SFXG35BYN02
SFXG35BYN02
    WISOL(威盛)
    SMD
SFXG35BYN02 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFXG35BYN02 DOC. No. SMS-51-L-SFT-FS-48 DATE Arp 18 , 2017 REVISION 001 WISOL Lee, Ju-Hyeong Hong, Sang-Dae Byun, Kyung-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 18103 http://www.wisol.co.kr Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 14 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 14 7-2. TEST ITEM & CONDITION ............................................................................................................... 15 8. REFLOW CONDITION ................................................................................................................................ 16 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 16 10. CAUTION ................................................................................................................................................... 17 11. PACKING ................................................................................................................................................... 18 11-1. DIMENSIONS.................................................................................................................................. 18 11-2. REELING QUANTITY ..................................................................................................................... 19 11-3. TAPING STRUCTURE .................................................................................................................... 19 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 20 11-5. OUTER BOX STRUCTURE ............................................................................................................ 21 12. TAPE SPECIFICATIONS .......................................................................................................................... 22 13. RoHS DATA ............................................................................................................................................... 23 SMS-51-L-SFT-FS-48 Page 2/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 1. REVISION HISTORY 000 Jau 11 2017 All Page 001 Apr.18. 2017 8-9/29Page Changed Wi-Fi frequency range SMS-51-L-SFT-FS-48 Make specification Page 3/29 Apr. 18, 2017 Surface Acoustic Wave Filter SFXG35BYN02 B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 2. DEFINITION 2-1. PART No. S F X G35 B YN 0 2 ① ② ③ ④ ⑤ No. ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency: ④ Input/Output 50ohm/50ohm, ⑤ Package size: 1.8×1.4mm² ⑥ Design Revision (02 : Molding Type) Tx 2535MHz (2500 ~ 2570MHz) 2-2. APPLICATION : UMTS B8 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT-FS-48 Page 4/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] Nt O XX X SMS-51-L-SFT-FS-48 Page 5/29 No. Function 1 Rx Output 3 Tx Input 6 Antenna 2, 4, 5, 7, 8 GND Apr. 18, 2017 Surface Acoustic Wave Filter SFXG35BYN02 B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 5. MARKING N t X X ○ X 5-1. N t XX - The 1st, 2nd character 'N t' indicates the model name of SAW Filter“SFXG35BYN02”. - The 3rd character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a 2017 1 2 3 4 5 6 7 8 9 A B C ※ This rotates by the 3 years. - The 4th, 5th character 'X' indicates Lot No. 5-2. O - This symbol indicates input pin 1. - This indicates the producing center ○ : China, 5-3. Marking : Laser Marking SMS-51-L-SFT-FS-48 Page 6/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 0.8 W Operating Temperature Range -20 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT-FS-48 Page 7/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -20 ~ +85℃ Item RATING CONDITION [MHz] UNIT Min. Typ.