282V;可对
应电压 0V~3.264V
放电时电池高温门限设置,N
VLTF-discharge = N *10H * 0.0008V
10.25 REG 80H:DC-DC 工作模式选择
默认值:E0H
Bit
7-3
保留,不可更改
2
DC-DC2 工作模式控制
1
DC-DC3 工作模式控制
保留,不可更改
0:PFM/PWM 自动切换
1:固定 PWM
10.26 REG 82H:ADC 使能 1
默认值:83H
Bit
VQ.QW WPPIQPWE CC
Confidential
Page 37/45
AXP209
7
电池电压 ADC 使能
6
0:关闭, 1:打开
RW
1
电池电流 ADC 使能
RW
ACIN 电压 ADC 使能
RW
ACIN 电流 ADC 使能
RW
VBUS 电压 ADC 使能
RW
VBUS 电流 ADC 使能
RW
APS 电压 ADC 使能
RW
1
TS 管脚 ADC 功能使能
RW
1
R/W
默认值
0:关闭, 1:打开
RW
1
0:关闭, 1:打开
RW
RW
R/W
默认值
RW
RW
11
10.27 REG 83H:ADC 使能 2
默认值:80H
Bit
7
6-4
AXP209 内部温度监测 ADC 使能
保留,不可更改
3
GPIO0 ADC 功能使能
2
GPIO1 ADC 功能使能
1-0
保留,不可更改
10.28 REG 84H:ADC 采样速率设置,TS 管脚控制
默认值:32H
Bit
n
7-6
ADC 采样速率设置
25×2
采样率分别为 25, 50, 100, 200Hz
5-4
TS 管脚输出电流设置:
00:20uA; 01:40uA; 10:60uA; 11:80uA
3
保留,不可更改
2
TS 管脚功能选择
0:电池温度监测功能,1:外部独立的 ADC 输入通路
RW
TS 管脚电流输出方式设置
RW
1
RW
00:关闭
01:充电时输出电流
10:ADC 采样时输入,可以省电
11:一直打开
10.29 REG 85H:ADC 输入范围
默认值:X0H
VQ.QW WPPIQPWE CC
Confidential
Page 38/45
AXP209
R/W
默认值
RW
RW
R/W
默认值
RW
FF
R/W
默认值
RW
00
R/W
默认值
定时器超时
写 1 清除此状态
RW
设置定时时间,单位为分
写全 0 则关闭此定时器
RW
0000000
R/W
默认值
Bit
7-2
保留,不可更改
1
GPIO1 ADC 输入范围
GPIO0 ADC 输入范围
0:0-2.0475V
1:0.7-2.7475V
10.30 REG 86H:GPIO1 ADC IRQ 上升沿门限设置
默认值:FFH
Bit
7-0
一个 LSB 为 8mV
10.31 REG 87H:GPIO1 ADC IRQ 下降沿门限设置
默认值:00H
Bit
7-0
一个 LSB 为 8mV
10.32 REG 8AH:定时器控制
默认值:00H
Bit
7
6-0
10.33 REG 8BH:VBUS 管脚监测 SRP 功能控制
默认值:00H
Bit
7-6
保留,不可更改
5-4
VBUS 有效电压设置
00:4.0V; 01:4.15V; 10:4.45V; 11:4.55V
RW
00
3
VBUS Valid 检测功能设置:0:关闭,1:打开
RW
VBUS Session 检测功能设置:0:关闭,1:打开
RW
Discharge VBUS 放电功能设置
0:关闭 VBUS 的放电电阻;1:使用 VBUS 的放电电阻
RW
VQ.QW WPPIQPWE CC
Confidential
Page 39/45
AXP209
Charge VBUS 充电功能设置
0:断开 VBUS 充电电阻;1:使用 VBUS 充电电阻给 VBUS 充电
RW
R/W
默认值
保留,不可更改
RW
AXP209 内部过温关机功能设置
0:不关机; 1:关机
RW
R/W
默认值
RW
RW
RW
RW
1
RW
1
RW
1
R/W
默认值
RW
1010
RW
101
10.34 REG 8FH:过温关机等功能设置
默认值:21H
Bit
7-3
2
1-0
保留,不可更改
10.35 REG 90H:GPIO0 功能设置
默认值:07H
Bit
7
