CCS811B-JOPD500
CCS811B-JOPD500
    AMSOSRAM(艾迈斯半导体)
    LGA10
    CCS811B-JOPD500
CCS811B-JOPD500 数据手册
CCS811 Ultra-Low Power Digital Gas Sensor for Monitoring Indoor Air Quality General Description The CCS811 is an ultra-low power digital gas sensor solution which integrates a metal oxide (MOX) gas sensor to detect a wide range of Volatile Organic Compounds (VOCs) for indoor air quality monitoring with a microcontroller unit (MCU), which includes an Analog-to-Digital converter (ADC), and an I²C interface. CCS811 is based on ams unique micro-hotplate technology which enables a highly reliable solution for gas sensors, very fast cycle times and a significant reduction in average power consumption. The integrated MCU manages the sensor driver modes and measurements. The I²C digital interface significantly simplifies the hardware and software design, enabling a faster time to market. CCS811 supports intelligent algorithms to process raw sensor measurements to output a TVOC value or equivalent CO 2 (eCO2) levels, where the main cause of VOCs is from humans. CCS811 supports multiple measurement modes that have been optimized for low-power consumption during an active sensor measurement and idle mode extending battery life in portable applications. CCS811 is available in a 10 lead 2.7mm x 4.0mm x 1.1mm, 0.6mm pitch LGA package. Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-04] 2018-Mar-09 Page 1 Document Feedback CCS811 − General Description Key Benefits & Features The benefits and features of CCS811, Ultra-Low Power Digital Gas Sensor for Monitoring Indoor Air Quality are listed below: Figure 1: Added Value of Using CCS811 Sensor Benefits Features • Manages the sensor drive modes and measurements while detecting VOCs • Integrated MCU • Provides eCO2 level or TVOC indication with no host intervention • On-board processing • Simplifies the hardware and software integration • Standard (100kbit/s) and fast (400kbit/s) I²C interface • Extend battery life in portable applications • Optimised low-power modes • Suitable for small form-factor designs • 2.7mm x 4.0mm x 1.1mm LGA package • Saves up to 60% in PCB footprint • Low component count • Designed for high volume and reliability (>5years lifetime) • Proven technology platform Applications This device can be mainly used for indoor air quality monitoring in: • Smart phones • Wearables • Home and building automation • Accessories Page 2 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − General Description Block Diagram The functional blocks of this device are shown below: Figure 2: CCS811 Block Diagram 10 6 VDD SCL 9 SDA 1 ADDR 8 H+ (With Integrated ADC) nRESET 7 EP Sense PWM GND H- nWAKE 2 MCU nINT 3 S+ 4 MOX Gas Sensor S- 5 Pins 4 and 5 mu st be connected together ams Datasheet [v1-04] 2018-Mar-09 Page 3 Document Feedback CCS811 − Pin Assignment Pin Assignment Figure 3: Pin Diagram Pin 1 Corner Index Area (Top View) (Bottom View) 5 6 4 7 8 3 2 9 1 10 Pin 1 Corner Index Area Pin Diagram: The Exposed Pad is underneath Figure 4: CCS811 LGA Pin Assignment Pin No. Pin Name 1 ADDR Description Single address select bit to allow alternate address to be selected • When ADDR is low the 7 bit I²C address is decimal 90 / hex 0x5A • When ADDR is high the 7 bit I²C address is decimal 91 / hex 0x5B. 2 nRESET nRESET is an active low input and is pulled up to VDD by default. nRESET is optional but 4.7kΩ pull-up and/or decoupling of the nRESET pin may be necessary to avoid erroneous noise-induced resets. This pin will be pulled low internally during reset. 3 nINT nINT is an active low optional output. It is pulled low by the CCS811 to indicate end of measurement or a set threshold value has been triggered. 4 PWM Heater driver PWM output. Pins 4 and 5 must be connected together. 5 Sense Heater current sense. Pins 4 and 5 must be connected together. 6 VDD 7 nWAKE 8 NC No connect 9 SDA SDA pin is used for I²C data. Should be pulled up to VDD with a resistor. 10 SCL SCL pin is used for I²C clock. Should be pulled up to VDD with a resistor. EP Exposed Pad Page 4 Document Feedback Supply voltage. nWAKE is an active low input and should be asserted by the host prior to an I²C transaction and held low throughout. Connect to ground. ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments 3.6 V Average Supply Current 30 mA In mode 1 IDDPeak Peak Supply Current 54 mA In modes 2 and 3 P Power Consumption 60 mW In mode 1 Electrical Parameters VDD (1) IDD 1.8(2) Supply Voltage Electrostatic Discharge ESDHBM Human Body Model ±2000 V ESDCDM Charged Device Model ±1000 V Environmental Conditions TAMB(3) Ambient Temperature for Operation -40 85 TSTRG Storage Temperature -40 125 RHNC Relative Humidity (non-condensing) 10 95 LT (4) Product Lifetime >5 MSL Moisture Sensitivity Level 1 oC o C % Years In mode 1 Unlimited max. floor life time Note(s): 1. The supply voltage V DD is sampled during boot and should not vary during operation. 2. The minimum supply voltage V DD is 1.8V and should not drop below this value for reliable device operation. 3. Sensors are electrically operable in this range, however indoor air quality performance will vary in this range. 4. Product lifetime for CCS811 will be longer in modes 2 and 3. ams Datasheet [v1-04] 2018-Mar-09 Page 5 Document Feedback CCS811 − Electrical Characteristics Electrical Characteristics Figure 6: Electrical Characteristics Parameters Conditions Min Supply Voltage (VDD) (1), (2) Supply Current (IDD) (3) Typ (6) 1.8 Max Units 3.3 V During measuring at 1.8V 26 mA Average over pulse cycle(3) at 1.8V 0.7 mA Sleep Mode at 1.8V 19 μA Idle Mode 0 at VDD= 1.8V 0.034 mW Mode 1 & 4 at VDD= 1.8V 46 mW Mode 2 at VDD= 1.8V 7 mW Mode 3 at VDD= 1.8V 1.2 mW Power Consumption Logic High Input (5) nRESET, nWAKE, ADDR VDD 0.6 VDD V Logic Low Input (5) nRESET, nWAKE, ADDR 0 0.6 V Logic High Output nINT Logic Low Output nINT VDD 0.7 V 0.6 V Note(s): 1. The supply voltage V DD is sampled during boot and should not vary during operation 2. The maximum VDD ramp time for Power On is 3ms 3. Typical values for 1.8V supply voltage (V DD) 4. Average Supply Current (I DD) for a sensor measurement once every 60 seconds 5. For SDA and SCL timing refer NXP I²C – bus specification and user manual UM10204 6. Typical values at 25 oC and 50% RH Page 6 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Electrical Characteristics Figure 7: Timing Characteristics Parameters Conditions tAPP_START tWAKE (1) tSTART (2) Min Typ Max Units Time between giving the APP_START command in boot mode and the device being ready for new I²C commands 1 ms Time between deasserting nWAKE pin and the device being ready for new I²C commands 50 μs Time between power on and the device being ready for new I²C commands 18 20 ms Time between deasserting nRESET pin or giving the SW_RESET command and the device being ready for new I²C commands 1 2 ms tDWAKE Minimum time nWAKE should be de-asserted 20 μs tDRESET Minimum time nRESET should be de-asserted 20 μs tRESET Minimum time nRESET should be asserted 15 μs Frequency of I²C bus supported 10 fI²C 100 400 kHz Note(s): 1. nWAKE should be asserted prior to and during any I²C transaction. 2. Up to 70ms on the first Reset after new application download. ams Datasheet [v1-04] 2018-Mar-09 Page 7 Document Feedback CCS811 − Detailed Description Detailed Description Modes of Operation The CCS811 has 5 modes of operation as follows • Mode 0: Idle, low current mode • Mode 1: Constant power mode, IAQ measurement every second • Mode 2: Pulse heating mode IAQ measurement every 10 seconds • Mode 3: Low power pulse heating mode IAQ measurement every 60 seconds • Mode 4: Constant power mode, sensor measurement every 250ms In Modes 1, 2, 3, the equivalent CO 2 concentration (ppm) and TVOC concentration (ppb) are calculated for every sample. • Mode 1 reacts fastest to gas presence, but has a higher operating current • Mode 3 reacts more slowly to gas presence but has the lowest average operating current. When a sensor operating mode is changed to a new mode with a lower sample rate (e.g. from Mode 1 to Mode 3), it should be placed in Mode 0 (Idle) for at least 10 minutes before enabling the new mode. When a sensor operating mode is changed to a new mode with a higher sample rate (e.g. from Mode 3 to Mode 1), there is no requirement to wait before enabling the new mode. Mode 4 is intended for systems where an external host system wants to run an algorithm with raw data and this mode provides new sample data every 250ms. Note(s): Mode timings are subject to typical 2% tolerance due to accuracy of internal clock Early-Life Use (Burn-In) CCS811 performance in terms of resistance levels and sensitivities will change during early life use. The change in resistance is greatest over the first 48 hours of operation. CCS811 controls the burn-in period allowing eCO 2 and TVOC readings to be used during initial device operation. Page 8 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Detailed