(25℃) Max. TX  ANTENNA 2500 ~ 2570(*1) dB - 1.95 2.9 2500 ~ 2570(*1)(*2) dB - 1.95 2.7 2500 ~ 2570 dB - 1.0 2.1 2500 ~ 2570(*2) dB - 1.0 1.9 2500 ~ 2570 - - 1.7 2.5 10 ~718 dB 30 55 - 832 ~ 862 dB 30 53 - 1559 ~ 1563 dB 30 40 - 1565.42 ~ 1605.89 dB 30 40 - 1605.89 ~ 1680.0 dB 30 40 - 1710.0 ~ 1785.0 dB 30 38 - 1805.0 ~ 1880.0 dB 30 37 - 1900.0 ~ 1920.0 dB 30 37 - 2010.0 ~ 2025.0 dB 28 36 - 2110.0 ~ 2170.0 dB 28 36 - 2401.0 ~ 2468.0(*3) dBINT 40 46 - 2451.0 ~ 2473.0(*3) dBINT 30 58 - 2456.0 ~ 2478.0(*3) dBINT 15 50 - 2461.0 ~ 2483.0(*3) dBINT 7 40 - 2590.0 ~ 2595.0 dB 1.3 4 - 2595.0 ~ 2620.0 dB 2 7 - 2620.0 ~ 2690.0 dB 45 54 - 5000.0 ~ 5140.0 dB 30 50 - 5100.0 ~ 5280.0 dB 30 52 - Insertion Loss Inband Ripple VSWR Absolute Attenuation Termination Impedance : INPUT / ANTENNA 50Ω(+2.4nH) / 50Ω(// 3.3nH) ANTENNA  RX 2620 ~ 2690(*1) dB - 1.9 3.1 2620 ~ 2690(*1)(*2) dB - 1.9 2.9 Insertion Loss SMS-51-L-SFT-FS-48 Page 8/29 Apr. 18, 2017 Surface Acoustic Wave Filter SFXG35BYN02 B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 2620 ~ 2690 dB - 0.8 2.1 2620 ~ 2690(*2) dB - 0.8 1.9 2620 ~ 2690 - - 1.8 2.5 1.0 ~ 2500.0 dB 35 46 - 2402.0 ~ 2470.0 dB 40 53 - 2500.0 ~ 2570.0 dB 45 51 - 2570.0 ~ 2600.0 dB 2.5 9 - 4900.0 ~ 5950.0 dB 20 35 - Inband Ripple VSWR Absolute Attenuation Termination Impedance : ANTENNA / OUTPUT 50Ω (//3.3nH) /50Ω(//5.1nH) TX → RX Isolation between Rx and Tx 2500 ~ 2570 dB 52 56 - 2620 ~ 2690 dB 50 54 - (*1). PCB loss is de-embedded. (*2)Valid at room temperature. (*3)Integrated attenuation per 18MHz over 6-2-2. TEST FIXTURE 50Ω 3.3nH 50Ω 5.1nH Antenna Nt X X ○ X Rx Output SMS-51-L-SFT-FS-48 2.4nH 50Ω Tx Input Page 9/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 6-2-3. GRAPH 6-2-3-1. Tx→Ant, Ant→Rx Transmission Characteristics NEAR BAND 0 0 -10 -1 -20 -2 -30 -3 -40 -4 -50 -5 -60 -6 -70 -7 -80 2400 2500 2600 Frequency (MHz) 2700 -8 2800 6-2-3-2. Tx→Rx Isolation Characteristics Isolation 0 -10 -20 -30 -40 -50 -60 -70 -80 2400 SMS-51-L-SFT-FS-48 2500 2600 Frequency (MHz) Page 10/29 2700 2800 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 6-2-3-3. Wideband Tx→Ant, Ant→Rx Transmission Characteristics Wide TX 0 -10 -20 -30 -40 -50 -60 -70 -80 0 1000 2000 3000 4000 Frequency (MHz) 5000 6000 5000 6000 Wide RX 0 -10 -20 -30 -40 -50 -60 -70 -80 0 SMS-51-L-SFT-FS-48 1000 2000 3000 4000 Frequency (MHz) Page 11/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 6-2-3-4. Wideband Tx→Rx Transmission Characteristics Wide Isolation 0 -10 -20 -30 -40 -50 -60 -70 -80 0 1000 2000 3000 4000 Frequency (MHz) 5000 6000 6-2-3-5. Smithchart Swp Max 2690MHz 2. 9 0. 3. 0 8 4 4. 0 5.0 0.2 10.0 5.0 4.0 3.0 2.0 1.0 0.8 0.6 0.4 0.2 10.0 0 ANT VSWR 10 0 0. 6 0.8 1.0 ANT Smith 7 6 5 4 -10.0 3 2 0 .0 .0 SMS-51-L-SFT-FS-48 -1.0 -0.8 -0 .6 -2 .0 -3 4 -4 . -0 -5. -0. 2 1 2400 Swp Min 2500MHz Page 12/29 2500 2600 Frequency (MHz) 2700 2800 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary Swp Max 2570MHz 2. 9 0. 0 3. 8 4 4. 0 5.0 0.2 10.0 5.0 4.0 3.0 2.0 1.0 0.8 0.6 0.4 0.2 10.0 0 TX VSWR 10 0 0. 6 0.8 1.0 TX Smith 7 6 5 4 -10.0 3 2 0 -4 .0 -3 .0 -2 2450 2500 Swp Min 2500MHz -1.0 -0.8 .6 -0 2 1 2400 .0 - 4 0. -5. -0. 2550 2600 Frequency (MHz) 2650 2700 2750 2800 Swp Max 2690MHz 2. 9 0. 3. 0 8 4 4. 0 5.0 0.2 10.0 5.0 4.0 3.0 2.0 1.0 0.8 0.6 0.4 0.2 10.0 0 RX VSWR 10 0 0. 6 0.8 1.0 RX Smith 7 6 5 4 -10.0 3 2 0 .0 .0 SMS-51-L-SFT-FS-48 -1.0 -0.8 -0 .6 -2 .0 -3 4 -4 . -0 -5. -0. 