GPIO0 上升沿 IRQ 或 Wakeup 功能
6
GPIO0 下降沿 IRQ 或 Wakeup 功能
5-3
2
0:disable
1:enable
保留,不可更改
GPIO0 管脚功能设置 Bit 2-0
1
000:输出低
001:输出高(3.3V)
010:通用输入功能
011:低噪声 LDO5
100:ADC 输入
1XX:浮空
10.36 REG 91H: LDO5 输出电压以及 EXTEN/GPIO 输出高电平设置
默认值:A5H
Bit
7-4
3
2-0
LDO5 输出电压设置
Vout=[1.8 +( Bit7-4)*0.1]V; defalt=1.8+10*0.1=2.8V
保留,不可更改
EXTEN 以及 GPIO[1:0]输出高电平设置
000:1.8V;001:2.5V;010:2.8V;011:3.0V;100:3.1V;101:3.3V;110:3.4V;111:3.5V
VQ.QW WPPIQPWE CC
Confidential
Page 40/45
AXP209
10.37 REG 92H:GPIO1 功能设置
默认值:07H
Bit
7
GPIO1 上升沿 IRQ 或 Wakeup 功能
6
5-3
保留,不可更改
2-0
GPIO1 管脚功能设置
0:disable
1:enable
000:输出低
001:输出高(3.3V)
010:通用输入功能
011:低噪声 LDO
100:ADC 输入
1XX:浮空
R/W
默认值
RW
RW
RW
RW
111
R/W
默认值
RW
RW
RW
RW
111
R/W
默认值
10.38 REG 93H:GPIO2 功能设置
默认值:07H
Bit
7
GPIO2 上升沿 IRQ 或 Wakeup 功能
6
GPIO2 下降沿 IRQ 或 Wakeup 功能
5-3
保留,不可更改
2-0
GPIO2 管脚功能设置
0:disable
1:enable
000:输出低
001:浮空
010:通用输入功能
XXX:浮空
10.39 REG 94H:GPIO[2:0]信号状态设置及监测
默认值:00H
Bit
7
保留,不可更改
6
GPIO2 输入状态
5
GPIO1 输入状态
4
GPIO0 输入状态
3-0
保留,不可更改
R
0:输入低电平
1:输入高电平
R
R
R
10.40 REG 95H:GPIO3 设置
默认值:00H
VQ.QW WPPIQPWE CC
Confidential
Page 41/45
AXP209
Bit
7
GPIO3 上升沿 IRQ 或 Wakeup 功能
6
GPIO3 下降沿 IRQ 或 Wakeup 功能
0:disable
1:enable
R/W
默认值
RW
RW
保留,不可更改
2
GPIO3 功能设置
0:NMOS Open Drain 输出
1:数字输入功能
RW
GPIO3 输出设置
0:输出低电平,NMOS 打开
1:浮空,NMOS 关闭
RW
1
GPIO3 输入状态
0: 输入高电平
1: 输入低电平
R
10.41 REG 40H 及 48H:IRQ 使能 1 及 IRQ 状态 1
IRQ 使能 1,REG40H:默认值:D8H
Bit
R/W
默认值
7
ACIN 过压 IRQ 使能
RW
1
6
ACIN 接入 IRQ 使能
RW
1
5
ACIN 移出 IRQ 使能
RW
VBUS 过压 IRQ 使能
RW
1
3
VBUS 接入 IRQ 使能
RW
1
2
VBUS 移出 IRQ 使能
RW
VBUS 可用但小于 VHOLDIRQ 使能
RW
保留,不可更改
RW
Bit
R/W
默认值
7-0
状态位的含义分别对应 40H 的各 bit;
例如:Bit7 即为 ACIN 过压 IRQ 状态位
RW
IRQ 状态 1,REG48H:默认值:00H
10.42 REG 41H 及 49H:IRQ 使能 2 及 IRQ 状态 2
IRQ 使能 2,REG41H:默认值:FFH
Bit
R/W
默认值
7
电池接入 IRQ 使能
RW
1
6
电池移出 IRQ 使能
RW
1
5
电池激活模式 IRQ 使能
RW
1
4
退出电池激活模式 IRQ 使能
RW
1
3
正在充电 IRQ 使能
RW
1
2
充电完成 IRQ 使能
RW
1
1
电池过温 IRQ 使能
RW
1
电池低温 IRQ 使能