Description Conditioning Period (Run-In) After early-life (Burn-In) use the conditioning period is the time required to achieve good sensor stability before measuring VOCs after long idle period. After writing to MEAS_MODE to configure the sensor in mode 1-4, run CCS811 for 20 minutes, before accurate readings are generated. The conditioning period must also be observed before writing to the BASELINE register. eCO 2 The equivalent CO 2 (eCO 2) output range for CCS811 is from 400ppm to 64000ppm. TVOC The Total Volatile Organic Compound (TVOC) output range for CCS811 is from 0ppb to 64000ppb. Temperature and Humidity Compensation If an external sensor is available this information can be written to CCS811 so that they will be used to compensate gas readings due to temperature and humidity changes. Refer to the ENV_DATA (Environment Data) Register (0x05). Interrupt and Interrupt on Threshold At the end of each measurement cycle (250ms, 1s, 10s, 60s) a flag is set and optionally interrupt (nINT) pin asserted. Refer to the MEAS_MODE (Measurement and Conditions) Register (0x01). The user can choose to only assert nINT if the eCO 2 value changes into a different range set by register values. Refer to the THRESHOLDS Register (0x10). ams Datasheet [v1-04] 2018-Mar-09 Page 9 Document Feedback CCS811 − Detailed Description Automatic Baseline Correction The resistance R S of the sensitive layer is the output of the sensor. However, metal oxide sensors do not give absolute readings. The resistance R S varies from sensor to sensor (manufacturing variation), from use-case to use-case, and over time. To mitigate this problem, the output of the sensor is normalized: R S is divided by R A. The value of R A is known as the baseline. R A cannot be determined by a one-time calibration; it is maintained on-the-fly in software. This process is known as baseline correction. The air quality is expected to vary in a typical environment so the minimum time over which a baseline correction is applied is 24 hours. Automatic baseline correction is enabled after initial device operation. Manual Baseline Correction There is a mechanism within CCS811 to manually save and restore a previously saved baseline value using the BASELINE register. For additional information on manual baseline control please refer to application note ams AN000370: CCS811 Clean Air Baseline Save and Restore. Page 10 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Information The recommended application circuit for CCS811 is shown below. Application Information Figure 8: Recommended Application Circuit VDD 4K7 4K7 Host Processor 4K7 Part of host system 4K7 VDD CCS811 Digital VOC sensor SCL SCL SDA SDA 4.7uF GPIOx nWAKE Reset nReset Interrupt PWM nINT ADDR Sense GND Note(s): 1. The PWM (Pin 4) and Sense (Pin 5) signals on CCS811 must be connected together. 2. A decoupling capacitor must be placed close to the supply pin VDD on the CCS811. 3. Pull-up resistors for SCL and SDA assumed will be part of host system. 4. If power is not an issue, nWake can be connected to ground if a spare GPIO is not available on the host processor. 5. ADDR must be connected to either VDD (logic 1) or ground (logic 0) depending on the required lsb of the CCS811’s I²C slave address. Host System Software Requirements 1. The minimum level of driver support that a host system needs is read and write I²C transactions of data bytes where the nWAKE pin is asserted at least tAWAKE before the transaction and kept asserted throughout. 2. An Interrupt handler is also recommended to tell the application code that the device has asserted an interrupt. ams Datasheet [v1-04] 2018-Mar-09 Page 11 Document Feedback CCS811 − Application Information I²C Interface I²C transactions require a register address to be selected (written) and followed by data, as described by the transaction types in the subsections below. Each Register location corresponds to a byte or multiple bytes. Multiple reads or writes in a single sequence will be to or from the same location (the address does not increment). Therefore, registers are sometimes referred to as mailboxes in this document. CCS811 requires the host processor supports clock stretching. I²C Register Write Figure 9: I²C Register Write Write, register address only Write value to register Write multiple data values to register (mailbox) S SLAVE ADDRESS W A DATA(REG ADDR) A P S SLAVE ADDRESS W A DATA(REG ADDR) A DATA A P S SLAVE ADDRESS W A DATA(REG ADDR) A DATA A