RS07A THRU RS07M
SURFACE MOUNT FAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 Volts
Forward Current - 0.7 Ampere
SOD-123FL
FEATURES
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
MECHANICAL DATA
Case: SOD-123FL molded plastic body over passivated chip
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=110 C (NOTE 1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load
Maximum instantaneous forward voltage at 0.7A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=125 C
Maximum reverse recovery time (NOTE 2)
Typical junction capacitance (NOTE 3)
VRRM
VRMS
VDC
RS07A RS07B RS07D RS07G RS07J RS07K RS07M
RA
RB
RD
RG
RJ
RK
RM
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
0.7
A
IFSM
25.0
A
VF
1.15
V
IR
10.0
50.0
µA
trr
CJ
Typical thermal resistance (NOTE 4)
RθJA
Operating junction and storage temperature range TJ,TSTG
Note: 1.Averaged over any 20ms period.
2.Measured with IF=0.5A, IR=1A, Irr=0.25A.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
4.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
DN:S09D01A0
UNITS
250
150
4
95
-55 to +150
500
ns
pF
K/W
C
STAR SEA
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES RS07A THRU RS07M
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
1.0
P.C.B mounted on
0.2*0.2"(5.0*5.0mm)
copper pad areas
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
25
8.3ms SINGLE HALF SINE-WAVE
10
5
175
10
100
NUMBER OF CYCLES AT 60 Hz
LEAD TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
1
0.1
0.01
0.2
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
200
TJ=25 C
100
10
1
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
DN:S09D01A0
STAR SEA
很抱歉,暂时无法提供与“RS07M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.37070
- 200+0.12320
- 1500+0.07722
- 3000+0.06127
- 国内价格
- 50+0.12420
- 500+0.10088
- 3000+0.08586