RW
1
VQ.QW WPPIQPWE CC
Confidential
Page 42/45
AXP209
IRQ 状态 2,REG49H:默认值:00H
Bit
R/W
默认值
7-0
状态位的含义分别对应 41H 的各 bit
RW
10.43 REG 42H 及 4AH:IRQ 使能 3 及 IRQ 状态 3
IRQ 使能 3,REG42H:默认值:03H
Bit
R/W
默认值
7
AXP209 内部过温 IRQ 使能
RW
充电电流小于设置电流 IRQ 使能
RW
保留,不可更改
4
DC-DC2 输出电压小于设置值 IRQ 使能
RW
DC-DC3 输出电压小于设置值 IRQ 使能
RW
LDO3 输出电压小于设置值 IRQ 使能
1
PEK 短按键 IRQ 使能
RW
1
PEK 长按键 IRQ 使能
RW
1
IRQ 状态 3,REG4AH:默认值:00H
Bit
R/W
默认值
7-0
状态位的含义分别对应 42H 的各 bit
RW
10.44 REG 43H 及 4BH: IRQ 使能 4 及 IRQ 状态 4
IRQ 使能 4,REG43H:默认值:01H
Bit
R/W
默认值
7
N_OE 开机 IRQ 使能
RW
N_OE 关机 IRQ 使能
RW
VBUS 有效 IRQ 使能
RW
VBUS 无效 IRQ 使能
RW
VBUS Session A/B IRQ 使能
RW
VBUS Session End IRQ 使能
RW
APS 低压 IRQ 使能(LEVEL1)
RW
APS 低压 IRQ 使能(LEVEL2)
RW
1
IRQ 状态 4,REG4BH:默认值:00H
Bit
R/W
默认值
7-0
状态位的含义分别对应 43H 的各 bit
RW
10.45 REG 44H 及 4C:IRQ 使能 5 及 IRQ 状态 5
IRQ 使能 5,REG44H,默认值:00H;
VQ.QW WPPIQPWE CC
Confidential
Page 43/45
AXP209
Bit
R/W
默认值
7
计时器超时 IRQ 使能
RW
PEK 按键上升沿 IRQ 使能
RW
PEK 按键下降沿 IRQ 使能
RW
保留,不可更改
RW
GPIO3 输入边沿触发 IRQ 使能
RW
GPIO2 输入边沿触发 IRQ 使能
RW
GPIO1 输入边沿触发或 ADC 输入 IRQ 使能
RW
GPIO0 输入边沿触发 IRQ 使能
RW
IRQ 状态 5,REG4CH:默认值:00H
Bit
R/W
默认值
7-0
状态位的含义分别对应 44H 的各 bit
RW
R/W
默认值
注:所有 IRQ 状态寄存器对应位写 1 将清除相应状态。
10.51 REG B8H:库仑计控制
默认值:00H
Bit
7
库仑计开关控制
RW
库仑计暂停控制,此位写 1 将暂停库仑计数,同时此位将自清零
RW
清除库仑计控制,此位写 1 会将库仑计清零,同时此位将自清零
RW
保留,不可更改
RW
解密 start 位,解密开始后自动清 0
RW
解密是否完成
0:未完成
1:完成
RW
R/W
默认值
10.52 REG B9H:电量计量结果
默认值:7FH
Bit
7
计量系统控制
0:正常工作模式
1:暂停工作
RW
计量结果,百分比
R
7F
VQ.QW WPPIQPWE CC
Confidential
Page 44/45
AXP209
11.封装(Package)
AXP209:QFN48
X-Powers cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in
a X-Powers product. No circuit patent licenses, copyrights, or other intellectual property rights are implied.
X-Powers reserves the right to make changes to the specifications and products at any time without notice.
VQ.QW WPPIQPWE CC
Confidential
Page 45/45
很抱歉,暂时无法提供与“AXP209”相匹配的价格&库存,您可以联系我们找货