From master to slave S Start condition W Write From slave to master P STOP condition R Read A DATA A P Acknowledge As shown above, a transaction may be: • Single Byte to select a register address for subsequent read • Two Bytes to select a register address and write a byte to it, typically to set a single-byte register value • Multi-Bytes to select a register address and write several bytes to it, typically to set multiple configuration bytes Page 12 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Information I²C Register Read Figure 10: I²C Register Read Select and read register value Select and read register value, as single transaction Select and repeatedly read multiple data values from register S SLAVE ADDRESS W A DATA(REG ADDR) A P (select register address) S SLAVE ADDRESS R A DATA N P (read register value) S SLAVE ADDRESS W A DATA(REG ADDR) A S SLAVE ADDRESS (select register address) R A DATA N P (read register value) A P (select register address) S SLAVE ADDRESS W A DATA(REG ADDR) S SLAVE ADDRESS R A DATA A DATA N P (read register multiple data) S SLAVE ADDRESS R A DATA A DATA N P (read register multiple data) S SLAVE ADDRESS R A DATA A DATA N P (read register multiple data) From master to slave S Start condition W Write A Acknowledge From slave to master P STOP condition R Read N Not acknowledge • Since no register address can be supplied during an I²C read, an I²C write needs to be prepended to select the required register first. • The write and read operations can optionally be combined into a single transaction using a repeated start condition, as shown in the second example above. • Select and repeatedly read multiple data values from register, if the three reads are from the same register (mailbox), or from three subsequent registers (mailboxes). ams Datasheet [v1-04] 2018-Mar-09 Page 13 Document Feedback CCS811 − Application Register Overview Application Register Overview All I²C transactions must use the (7 bits) slave address 0x5A or 0x5B depending on status of ADDR pin when writing to and reading from the CCS811. Figure 11 shows the register map for CCS811. Figure 22 shows the bootloader register map. Figure 11: CCS811 Application Register Map Address Register 0x00 STATUS 0x01 MEAS_MODE R/W Size Description R 1 byte Status register R/W 1 byte Measurement mode and conditions register Algorithm result. The most significant 2 bytes contain a ppm estimate of the equivalent CO2 (eCO2) level, and the next two bytes contain a ppb estimate of the total VOC level. 0x02 ALG_RESULT_DATA R up to 8 bytes 0x03 RAW_DATA R 2 bytes Raw ADC data values for resistance and current source used. 0x05 ENV_DATA W 4 bytes Temperature and humidity data can be written to enable compensation 0x06 Res 4 bytes Reserved for future use 0x10 THRESHOLDS W 4 bytes Thresholds for operation when interrupts are only generated when eCO2 ppm crosses a threshold 0x11 BASELINE R/W 2 bytes The encoded current baseline value can be read. A previously saved encoded baseline can be written. 0x20 HW_ID R 1 byte Hardware ID. The value is 0x81 0x21 HW Version R 1 byte Hardware Version. The value is 0x1X 0x23 FW_Boot_Version R 2 bytes Firmware Boot Version. The first 2 bytes contain the firmware version number for the boot code. 0x24 FW_App_Version R 2 bytes Firmware Application Version. The first 2 bytes contain the firmware version number for the application code 0xE0 ERROR_ID R 1 byte Error ID. When the status register reports an error its source is located in this register 0xFF SW_RESET W 4 bytes If the correct 4 bytes (0x11 0xE5 0x72 0x8A) are written to this register in a single sequence the device will reset and return to BOOT mode. Note(s): 1. The number of bytes read from a register must not exceed the size in this table. 2. For more information on CCS811 programming requirements please refer to ams application note AN000369. Page 14 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Register Overview STATUS Register (0x00) Single byte read only register which indicates if a device is active, if new data is available or if an error occurred. Figure 12: Status Register 7 6 5 4 3 FW_MODE APP_ERASE APP_VERIFY APP_VALID DATA_READY Bit(s) Field 7 FW_MODE 0: Firmware is in boot mode, this allows new firmware to be loaded 1: Firmware is in application mode. CCS811 is ready to take ADC measurements 6 APP_ERASE Boot Mode only. 0: No erase completed 1: Application erase operation completed 5 APP_VERIFY Boot Mode only. 0: No verify completed 