150 Watt Medical
Features
4 x 2 x 1.3 inches form factor
150 W with forced-air cooling
l Class 1 & Class 2 options
l 12 V @ 0.5 A fan voltage auxiliary output
l High Efficiency > 86%
l Low conducted and radiated noise
l Light weight
l Medical approvals
• Meets standard IEC60601-1-2 : 2014 (4th Edition)
l
l
Electrical Specifications
Input Voltage
Input Frequency
Input Current
No Load Power
Inrush Current
Leakage Current
Efficiency
Hold-up Time
Power Factor
Output Power
Peak Power
Line Regulation
Load Regulation
Transient Response
Rise Time
Set Point Accuracy (Main Output)
Output Adjustability
Over Current Protection
Over Voltage Protection
Short Circuit Protection
Switching Frequency
Operating Temperature
Storage Temperature
Relative Humidity
Altitude
MTBF
Isolation Voltage
Cooling
90-264 VAC/120-390 VDC, Universal
47-63 Hz
120 VAC: 1.7 A max.
230 VAC: 0.85 A max.
1.2 W
120 VAC: 35 A max.
230VAC: 65 A max.
120 VAC: < 140 µA
230 VAC: < 250 µA
120 VAC: 84% typical
230 VAC: 86% typical
120 VAC: 6 ms
230 VAC: 10 ms
120 VAC: 0.99
230 VAC: 0.95
150 W
170 W for 0.2 s
+/-0.5%
+/-2.0%
< 10%, 50% to 100% load change, 50 Hz, 50% duty cycle, 0.1 A/µs,
recovery time < 5 ms
< 100 ms
+/-1%
+/-3.0 %
110% typical above rating
110 to 150%
Short term, autorecovery
PFC converter: Variable, 35-250 kHz; 90 kHz typical
Resonant converter: Variable, 35-250 kHz; 90 kHz typical
-20 to +70°C, refer derating curve, -20 to 0°C, start-up is guaranteed
-40 to +70°C
95% Rh, noncondensing
Operating: 10,000 ft.; Nonoperating: 40,000 ft.
2.4m Hours, Telcordia -SR332-issue 3
Min. 5900 VDC between input to output
Convection: 80 W; 300 LFM: 100 W (5 V model)
Convection: 100 W; 300 LFM: 150 W (other model)
61
4EM-19-180
39-DE60-45350-002 / B4
Model Number
Description
LFMWLT150-1000
Class 1 with Screw Terminal
LFMWLT150-1000-2
Class 2 with Screw Terminal
LFMWLT150-1300
Class 1 with JST Connector
LFMWLT150-1300-2
Class 2 with JST Connector
LFMWLT150-1001
LFMWLT150-1001-2
LFMWLT150-1301
LFMWLT150-1301-2
LFMWLT150-1002
LFMWLT150-1002-2
LFMWLT150-1302
LFMWLT150-1302-2
LFMWLT150-1003
LFMWLT150-1003-2
LFMWLT150-1303
LFMWLT150-1303-2
LFMWLT150-1004
LFMWLT150-1004-2
LFMWLT150-1304
LFMWLT150-1304-2
LFWLT100-CK metal cover kit accessory
Voltage
Max. Load1 Max. Load1
(Convection) (300 LFM)
Min. Load
Ripple2
0.0 A
1%
20.0 A
5V
16.0 A
16.0 A
12 V
8.33 A
12.5 A
0.0 A
1%
15 V
6.67 A
10.0 A
0.0 A
1%
24 V
4.17 A
6.25 A
0.0 A
1%
48 V
2.08 A
3.13 A
0.0 A
1%
Notes
1. Combined output power from V1 and VFAN should not exceed the total output power rating.
2. Ripple is 2% up to 20% load and < 1% above 20% load. Ripple is peak to peak with 20 MHz bandwidth and 10 µF (Electrolytic capacitor) in
parallel with a 0.1 µF capacitor at rated line voltage and load ranges.
3. Fan output voltage tolerance is +/-20%.
4. Peak current for fan output is 1 A.
5. Class 1 products have an Earthing tab. Class 2 version available, Add “-2” suffix at the end of the Model Number.
6. Specifications are for nominal input voltage, 25°C and max. load unless otherwise stated.
7. Derate output power linearly to 80% from 90 VAC to 80 VAC input.
8. When used in Cover Kit, de-rate output power to 70 % under all operating conditions.
2
4EM-19-180
Innovations in Power
Connectors
J1
Pin 1
Pin 2
Spade Connector
(Class 1 product only)
J2
Pin 1, 2
Pin 3, 4
J3
Pin 1
Pin 2
AC LINE
AC NEUTRAL
EARTH
V1
RTN
VFAN (12 V/0.5 A)
RTN
Mechanical Specifications
AC Input Connector (J1)
Molex: 26-60-4030 or equivalent
Mating: 09- 50-3031; Pins: 08-50-0106
EARTH
Molex: 19705-4301 or equivalent
Mating: 190030001
DC Output Connector (J2)
Option 1: Tyco: 1776112-4 or equivalent
Mating: 13 AWG wire
Option 2: JST: B4P-VH-B (LF) (SN) or B4P-VH (LF) (SN) or equivalent
Mating: VHR-4M; Pins: SVH-41T-P1.1
Fan Connector (J3)
Tyco: 640456-2 or equivalent
Mating: 640440-2
Dimensions
4.0 x 2.0 x 1.324 inches
(101.6 x 50.8 x 33.63 mm)
Weight
150 g
EMC
Parameter
Conducted Emissions
Radiated Emissions
Input Current Harmonics
Voltage Fluctuation and Flicker
ESD Immunity
Radiated Field Immunity
Electrical Fast Transient Immunity
Surge Immunity
Conducted Immunity
Magnetic Field Immunity
Voltage dips, interruptions
Conditions/Description
EN 55011-B,CISPR22-B, FCC PART15-B
EN 55011 B
EN 61000-3-2
EN 61000-3-3
EN 61000-4-2
EN 61000-4-3
EN 61000-4-4
EN 61000-4-5
EN 61000-4-6
EN 61000-4-8
EN 61000-4-11
Criteria
Pass
Pass
Class D
Pass
Level 4, Criterion A
Level 3, Criterion A
Criterion A & B
Safety
CE Mark
Approval Agency
Safety Standard(s)
Safety File Number(s)
63
4EM-19-180
Complies with LVD Directive
Nemko, UL, C-UL
EN60601-1, IEC60601-1 (ed.3),
ANSI / AAMI ES 60601 - 1, CSA C22.2 No. 60601-1
Nemko: P16220661; CB: NO90218
UL: E173812
Derating Curve
Convection load: 80W up to 50 °C
De-rate above 50 °C @ 3.125% per °C
Forced air cooled load : 100W up to 50°C
De-rate above 50 °C @ 2.5% per °C
Convection load: 100W up to 50 °C
Forced air cooled load : 150W up to 50°C
De-rate above 50 °C @ 1.67% per °C
4
4EM-19-180
Mechanical Drawing
Notes: In case the PCB is mounted in a metal enclosure, using metal hardware ensure the following
1. Stand off, used to mount PCB has OD of 5.4 mm max.
2. Screws, used to fix PCB on stand off, have head dia of 6.0 mm max.
3. Washer, if used, to have dia of 6.5 mm max.
65
4EM-19-180
很抱歉,暂时无法提供与“LFMWLT150-1003”相匹配的价格&库存,您可以联系我们找货