2 1 2500 Swp Min 2620MHz Page 13/29 2550 2600 2650 2700 Frequency (MHz) Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (MSL 2a) (JESD22-A113) (n=191) HTS (n=23) ESD(HBM) (n=9) Board Level Drop (n=11) LTS (n=23) ESD(HBM) LIMIT (n=3) Bending (n=11) uHAST (n=23) ESD(MM) (n=9) Solder Heat (n=11) THS (n=23) ESD(CDM) (n=6) Solderability (n=11) Temp. Drift (n=5) TC (n=23) Final Electrical Data (n=115) SMS-51-L-SFT-FS-48 Final Electrical Data (n=27) Page 14/29 Final Electrical Data (n=49) Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning TEST CONDITION REMARK Bake + Soak(MSL or above) + 3X Reflow duration ( Soak 60℃ 60% 120HR) JESD22-A113 TEST ITEM REMARK TEST CONDITION Duration HTS (High Temperature Storage) JESD22-A103 condition A 125(-0/+10)℃ 1000hr LTS (Low Temperature Storage) JESD22-A119 A -40(-10/+0)℃ 1000hr uHAST (Unbiased HAST) JESD22-A118 130℃ /85% /33.3psi 96hr JESD22-A101 85℃ /85% RH 1000hr TC (Temperature Cycle) JESD22-A104 Condition G (-40℃ /125℃) 1000cycle ESD(HBM) JESD22-A114 250V or above - ESD(HBM) LIMIT - 300V or above - ESD(MM) JESD22-A115 No spec butneed data - ESD(CDM) JESD22-C101 500V or above - Board Level Drop Test JESD22-B111 1500G Duration 0.5ms 150cycle THS (Temperature Humidity Storage) Bending Test 0.5㎜/sec 3times (1mm distance) Solder Heat Resistance 260℃ 10sec Solderability 235℃ 3sec Temp Drift SMS-51-L-SFT-FS-48 -40℃ Page 15/29 → +25℃ → +125℃ Per conditions 2HR Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [UNIT : mm] [SAW, X-ray Top View] SMS-51-L-SFT-FS-48 [PCB, X-ray Top View] Page 16/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT-FS-48 Page 17/29 Apr. 18, 2017 Surface Acoustic Wave Filter SFXG35BYN02 B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.60 2.00 Ø1.55 Ø1.00 1.75 3.50 4.00 4.00 2.00 0.25 0.80 8.00 0.05 0.05 0.05 MIN 0.10 0.05 0.10 0.10 0.05 0.05 0.05 0.10 -0.05 -0.05 -0.05 - -0.10 -0.05 -0.10 -0.10 -0.05 -0.05 -0.05 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø258.0 +1.0 -0.5 Ø81.0 +1.0 -1.0 Ø13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT-FS-48 Page 18/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 11-2. REELING QUANTITY 10 inch reel : 8,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. Nt XX O X Nt XX O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT-FS-48 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8000 / qAFYU Quantity / Marking Page 19/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material: Polyethylene + Aluminium Size: 310×370mm2 Material: Size: Paper (D)260×(W)37×(H)265mm3 SMS-51-L-SFT-FS-48 Page 20/29 Apr. 18, 2017 . . Surface Acoustic Wave Filter SFXG35BYN02 B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT-FS-48 Page 21/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT-FS-48 Page 22/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Version: Preliminary 13. RoHS DATA SMS-51-L-SFT-FS-48 Page 23/29 Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 24/29 Version: Preliminary Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 25/29 Version: Preliminary Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 26/29 Version: Preliminary Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 27/29 Version: Preliminary Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 28/29 Version: Preliminary Apr. 18, 2017 Surface Acoustic Wave Filter B7 DPX-Tx 2535MHz B7 DPX-Rx 2655MHz SMS-51-L-SFT-FS-48 SFXG35BYN02 1.8×1.4×0.55mm3 8pin lay-out Page 29/29 Version: Preliminary Apr. 18, 2017
SFXG35BYN02 价格&库存
很抱歉,暂时无法提供与“SFXG35BYN02”相匹配的价格&库存,您可以联系我们找货