1: Application verify operation completed After issuing a VERIFY command the application software must wait 70ms before issuing any transactions to CCS811 over the I²C interface 4 APP_VALID 0: No application firmware loaded 1: Valid application firmware loaded 3 DATA_READY 2:1 - 0 ERROR ams Datasheet [v1-04] 2018-Mar-09 2 1 - 0 ERROR Description 0: No new data samples are ready 1: A new data sample is ready in ALG_RESULT_DATA, this bit is cleared when ALG_RESULT_DATA is read on the I²C interface Reserved 0: No error has occurred 1: There is an error on the I²C or sensor, the ERROR_ID register (0xE0) contains the error source Page 15 Document Feedback CCS811 − Application Register Overview MEAS_MODE (Measurement and Conditions) Register (0x01) This is Single byte register, which is used to enable sensor drive mode and interrupts. Figure 13: Measure Mode Register 7 6 - 4 DRIVE_MODE Bit(s) Field 7 - 6:4 5 DRIVE_MODE 3 2 INTERRUPT THRESH 1 0 - Description Reserved – write ‘0’ 000: Mode 0 – Idle (Measurements are disabled in this mode) 001: Mode 1 – Constant power mode, IAQ measurement every second 010: Mode 2 – Pulse heating mode IAQ measurement every 10 seconds 011: Mode 3 – Low power pulse heating mode IAQ measurement every 60 seconds 100: Mode 4 – Constant power mode, sensor measurement every 250ms 1xx: Reserved modes (For future use) In mode 4, the ALG_RESULT_DATA is not updated, only RAW_DATA; the processing must be done on the host system. A new sample is placed in ALG_RESULT_DATA and RAW_DATA registers and the DATA_READY bit in the STATUS register is set at the defined measurement interval. 3 INT_DATARDY 0: Interrupt generation is disabled 1: The nINT signal is asserted (driven low) when a new sample is ready in ALG_RESULT_DATA. The nINT signal will stop being driven low when ALG_RESULT_DATA is read on the I²C interface. At the end of each measurement cycle (250ms, 1s, 10s, 60s) a flag is set in the STATUS register regardless of the setting of this bit.. 2 INT_THRESH 1:0 - Page 16 Document Feedback 0: Interrupt mode (if enabled) operates normally 1: Interrupt mode (if enabled) only asserts the nINT signal (driven low) if the new ALG_RESULT_DATA crosses one of the thresholds set in the THRESHOLDS register by more than the hysteresis value (also in the THRESHOLDS register) Reserved - write 00 ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Register Overview ALG_RESULT_DATA (Algorithm Results Data) Register (0x02) This multi-byte read only register contains the calculated eCO 2 (ppm) and TVOC (ppb) values followed by the STATUS register, ERROR_ID register and the RAW_DATA register. • If only eCO 2 is required, only the first 2 bytes need to be read. • If TVOC is required, 4 bytes need to be read. • In a system where interrupts are not implemented and the host needs to poll the STATUS register to determine whether there is new data, an efficient alternative is to read 5 bytes in a single transaction since that returns eCO2, TVOC and the status register. • Optionally, all 8 bytes could be read in a single transaction, so that even the error status and the raw data is available. Figure 14: Algorithm Results Register Byte Order Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 & 7 eCO2 High Byte eCO2 Low Byte TVOC High Byte TVOC Low Byte STATUS ERROR_ID See RAW_DATA RAW_DATA Register (0x03) Two byte read only register which contains the latest readings from the sensor. The most significant 6 bits of the Byte 0 contain the value of the current through the sensor (0μA to 63μA). The lower 10 bits contain (as computed from the ADC) the readings of the voltage across the sensor with the selected current (1023 = 1.65V) Figure 15: RAW_DATA Register Byte Order Byte 0 7 6 5 4 3 Current Selected 5:0 ams Datasheet [v1-04] 2018-Mar-09 Byte 1 2 1 0 7 6 5 4 3 2 1 0 Raw ADC reading 9:0 Page 17 Document Feedback CCS811 − Application Register Overview ENV_DATA (Environment Data) Register (0x05) A multi-byte register that can be written with the current Humidity and Temperature values if known. Relative Humidity Figure 16: Relative Humidity Fields and Byte Order Byte 0 Byte 1 Humidity High Byte Humidity Low Byte 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 64 32 16 8 4 2 1 1/2 1/4 1/8 1/16 1/32 1/64 1/128 1/256 1/512 Humidity % Humidity % Fraction Humidity is stored as an unsigned 16 bits in 1/512%RH. The default value is 50% = 0x64, 0x00. As an example 48.5% humidity would be 0x61, 0x00. Temperature Figure 17: Temperature Fields and Byte Order Byte 2 Byte 3 Temperature High Byte Temperature Low Byte 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 64 32 16 8 4 2 1 1/2 1/4 1/8 1/16 1/32 1/64 1/128 1/256 1/512 Temperature 25°C Temperature 25°C Fraction Temperature is stored as an unsigned 16 bits integer in 1/512 degrees; there is an offset: 0 maps to -25°C. The default value is 25°C = 0x64, 0x00. As an example 23.5% temperature would be 0x61, 0x00. The internal algorithm uses ENV_DATA values (or default values if not set by the application) to compensate for changes in relative humidity and ambient temperature. For temperatures below-25°C the 7-bit temperature field in Byte 2 above should be set to all zeros. Page 18 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Register Overview THRESHOLDS Register (0x10) If ‘interrupt on threshold change’ has been set in the Mode register (see above), the values in this multi- byte write only register are used to determine the thresholds. Figure 18:--[‘ Thresholds Register Byte Order Byte 0 Byte 1 Byte 2 Low to Medium Threshold High Byte Byte 3 Medium to High Threshold Low Byte High Byte Low Byte An interrupt is asserted if the eCO 2 value moved from the current range (Low, Medium, or High) into another range by more than 50ppm. • Low to Medium Threshold default = 1500ppm = 0x05DC • Medium to High Threshold default = 2500ppm = 0x09C4 BASELINE Register (0x11) A two byte read/write register which contains an encoded version of the current baseline used in Algorithm Calculations. A previously stored value may be written back to this two byte register and the Algorithms will use the new value in its calculations (until it adjusts it as part of its internal Automatic Baseline Correction). For more information, refer to ams application note AN000370: CCS811 Clean Air Baseline Save and Restore. HW_ID (Hardware identifier) Register (0x20) Single byte read only register which holds the HW ID which is 0x81 for this family of CCS81x devices. HW_Version (Hardware Version) Register (0x21) Single byte read only register which holds the Hardware Major and Minor Hardware versions. The top four bits read major hardware version 1 – identifying the product as CCS811. The bottom four bits identify any build variant. The default value is 0x1X. ams Datasheet [v1-04] 2018-Mar-09 Page 19 Document Feedback CCS811 − Application Register Overview FW_Boot_Version (Firmware Bootloader Version) Register (0x23) Two byte read only register which contain the version of the firmware bootloader stored in the CCS811 in the format Major.Minor.Trivial Figure 19: Firmware Bootloader Version Format Byte 0 7 6 5 4 3 Byte 1 2 Major 1 0 7 6 5 4 Minor 3 2 1 0 Trivial FW_App_Version (Firmware Application Version) Register (0x24) Two byte read only register which contain the version of the firmware application stored in the CCS811 in the format Major.Minor.Trivial Figure 20: Firmware Application Version Format Byte 0 7 6 5 Major Page 20 Document Feedback 4 3 Byte 1 2 1 Minor 0 7 6 5 4 3 2 1 0 Trivial ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Application Register Overview ERROR_ID (Error Identifier) Register (0xE0) If the ERR bit [0] of the STATUS Register is set, this single byte read only register indicates source(s) of the error. Figure 21: ERROR_ID Register Codes Bit ERROR_CODE 0 WRITE_REG_INVALID The CCS811 received an I²C write request addressed to this station but with invalid register address ID 1 READ_REG_INVALID The CCS811 received an I²C read request to a mailbox ID that is invalid 2 MEASMODE_INVALID The CCS811 received an I²C request to write an unsupported mode to MEAS_MODE 3 MAX_RESISTANCE 4 HEATER_FAULT The Heater current in the CCS811 is not in range 5 HEATER_SUPPLY The Heater voltage is not being applied correctly 6 - Reserved for Future Use 7 - Reserved for Future Use ams Datasheet [v1-04] 2018-Mar-09 Description The sensor resistance measurement has reached or exceeded the maximum range Page 21 Document Feedback CCS811 − Application Register Overview SW_RESET Register (0xFF) As an alternative to Power-On reset or Hardware Reset a Software Reset is available. Asserting the SW_RESET will restart the CCS811 in Boot mode to enable new application firmware to be downloaded. To prevent accidental SW_RESET a sequence of four bytes must be written to this register in a single I²C sequence: 0x11, 0xE5, 0x72, 0x8A. For details, please refer to application notes ams AN000369 and ams AN000371. Page 22 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Bootloader Register Overview Bootloader Register Overview All I²C transactions must use the (7bits) slave address 0x5A or 0x5B depending on status of ADDR pin when writing to and reading from the CCS811. Figure 22 shows the bootloader register map for CCS811. Figure 22: CCS811 Bootloader Register Map Address Register R/W Size Description 0x00 STATUS R 1 byte Status register 0x20 HW_ID R 1 byte Hardware ID. The value is 0x81 0x21 HW Version R 1 byte Hardware Version. The value is 0x1X 0x23 FW_Boot_Version R 2 bytes Firmware Boot Version. The first 2 bytes contain the firmware version number for the boot code. 0x24 FW_App_Version R 2 bytes Firmware Application Version. The first 2 bytes contain the firmware version number for the application code. 0xE0 ERROR_ID R 1 byte Error ID. When the status register reports an error it source is located in this register 0xF1 APP_ERASE W 4 bytes If the correct 4 bytes (0xE7 0xA7 0xE6 0x09) are written to this register in a single sequence the device will start the application erase 0xF2 APP_DATA W 9 bytes Transmit flash code for the bootloader to write to the application flash code space. 0xF3 APP_VERIFY W - Starts the process of the bootloader checking though the application to make sure a full image is valid. 0xF4 APP_START W - Application start. Used to transition the CCS811 state from boot to application mode, a write with no data is required. Before performing a write to APP_START the Status register should be accessed to check if there is a valid application present. 0xFF SW_RESET W 4 bytes If the correct 4 bytes (0x11 0xE5 0x72 0x8A) are written to this register in a single sequence the device will reset and return to BOOT mode. Note(s): 1. The number of bytes read from a register must not exceed the size in this table. 2. For more information on performing application code download please refer to application note ams AN000371. ams Datasheet [v1-04] 2018-Mar-09 Page 23 Document Feedback CCS811 − Bootloader Register Over view Registers not detailed below are documented in the Application Register Overview section. APP_ERASE (Application Erase) Register (0xF1) To prevent accidental APP_ERASE a sequence of four bytes must be written to this register in a single I²C sequence: 0xE7, 0xA7, 0xE6, 0x09. The APP_ERASE can take a variable amount of time. The status register can be polled to determine when this function is complete. The 6 th bit (0x40) is initialised to 0 and set to a 1 on completion of the APP_ERASE function. After an erase this bit is only cleared by doing a reset or starting the application. APP_DATA (Application Data) Register (0xF2) Nine byte, write only register for sending small chunks of application data which will be written in order to the CCS811 flash code. APP_VERIFY (Application Verify) Register (0xF3) Single byte write only register which starts the application verify process run by the bootloader to check for a complete application code image. Command only needs to be called once after a firmware download as the result is saved in a flash location that gets checked during device initialisation. The APP_VERIFY can take a variable amount of time. The status register can be polled to determine when this function is complete. The 5 th bit (0x20) is initialised to 0 and set to a 1 on completion of the APP_VERIFY function. After an APP_VERIFY this bit is only cleared by doing a reset or starting the application. For details on downloading new application firmware please refer to application note ams AN000371. APP_START (Application Start) Register (0xF4) To change the mode of the CCS811 from Boot mode to running the application, a single byte write of 0xF4 is required. The CCS811 interprets this as an address write to select the ‘APP_START’ register and starts running the loaded application software if it is a valid version (Refer to the STATUS Register (0x00)). Page 24 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Package Drawings & Marking Package Drawings & Marking LGA Package Outline Figure 23: LGA Package Drawings Pin 1 Corner Index Area (Top View) (Side View) D A E 1.2 nxL nxW 6 5 e D1 2.4 1 Pin 1 Corner Index Area RoHS 10 (0.3) Green E1 (Bottom View) Symbol Total thickness Body Size Lead Width Lead Length Lead Pitch Lead Count Edge Lead Centre to Centre A D E W L e n D1 E1 Min - 0.25 0.45 Dimensions Nominal 4.0 2.7 0.3 0.5 0.6 10 2.4 2.2 Max 1.1 BSC BSC 0.35 0.55 BSC BSC BSC Note(s): 1. All dimensions are in millimeters. ams Datasheet [v1-04] 2018-Mar-09 Page 25 Document Feedback CCS811 − Package Drawings & Mark ing The recommended package footprint or landing pattern for CCS811 is shown below: Figure 24: Recommended Package Footprint for CCS811 2.7 0.6 0.3 0.75 1 10 0.3 0.4 0.6 4 0.4 5 6 1.3 0.7 (Top View) Note(s): 1. All dimensions are in millimeters. 2. PCB land pattern in Green dash lines 3. Pin numbers are in Red 4. Add 0.05mm all around the nominal lead width and length for the PCB land pattern Page 26 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Ordering & Contact Information Ordering & Contact Information Figure 25: Ordering Information Ordering Code Description Package MOQ CCS811B-JOPR5K CCS811 digital gas sensor for Indoor Air Quality Monitoring 2.7mm x 4.0mm x 1.1mm LGA 5000 CCS811B-JOPD500 Sample of CCS811 digital gas sensor for Indoor Air Quality Monitoring 2.7mm x 4.0mm x 1.1mm LGA 500 Note(s): 1. Refer to JEDEC J-STD020 lead-free standard for typical soldering reflow profile Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-04] 2018-Mar-09 Page 27 Document Feedback CCS811 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 28 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-04] 2018-Mar-09 Page 29 Document Feedback CCS811 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 30 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Revision Information Revision Information Changes from 1-03 (2017-Sep-28) to current revision 1-04 (2018-Mar-09) Page Updated text under General Description 1 Updated Figure 1 2 Updated Figure 2 3 Updated Figure 3 4 Updated Figure 7 and notes under it 7 Updated text under Early-Life Use (Burn-In) 8 Updated text under Conditioning Period (Run-In), eCO2, TVOC and Automatic Baseline Correction 9 Updated text under Manual Baseline Correction 10 Updated text under I²C Interface 12 Updated Figure 11 14 Updated Figure 12 15 Updated Figure 13 16 Updated text under RAW_DATA Register (0x03) 17 Updated text under Figure 17 18 Updated THRESHOLDS Register (0x10) and BASELINE Register (0x11) 19 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v1-04] 2018-Mar-09 Page 31 Document Feedback CCS811 − Appendix Appendix References Figure 26: Document Reference Document Reference Description ams AN000367 CCS811 Assembly guidelines ams AN000368 CCS811 Design guidelines ams AN000369 CCS811 Programming and interfacing guide ams AN000370 CCS811 Clean air baseline save and restore ams AN000371 CCS811 Performing a firmware download ams AN000373 CCS811 Manufacture test procedure ams WP000102 IAQ User experience during initial operation Page 32 Document Feedback ams Datasheet [v1-04] 2018-Mar-09 CCS811 − Content Guide Content Guide 1 2 2 3 General Description Key Benefits & Features Applications Block Diagram 4 5 6 Pin Assignment Absolute Maximum Ratings Electrical Characteristics 8 8 8 9 9 9 9 9 9 10 Detailed Description Modes of Operation Early-Life Use (Burn-In) Conditioning Period (Run-In) eCO2 TVOC Temperature and Humidity Compensation Interrupt and Interrupt on Threshold Automatic Baseline Correction Manual Baseline Correction 12 12 13 13 14 Application Information Host System Software Requirements I²C Interface I²C Register Write I²C Register Read 15 16 17 22 23 Application Register Overview STATUS Register (0x00) MEAS_MODE (Measurement and Conditions) Register (0x01) ALG_RESULT_DATA (Algorithm Results Data) Register (0x02) RAW_DATA Register (0x03) ENV_DATA (Environment Data) Register (0x05) Relative Humidity THRESHOLDS Register (0x10) BASELINE Register (0x11) HW_ID (Hardware identifier) Register (0x20) HW_Version (Hardware Version) Register (0x21) FW_Boot_Version (Firmware Bootloader Version) Register (0x23) FW_App_Version (Firmware Application Version) Register (0x24) ERROR_ID (Error Identifier) Register (0xE0) SW_RESET Register (0xFF) 24 25 25 25 25 Bootloader Register Overview APP_ERASE (Application Erase) Register (0xF1) APP_DATA (Application Data) Register (0xF2) APP_VERIFY (Application Verify) Register (0xF3) APP_START (Application Start) Register (0xF4) 18 18 19 19 20 20 20 20 21 22 ams Datasheet [v1-04] 2018-Mar-09 Page 33 Document Feedback CCS811 − Content Guide Page 34 Document Feedback 26 26 Package Drawings & Marking LGA Package Outline 28 29 30 31 32 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information 33 33 Appendix References ams Datasheet [v1-04] 2018-Mar-09
CCS811B-JOPD500 价格&库存
很抱歉,暂时无法提供与“CCS811B-JOPD500”相匹配的价格&库存,您可以联系我们找货
